View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 [225] 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. _ Advice, Help and Info with a stepper motor and Arduino
  2. Could use some help picking the right Square D overload.
  3. Noise and chatter when milling, HF 42976 machine
  4. propane stove
  5. Alternative Responce to the "Versus Thing".
  6. Alloying aluminum and zinc
  7. OT - Postal Rant
  8. my new metall bender
  9. Bearing fit tolerance question
  10. ToolMex / Bison....... Poor Customer Service
  11. Legends of the past
  12. Bucks County, PA intro metal working program
  13. Re-thinking Quill rattles...
  14. Help finding 6-1/2" OD Aluminum Tubing
  15. Need advice on local BP Series I CNC
  16. Request for information regarding selection of fiber optic cable
  17. Your a class act G.B.
  18. Metal supply problems!
  19. Bearing quality in bench grinders?
  20. Just out of hospital
  21. OT? Electric Ground Question
  22. Dry Sand
  23. Youtube type videos
  24. Source for Silicon to alloy w/ 6061 for casting?
  25. The Gorilla Tool - split die thread repair
  26. Enco double discount 20% and free shipping today
  27. Need help with a quote I have...Understanding micro finishes..
  28. Right angle milling head question
  29. mill motor runs 1/2 speed in reverse ?
  30. OT? Flat rubber belts in old B&D electric mower
  31. Our zero turn is sick.
  32. Recovering from lathe crash Jet 1024p
  33. Reading Mic Vernier ?????
  34. Gloat!!! Parting tooling
  35. Ryobi String Trimmer 2Cyl.
  36. Always secure your loads
  37. OT- Safe Combo Change
  38. Fabulous Freebee Day
  39. easy differential design
  40. Dust collector
  41. 4-jaw backplate holes
  42. YG end mills Futura carbide
  43. Looking for ideas on how can I machine this part?
  44. polyiso sheet
  45. Ideas on where to find South Bend Lathe Parts (not ebay)
  46. Motor amperage question
  47. Stiff work surface for desktop machine?
  48. Horizantel Shop made Knee Mill attchment
  49. OT: What it this thing?
  50. Ryobi flywheel fix...
  51. Working silicon bronze
  52. what do you make of this is it useable? cheap ?any6 good???
  53. OT: Car trouble - good luck, bad luck, and decisions gone awry
  54. Great British Car show on Sunday
  55. Gas tank for hit and miss engine
  56. Milling machine spindle bull gears quote !
  57. Monarch 10EE cross slide stop
  58. space efficient workshop
  59. Is there a kosher way to ask for bids on a small CNC job here?
  60. Do you think they are made from...
  61. Anyone want to CNC a run of some small parts for me?
  62. How do you chrome plastic parts
  63. 15" bridgeport rotary table too big
  64. OT: Backup software
  65. RPC question (amp ratings)
  66. Threading and lathe change gear (mis)adventures
  67. I got a call from the office today...
  68. Rotary table help PLEASE... desperation... :(
  69. old new guy
  70. OT: So bad day at work then?
  71. Old machines
  72. Tap and die kits - cheap to expensive - carbon steel, alloy, or HSS
  73. Lowes saved me a lot of time and effort.
  74. OT - advice on selecting a log splitter - features, etc
  75. Strenght of Materials Question
  76. Birds nest while drilling
  77. Have I missed anything?
  78. Scrapper mentality!
  79. OT - Bought an interesting new toy today.
  80. Machinist tools on local Craigs list
  81. Tools, messes, too many machines, what's theh shop for...etc......
  82. Craftsman Metal Cutting Band saw
  83. Need help with a simple job & math error...can't see the forrest for the trees, etc.
  84. a simple lathe
  85. Ace bench grinder
  86. Welding table clamps question
  87. tube bending die.
  88. 3-D Wire Bending
  89. solar panel fun
  90. Proper way to set up this knurling tool
  91. cylinder honing
  92. 40 years of vibrations . . explained to a degree
  93. Cylinder Honing Fit ???
  94. Need help - lathe on/off switch buzzing
  95. Follow Rests: Should they lead or follow the tool?
  96. Inferior Chinese pipe fitting rant
  97. Enco 20% off & free UPS 2 days only!
  98. Mitsubishi vs AB PLCs?
  99. Motion detector switch to cut power to shop
  100. A Grand Weekend
  101. smoke while grinding
  102. sanding disc sixteen inches How to ?
  103. Anybody have a digital soldering station...?
  104. The good ol' days. Belt driven shop
  105. Lock Washer Size ???????
  106. Plastic bending and glueing
  107. OT windows/microsoft update, now weird.
  108. Super Neat Screw Size Chart
  109. Manual lathe spindle crank vs "back gear" vs variable speed drive
  110. Bench grinder setups
  111. Mysterious electrical problem
  112. Bad Seized Hinges
  113. Aircraft: glues, screws, welding
  114. Think twice about the Alibre / GeoMagic design CAD program
  115. Interesting lathe on CL, can anyone id?
  116. Gear Dogs
  117. OT-Central Vac Carpet Head
  118. My latest project. Woodworking, not metalworking, but it kept me occupied
  119. Bought myself a new calliper
  120. gear dp for hf 44142
  121. Need the name for a type of clutch.
  122. 7th Annual Massachusetts Antique Fire Apparatus Association
  123. New throttle bodies for my car
  124. where to carry a spare key?
  125. cutting slits in thin steel tube
  126. _ MINI NC Controller for the Head of a Manual Mills Z-axis: Stage One (vid)
  127. Variable speed head how to quieten back gear assembly ?
  128. DC motor for lathe?
  129. deburring wheel???
  130. Request Shaper Build Info
  131. Happy Fathers Day
  132. QC tool golder for Griz Lathe.
  133. Help Identify Mini Lathe - Emco?
  134. craftsman commercial spindle belt replacement
  135. Community workshop gloat?
  136. Molded fiberglass gears
  137. looking for spring steel
  138. A question for Alibre/Geomagic/Rhino users
  139. Shop Lighting ???????
  140. " old indian lathe"
  141. Cool Beginner projects on lathe
  142. the three-way weld
  143. Shop made toolpost grinder
  144. where to look for tooling machine related stuff
  145. Rotational Balancing
  146. Hardinge Info
  147. Interesting - "Milwaukee Saw Trimmer" on St Louis CL
  148. Hooray!! No more yucky toothbrushes.
  149. 4 Inch Riser on a BP Clone
  150. Norseman drill group buy
  151. 3D CAD "Best practices" ?
  152. homemade abrasive wheel
  153. Another nice surprise today, 1,800HP engine.
  154. Bridgeport vari-speed head noise
  155. Pimp my oil can! Ridiculously over-built pot for cutting oil
  156. lubricating lathe spindle bearings on HF 9x20 (model 45861)
  157. Indicator repair
  158. Anybody do watch repair?
  159. Mill cutter orientation
  160. Is there a wood carving tool like this?
  161. Work holding
  162. An Indicator Accessory Project
  163. Tesla released patents
  164. OT: By chance (the law of averages has it's day), or by intent?
  165. Do your research first
  166. Cam Timing--Lap, lead, etcetera
  167. Tooling design question...
  168. OT – Lost power cord for Nextar GPS
  169. Ring making on lathe
  170. OT-Car A/C charging
  171. What can I do with two 250-gallon propane tank cylinders (end caps removed) ?
  172. May buy a small machine shop
  173. _ Stage 2 - Drill Cycle: MINI NC Controller for Milling Head
  174. I bought a new toy today...
  175. Owning Old Ford Trucks
  176. Horsepower for garden tractor?
  177. Online bandsaw blade recomendations
  178. New member with possibly dumb question about building a lathe base.
  179. Very small tooth counts: 9 tooth pinion, 8 DP, 14.5 PA.
  180. OT Seeking advice for supersucker trailer build
  181. Touching up carbide lathe tooling
  182. Threading Software help needed
  183. Chrysler tank production in WWII
  184. OT:Does Photobucket have people?
  185. Oh woe is me; shop A/C quit! (Brass vs copper?)
  186. Advice needed on bearing preload.
  187. O/T Have you seen Hydrographics?
  188. And so it begins
  189. Tool Post Grinder: Listing
  190. Solidworks animation question....
  191. Need Instruction sheet/manual
  192. Which Haimer 3D device??
  193. Delrin is it good for small gears ?????????????????
  194. Loose handle (Looking for fix)
  195. Editing Post Titles -- YES, You Can!
  196. IGUS iglide bearings, anyone use them?
  197. Lathe and tooling CL listing
  198. Gloat - angle plate
  199. dovetail cutters for making slides, etc.
  200. Testing my new table with a Rupnow sheep!
  201. The Old Truck Saga Continues
  202. Need help, lathe switch wiring
  203. Surface Grinding or Hand Lapping?
  204. Seeking Harrison L5 info
  205. Balancing act
  206. Looking for X3 mill DRO advice.
  207. Enco 20% PLUS FREE SHIPPING NO MINIMUMS/EXCLUSIONS
  208. molded gear teeth
  209. How to test an R8 taper?
  210. Tapping a hole in 1/4"stacked plates question
  211. can you help with advice on buying a welder?
  212. short video of the tipping mechanism of my sheep handler
  213. Central Massachusetts Steam, Gas and Machinery Association Show
  214. 5/16" Square Socket for Lathe Chuck Adjusting Screws
  215. Vfd choice
  216. OT - excavator-mulcher machine
  217. Servo power feed
  218. Devcon Cure Time ??????
  219. Well-Index Mill
  220. I hate when that happens!
  221. more gear stuff
  222. Made a jig for straightening a crank handle
  223. E-Z out worked again..... Can the lottery be far behind?
  224. Change of direction???
  225. Roll pin vs key way
  226. OT: Gourd Festival (well, there are some tools...)
  227. Square groove cutting on lathe
  228. Grinding mild steel..
  229. Semi-OT: Does anybody have a source for dogwood lumber?
  230. OT Email App
  231. Using Harold Hall’s Deluxe Grinding Table and jigs
  232. small carbide tipped scraper (video)
  233. Not a change of direction BUT---
  234. OT: Chainsaws and Dead Trees
  235. Gear purchase
  236. Welding table vent hood CFM?
  237. Best wishes to all in Arthur's path
  238. First try at using my NextEngine laser scanner
  239. O.T. carbon monoxide poisoning - something everyone should read.
  240. No google-foo today. Link to thread about massive weight standard?
  241. Grinding to touch up and align ER20 spindle taper
  242. What's a "blow-in" Card?
  243. Problem: how to machine a spiral groove in a flat disk (like a record groove, but...
  244. Wire size for VFD
  245. Shars products
  246. Where to get SINO DRO encoder?
  247. Happy Fourth!
  248. best scantool
  249. anyone seen one of these before?
  250. Here's the finished can collection trailer.
