View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 [219] 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. OT - automobile manual trans "bearing" noise - no apparent bad bearing
  2. One of Santa's elves told me....
  3. Troublesome MT #1 Taper (male)
  4. Power feed parts?
  5. Me too! Me too! (3D printing)
  6. My precision abrasive chop saw
  7. Got my first lathe - Craftsman 6 x 18
  8. Merry Christmas and Happy holidays to All
  9. Video of drilling a clear acrylic rod in the lathe, and a rocket engine.
  10. Quick VFD wiring question
  11. Looking for engaging techniques
  12. Oilite bushings
  13. Merry Christmas!
  14. Santa was good to me!
  15. The Anti-Squirrel Ball---
  16. Kasto Power Hacksaw - troubleshooting hydraulic feed.
  17. End of Year again??
  18. Surplus tools and contaminants?
  19. _ What material to make an "Arbor Press" pinion out of ?
  20. ohmnic sensing for tool height?
  21. magnets instead of spider
  22. What will you buy?
  23. January/Febuary Issue of Home Shop Machinist Out?
  24. Distributor cap and rotor problems
  25. Hendy Lathe
  26. 30 Ton Press Project, a monster or how to over build it.
  27. Humble announcement
  28. What I made on Christmas Day
  29. OT- Which Flat Screen TV?
  30. Enco collet difference?
  31. What I ate on Christmas day
  32. Newbie from SW Georgia
  33. Modern Technology, Aint It GREAT
  34. Electromagnet?
  35. Tail Stock Tap Holder
  36. 3 Phase Contactor Help
  37. What's "the" machine tool color for 2014?
  38. 5.5KW Motor and VFD, Have I got this right?
  39. Countersinks
  40. OT: REAL hominy grits
  41. Windows 8 ?????
  42. Fully equipped machine shop FS in Jessup, GA
  43. Screen names
  44. 135* drill point gauge
  45. DIY desktop wire bender
  46. Monarch 10EE Metal Lathes
  47. Will welding distort tapped holes?
  48. Worn Grinder? - Video Question
  49. Mars-red
  50. ID markings on mystery plastic?
  51. Maximat 7 with milling head – mill has stopped running – need advice
  52. Now here is an extremely cool, useful and doable project
  53. Weldon tool holder
  54. Insurance Coverage For Home Shop Tools
  55. Designing a 5c indexer--compromises, compromises. . . .
  56. How times have changed.
  57. Way WAAAAAAY O/T - (For the culturally inclined only)
  58. My new to me milling machine
  59. New Calendar for 2014
  60. Carriage lock
  61. Plans for a radius fixture?
  62. Dealing with chips. swarf, and broom tangling strings
  63. 110v servo motor?
  64. Free 8x24 magnetic chuck
  65. Help with milling surface *rough pattern*
  66. Is there a better way to make these?
  67. Ice auger blade sharpening, lookin to build a grinder.
  68. Hot Water Tank ?????
  69. 2pt Epoxy in Syringe Dispenser - Shelf Life after 1st Use ?
  70. Reversing a single phase motor...
  71. We have it EASY---
  72. Green Bear 12" box & pan (finger) brake cheaper than 12" regular brake? Why?
  73. Demagnetizer
  74. Ring gear engine
  75. Learning CNC maching
  76. Copyrighted Text Documents
  77. OT: GFCI Breakers and Generator Transfer Switch
  78. Odd sources of income.
  79. 3M Polyflex type belt spec?
  80. OT- balsa, spruce, cedar for model building
  81. Tool gloat & offer
  82. Searching for part: need help
  83. old cast iron - metal shaper - what to look for upon initial inspection?
  84. Caswell Plating, Getting Rid of the Solution?
  85. Happy New Year to All
  86. Never heard of this brand lathe, he he
  87. Shameful shipping company
  88. Hydraulic Cylinder question
  89. internal threading help
  90. Shameful shipping company
  91. New Grizzly Surface Grinder
  92. OT: Computer File Synchronization/Backup
  93. 3/32 square collet and holder
  94. Vacuum chamber and the characteristics of glass?
  95. Has anyone made a Thread Mill out of an old Tap?
  96. Best way to cut holes in copper sphere?
  97. Silver & Deming Drill Bits
  98. How were these made??
  99. World's smallest working model three phase AC induction motor project
  100. Turning a ball in 1903
  101. OT - light bulbs - what to do.
  102. Shop related New Year's resolutions?
  103. OT:Power shut off causes BSOD on XP Pro
  104. Evanut and CNC machine
  105. Seco Crown Loc drills?
  106. copper sulfate (sulphate if you will)
  107. Jet JBS14-MW - Metal/Wood Bandsaw - Slowing to cut steel
  108. Stuck 14N Jacobs Chuck disassembly?
  109. 110 to 12v converter?
  110. Dalton TL Lathe
  111. How did they make these??
  112. Amazon getting into the industrial supply business
  113. Replacing Fireplace nat Gas
  114. Snowblower shear pins....
  115. Flux update
  116. I need a machinst in central Ohio to grind some metric threads----
  117. Punch and die for thin matal (motor laminations)
  118. OT: Treachery of GPS Devices.
  119. What's the largest sized tap I can power-tap with a 1 HP motor?
  120. lathe chuck question
  121. sometimes you just get lucky
  122. Automobile production...
  123. excello 602 information wanted
  124. Scraping Class in Kalamazoo MI
  125. Anyone Here Experienced With Thread Forming Taps?
  126. Idiocy at the big box hardware store
  127. Are one shot lubes all there cracked up to be?
  128. OT- heat-sealing fire hose
  129. Surface Grinder rebuild
  130. slowing down single phase motor
  131. drill press improvement
  132. How Would You Make This: cutting a disk into a BIG flycutter
  133. DRO from Shars or Little Machine Shop
  134. 6.5 kw generator question
  135. end mill best choice
  136. Miniature Switched Reluctance Motor (SRM)
  137. Gear Cutting Hobs
  138. Shop Space -
  139. Forum Advertiser
  140. Cutting 11.5 tpi on a Craftex B227l lathe
  141. Color-matching filler for cast iron?
  142. Ba$#~£d day, ba<*":d job.
  143. UPS Freight pays up
  144. Starting a tech school
  145. borletti bcd 1002 sewing machine
  146. Help with a gear ID?
  147. Cross feed dial locking methods
  148. Problems with heat controller...
  149. question for the engineer types
  150. Getting started with lathe mill combo, super basics needed
  151. Options for powering a TOS FNK25 mill
  152. OT: Destroying Disks and Drives Video
  153. DIY Ultrasonic Cleaner?
  154. Rigging Gear and Rust - When Does Cosmetic Become Structural ?
  155. Purchasing a lathe
  156. How do I contact a crertain member?
  157. Bridgeport way wipers question.
  158. shaper/mill
  159. Dovetail Cutters
  160. Floaters.
  161. Thawing Pipes -- A Public Service Announcment From An Utter Ba5tard
  162. What does this 15" steady fit?
  163. Low Cost DRO for Lathe Cross Slide
  164. Roller Bearing Surface Hardness???
  165. About Nick's "Dovtailometer" and other things
  166. Enco lathe question?
  167. Enco lathe question?
  168. Le Blond Regal 15"
  169. How to cut a coffee plunger pot?
  170. Wacky quill balance spring
  171. Can crushing
  172. New gasoline engine design
  173. Interchangeable tip Live Centers?
  174. No good reason: 1/4" End Mill holder?
  175. Supplier Question qu-bd.com
  176. OT - Aviation: Factory Finish on 40's era Wooden Prop ?
  177. Broken drill
  178. How to Enlarge a Hole in PVC Fitting
  179. OT - Computer problems caused by aurora borealis?
  180. Drill bolt access in heat sink material
  181. VCR engines - the next frontier
  182. DA tool holder nuts: tightening torque?
  183. OT: tankless water heaters
  184. Another newbie lathe question. 80 t plastic gear?
  185. Shear Pins and shear-pin metal
  186. South Bend Follower rest question
  187. Starrett 161d parallel clamp
  188. Bearing sea gold, those dredge pumps, how do they pass such big rocks?
  189. Press Fit vs Loctite Bearing Mount
  190. Home shop CNC plasma....
  191. thread OD 5/8" what size to cut.
  192. Smart Cell Phones and Welding
  193. Old Ungar soldering setup...??
  194. Interstate end mills
  195. Floor jack repair help again please
  196. Amazon
  197. economy press
  198. Shopwork and extreme weather.
  199. Moglice help
  200. Red hot cylinder?
  201. Thrust ball bearing fit
  202. Help - stuck chuck, stripping gears on Craftsman 6x18
  203. 3D printing
  204. Bokum boring bars... Sharpening?
  205. Power tapping 1/2" mild steel plate
  206. Any secrets to using a Rotabroach in a mill?
  207. Another over-unity nutter
  208. Lubricants for Various Threading Materials
  209. OT: For the model train nuts
  210. Looking for HSM magazines from Nov/Dec 2003 and Jan/Feb 2004
  211. Does "direct to metal" paint mean no primer?
  212. Bridgeport clone 3 or 5 hp
  213. _ LED Lights: Criss - Cross light beam contamination/cancellation ?
  214. Wask wrench?
  215. Question about car dolly
  216. Question about clamping threaded rod vertically on a mill.
  217. finally bought collet indexer, need advice please
  218. Idea's on a cheap, nice CNC project
  219. O/T Slime on glass
  220. Make a shear using planer blades?
  221. removing oxygen from air
  222. Small mill X2 and surfacing
  223. Enco 20% PLUS FREE SHIPPING NO MINIMUMS/EXCLUSIONS
  224. OT - GeoThermal Heating & A/C
  225. Static converter with idler question
  226. Switch for 3 phase motor
  227. Beware the gummies!
  228. keyboard question cnc
  229. Looked at a mill today!
  230. WTB: Used Square Column Mill Washington / Oregon
  231. LED question
  232. Anyone have experience with a "Brush Grubber" for pulling saplings?
  233. Yet another new toy, Thermal IR
  234. Motor start capacitor mfd rating..........?
  235. Best Milling machine under 1500lb and $10k
  236. Rebuilding a Power Hacksaw
  237. HSM stuff in St. louis??
  238. Boring bar setup selection
  239. Cutting a15 tpi thread
  240. New to me boring bars what insert type.
  241. tool gloat
  242. Insert size - 22_ vs. 21.5_
  243. Nuts or balls, rod or rail ?
  244. What size rotary table?
  245. stupid math!
  246. Tapping heads: Procunier or Tapmatic
  247. dumbell
  248. converting LED flashlight to mains power?
  249. where to download machine shop charts from the web
  250. Injection Molding Nozzle flow
