View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 [227] 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284
  1. OT: So much for Honda reliability
  2. OT / colonoscopy prep instead of drinking putrid jugs of.....
  3. Weird lighting
  4. Making a pistol??
  5. Home Grinding Part
  6. New aluminum casting method - stick welder, graphite and kinetic sand
  7. armature question?
  8. Ball Bearing Speed Ratings...
  9. The Geneva Hours Clock from Digital Machinist
  10. Source for hi-speed plastic gears?
  11. good yard sale haul
  12. hole saw
  13. fixing a scarred iron casting using JB Weld
  14. OT - sort of - 3D Printers
  15. Finishing ideas...
  16. Totally off topic IRS
  17. Benchmaster mill spindle lube?
  18. Weekend Events from the NEMES Calendar
  19. Sir John
  20. OT: Trouble with Windows 8 update
  21. Picked up some gage blocks and a height gauge
  22. case hardening
  23. A2Z Sale
  24. MAF cleaner
  25. Band saw gear lube
  26. Canandaiguq NY Pagent of Steam and Antique Construction Equipment
  27. help get a 'kink' out of knife edge
  28. instant change of rotation on lathe - bad?
  29. Oldham coupling
  30. Belt Skiving Machine - Usage Advice Please
  31. Do I really need a drill press and a Milling machine?
  32. matched RH/LH worm/pinion sets?
  33. More on threading...
  34. Back to the Bricks - a harebrained(?) idea?
  35. Some materials are just tough to machine
  36. Look Ma, No Spark Plugs
  37. Remember the end caps from the 500-gallon propane tank?
  38. I wet my pants.
  39. test bar from old copier machine
  40. Wiring the control cabinets for my sheep shearing machine
  41. OT: G. D. F. Microsoft Windows Blue Screen of Death
  42. Anyone else having problems with?
  43. Having a problem with my mig welder?
  44. Unwanted software being loaded onto PC
  45. Chuck backplate project
  46. testing machine autotransformer
  47. Engineering question.
  48. Sources for good files?
  49. Kool Mist -Gloat?
  50. Rusty Frame Question
  51. Shipping Logistics
  52. Rockwell Spindle Bearings
  53. Small geared down electric motor
  54. Aluminum "grease"
  55. Digital Readout for a 4x6 Bandsaw
  56. Paging OldHat
  57. Optimum settings
  58. Proodreader's day off..
  59. ??? a Cincinnatti BridgePort ??? LoL
  60. Heat Treat Oven ID Help Please.............
  61. Wire wheels
  62. More John Sherris video from the Canandaigua Show
  63. Interesting Circle Illusion
  64. small DC motors, series or parallel?
  65. New P/T job!
  66. Help How to remove bearing
  67. method of mounting tooling on a mill/drill
  68. Sebastian lathe
  69. OT: C-130 Hercules turns 60
  70. George King III and his restored AFS ambulance (Ford T)
  71. How'd I manage without it?
  72. Hooray!! No more flat tires on the gate.
  73. planer blade grinder machine is this suitable for hollow grinding etc?
  74. Off Topic IE video problem
  75. Estimating / Quoting question.
  76. Thank you, thank you, thank you!
  77. Building a belt grinder?
  78. sharpening stone - seen better days
  79. OT: Math Puzzle - A Challenger
  80. My daughter's first solo flight!
  81. I have a few lapping questions, I know little about this subject.
  82. Minor tool gloat
  83. OT: Death of a Lucas CAV IP and Cleaning algae out of a diesel tank
  84. South Bend lathe bearings
  85. Wrongly marked gear cutters
  86. Cincinnati toolmaster mt opinions
  87. Bamboo work surface....
  88. Liquidation of McDermott INC in Amelia LA
  89. Today's Estate Sale Gloat
  90. Mitutoyo 192-116 Dual beam Height Gage - very sticky/jumpy - what to do?
  91. Source for #10 x 40 Machine Screw?
  92. My machinery gloat a little different than most on here.
  93. This weekend's project.
  94. Talk about cat like reflexes
  95. Uneven dirtbike front suspension?
  96. Scored some goodies today!
  97. New Guy
  98. Line Boring Tooling pics
  99. pretty good haul
  100. What is this item? Sharpening fixture I assume, but for what?
  101. Pan box brake plans
  102. Shaper Tool Holder now Semi Gooseneck
  103. Stepped clamps for rotary table
  104. casting an adapter for a high speed spindle
  105. Hossfeld #1 pin size
  106. Foredom flex shaft grinder problems
  107. Woke to a lovely suprise today! Ot
  108. Went to an auction, whatsit?, and auctioneer gripe...
  109. September Issue Errata
  110. Test Set cabinet frame using aluminum T-slot extrusions
  111. Source for Continental Varidur Timing Belts in USA ?
  112. john deere 450 dozer
  113. Tapatalk is Up and Running
  114. Estimating Drag on Spinning Disk with "Spokes"
  115. My ironing machine is doing funny things.
  116. Flat Leather Belts
  117. Machined a couple of simple puzzles
  118. Air pressure required to lift water?
  119. enco post card
  120. Working with Precision Steel Shaft from McMaster (Round rails for linear motion)
  121. For Winchman-----OT, but fabricating----
  122. Rotary table with mini-lathe chuck and adjustable jaws in T-slots
  123. harnessing lightning
  124. Cover for the tank I made from the end cap off the 500-gallon tank.
  125. Where are Exact Metals and Steeldawg (Oakland Steel) on eBay? (+ Favorite suppliers)
  126. Accuracy of Jet 18 PF
  127. #6561h Logan Lathe new guy
  128. 20% off at Essentra Components
  129. armature commutaor repair skimming
  130. Progress
  131. Anyone ever work on a Pacemaker head stock?
  132. Water filtration for a plasma table.
  133. Craftsman Belt Sander Tracking Repair Problem
  134. How much brake drum rub is acceptable?
  135. collet question
  136. Need Help. What is it.
  137. made another nice tool haul today
  138. Do welding gases seperate?
  139. My Classes in Machine Tool Processes at Community College of Baltimore County
  140. High Speed Rotary Burrs (Dremel) - Diamond, Carbide, HSS
  141. How should I modify my crankshaft?
  142. 2 1/2" HF Vise
  143. Tool identification
  144. ANy one who owns a wohlhaupter UPA2!
  145. Welding angle clamp
  146. AXA or BXA
  147. Kudos to George!
  148. My mitutoyo died today. :(
  149. Free electricity?
  150. OT, a new computer scam.. anybody else?
  151. Cutting a curve
  152. Kinetic art project
  153. control cabinet wiring
  154. A little help with pricing a metal shaper
  155. Goodell Pratt Whazzit.
  156. Picked up a set of gauge blocks
  157. Histories of Goodell-Pratt and Millers Falls tool companies
  158. Shaper Gloat
  159. OT - Electrical Assistance
  160. This is the gantry for my CNC plasma table build.
  161. Are these a new concept? Ball Bearing V-blocks
  162. SB9 carriage clutch
  163. aluminum to stainless steel color?
  164. Gas welding setup, torch and tanks......possible gloat or not?
  165. is it wise for a beginner to...
  166. New to HomeShopMachinist.net - buying first lathe, need tool list
  167. Hourly wage breakdown
  168. Making a Square End
  169. dial calipers vs micrometers - do I need both?
  170. Free Plotter
  171. Thread cutting article in HSM Question?
  172. Potter & Johnston shaper question
  173. Slightly bent crank?
  174. Need to clean and remove rust from newly acquired lathe
  175. Need help with inspection of Bridgeport vertical mill I may buy
  176. OT: How can I identify source of hidden window in Firefox?
  177. Finally got around to modifying my Spindex
  178. What are the current best options for a DRO for a lathe?
  179. Import Alloris type tool holders?
  180. I need a source or ideas for drawer organizers.
  181. OT: looking at laser printers....opinions....??
  182. Chamfering A Hole From The Inside Out
  183. OT need finish advice for Concrete Floor
  184. Milling bits - single/double end, 2,3,4 flute, end/side cut, collet vs Weldon holder
  185. Buying perscription safety glasses on line?
  186. A table for my Craftsman Atlas 12x36 lathe
  187. Thermal dynamics cutmaster 12 plus
  188. OT Mold making
  189. Another Energy Cost Saving Thought
  190. 40 & Out ! a Seriously flawed concept.
  191. PCT End Mills
  192. OT: West System Epoxy
  193. OT - Dell 1320c Color Laser Printer Toner Cartridges - FREE
  194. Western NY Gas & Steam Engine Rally
  195. Octagon collet block?
  196. Lantern tool post out, QCTP in!
  197. Central Machinery 6" x 12" Surface Grinding (Made in USA?)
  198. Accurate bore after hardening?
  199. Three Jaw Chuck Size for Logan 10?
  200. What metal should I use?
  201. For you old guys!
  202. From Freezer to Refrigerator
  203. Groove in lathe rail - is this really bad?
  204. Here's a gem for the mechancially / cnc inclined
  205. OT Shipping woes in Duluth, Minnesota
  206. OT, but Reno or bust----------
  207. How to pickup and transport a 2000# mill
  208. Can you identify this Bridgeport mill?
  209. please tell me what is the difference between these two ? and which is best?
  210. Complete newbie to rewinding 1 question?
  211. Dead center size
  212. Grey cast iron for QCTP tool holders?
  213. can you identify the model of this Tree mill?
  214. 4140 Prehard, RC34: bandsaw cut or no?
  215. When would you use a "dead" center vs. "live" center?
  216. Thanks for the Calipur /Mic thread
  217. Cutting Acme threads - straight in or at 14.5 degree angle?
  218. Scraping with Tungsten Carbide
  219. Paging Lazlo..
  220. Laser sintering-For component repair
  221. Tryed long-hand G-coded Macros again
  222. Oil for bearings, grease for gears in my Atlas lathe?
  223. What are the must have tools for a vertical mill?
  224. How REAL MEN built steam locomotives- Video
  225. How to replace main seals on Atlas lathe
  226. Buying online safely
  227. Pi Tapes, just when you thought............
  228. What realy matters . . . isn't any different in extra-professional machining.
  229. Kurt vise jaw mis-match
  230. What insert to use for tough cutting
  231. Pet Peeve, Dead Photo Links
  232. Sent wrong metal possibly?
  233. OT: Raycom & DirectTV drawing a line in the sand.
  234. $100 chinese ebay vise deflection vs. torque vs. force test! data inside!
  235. motorized stop block for right angle head = cheap 5th axis?
  236. Laser center finder, anyone here make/use one?
  237. OT, maybe, Smokestack verses High Tech.
  238. What's the point of the "Ignore" list?
  239. Harrison lathe for sale
  240. "I'll never need a bigger machine..."
  241. How not to service a Jacobs chuck
  242. FREE: Lathe stand (in Leeds, UK)
  243. Grinding wheel question
  244. OT ---I just realized that----
  245. ENCO Free shipping (FREESEP)
  246. Adages & Proverbs Applicable To The Home Shop Machinist
  247. Bardarbunga (Iceland volcano) putting on a show
  248. Warco 1327R Lathe. Any help please
  249. Speed and Feed for Carbide Endmill in A36 Steel
  250. Duramax Repair Question
