View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 [224] 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
  1. Got My Shaper Home
  2. poer feed
  3. Java
  4. One engine, many tools
  5. Castings - Zinc vs Aluminum (?)
  6. Print your next shop or add-on
  7. OT: MS Access report printing weirdness
  8. 3d printer makes aluminium Landrover!
  9. Bernzomatic it died do they maker rebuild kits
  10. New Machine Purchase.CNC
  11. Four jaw chucks
  12. Couple of "How do they do it?" Questions
  13. OT - A Way to Recycle Mail Envelopes
  14. My "New" Hardinge DV-59
  15. Magnetizing Cast Iron/ Cast Steel
  16. What Lathe Is This?
  17. Is zinc paint any more effective at stopping rust than any other good paint.
  18. A Quorn tool and cutter grinder for sale
  19. OT: Trouble in the skies over New Brunswick
  20. Do you need Mobil Vacuoline 1409 in less than 5 gal. quantities?
  21. Anyone have experience winding carbon fiber tubes?
  22. PWR Management Units, do they work?
  23. National Gap Bed Lathe 14x40?
  24. How do I make this?
  25. OT: It's a wonderful day in the neighbourhood
  26. Turning an MT2 internal taper
  27. 45* Face mill - opinions on inserts?
  28. 2014 NAMES Photos
  29. somewhat O/T but awesome mechanism
  30. Spotting drill vs center drill for accurate hole drilling
  31. 12 Volt DC Motor tachometer
  32. Rant on Shipping
  33. OT: Massey Ferguson 135
  34. Bridgeport Spindle 4 Bearing Conversion
  35. My 9mth gestation is complete - I'm moving to WA!
  36. OT: how to measure a strobe in Ws or Joules?
  37. Boring Head-Ball Turner
  38. Expanding Track (Design Content)
  39. Best vise advice for a 6 inch benchtop drill press
  40. Box of Rex AAA GROUND TOP BITS 1/4 & 3/8 worth anything??
  41. Anyway easy of checking shoulder lengths of 9 ft. rolls?????
  42. Where to buy a new lathe chuck
  43. Bridgeport "M" head attachment
  44. Press Brake Dies ????
  45. How to ship a mill
  46. OT - What's in a name?
  47. Threading hardened JB Weld?
  48. HSM Editorial - George's Glasses
  49. Questions On Disassembling 4 Jaw Chuck
  50. My turn... second hand spoils
  51. Good, bad, and ugly - odd tools
  52. Internal threading help
  53. How do you bore with quill on Excello 602?
  54. Chuck/Spindle travel limit setting on HF mill/drill 42976
  55. CNC machines made me better with manual machines.
  56. Water pump impeller question
  57. H13 Steel
  58. Fabricating a tool arm
  59. B & S valve guide.
  60. Quoting for work...
  61. OT Tecumseh HH12 valves
  62. Arboga double ended bench grinder information sought?
  63. Solder Brazing - What type to use?
  64. NAMES Video Posted
  65. Acroloc Mill
  66. Dressing grinder wheels - rotary spur type
  67. Small hose repair
  68. analog thermostats
  69. Exhaust studs
  70. Extending a "fish grabber" project, vid and pics.
  71. ENCO Free shipping
  72. Lead carving - a bit off the main stream
  73. my new pull scraper
  74. SB 13" Taper Attachment Problem/Questions
  75. Roll Pin hole size Question.
  76. please help should I patent this idea
  77. OT: I think I'm in love with Internet Exploror......
  78. Insulation Question
  79. Vacuum Cleaner Hose, Small?
  80. Cool soviet mill
  81. Coupling a gear reducer to a motor
  82. Injection molding - low volume
  83. Water on the deck
  84. Pressure washer
  85. How do I make this shape?
  86. Invented perpetual motion. Please help me stop it.
  87. venturi vacuum pump .... for liquid, boat bilge pump idea
  88. A question about the "fixing a mini lathe" article.... in current magazine issue
  89. HSM Article on drill sharpening
  90. Sticky shifter
  91. Magnetic Putty
  92. Time marches on...
  93. Closed crankcase engines--etcetera
  94. Italian machininst sculpture
  95. Enco Free Ship Code May 14: MAY25
  96. Reducing a diameter
  97. Cleaning rope seals
  98. Heavy Duty Slip Roller, other options?
  99. O/T can anybody calculate these odds?
  100. car hoist
  101. Reid museum of mechanical models.
  102. Replacing bandsaw tires... gluing? crowning?
  103. South Bend vs Myford vs Logan
  104. New anvil on wheels good or bad idea !
  105. HF Portaband saw, Good, OK, So So, or C***
  106. OT: Problem with Adobe Flash in Firefox and Chrome, but not in IE10.
  107. Bench Top Advice Sought
  108. How much grease?
  109. Bought a new boring bar
  110. OT: Dehumidifiers
  111. Trouble shooting BP power feed X-axis
  112. A question about ASTM A513 pipe
  113. Help remembering passwords
  114. The Leveraxe
  115. What does a Milw die filer sell for?
  116. Good way to start the day from 1000 feet up OT
  117. Cutting square threads on lathe (3/4-8 LH)
  118. Things to see and do in northern New Jersey and New York City
  119. Advice for pipe or tubing for project
  120. OT: Woodworking Site - Stumpynubs.com
  121. New way to remove carbide
  122. What was it (is it?) about Keighly regarding lathes
  123. Metalworking Professions: "Ironkill"
  124. Copper Anti-seize + Aluminum + Water?
  125. 32 moly machine oil
  126. Excello 602 head disassemble help
  127. Modify an ER collet?
  128. New beginner lathe questions
  129. Long-lead multistart threading / design query
  130. Another model engine artist.
  131. Reverse Flow Smoker
  132. Computer help needed
  133. Dempster no. 2 water hand pump remake advice?
  134. Magneto's
  135. Nemett Jaguar
  136. Crankshaft making
  137. Nemett Jaguar--Canadian Style
  138. Sears belt sander
  139. Another computer question...
  140. New table for my sheep shearing machine
  141. Excellent customer service from PowerMatic
  142. Which Motor for My Lathe?
  143. Tool gloat (small)
  144. Mill tools on a lathe
  145. OT - The wind blew and 'look out below'
  146. weird transformer
  147. Advice on milling some indexed flats on a shaft.
  148. Mounting 4-jaw independent chuck on threaded spindle
  149. The threading bit for a 45 deg boring bar
  150. Interference fit.
  151. Eldorado convertible
  152. Inksy Dinksy little tools/toys!
  153. spindex "free" cutting...
  154. What Is This Plumbing Fitting?
  155. I need a power supply
  156. Hall effect sensors and dirt/oil?
  157. 3D cad for metric gears
  158. Genie garage door opener screw drive plastic coupler thingy
  159. OT: Looking for button diode supplier
  160. Refinishing Atlas Shaper Wood Bases
  161. _ Any GMT (Glacern) vise owners ?
  162. HF 9x20 lathe gear changes, metric/inch, invisible levers, and reverse (LH thread)
  163. Aluminum casting additives
  164. Thermal wax question
  165. painting inside of a cast-in coolant sump
  166. Pinging Thomas Staubo
  167. OT- outdoor use of LED lamps
  168. My latest reverse smoker build...it's really different.
  169. _ Welding tool steel, when ?
  170. Gear Scrounging
  171. Getting An Involute Gear Cutter Sharpened in/around Toronto?
  172. What kind of collets are these with this Craigslist Lathe?
  173. First test of my new sheep handler
  174. Press fit ?
  175. Turning soft foam on a lathe
  176. Home Made 1 ton Gantry
  177. Questiion for Linux users about antivirus
  178. Credit Card Reward Points ??????
  179. Making a small boring bar, from drill rod?
  180. parting tool holder/ hardened?
  181. Today's fun project
  182. Paging cuiemaker
  183. Friction Drill;, how to grind tungsten carbide?
  184. Craftsman 1x42 Belt Disc Sander Repair
  185. Holding 1 mm thick washers for grinding?
  186. A drill whatsit found on CL
  187. metal stitching
  188. Gloat - and grinder ident help
  189. Google question
  190. Got the meuser up and running short vid
  191. Pornography For Machinists
  192. Drill press.
  193. useless obscure thread titles - How to fix?
  194. Question On BP Right Angle Adttachment
  195. Building a crankshaft polisher
  196. Problem with Band Saw Adjustments
  197. V Belt and Link Belts
  198. Lynton & Barnstaple narrow gauge RR
  199. Chamfering Edges Of A Key Slot
  200. Aerol casters?
  201. Video of a sheep on my table
  202. Precision honing in general / drill press attachments particularly
  203. Adhesive for rifle sight????
  204. looking to complete my Prazi SD-400
  205. New old Clausing lathe in MN, interesting
  206. Yesterday it was my birthday! I hung one more year on the line LOL
  207. Enterprise 1340 lathe Need help with cross slide screw
  208. Paging Errol Groff
  209. Watch These Mini Engines Run!
  210. Some machines and stuff available in NE Massachusetts...
  211. 2F or 4F best to mill flats on a shaft?
  212. E-Bay has been hacked, change your passwords.
  213. OT: Copper plumbing fittings with solder ring pre-installed
  214. Tom Senior M1 paintwork almost done
  215. Can it be calculated, or are we left guessing?
  216. Starrett special threads.....Ugh.
  217. homeshop test - minimum viable rotary broach
  218. Vortec cold air gun
  219. OT: Detecting Fake Coins
  220. OT: D-Sub Connectors - DB25 Right Angle "Reversed" ?
  221. Source for Die: M34-0.5
  222. Addressing the Class
  223. OT: Testing microwaves for radiation leaks
  224. I made a mistake measuring once, but it didn't cost $68 Million to fix it.
  225. Enco Selection?
  226. OT-Plug Wires
  227. How to switch dual voltage motor from 220V to 110V???
  228. sizing holes for press fit
  229. How to stop carbide turning black with heat?
  230. an introduction to linux
  231. CDCO Toolpost
  232. 100 year old machine shop
  233. Linear Motion and Optics: Anodized Aluminum/Acme
  234. Camelopardalids Meteor Shower, Live
  235. Does Any One have a Manual for a Deckel SO grinder
  236. Welding bandsaw blade along it's length - annealing?
  237. _ GMT (Glacern) vise packaging/shipment - nice job (pics).
  238. A Fix for the Mini-Lathe, by Marco Crivellari, May/June 2014 Home Shop Machinist
  239. 220 volt motor wiring
  240. surface grinding versus face milling?
  241. Need spec for indexable tool holder
  242. Help with helical bevel gears please
  243. Best Wheel For Grinding Cast ?????
  244. ANY American made lathes still in production???
  245. camera battery lifetime
  246. un-warping piece of 1/2" steel plate?
  247. _ Bored out my spindle tube while it was still in the machine: 2"dia 12" long (vid).
  248. OT email account
  249. Baby High Wall rifle (Finally!)
  250. _ Advice, Help and Info with a stepper motor and Arduino
