View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 [229] 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. BMW airbag actuation? OT question
  2. BMW airbag actuation? OT question
  3. Mystery Motorcycle
  4. Atlas 10", DC motor + speed control upgrade
  5. Gotta love pawn shops.
  6. 8 inch shear is nice, but is the blade supposed to do this?
  7. Need an Ubuntu guru
  8. Found: a source for ball handles, handwheels, etc
  9. South Bend 9-inch Underneath Motor Driven Precision Lathe Model A
  10. Valve guide update.
  11. Lets see your home made lathe benches!
  12. Challenge: Let's Design a Solar Powered Drink Cooler
  13. Heres my spindle removal story on an Atlas 10" lathe
  14. VFD cable and shielding info request
  15. Edge Finder
  16. New machinery at work!
  17. wait a sec....would this work?
  18. Trashed Grizzly 1440 gunsmith lathe
  19. Google Chuckle
  20. Scrounging Successes and Nice People
  21. Surplus Shed 40% off sale through Tuesday Oct 14
  22. Noise Pollution
  23. OT: Waste veg oil scrap melter fail
  24. If you like free stuff
  25. Trying to improve my business but....
  26. Oil or Grease--Needle roller brg. lube
  27. Unwanted emails from Facebook , Apple
  28. Spoon cutter end mills?
  29. Painting new channel iron
  30. Whatsit? No idea. Any guesses?
  31. tool gloat
  32. OT Drive way ROCK question ?
  33. OT: Wood deck coating
  34. Atlas Lathe project! MT2 to 1.5" 8 tpi adapter?
  35. Fresh from the auction.
  36. small jig borers, who made them
  37. Need help remembering what it was...
  38. drill and tap thompson shafting, induction hardened shaft, hard chromed shaft
  39. CNC machined change gear for Atlas Lathe
  40. Turning between centers...Monarch ee lathe
  41. OT - Quickie rust spot fixes on old truck
  42. any reason to keep two 1" micrometers?
  43. Atlas TH54 rebuild
  44. horay sir john is back!
  45. Sunday- a day off??
  46. Drill sharpening jig question
  47. it does not grok..why the compound slide in threading?
  48. Small Round HR stock description /suppliers
  49. Added some gib screws to my Atlas 10 topslide
  50. _ BXA/200 tool holder material, cast iron ?
  51. Making foam cutting tools
  52. What are these do-dads
  53. Chatter in my Craftsman Atlas lathe
  54. Thumb whacker yes I have done it again ?
  55. Flat grinder easy solution please
  56. Doozer's poetry
  57. Machinist level
  58. Pioneer Valley Truck Show
  59. OT: Ebola what is it
  60. OT- Third Brake Light on Truck Cap
  61. Next time I think I'm making good parts I'll watch this again
  62. Enco codes
  63. Smart phone app for forums ?
  64. Looking for help in Detroit, MI and Vancouver, BC areas
  65. Cutting a file
  66. fine machining
  67. Mid-East Ohio Model Engineering Show
  68. Not quite a DRO question.... new project
  69. Tool gloat Hossfeld Bender
  70. Barn find lathe
  71. Tube cutting
  72. Highway Patrol red light up ahead----OT, but subject came up in shop safety meeting
  73. searching parts for HOLKE F-11-V
  74. Slightly OT: Uses for an old Aluminum Scuba Tank
  75. Software / Program For 3D Viewing / Rotating etc.
  76. Gas in Onnan generator oil
  77. OT - Auto body Fiberglass resin question
  78. surface plate alternative
  79. Thread cutting
  80. Boring question.
  81. Lathes for sale Canada
  82. OT: most cost effective 2" camlock cap locking setup
  83. OT... Someone on the railroad lost something.....
  84. Mayor
  85. OT: #%@#&% Stupid Adobe popup
  86. Moriya by Dr James R Senft
  87. What Did I Do Wrong?
  88. Interesting Surface Finish on Aluminum - Looks Galvanized
  89. Broken bolt extraction
  90. Dehumidifier / heater for small spaces???
  91. Help with Grizzly T21321 Hand Punch
  92. Score!
  93. Grinding Hardened Steel Tool Bit
  94. Turned Bolts?
  95. Looking for a small forward/reverse transaxle (mower type)
  96. standard taper for tie rod ends?
  97. Best speed range for a small lathe
  98. OT - Circuit Breakers
  99. Aligning center punched work in the 4-jaw?
  100. converting a woodworking saw to a ?
  101. Keep me in your thought's please from time to time.
  102. Anchor to the floor or not? (new lathe)
  103. Made a tool post grinder....what do you think?
  104. John I saw this and couldn't resist sharing this great deal with you.Alistair
  105. O/T Ford Escape, strange chime sound
  106. How do you turn something like this shape?
  107. lube question
  108. Seated working at machine
  109. OS X Yosemite nudges out Mavericks
  110. Show me your bandsaw blade welding jigs
  111. 1937 south bend lathe threading dial question
  112. ZAY7032G head set horizontal for drilling/boring?
  113. Another noob....
  114. Sold my SB 16 lathe today :(
  115. Auto screwcutting attachment
  116. A good oil for open gear lathes
  117. We Lost Another Member
  118. Possible lathe cutting issues. The 2nd part of alternative surface plate
  119. OT: What kind of gun is this?
  120. ~OT? Crazy wood turning on lathe - pattern matching - could it work for metal?
  121. Effect of purple cleaner on aluminum parts... tested
  122. Can These Go Intermittent ????
  123. OT: Anyone have their YouTube channel to share? Here's mine .....
  124. Burdick Open Quick Change Tool Post
  125. OT: Fun with a borescope
  126. OT slightly... its still a machine.... parts for Sears 936342?
  127. OT: Daughters friend goes blind
  128. OT: Most Popular PIC or Microcontroller Devices
  129. Drilling and tapping a block for bigger head fasteners...
  130. Look what I found!
  131. cutting a tooth on a rack
  132. Aloris Tool Post
  133. Thinking of redesigning my CNC table...
  134. Electrical Question?
  135. DIY master spiller for oil !
  136. Egg-beater drill for metal...?
  137. Keller Die Filer Model 1A - Documents, Overarm Info
  138. Two giant lifting hooks qith pics
  139. O.T. Trying to identify to replace or repair blower motor
  140. Semi OT: Polypropylene Parts
  141. Hardinge turret lathe
  142. Lectric heat in the middel of the floor.
  143. Another Electric Wiring Question: Chaining Outlets
  144. OT: post cataract surgery glare... anybody else?
  145. Align power feed unit.
  146. Just about to order a Diamond Tool Holder
  147. OT---Auto seat related
  148. Poodle
  149. Anyone ever fix old vise grips? The worn, melted away jaws.
  150. metric Threading
  151. Yep, I Heard You
  152. Basement shop enlargement, ballpark cost idea?
  153. Recommend structural steel tube size for...
  154. *** Note to member MFolks ***
  155. O.T. Elm tree mitigation
  156. October Enco code?
  157. south bend 9 apron lock problem
  158. __ Boy, being off by 10 deg can sure look silly ! (pic inside)
  159. B&S #9 collets
  160. O.T. Attempted Murder...
  161. OT skydive record broken, didn't take long
  162. What is the difference between ER40 & 1" series collets?
  163. Tampa FLA visit
  164. How did I do?
  165. Flywheel pattern making
  166. Look what I scored on
  167. DIY digital gauge; thoughts?
  168. Round HSS inserts
  169. Giddings & Lewis, surface contact-sensing feature, Amazing why not today?
  170. pressure washer as hydraulic pump
  171. New Toy: Electron Microscope - and repair.
  172. Attachment on turret lathe question
  173. Rarely used tools you have no regrets about buying.
  174. drill organization
  175. Pin Spanner Wrench for Thread Protector of South Bend 10K Collet Closer
  176. Windows 95 operating system.
  177. OT: Visual Basic (2010)
  178. Would you try to take an OD cut on this?
  179. open ended sheet metal bender
  180. Penmaking in Japan
  181. OT:Flash player
  182. OT fitness in the workshop
  183. Cool Cannon build...
  184. How to build a battery tester?
  185. the last hand-cranked automobile engine
  186. Building a tailstock turret
  187. Graziano SAG 12 Lathe Chuck Changing Proceedure
  188. OT: Started a new business to offset costs of machining!
  189. Advertising material coming in via google
  190. Need some suggestions on leveling concrete floor
  191. I got an auction flyer yesterday - lathe is a bit too big for my workshop
  192. Enco discount code
  193. This shape
  194. motor brushes
  195. My Lathe Dog
  196. help wiring a GE 1 1/3 HP motor
  197. First time single point threading on lathe 3/8-16
  198. Male breast cancer
  199. drill sizing
  200. 3 phase power
  201. O.T. any inventive type out there?
  202. Ball turning tool for QCTP
  203. Sharpening brazed carbide?
  204. Nardini 1230TT E Request for documentation
  205. Motion Sensing Light--sensitivity
  206. Changegear storage solutions
  207. Do I have a place in my shop for a Burke #4?
  208. sourcing neodymium magnets in Canada
  209. Explanation for roughing end mills?
  210. Cross-slide stop for 9x20 lathe
  211. Best Type of Plastic For Application?
  212. Newbie 7x12 lathe questions
  213. Gimme a Brake!
  214. what to do with an old?
  215. Power for shop
  216. This is not far away from me and I am not sure exactly what it does.
  217. Who know where this might lead! Windows 95.
  218. Memory Quiz - gasket material
  219. O.T. Cellular reception in a metal building
  220. Rearranging shop
  221. Ethanol Shield 2 stroke oil
  222. Would you call this metalworking?
  223. Hydraulic Shaper
  224. OT: Introducing the 'new' ford V8
  225. Dust collection?
  226. _ Pair of boat seat frame clamps (short video inside)
  227. Small Boring Head
  228. Miniature M1911 3:1 scale
  229. drill organization / index build / proof of concept
  230. Quill stop and depth gauge DRO for small mill/drill machine
  231. OT- music video
  232. OT: Completely...
  233. OT: Texas Motor Speedway what is it....
  234. Bpt. Mill Power feed knob question
  235. Smart phone cases for machinists?
  236. chuck lubrication
  237. A Sad Day - R.I.P Tom Magliozzi
  238. Driven Geneva gear
  239. Cutting and punching hard shim stock
  240. Generator idea
  241. Sheldon lathe EXL-46-P
  242. Interesting video if you are into steam engines
  243. OT; portable generator protection
  244. What a stupid idea, new car.
  245. Craigslist Score - Granite surface plate 12 x 18 x 3 - $35
  246. Fire pits
  247. Ettco collet
  248. Wet cell batteries and stainless steel
  249. Shop Fox 1018
  250. All-in-one tap & die tool
