View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 [222] 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
  1. How would you make this?
  2. How to make my South Bend lathe cut metric threads?
  3. Cheap super glue
  4. Endmill +chromed shafting?
  5. How far can a drill drill ?
  6. Drill bit length preference
  7. 1994 chev. truck
  8. Carbide Cutting Speed
  9. Internet Auction - Lathe
  10. It's Baaaaaaaaak....... Return of the double post
  11. OT - How to flip a wooden boat over?
  12. spindle diagnostic
  13. Control board for CNC Laser Mach 3 Cat 5 Ethernet
  14. Memory refresh, computers and post to forums like this.
  15. Chisel Sharpening Fixture
  16. crashed the gearbox of the Meuser
  17. Really nice Power supply manager
  18. I Love Craig's List
  19. Mill edge finders......
  20. Mini lathe tailstock
  21. New to me Aurora camelback drill
  22. Slitting or Slotting Saw. What's the differance?
  23. Machine tool porn
  24. Finding center in egg shaped hole.
  25. Atlas Banjo gear loosens itself by design?
  26. OT? Monitoring State of Charge in Lead-Acid Battery
  27. Another day at the office.
  28. Collet chuck for lathe
  29. Free magnetic chuck???
  30. What's slicker than snot
  31. Why Is It Every Aloris Tool Post Looks Like This ????
  32. grazioli
  33. Aluminum Head Repair
  34. Please talk me out of getting a 16" x 120" Leblond lathe.
  35. Heavy duty adjustable feet
  36. I just scored a new cutter....it needs inserts
  37. Trip lever redux
  38. Inside calipers, outside calipers, and dividers storage thoughts..........
  39. Auto stop for lathe
  40. Differences in piston and wedge type tool posts .
  41. Hydraulic press build pictures
  42. "Pro" riggers
  43. OT: What was helicopter doing?
  44. Some dads build their kids go karts, and some build.....
  45. Rack for storing long extensions on outside of toolbox...any suggestions?
  46. Ideas for storing small lengths of tubes
  47. Modest tool and material gloat
  48. surface grinder hub adaptors
  49. Ancient mini lathe sage continues
  50. Bandsaw wheel crown?
  51. OT, way OT automatic Chicken House Door
  52. Anyone need a STARRETT Micrometer? Today's chuckle...
  53. The weekend project, vertical head for the Lewis
  54. Moving the lathe the smart way. Lotsa pics.
  55. What size stepper motor (how long is a piece of string)?
  56. Learnt by failing, broken taps
  57. New Office/ Machine Assembly Area
  58. Poor Customer Service From Princess Auto.
  59. Used machine tools and accessories in South Bend, IN
  60. Pull stroke clapper box
  61. Enco Free Shipping Code
  62. Interesting, funny, useful to some of us...
  63. More ENCO codes
  64. This Poor Delta Milwaukee Bandsaw Needs Help!
  65. Tool and DieGuy.com?
  66. OT- Cleaning Out a Switch
  67. Model I.C. Carb with Throttle
  68. School me on clones...
  69. My next index for my taps
  70. uses for monel wire
  71. pneumatic valve help needed.
  72. Mill ID
  73. Turning scrap tool steel into BIG punch dies with a small boxford lathe
  74. A heat straightening primer from the gov.
  75. Ex-cell-o grinder cartridge help
  76. Questions On Painting Cast Aluminum Machine Parts
  77. Lever collet closers
  78. Straightening shafting by selective cold rolling
  79. Slotting Job
  80. Not so hypothetically, how to get customs duties info on imports?
  81. Carburetor Theory: Controlling Small Engine Speed
  82. OT: Odd snowthrower problem and cure
  83. Incredible out the front switchblade mechanism
  84. 3/8 carbide EM feeds/speeds
  85. Somewhat OT: "Bricycle" physics
  86. Pinning a timing gear
  87. OT: So what's your theory on the missing plane?
  88. Left-Hand Threading Problem
  89. Drill Press Quill Wear and Options
  90. O.T. Folsom Dam flood control improvements
  91. 3/4" female hex help
  92. How to straighten spring steel strips
  93. molasses and derusting
  94. Parting on a lathe-is it the tool?
  95. Straightening spring steel strips
  96. Priceless
  97. Atlas Mill Base Ideals Needed
  98. Ticked off at last
  99. OT- SwageLock Fittings
  100. Thread description help
  101. O/T but related to engineering/forces (and chevy's ignition key malfuntion junction)
  102. Surface Plate Table
  103. Sheet metal Folder
  104. HSM Very Slow
  105. OT: 2 Cycle Toro Mower Question
  106. Bridgeport sizing
  107. Anyone in the US used the new ebay system for prepayment of customs duties?
  108. Home made "100 ton-ish" press structural failure
  109. Great work lights!
  110. SOT: Customs
  111. looking for a new caliper
  112. 'IceHook' for Lifting Lathe Chucks
  113. O.T. Thinking about a new p/u truck
  114. The Movers Are Here!
  115. Big circular saws OT
  116. How flat is glass?
  117. Side Milling Cuters....... ??????
  118. I need to build a transmission
  119. Since we are having a debate re the missing plane I ask what about oscar pretorious
  120. OT: sort of - web hosting sites
  121. ESOP's
  122. Triangular Gib Key exploration
  123. Can't split my Biax, need ideas.
  124. Electrical issue, whats the failure path here?
  125. Using 3/4" R8 collet to drive a 2" Hougen annular cutter?
  126. Help with 14" Hendey lathe
  127. Kao Fong Mill parts
  128. Well, I have made a few simple things..but am a bit proud of them...
  129. Rockwell Mill
  130. OT:ICE Violation
  131. The double posts are still happening....
  132. Ebay and shipping scam
  133. CNC Mechanical issues...
  134. Where to find Machining Info? Advice needed
  135. propane orifice size ?
  136. Biax Half Moon metal scraper speed controller
  137. Dahlgren drawings?
  138. Generator Drag!!
  139. parts washer solvent
  140. Power steering pump off a what?
  141. accurate cross drilling
  142. Rebuilding a 12VDC-PM Motor
  143. Looking for a 4" Mill Vice
  144. Slotting recommendations?
  145. I have had a BP mill boo boo and need to fix something...
  146. Switch died from old lube. What new lube? Makita angle grinder.
  147. Why does the quality of the arc change in the last 1 1/2 to 2" of the welding rod?
  148. Some wreckage found
  149. electrical curiosity
  150. Trying to decypher presicion taperered roller bearing classifications
  151. OT: Rebuilding 'Lazarus', a toasted B2 bomber
  152. Which Stainless Steel Alloy for Automotive Brake Lines?
  153. Quality of dial calipers?
  154. What's in the drawer?
  155. Power drawbar build
  156. Specification on mill table flatness
  157. are starrett 12 98 level usefull for scraping or should I pass?
  158. Sorta OT: Sander pad replacement
  159. Way O/T. Cigarette, Cigar smokers?
  160. Open belt drives and chips
  161. belt sander project coming along
  162. HSMAdvisor, Anyone on here tried it yet?
  163. What dissolves Wite-Out
  164. Laser printer fusers
  165. Avey drill press?
  166. How to remember?
  167. Crank Shaft Bearing Housing Play and Options
  168. 4 roll slip roller
  169. Will this VFD work ??
  170. DIY milling attachment for lathe
  171. Chuck backing plate mounting?
  172. trying for an elegant and effective quick change tool post
  173. Noticed Something About My Jacobs Chuck Today........
  174. Hardinge ESM-59 Lathe
  175. CRS bar stock run out.......
  176. Lathe on Craigslist
  177. D camlock Help...
  178. 304SS mill or grind
  179. Quill lube question...
  180. Iron oxide
  181. Gear puller recommendations?
  182. I will let you guys tell me if this is a gloat or not.....
  183. spotted in Norway
  184. epoxy pump
  185. Norseman black gold drill sets
  186. Sorta gloat
  187. Looking for 13/16" diamond punch and die.
  188. Shaper Vise Score
  189. Hot Blue and Other Processes...????
  190. Recommendation for 10” Aluminum Oxide Wheels
  191. Angle grinders: buffing?
  192. REBUILDING & SCRAPING CLASS IN NORWAY and SWEDEN 2014
  193. Eisen lathe
  194. Window shopping for a mill
  195. Big project for a round column mill
  196. Moving day part 2. Moving the mill into the shop
  197. Question On location OF Surface Grinder In Shop
  198. Boring deep holes in aluminum rod
  199. my rendition of a press
  200. Gibs tightened up... why?
  201. Will Weather Affect LockTite if Used Outdoors?
  202. Questions about Paul's QCTP design
  203. Clausing/Kondia FV1 mill
  204. Stanley "carbide" utility knife blades; real or scam?
  205. Pistons and Scraper Rings....... ???
  206. Another use for coin holders!
  207. solar welding helmets
  208. Hole saw, 2" hole in cement block
  209. More shop LED lighting.
  210. taper plug friction welding
  211. The reason I have a shed (shop)
  212. OT LP stove flame yellow and smoky
  213. Walton tap extractor
  214. Help adding a brake to my lathe.
  215. BP clone spindle backlash
  216. OT antenna splitter
  217. Power drawbar - the first installment.
  218. Removable adhesive for plastics?
  219. Length and Perpendicularity
  220. Bearing cup removal
  221. GE pushbutton ID?
  222. 3 phase motor runs on single phase
  223. Power draw bar
  224. Sanford SG-48 surface grinder survey
  225. Grinder wheels
  226. Precision Scope Ring Alignment Reamers: How Are They Used?
  227. Mold texture - how do they do it?
  228. Anyone know what model Craftsman metal lathe this is?
  229. 7 1/2 HP 3 phase motor running on static convertor
  230. Small Bench Top Vacuum Cleaner
  231. Huge machine and tool auction - nucular site (sic)
  232. Tappet Stem Clearance On Briggs Engine
  233. Sidney Lathes??
  234. Stepper motor ?
  235. My Hardinge V59 might not have been such a good deal
  236. Almost ON topic- identifying silver
  237. Awww - Cute little terco trainer..
  238. Help needed with a Hardinge – Sjogren No 2 Speed Chuck
  239. Looking for advice on coolant mister setup
  240. Site Outage
  241. 12" guillotine metal shear bench top
  242. What threads on a CO2 bottle??
  243. How Did My Tail Stock Get .008 Higher ??
  244. OT- Virus?
  245. Advice Needed for Sanford SG 48
  246. Rockwell Mill
  247. wide belt sander musings
  248. OT: email from Jamie Dimon
  249. Anyone purchase from CDCO Machinery Corp?
  250. Is there anything else I need to know before performing spindle shim adjustments?
