View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 [218] 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
  1. Source for small diameter tubing?
  2. Countersinks.... there sure are a lot of sizes, some I don't understand.
  3. Quick project: Squaring the base of a 3" drill press vice (pics inside).
  4. Steam Tempering
  5. Any updates on Guy?
  6. Riser Block
  7. That Lazy Machinist
  8. OT: electrical smart meter quiz. What do these messages mean?
  9. how to mount this cuter
  10. __ Indexing plates, forget how many times you turned the handle ?
  11. OT: PVC Door Frame Repair
  12. Telescoping Taper Atch'mt - How'deywork?
  13. Pneumatic centering vise design
  14. Hydraulic cylinder help
  15. Buy your own village complete with hotel...
  16. Cruel cruel joke...
  17. Siemens apprentceship program
  18. saving a shaper
  19. Atlas Metal shaper 7B
  20. Pillow blocks
  21. welder question
  22. Electrical sealer
  23. How to make a diaphragm air pump.
  24. Massey Ferguson Steering Cylinder Repair
  25. Need 7" Maximat lathe cut-off tool holder
  26. Shop press
  27. Magic stuff to clean old gas engine fuel systems...???
  28. Big old mill for sale in Rochester...
  29. Adding a DRO?
  30. Enco 20% off plus free shipping (no exclusions).
  31. Kearney Trecker model AC
  32. Making the press from Popular Mechanics
  33. For The Railway Buffs
  34. Bradford Metalmaster lathe on Baltimore CL
  35. Enco Cyber Monday Discount Codes
  36. OT Electric Ranges
  37. BBC Australia question
  38. 2-3" fly cutter with straight shank?
  39. Junk made-in-USA products
  40. Last US lead smelter shut down by the EPA
  41. Potential bandsaw buy and vfd question.
  42. Help in Walla Walla, Wa.
  43. South Bend 10K
  44. Auction Heads up.
  45. Yet Another Pie-In-The-Sky Free Energy Farce
  46. Clausing Lathe Variable Drive Bushings
  47. Is there an inexpensive software to convert .dwg files to .pdf?
  48. Moglice or Babbitt
  49. Amazons drones - seriously?
  50. Help with tooling setup to machine a large disk
  51. Guy explains imperial measurements
  52. OT: Delray's diggers find scrap metal, pride and fellowship.
  53. Vise parts?
  54. searching for drill bits with guide attached (are they out there?)
  55. OT: 0W-20 oil use in new cars
  56. Making Graded Bolts
  57. K & D Tools
  58. Grizzly chain hoist quality
  59. OT - Network/Internet Test
  60. Indicator Stand Help Needed
  61. Broken motor shaft, does this show why?
  62. Looking for budget 115 pc drill set reviews
  63. OT:Quirky XP Pro
  64. Boslab
  65. More Employment Games -- Fake Job Openings.
  66. Christmas Score/gloat! Pratt Burnerd EE collets and chuck
  67. mechanical advantage, need to pull your car out of a hole in the ice
  68. car timing belt
  69. Mystery vintage bench mill ID
  70. Removing rust?
  71. Throw it out and buy a new one.
  72. Enco Free Shipping Thru Dec
  73. Maybe a battery?????
  74. delicate electrical connectors
  75. Opinions on Husky tool chest?
  76. It took 20years before I realised what was wrong!
  77. Hex Key Hole ???
  78. small electric motor repair question
  79. Lathe Problems?
  80. Old greybeard has the right idea/tool for lifting
  81. straight shank vs. dedicated shank milling tools
  82. How to install new feed screws on SB 16"
  83. How old is this Hunter alignment machine?
  84. Digital read out on horizontal mill.
  85. Bent Crank shaft
  86. OT Computer help, virus and stuff
  87. Electrical Help needed
  88. Face mills 45 vs 90 deg?
  89. DRO Installation Question
  90. Wow, cool boring bar!!
  91. magnetic transfer blocks -- how do they work?
  92. Need some help/instructions...MT5 taper to MT4
  93. doesn't this look suspiciously just like an elctric motor?I can't get this at all!
  94. Vision CNC Router Table Pin-Outs?
  95. Too Gloat: work auction
  96. Atlas 7B Belt size
  97. Surface grinder motor trouble
  98. NEMES Annual Holiday Get Together
  99. Types of steel, aluminum, brass, etc., ease of machining and other properties
  100. Cutting a tapered thread.
  101. HomeShopMachinist Podcast?
  102. DIY Mag Drill Pipe Drilling Base
  103. Advice, suggestions, info on motorizing a Mill's head (replacing column hand wheel) ?
  104. Looking for a no weld solution to repair broken aluminum casting
  105. wind pressure
  106. Items of interest on Craig's List
  107. Help with electrical problem(!)
  108. bushing a surface grinder wheel
  109. new-to-me Surface Grinder -- Need some pointers.
  110. OT Computer Questions............
  111. 4" disk in a 4 Jaw setup question
  112. Belt for old Dumore Grinder?
  113. iso 30
  114. Indexer help
  115. How do they thread these?
  116. What happens when you pour 1200F molten aluminum into an anthill?
  117. Metal Cutting?
  118. OT, are you having problems with IE11...?
  119. Horizontal Band Saw Problems
  120. You know its going to be a bad day when you get your weiner stuck
  121. Protecting steel
  122. Old-school saves me yet again!
  123. Unusual source for aluminum - and lead - and mercury
  124. Days in the month.
  125. AC electric motor "hum"
  126. 5C collet holder for lathe
  127. Controlling a small 12v motor
  128. Concord Liberty Stairlift
  129. copper strands
  130. O.T. : PayPal "issues", a hassle I don't need
  131. Threaded lathe chuck mounting procedure
  132. Dumore #44 Tool Post Grinder Pulleys?
  133. wadkin pp saw
  134. Why are machine reamers so long
  135. steel vs gunpowder
  136. Magnetic base dial indicator recommendations (and Rescue Tape)
  137. Sharpening Carbide Tip Saw Blade
  138. TCMT Insert vendor
  139. Playstation3 YLOD repair and Silicon termal Compound Paste?
  140. drilling aluminum with or w/o coolant?
  141. QCTP Holders
  142. Dangers of grinding wheels...
  143. Shop Vac For Fuel?
  144. hows it made - extruded copper pipe?
  145. OT-- Florida weather crisis
  146. Electric motor bearing problem...
  147. Vacuum bagging using air compressor
  148. Versa-tools or Oscillating Multifunction Tools and accessories
  149. Masonary Drill bit RPMs?
  150. Bending Fixtures - Will it solve My Problem?
  151. ENCO 13% off everything today only!
  152. tool grinding
  153. Copper Tube Fittings (and other wrought fittings)
  154. BIG Daishowa Seiki drilling speed increaser - lubrication?
  155. Power draw bar verses Mach 1 quick change Tool system
  156. non destructive testing of materials
  157. Southbend 9 on Craigslist.
  158. OT: Marrying DSLR camera & macro flash
  159. Paging Doctor Demo ... Dr Demo please pick up the white courtesy phone
  160. How would you make this part?
  161. Step chuck held in 3 jaw?
  162. Help indentifying a mill drill
  163. When was the last time you cast something out of aluminum?
  164. O/T Edit? Edit what :p
  165. Scraping Crossslide
  166. Hardened D-2 Machining
  167. jacked up trucks
  168. Fun With Snowblowers...
  169. not sure what the proper forum is for this, but hopefully a Mod can move it if needed
  170. fixturing to faceplate on lathe
  171. Gorra3Dprinter
  172. OT, "upgrading to Vista on Dell Latitude D610: ACPI error??
  173. Everlast welders at Home Depot
  174. Which zerk(s) for the saddle/knee ways on round head Millrite
  175. EDGE: Pro Tram System
  176. Strange bolt?
  177. New to me drill sharpner
  178. Water Jet Cutting Machine
  179. Uni-Grind: video question of the week.
  180. What's up with Evan?
  181. looking for indexable carbide insert tool holders for turning.
  182. Why I like hondas?
  183. turning water into water
  184. Boring Bar Repair
  185. 5hp Honda keeps shuting down
  186. OT: How do you open the doors after you put your car in an enclosed hauler?
  187. Polishing round stock safely on lathe
  188. Two machines one line
  189. OT: refinishing marble tile question
  190. Clausing 5900 spindle question
  191. what the hell is this about?
  192. Why smoke sensor are sensitive to plasma cutting
  193. A different opposed piston engine--
  194. magnetized chips
  195. Outside combustion air intake on furnace
  196. Removing aluminum from carbide
  197. Assorted plastic materials
  198. My Millrite Project
  199. Yanmar Nikki Negative Pressure Pump Puzzler
  200. The DeLorean that could have been:
  201. Enco MSC discount codes?
  202. Machine shop simulator software?
  203. Double acting internal combustion engine...
  204. Spark Plug wire nuts
  205. Santa came early
  206. Name change
  207. Air heat exchanger for shop
  208. Face Plates and Drive Plates
  209. Electronic parts have gotten ridiculous.... just look at this....
  210. Odd dimensions for SS 1/2-13 T-nut, won't fit HF Mill/Drill
  211. Finally. A pie chart we can all relate to...
  212. Abrasive Evan
  213. Drill press LED light
  214. Questions on Loop Collet Chuck Details
  215. A take on Frank Ford's auto feed for 14" Delta Vert band saw
  216. Solder paste/ tinning compound
  217. Stirling Engine: Suitable for Green Energy at Home?
  218. MoJo 3D printer?
  219. Follower Rest Question
  220. Dragging your quill ------------- ?
  221. cutoff wheels for surface grinders
  222. Gear Cutter via 2 button method
  223. dealing with raised gap due to lathe bed wear
  224. Sag at ends of mill table
  225. N.E.M.E.S. Model Engineering Show
  226. Stuart Turner Print Question
  227. O.T. Web page cache
  228. good english steel grades
  229. OT - Any experts on the science of cracking glass around here?
  230. Pop up's on web pages
  231. The Writer Automaton, Switzerland
  232. 4140 H/T scrap piece
  233. Gallery of lathes on Craigslist
  234. My wishes
  235. Merry Christmas
  236. DRO - Mill or lathe ?
  237. Atlas 6X18
  238. Hardinge/Sjogern chuck
  239. So, a Unemployment question for you, NY State
  240. Endmill sharpening
  241. I pledge alliegience
  242. OT-Trying to stay warm and looking for advise
  243. Any other women out there? I could use some advice.
  244. Armature magnet trouble
  245. Handy modification to my rol laround tool box
  246. Lathe backsplash out of plastic??
  247. Router bits for steel???
  248. Owner built precision regulator clock
  249. OT Keith Fenners toolbox giveaway
  250. OT - automobile manual trans "bearing" noise - no apparent bad bearing
