View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 [223] 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
  1. Flat rubber belt pulley in cassette tape deck - flange vs crown?
  2. glueing brass
  3. Jet 3230 Band Saw leftover part after assembly
  4. Lathe Identification
  5. Batteries for digital cameras
  6. Still alive
  7. Yet another dumb Motor wiring question
  8. what blade to use
  9. Atlas collet closer
  10. Another motor question about reversal
  11. Tiny Bridgeport
  12. Pilot on a 7/8 - 40 Tap
  13. OT- End of XP?
  14. National From Thread Gauge
  15. Sliver soldering Band saw blades
  16. Dumb question: LH nut on RH screw possible?
  17. Enco 15% Discount & Free shipping!
  18. Super Enco Deal - 15% off AND free Shipping. No exclusions!!!
  19. Ream job
  20. The Inner Workings Of A Roto Cap & The Theroy Behind It
  21. Snap ring groove cutter
  22. Dimensioning Uneven Stock?
  23. wide belt sander update
  24. Material sources, 4130
  25. Rubberflex
  26. Anyone have a couple 7/8-9 x 9" square head bolts they can part with?
  27. Jones & Shipman 1212 Cylindrical Grinder
  28. Automatic Centering Under Mill Spindle
  29. Stupid Genes?
  30. OT HSM shipping
  31. Current Transformer mounting help.
  32. Will this switch work to split 240 single phase
  33. Enterprise 1340 lathe wiring and rebuild
  34. Measuring Surface Roughness
  35. Ebay and paypal....
  36. Will Macona please answer the phone
  37. Identify this vise?
  38. CNC plasma table THC wiring....
  39. My new girl
  40. Free vertical band saw
  41. OT- End of XP...Move to CentOS?
  42. ABS Or Delrin Sheet ????
  43. Question for those suggesting non-windows OS'
  44. Spindle taper surprise....
  45. Bridgeport Boring Head Mod or Adapter
  46. Electric Motor Starting Capasitor
  47. Modding a Flo Lock carbide tool holder to fit my AXA generic QCTP?
  48. lathe chuck off center
  49. Aluminum for disk grinder disk
  50. OT... How do I Emulate power factor?
  51. Where to find SMALL involute gear cutters?
  52. OT-msd ignition system
  53. OT: Water Filter Question
  54. A little tool gloat
  55. Power feed drawbar question.
  56. Somebody buy this shaper
  57. Tool Post Grinder Wheel Dresser
  58. Not OT: does not contain any content that will cause an argument or hurt feelings
  59. Replacement for broken vise handle
  60. Job for a little shaper..
  61. Anyone seen a rig like this for tilting a car?
  62. OT Battery Question
  63. I broke my bench vise
  64. Bijur oil lubricator reservoir needed
  65. Speed and Feed
  66. Need advice on 3 phase converter
  67. Fun with Worm Gear Drives
  68. OT where to go- what to see
  69. Debased my Craftsman 12" lathe
  70. Pinging Tubal Cain - MrPete222
  71. Cabin Fever
  72. Craigslist optimism and understatement - "Small trees have started to grow"
  73. Ebay double listing, against policy?
  74. How to machine a disc from plate?
  75. Missed a pallet of straightedges at HGR today
  76. How di I remove these live center bearings?
  77. ac/dc "pulse converter"
  78. ENCO 20%off $199
  79. Bad Design ??
  80. grip pressure with vise
  81. Forum
  82. Thinking inside the box but working outside of it.
  83. The Heartbleed Bug
  84. OT: Okay, which one of you was this?
  85. Ballscrew advice requested
  86. OT but IMPORTANT!
  87. plugging engine oil leaks
  88. Cleaning up a rusty old lump
  89. Building a model Gas Tank
  90. OT: More email scams
  91. Best Way To Set This Casting Up On Mill
  92. Problem with Delta 28-300 Wood / Metal Cutting Bandsaw
  93. Back up and Running!
  94. Laser cut parts quality...
  95. Machined Golf Putter Gift
  96. Retired Airframe/Powerplant Mech auction/sale
  97. Need some help with a Hardinge HV4 5C Indexer
  98. ruining endmills --cutting down insert holder with carbide endmills?
  99. Too Easy
  100. Help! Crawfish are killing me.
  101. OT End of XP Zorin OS???
  102. Disk format differences XP vs Win7??
  103. Have I told you about our "new" aeroplane?
  104. Forum database error
  105. OT End of XP Commedore 64 ?
  106. Trying to post reply to another thread about machining 3-1/2" disc
  107. Data Base Error
  108. OT: Reply count
  109. Another WhatIsIt
  110. Way OT- site hackers, Warning rant
  111. Scrap prices? Sorta OT, maybe not
  112. Junkyard Cast Iron
  113. Drill doctor grinding dual point al of a sudden?
  114. Can anyone explain what I did?
  115. Grinding Wheel hubs where to buy ?
  116. Disappearing posts
  117. N.A.M.E.S Expo 2015 flyer
  118. My poor man's "DRO" / Carriage Stop
  119. BTC1 Gloat Worthy ?
  120. Found my Old Hat !
  121. OT: Phonograph TT/Cartridge Adventures
  122. Too Easy - the sequel
  123. O.T. fuse temperature
  124. OT fiberglass roofing panels
  125. Excello 602 brake handle info
  126. Coventry die head
  127. Tooling purchase at Cabin Fever expo
  128. Separating Die shoes.
  129. Excited! I get to use my generator.
  130. Where can I buy this?
  131. Remote CNC Plasma Diagnoses :)
  132. New site problems
  133. Where can I buy this--Continued
  134. Another South Bend followed me home tonight.
  135. Kid builds a one cylinder engine from stray bits, open crankshaft, drives a bicycle.
  136. DRO user interface options?
  137. Slitting saw (mis)adventures
  138. place for gears
  139. O/T Total lunar eclipse
  140. OT Astounding Blood Moon right now!!
  141. OT- Trojan Downloader
  142. Old Spring Type Weight Scale – Any Usable Parts?
  143. Excited to use generator continued.
  144. Hello From Louisiana
  145. Enco code. Ground Shipping plus 20% off* orders of $199 or more
  146. Site Problems
  147. OT: digital alarm clock innacuracies
  148. Boring head - 90 degree adapter
  149. Kinda OT, I Invented Anti-Gravity!!! Now What?
  150. Big model engine auction
  151. Advice wanted: Arbors or Mandrels?
  152. BP Interact
  153. My latest big project...a can collection trailer.
  154. Drill & Tap or Screw?
  155. Smelters
  156. Made a bolt because it is too far to walk across the street to buy one.
  157. New guy from CT.
  158. Gear Problem
  159. Virtual machines ?
  160. making a tailstock
  161. Thank you George and Daron and all involved in the "fixin" feels like home again...
  162. Virtual "machines" (Iron)
  163. New machines! wahoo!
  164. Fixing a Wonky Crankshaft
  165. Are these model railroading or R/C car parts?
  166. Pratt and Whitney Model C Cross Slide Nut
  167. Southbend Heavy 10 lathe
  168. KINDA ot RE oils for autos.
  169. Do Yourself Awning
  170. OT - Am I Being Set-Up for a Scam?
  171. Redoing my gibs, need opinions.
  172. Found My Tail Stock Problem
  173. Totally OT: Bread flour
  174. Cross slide lock for lathe with tapered gibs. Question.
  175. Unusual set screw sizes from Harbor Freight
  176. Somewhat O/T
  177. Chip re-cutting, re-welding, compressed air, and other follies
  178. Wow, Did not know they had air impact hammers back then...
  179. Boring a hole on my milling machine - cheap boring head woes
  180. brush cutter repair.
  181. Toolpost grinder
  182. OT-Painting a Standing Seam Metal Roof
  183. Vfd or rotary phase converter
  184. OT fiberglassing
  185. Any use for a 36V DC motor?
  186. AXA sized tool holder for QCTP
  187. Old movies of British model engineering
  188. Small hollow shaft with flats - best way to make?
  189. DTI tip removal
  190. Mcgyver/Mike Ward?
  191. You Suck, twice in one week!
  192. New to me layout table
  193. 15th OWAMMO's Gathering / Swap Meet - April 25-26
  194. Need help finding metric change gears for my Jet 2014P lathe
  195. Doall speed lathe
  196. What is this magnet tool used for?
  197. Starrett Easter Egg Score!
  198. How do I keep the aluminum parts from corrosion ?
  199. New edition to the shop
  200. How to sell extra metal?
  201. Metric Lead Screws Vs. Metric Transposing Gears
  202. Bending Rectangular tube take 5
  203. Phase Converter: General Question
  204. Semi OT gloat
  205. 3 Phase motor problem
  206. Anybody rebuilt an Enerpac cylinder?
  207. OT- Ventilating a Sea Container
  208. Socket Head Cap Screw question
  209. OT - occupancy sensor ?
  210. Milling radius on ends of steel bar
  211. Way Oil Question
  212. Bicycle cone bearings?
  213. Dovetail mount for telescope
  214. Looking for Rockford Lathe Parts
  215. Digital protractor advice
  216. Ressurected Indy Motor
  217. OT: Briggs and straton generators.
  218. Can someone help me in identfying this lathe?
  219. Cross Slide Nut Question
  220. Jet 1024 lathe wiring
  221. Saving HTML File ????????
  222. Ridge bumps on machined piece
  223. Arrival of the latest HSM issue (May/June 2014)
  224. DIY Equatorial Telescope Mount
  225. Soldering a throttle cable.
  226. Plumb Bob
  227. Rusty old transmissions
  228. OT, Virus or (?) affecting IE and not Mozilla...???
  229. Lathe Boring Tool Holder Question....
  230. Visiting Houston TX. What are the must see's
  231. QC gearbox for small lathe
  232. CNC the Sieg X3 vertical mill in Australia
  233. Estimating tension on a pin
  234. Not really OT: virus
  235. Excello 602 way wiper and VFD conversion questions
  236. OT dry ice, rhubarb
  237. Jones and Shipman Camel Back style drills
  238. Interesting lathe on CL Baltimore
  239. I need 2 or 3 security head 1/4-20 socket head screws, 3/4" or 1"
  240. Old Garage Door Opener
  241. Lubricating oils and grease for lathes and other machines
  242. My wife fainted over my new project!
  243. Differences of quick-change toolposts
  244. Looking for good quality grinding wheels for Foredom flex shaft
  245. Inventory your shop?
  246. Denford 280 Synchro lathe
  247. Well, I made something else this weekend.. hex bolt cutting..
  248. More sub-standard merchanise, Home Depot changes supplier/manufacturer
  249. Button head socket screws
  250. Lifting a Table Saw Question
