View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 [214] 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. ??? about making a D-reamer
  2. Questions on the LH Sparey Dividing head
  3. OT -- Legal Fun! Fake Degree
  4. One For The Blacksmiths
  5. Phase converters versus gensets
  6. Soldering brazing rod
  7. Here's a boring bar I found, and broke. How can I fix it?
  8. Checking a computer for timing problems re CNC and other issues
  9. Tailstock die holders
  10. End mill in drill press?
  11. AA batteries reversing polarity
  12. What type of tap is this?
  13. Electric Motor Brushes.
  14. ID This Lathe?
  15. Do I need a fancy wheel dresser?
  16. Ot. Iron removal in well water
  17. quick chuck question
  18. Bending aluminum to make an 85 deg. angle
  19. Unimat
  20. Trying to tap 4140PH???
  21. Waterford Michigan, Anyone Close?
  22. O.T. - Way O.T.: You gotta love retailers
  23. Removing a Broken #40 Drill Bit Tip in Blind Hole
  24. This old thing followed me home
  25. De-rusting tools.
  26. OT: Meet Blane Nordahl, master silver thief
  27. ENCO: 15% off and free shipping
  28. OT: What is it? Nail & spring?
  29. How do I tighten the lantern tool?
  30. Lathe give-away
  31. What is a Knockout Punch?
  32. OT I know we have some outboard motor guys here, any knowledge of a west bend?
  33. How Do Ya Measure a Bore 2ft Long ?
  34. Product review: Metal cutting circular saw
  35. Gorton mill listed on craigslist near me....$350
  36. OT: Non-fiberglass, cut-able insulation panel
  37. Digital Indicator w/ Remote LCD
  38. Mr.
  39. Delta IV Heavy Launch, Vandenberg
  40. Critique my patterns, please
  41. 9 jr half nuts in need of replacement
  42. GoBookee?
  43. O/T- Much more air traffic
  44. OT- "STORMY CHROMER" Caps!
  45. jet lathe
  46. How do you close the loop with a cut-to-length timing belt?
  47. Way OT - Was George Jetson a machinist?
  48. Unibor annular cutters
  49. OT (sorta) Engine pre-lube unit
  50. Jet 1340 GHB tail stock problems.
  51. Very interesting video about a car differential.
  52. Blueing stainless with heat
  53. When is Mach4 coming out?
  54. OT: Breathing air use a regular compressor
  55. Yahoo Groups New Design :(
  56. welding sheet steel
  57. OT: Royal security: what is he carrying?
  58. The Build Up Of Internal Stresses
  59. Correct oil for vintage GE Electric motor?
  60. Surface grinding objects larger than the grinders capacity
  61. HVAC Parts - Devair/Hankison 8010 Refrigerated Air Dryer Fan.
  62. OT: AutoDesk Falcon Wind Tunnel software available again
  63. OT Need a Metric Thread Pipe Nipple
  64. A Heartwarming Story
  65. OT old school hard ware store
  66. Decent counterbore set?
  67. DRO for 6x26 mill
  68. Mill processor
  69. Bridgeport Gib help
  70. OT: Crazy idea- DRO from computer mouse.
  71. Myford flexing their muscle again.
  72. Workshop dust extraction help please...
  73. Vanishing Text and Dimensions
  74. Threading question
  75. To Tumble or to Vibrate
  76. Brown & Sharpe 10" Dividing head assembly diagram?
  77. "I am sure it can be welded"
  78. Spindle Brake Cut out switch modification ?
  79. Another i thought i'd seen it all:
  80. Need Help - Nail gun problem!
  81. CPO Tools sale
  82. OT: Selkirk Rail Yards near Albany NY
  83. underpowered hydraulics - what happens?
  84. Pm problem
  85. new upgrade
  86. DRO For Sale, What Do We Know About This?
  87. Anyone in Yahoo groups and having problems with the "new yahoo"?
  88. Buck 4 jaw chuck screw question
  89. Bridgeport or Grizzly?
  90. tell me about this hydraulic hand pump, please
  91. Question About Forum: Resizing?
  92. Unicam Fixture
  93. Stuck 4-Jaw Chuck
  94. Fabtotum - 3D rpint, scan, mill in one machine?
  95. Wells Index - Deal or not?
  96. OT email service problems
  97. OT ideas on cutting steel plate?
  98. Another cutting question
  99. ENCO Free shipping
  100. Help: bandsaw blade backwards???
  101. OT- An Electrical Question
  102. A call to other beginners
  103. OT Email
  104. How do mfg's print colored graphics and text onto aluminum plate?
  105. Turning 45 degree bevels.
  106. what is the hardest aluminum
  107. OT, politically incorrect, but heck, it's John Cleese....
  108. Want to make a bench grinder arbor
  109. Altered Multifix threading tool
  110. last chance, experienced advice please before I spend my money?
  111. Real, Core, Machining Question: How Would You Finish/Debur This
  112. OT:Stumped by gerotor hydraulic motor
  113. OT . Double or Multiple Clicks to Back out of WebSites
  114. tail stock for a sharp 1440F lathe
  115. What series would aluminum be off the shelf?
  116. Zamac versus aluminum for Atlas gears? Fixing crooked shafts in Atlas mill gearbox?
  117. OT: E-mail issue to report
  118. Rottler CA Borring Bar info needed
  119. OT: solvent for transformer varnish?
  120. Anyone know this lathe?
  121. What would you use this DRO for?
  122. Dangers of model helicopters, slight OT but relevant
  123. Spiral point taps
  124. Check out this fastener
  125. shop press build! (& question)
  126. Recycling a laser printer
  127. universal press design
  128. Southbend 8 x 18
  129. Powder Coat Application Thickness: An Academic Question
  130. Drill press taper has a burr
  131. Cubicle Square Question????
  132. What type of cast iron for making gear replacement?
  133. Missing and Broken Gears for Lathe
  134. OT: The broken back, burning & sinking of the MOL Comfort
  135. Model "Diesel" airplane engine with ball bearings - which shields to remove if any?
  136. how do I get these rivets out ?
  137. Home made Tube Bender tooling
  138. Wire EDM problem and test cuts
  139. On-line progamme for X Z coordinates for a curve
  140. Mounting C faced motors
  141. North Texas Hobby Machinist Club
  142. OT: Problems with cable tv service
  143. What is a jig bore reamer
  144. Childishness in the shop
  145. New steam engine book
  146. thermoelectric modules
  147. tractor update
  148. The HELL with Google. I'll just ask ya'll.
  149. back to the RR tracks
  150. Lufkin inside micrometer
  151. Sketchup printing woes
  152. Recent Shows of Interest
  153. How To Clean Mud Dauber Mess From Motor Windings?
  154. OT: mystery trailer hitch?
  155. Front page hacked or what?
  156. Is there a "bug" lurking in this BBS?
  157. can someone help a newbee?
  158. newbie motor help?
  159. cutting an impeller on the lathe
  160. Praise the Lord and pass the 1144 & HSS
  161. A good evening :)
  162. Knurling 1/4" - ideas please
  163. album setting
  164. Stepper Direct drive indexer accuracy?
  165. Best paint match
  166. OT- bike conversion
  167. OT cargo box
  168. 5 inch vise help
  169. Phase converter build question
  170. Board Maintenance
  171. Electrical Ideas
  172. Sargon DRO
  173. Looks like PM has the lurgi now too.
  174. Way OT Road trip
  175. Knurling Tool,Eagle Rock???
  176. OT Arrrrr! It's national talik Like a Pirate Day
  177. Reconditioning A BP Vise
  178. 9-11
  179. Screwy redirect when trying to access the forum from the homepage
  180. Speedy Metals
  181. Calculating max stress on steel
  182. OT: Tax question..Knowing none of you are tax experts.. but...
  183. Trip levers
  184. Gear calculation help please
  185. B16 Taper
  186. Expansion reamers
  187. OT- 2 cycle experience needed.............
  188. Blood brothers
  189. Dressing Grinding Wheel
  190. Way OT Clarinet recorking
  191. need conveyor advise
  192. dado set
  193. Evanut mounting question
  194. How to make a ball turning form tool????
  195. O/T Mcmaster-Carr shipping to Canada now ??
  196. c-d ignition plans
  197. BROACH question
  198. removing detents from a hydraulic valve
  199. O.T. computer monitor warm-up ?
  200. Drill Point End Mills for Grooving
  201. OT: Falkirk Wheel
  202. Micro-drop coolant and Proto wrenches.
  203. Grizzly G0602 threading won't synchronize
  204. First Gear discovered in a living creature
  205. Fun things come in small packages!
  206. Small Gloat...It's been a couple of good weeks
  207. Single point threading, backgear only?
  208. Found more parts to Dad's Atlas Lathe - what are they, please?
  209. Decent 1" x 30" sander belts? Where to get them?
  210. Looking for member who might live in Casa Grande Arizona
  211. Machining a Weld
  212. Qusetion On Transit
  213. Electronics: PWM controllable constant current source?
  214. OT - What is Forane used for?
  215. O/T making a tea ball from scratch with DIY stamping?
  216. Air Valves, Air Guns, Pneumatics and Related...
  217. Which motor would be better for T&C grinder?
  218. How do you take dents out of a round aluminum tank?
  219. Wiring a single phase Farm Duty motor
  220. Solution To Prior Post Problem
  221. Lift calculation
  222. Busy weekend photos
  223. OT - 2 antennas for OTA TV reception improvement?
  224. Drilling in 1.5" solid square mild steel
  225. My recently assembled computer
  226. Thread Repair Exhaust
  227. Public Auction in Wiscosin
  228. OT Shop gathering
  229. $ See what Ben Bought! $
  230. Unimat "cartridge" spindle... OD?
  231. Problem Shortening AXA QCTP tool holders
  232. Molex Mini-Fit Jr pins
  233. Need some tool grinding advice.
  234. What paint to use?
  235. OT: What's up with Windows Defender Update taking so long to check for updates?
  236. Costa Concordia
  237. Trying to out do flylo
  238. oil drain plug washers
  239. Options for stripping lathe bed/headstock to bare casting
  240. Oliver Spinning Lathe
  241. SEMI OT: Brio style train wheels
  242. Wilton 800s vise!
  243. What's the most Enco 12x36 lathes tend to go for?
  244. machinists level help
  245. Real machinists make blue chips
  246. Brain teaser: How do you cut teeny gears...
  247. 1920s taper call put
  248. Clausing 8520 mill
  249. Starting the build on my Firewood processor
  250. Keyless Chuck
