View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 [211] 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. 40% Off Code from MSC - Code is MISS40W
  2. 2 piece milling vice keeps slipping on table
  3. are pin vice sets precision enough for holding small carbide?
  4. [Plastic Molding, Industrial, Chemistry] Cleaning water passages in a tool-steel mold
  5. For thoses who like motors,cams,gears & mechanical systems, watch this.
  6. negative radial positive axial rake
  7. Modified a screw.
  8. can a few parts be outsourced to a shop with a surface grinder?
  9. milling machine ID
  10. Portaband Stand plans
  11. A use for overhead garage door cable pulleys
  12. How to build a motorcycle
  13. Tuning of a digital Caliper
  14. neead a source - metric ball screws
  15. What materials can withstand temperatures of 100 degrees F?
  16. Blasting method / media advise
  17. Sterling Engine Plans
  18. Looking for info on ZX30
  19. Chased back to Canada!!!
  20. Which ATF, or does it not matter?
  21. OT: Marks on Mars caused by Dry Ice?
  22. What's this thing? Grinding fixture?
  23. Propane conversion
  24. Large capacitor inside my grinder?
  25. Machining to tolerance. What is yer Tolerance?
  26. wedge tangential tool
  27. Here I go again /xq/#&
  28. OT Med Cost
  29. OT: How to for concrete
  30. machinist's tube?
  31. I may design an i.c. engine---
  32. Should I swap motors on my lathe and mill?
  33. a question about epoxy granite
  34. A litte OT - Heathkit is back
  35. OT: Female Russian Snipers of WWII
  36. What kind of shop clothes do we wear when working!
  37. Tengential guys: searching for the bits.
  38. OT ATV front loader bucket
  39. DRO Longevity
  40. Tangential holder hype
  41. Ideas/Opinions on Repair Method
  42. Microscopy in the Home Shop
  43. SCAM WARNING - Avoid AMTOOL.COM
  44. O/T Member Apparently MIA
  45. Using a radius & angle dresser on surface grinder
  46. small mill question
  47. VFD advise
  48. Plastic air supply lines for shop air. (not PVC or CPVC)
  49. Pine Drill Grinder
  50. Taper attachment design queston.
  51. BXA too big for 10x20 lathe, lower compound directly unto cross slide?
  52. OT: Computer Repair 101: Why the Mother Board?
  53. Zero turn radius mower
  54. Cobalt tooling, am I do something wrong?
  55. 220V splice
  56. Check him out
  57. Dremel schwitches fail to much
  58. (WARNING PICURE OF MACHINING STUFF INSIDE) Buffalo Naval Park
  59. Static phase converters? Phase-a-matic
  60. Reamer advice please!
  61. How do these end-mill sharpeners work?
  62. Thread details
  63. what kind of paint is this
  64. solder for aluminum
  65. Electroplating: how bad is it?
  66. Gloves for machinery use (READ THE POST!)
  67. Can I make epoxy paint?
  68. electrolytic derusting - does it make anything bright?
  69. Precisely speaking, what's the difference between CVD and PVD
  70. Brazing HSS stubs when they get too short
  71. What are these types of leadscrew covers called
  72. OT Contacting Ebay to allow buyers to specify carrier other than Postal
  73. Imperial to Metric Thread OK??
  74. Stamping metal into concave shapes?
  75. New lathe - What tooling for beginner?
  76. File roughness
  77. Anticensorship in the Network Infrastructure
  78. "Foldup" sandblasting cabinet /booth ideas?
  79. Brown & Sharpe no 25 Micrometer??
  80. Machine Shop Labels... ?
  81. Jones Motrola Double Range Model 3200 Hand Tachometer
  82. Fluid Film, anyone using it as a machine protectant?
  83. brick red silicone rubber curing and zamac (zinc)
  84. Derbyshire 750 headstock - turns but with resistance
  85. Aluminum radiator tube leak repair?
  86. My Small Gloat For The Day
  87. Adding a hydraulic thumb to my Kubota backhoe???
  88. OT:Using a different wireless with ATT "Uverse"?
  89. Gear Question
  90. Surface grinding on a horizontal mill
  91. Southbend Crossfeed Bearings
  92. SK Wayne alive and "well"
  93. On topic for some - Adobe has gone to the cloud
  94. Tooling Ideas
  95. 5C Collet Set 64ths
  96. stainless bolt/ aluminum/ steel/ salt water interaction
  97. Source for 8mm studs (same as wheel studs)
  98. 10" Atlas - Worth $200
  99. Heat treatment oven build (photo heavy)
  100. Case hardening success
  101. Hydraulic Pump for Log Splitter
  102. Myford? Hydraulic Tracing Attachment Parts for Sale
  103. 3" 4-jaw: no good for 4" stock
  104. Interested in a Tree 2UVR...
  105. supermax 1440 update
  106. Denford Lathe Toolchanger
  107. OT. Any good degreasers out there?
  108. Help with 10" 4 jaw chuck
  109. OT: Paul's Law - Not This Paul
  110. easy (and cheapest) way to strip relatively large objects
  111. Anyone here built a bike rack that clears the tailgate of a pickup?
  112. OT: Omega Datalogger software for a MAC
  113. EMJ Metals WARNING :(
  114. Source for Insulating Firebrick Chicago Area?
  115. Replacement gasket: recommendation?
  116. quick Q - can a use a tap and die to make a spindle and chuck fit?
  117. Please Help Me Disassemble Pexto Shear
  118. update supermax 1440 manuals
  119. Positive Report for Made in USA Triumph Twist Drill Bits!!!!
  120. Run capacitor went out on the baldor today.
  121. Advice on electric motor conversion
  122. Semi OT - Sensing 3-phase Current?
  123. Plasma Cutter
  124. best tapping fluid for stainless steal
  125. Antigloat
  126. Taper Help
  127. Waay ot big scare
  128. OT computer power conditioner
  129. spindle bearing question
  130. The biggest super moon
  131. OT skidsteer bushings
  132. OT but check out the trusting welder----where's OSHA--------
  133. Cutting gears on a shaper...
  134. A little OT- uses for golf club shafts
  135. Benelli Mojave gas tank mod
  136. Simple control for a stepper motor
  137. grinding vises
  138. Lathe files, tips&pointers?
  139. FREE in Sacramento area
  140. OT - Pump Up Sprayer
  141. Can I gloat without.....
  142. Several "what is this?" photos
  143. Help me write an ad for Dad's lathe - many photos
  144. What is this lathe part called?
  145. 1.5 trillion and counting
  146. OT tightrope walk across the Grand Canyon
  147. A Simple Electromechanical Stepper Motor Control - DM 2006
  148. More SS fastener problemo's
  149. portable air supply
  150. OT: My health
  151. Drilling a 'big' hole in thin aluminum
  152. Inspired by Weston Bye: Stepper switch expedient
  153. Minature end mill source - just found
  154. What am I doing wrong? Turning 3/8" shaft down to 0.300
  155. O/T Those amazing tiny batteries!
  156. '32 metro street rod
  157. I got a Simonds All-purpose file - some observations
  158. Simple Stepper Drive: Another New Thread
  159. Motor Cycle Wheel Truing Jig
  160. Please Help Me Disassemble Pexto Shear
  161. July/August HSM missing pages
  162. Merlin Tools reamer quality?
  163. Enco Codes Ending Friday
  164. Enco deal!
  165. Reid Supply Company web sale en 6/28
  166. Press Fit Help Requested
  167. Junk or sell this old power hacksaw?
  168. Brian's clutch V2.5
  169. Powered hand sheet metal shear - what is best type?
  170. NTA at Wauseon, OH
  171. one more electric motor question
  172. New (to me) Lathe Gloat .. with an M
  173. Chucking reamers
  174. Using epoxy to fix bearings in place accurately?
  175. Is there such a thing as a stud 5/16-24 on one end and 1/4-28 the other?
  176. Broken gear teeth
  177. Tool Gloat
  178. Can't Index My Cursor Since IE 10 Upgrade
  179. Pen project
  180. Correa UF1A mill...looking for advice/info
  181. Possible Photobucket issue
  182. a little OT but a treasure trove
  183. Vintage aricraft engine builds
  184. somebody please help me with this one (need title of an older book)i
  185. Hydraulic cylinder help
  186. South Bend 10K - anchoring and leveling questions
  187. OT: hydraulic pump?
  188. Took (old) grinder apart - a wire broke - don't know where it goes, could use help.
  189. Shaper or Slotter??
  190. dry-cell testors
  191. Mick Duffin USB rotary controller
  192. OT- For lovers of old aircraft!
  193. Anybody do better than .0015" runout on a HF jacobs chuck?
  194. Brooks-Stent Cutter Grinder planes
  195. How do I get a slitter saw to work?
  196. Heats of expansion for granite
  197. Excello milling machine????
  198. Blind rivits - removing, installing - How to?
  199. Ahh that new Lathe smell
  200. Info on slotting machines...
  201. Looking to give away taps to a new to the hobby person who is of limited on means..
  202. Cutting Aluminum Columns
  203. What do I have?
  204. anyone familiar with the Sloan & Chace #5 headstock?
  205. How stupid can I be? This stupid. #$%)*ed up the thread on my tailstock spindle
  206. New member from West Virginia
  207. OT- plain jane deck railing
  208. DIY slip roller, tubes or solid?
  209. OT Light bulb identification.
  210. Centering a nut in a round opening to weld.
  211. Interesting repair... some people are still not into the throw-away culture
  212. Another way PAYPAL Cheats You
  213. Honest Ebay Seller "NASTY CHEAP INDEXABLE LATHE TOOLS SUIT OPTIMISTIC ENGINEER "
  214. Woodworking carbide router bits for metal working???
  215. crazy?? idea for a machine drive (lathe)
  216. Screw size when you know only the ID of the nut
  217. metal finish
  218. Steel in Nicholson files
  219. Fair deal on CL/Dayton for a Sheldon lathe with accessories
  220. OT- Medical or Flying- Great deal on a Drive Oximeter! $22.99/shipped
  221. Grinder Spindle Magnatized
  222. What's This Part? (RC Boat Edition)
  223. Turning Tagua Nuts
  224. CL so many machines
  225. Quite an"endmill" on Craigslist!
  226. Bridgeport replacement working well
  227. OT my wife is trying to kill me.
  228. (WDRO) Wireless Digital ReadOut on the cheap!
  229. Installing DRO On Grizzly G0730G Mill
  230. Jib Crane Ideas
  231. CMSGMA Show
  232. Shrink fit - need to fit a sleeve over a bearing
  233. What's up with Walden Specialties?
  234. 4" H5940 rotary table from Griz.
  235. ball screw help needed
  236. Enco Code for July???
  237. Axle bearing/retainer press fit question
  238. Nice old school drill press
  239. Q C Post Question
  240. parting tool question
  241. keyway questions
  242. Mold on tools....how bad is it?
  243. First post, meet my girlfriend...
  244. Bench grinder: Re-assemble, was fast now is slow ???
  245. Stud in blind hole installation
  246. Files (tools)
  247. ot Buying a new car
  248. Inside Keyway in a Blind Hole.
  249. stoning of ways
  250. V13 Steal
