View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 [220] 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281
  1. Stepper motor wiring...
  2. I need little bevel gears
  3. WOT: L Band Radio
  4. harbor freight band saw now bending blades
  5. Way way OT but interesting: Trimming trees with a helicopter
  6. ok the DYKEN stuff wont stick
  7. measuring small angle tapers
  8. Vincent R Gingery: HM Bandsaw.
  9. telescoping gauges - break in?
  10. Rotary Phase Converter -- Buffalo
  11. OT: One For The Aspiring Tinsmith!
  12. Bending 1 1/2" aluminium Tube
  13. Anything useful in scrapped paper shredders?
  14. machinist level
  15. Questions on anvils
  16. H5940 4" rotary table rebuild
  17. Procunier tapping head arbors
  18. RPM on Grizzly G4000 or any Lathe
  19. Using Edge Finder horizontally
  20. How to Form a Metal Cone?
  21. Cutting large steel plate
  22. I need some ideas for this pile of steel plate.
  23. another question from the peanut gallery
  24. OT: New credit card scam warning
  25. _ Another Mill Head light by LED's (pics)
  26. Adjusting harrison lathe headstock bearings
  27. Big lathe and mill on St. Louis CL for $1000 about to be scrapped.
  28. Vacuum motors, whats the specs, what are they good for?
  29. planetary gearset out of automatic transmisison?
  30. .125 hole in 3/8" ball
  31. today's project done.
  32. Source for steel bands/hoops?
  33. Tool Gloat
  34. Palmgren Vise - Horribly Abused (Flea Market Find)
  35. Single-point a dovetail with mk1 eyeball setup.
  36. 3/4" arbor is too big
  37. manual shear
  38. World record EvaNut machine
  39. Looking for source of lead screw nut
  40. Mighty Mag - should it look this bad new?
  41. ENCO 25% Discount - Today Only!
  42. Weed Eater cutter mod
  43. Horizontal Band Saw swarf brush ( blade cleaner)
  44. How do I cut 2024-T4?
  45. Grizzly G1006 collet change
  46. Looking for gear change chart for Edison lathe
  47. C/L Heads Up
  48. Metric Dial gauges
  49. Missed Doall gloat?
  50. DRO Pros Sieg SC8 lathe, I now have one
  51. Quick Tip: Magnetic Belt Speed Pointer
  52. Sould o1 be able to cut 4140ph? What wrong with my HT.
  53. Aus. Turret Mill variable motor half spool replacement ?
  54. Monarch EE on eBay
  55. Slow motion lathe crash
  56. Replacement Change Gears for Atlas / Craftsman Metal Lathes
  57. multi spindle automatic screw machine questions
  58. Gyroscopically Stabilized pool table on a cruise ship.
  59. Unusual wood working project
  60. _ Motorizing Milling Head with a cordless screw guns motor (video)
  61. Little machine shop poor service, DRO Pros did a great job though.
  62. Flylow???
  63. USB Microscope
  64. Making my first D bit--
  65. Thread ID 3/8x24 brass
  66. artco tool grinder??
  67. Can a chrome-plated wrench extension be knurled?
  68. Machine Tools Warehouse Ontario Canada, do they still exist
  69. If you ever need a special drill chuck
  70. 21st birdie watching guide !
  71. 3 inch tube bending
  72. OT, for the Englishmen, telephone/power poles...?
  73. Anyone else need Mobil Vacuoline 1409?
  74. Book: "Classic Motorcycle Race Engines"
  75. Woodworking
  76. Anyone Sell a Die Grinder that is Electric with 1/4" 90deg head?
  77. Totally off topic! Big Boys Photo Sniper..
  78. Make: Ultimate Guide to 3D Printing 2014
  79. Feeler 618 Lathe - Hardinge Clone
  80. First attempt at acetal nut
  81. Mr Bleichert's cast spoked wheels
  82. Rotary tool (Dremel) storage solution.
  83. I'm eyeballing a 10EE
  84. 5C Collet Chuck
  85. Man Computer Problems again!!
  86. Handheld Laser welding
  87. R.I.P. Ower Gert.
  88. Multi-Start ACME rod
  89. restoring bellows covers
  90. HSS carbide centre drill
  91. Latest from Kieth Fenner - Cutting and Internal Spline
  92. grinding/making form tools
  93. Question on anvils
  94. Delta Scroll Saw/ Die Filer
  95. granite slipper plate
  96. S3 Telescope mount
  97. Found a way to get back in here.
  98. OT - Retirement and Social Security delayed payments
  99. Collets
  100. Cleaning, oils, grease question.
  101. Dial Indicators; Removing the bezel
  102. Thrust bearing died on mill vise
  103. Power Box
  104. Noga mag base and indicator holder
  105. Favorite thick cutting fluid
  106. Dial indicator tutorial
  107. quick machinist math question
  108. Remember this? it's done, but they are not using it
  109. shaper question
  110. OT - Water on the Int'l Space Station
  111. First post! Just upgraded my lathe as well. Pics coming soon!
  112. Carbide Insert Sharpening Fixture
  113. VA vs. Watts - Why can't they just make it simple?
  114. Goldenrod Pistol Pump Oiler - Seepage
  115. Plasma cutter torches
  116. Fireplace/move heat from room question
  117. Spiral point taps
  118. Tos Kurim Rotary Table
  119. ball bearing heat sink
  120. Valenite Boring Bar Insert
  121. New lathe for You
  122. Posting Photos and Starting Threads
  123. Dynamic Balancing in home shop
  124. Logan 820 Spindle Removal
  125. Slocomb Mic Adjustment
  126. OT: Legal Question, re Using a Published Idea
  127. Dust Collection Hood for my Boyar Schultz Surface Grinder
  128. Gearotic question
  129. Looking for Aluminum Swarf
  130. Anyone fluent in Mach3 problem solving????
  131. Photos
  132. Help with Omega CN7600 Process Controler
  133. Any Experiences With SERVO Brand Power Feeds?
  134. First 10 years of Home Shop Machinist for sale
  135. Another screwy idea - not Clarkson Autolock
  136. Core Drill to Tow Hitch Adapter
  137. OT, problem with DVD drive, W7....
  138. Front Dust Shield on Boyar Schultz surface grinder
  139. Need help from geometrical tin bashers.
  140. Is the Vertical Shear Bit just for steel?
  141. IPB for a Kurt Vise D60
  142. dividing head question!
  143. Storing oily rags
  144. Best Beginers O-Scope Reference?
  145. Preventing cross-slide lift when boring?
  146. Shaping, Planing and slotting
  147. PSA: J.I.S. (Japanese Industrial Standard) Screwdrivers
  148. Jim Sehr's metal sculptuire Balls in a ball
  149. Slightly O/T Windows XP support ending shortly
  150. 1144 vs "real" "Stressproof"
  151. One for John Stevenson
  152. Bench grinder
  153. O/T Turning off the mouse pad
  154. Follower rests that you have built
  155. Made a tool chest
  156. When a gloat goes wrong
  157. OT: My $3500 screwdriver
  158. single point internal pipe thread on the lathe
  159. old manchester end former
  160. Hi, new to site & need cross slide table advice
  161. Getting a nice smooth finish out of cast?
  162. OT-Heat Pump Stat Wiring
  163. in defense of letting stuff go
  164. truing a roller
  165. RE: Windows XP support ending soon. New computer specs?
  166. Yer Hoo a gloat to end all gloats.
  167. Storing cutting fluids
  168. Exploding paint tins OT
  169. verical toolbit lathe toolholder
  170. Homemade Bowl Lathe
  171. Calling Black Forrest to the bar.
  172. Tool id and advice
  173. Sharpening End Mills........???
  174. Brazed carbide tools, are they created equal?
  175. Sourcing Tiny Staples
  176. Carl Zeiss Jena 35mm on F mount Nikon
  177. Any of the Chinese Boring Heads good?
  178. Source for M4-0.75mm set screws?
  179. OT. Small utility tailer hub rebuild question.
  180. Making a replacement handwheel for dividing head
  181. OT: First Ford Race Car, Circa 1901
  182. O/T PC recomendations to run Linux
  183. Moving the lathe from a basement
  184. Round bottom hole
  185. Snowmageddon
  186. 100 ton die press on the cheap
  187. Trusty 4x6 bandsaw - mod to improve downfeed
  188. Would you buy this mill?
  189. hydraulic jack orientation
  190. ENCO Free shipping
  191. O/T Phantom II Vision Quad-copter
  192. 3/8" Lathe bit holder for 1/2" turret - first real milling job with steel
  193. Anyone have extra gear cutters?
  194. Anyone have instructions on how to build a power supply?
  195. Steam whistle plans needed.
  196. CNC Plasma Speeds?
  197. Metal for lathe change gears...?
  198. Your gloat for tonight
  199. Starrett Tool Identification
  200. Russian Dividing Head "Stanko A265" manual ? info?
  201. Boring a precise hole-advice needed.
  202. Babbit for crank bearings and its use today
  203. Sloppy Drill Press
  204. Solenoid Valve Selection
  205. Way OT. Have you ever done the right thing without even thinking about it?
  206. OT:cxml file problem on tax software
  207. sheet stampings / pressings guidance?
  208. Small Machining Job
  209. Connector type for Acu-rite III DRO?
  210. Bridgeport 440 to 220 volt conversion?
  211. Attn: Village Press - Machinist's Delivered Today in Canada (Finally)
  212. Minimum height opening for a standard pallet jack?
  213. Dividing head back lash..
  214. Interesting reference site
  215. Tool Gloat by association...
  216. Dropping voltage from AA battery...resistor or diode?
  217. A way to figure hole spacing
  218. Spiral point taps
  219. Rockwell 11" lathe in North Carolina
  220. OT - Wireless Capability for an Old Desktop
  221. Bent motor shaft - need advice
  222. bleeding a bottle jack
  223. Bridgeport Z axis Stop Loose cant figure out how to remove to fix
  224. OT: Diary of a snow shoveler!
  225. Hertzian contact stress
  226. 5 tpi
  227. OT- Gas Struts
  228. OT- Wood gas
  229. LED Halogen floodlamp replacement
  230. Worm gear sources for spindex?
  231. Drill Dr. Question...........
  232. Shoe Goo
  233. Knee travel not parallel with spindle
  234. Vertical plasma table?
  235. Is it O.K. to run a 14" chuck on a 16" South Bend lathe.
  236. SAE 10W for tapping head.
  237. DRO Pros Sieg SC8 lathe, install redone
  238. Dividing head question (another one, sorry about that).
  239. Round column mill
  240. Drip Feed Oiler source
  241. Anyone got a South Bend 9" lathe in bits ?
  242. Has anyone taken a scrapping course?
  243. Face plate
  244. Clausing vari drive countershaft bushing questions with video
  245. Metric Thread Major Diameter question
  246. Knurling sizes
  247. Small Gloat for a Small Shaper
  248. 3 Phase puzzler.
  249. South Bend 10" Lathe project, what am I in for?
  250. Sieg Lathe and Mill Seem to Play Well Together
