View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 [231] 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281
  1. Oil orifice for motorcycle head
  2. Moding Draper Mini-lathe
  3. Possible to repurpose a "car bored" cutter
  4. Add me to the walking wounded list.
  5. OT: seeking some ebay paypal advice
  6. not sure where to start
  7. OT - Crazy Day & Hard Weekend
  8. MW (Vol27, No6) - Mini Bench Shear by R. Ballantine & Other Subjects
  9. silver/copper/phosphorus brazing strips
  10. Hello!
  11. SpaceClaim, anyone on here ever used it?
  12. Can original thought be machine born. semi OT
  13. If only they had told me what they were doing......
  14. OT - I see an ad for Vectric up top of the page.
  15. Hard time adjusting tail stock
  16. Recording device, stainless steel?
  17. New iron, but woodworking so don't be sad
  18. Castable and machinable ceramics
  19. further to maximat v 10 mentor rebuild
  20. Clever screwcutting method
  21. Another what is it.
  22. Need Belt Drive Help
  23. Very cool, The Littlest Engine That Could: World's Simplest Electric Train
  24. "At what point is the bronze applyed to bronze clad die bars?"
  25. Chuck adapter for Yankee push drill
  26. Mill-Lathe Combo Unit Sugestions Requested
  27. I let the smoke out of the bandsaw...
  28. DIY live tooling for the lathe
  29. Enco Free Shipping Code: DEC29 Valid Until 1/5/15
  30. *** Seldom seen member rvannatta
  31. "The Big Machine" giant homopolar generator for AU physics research
  32. Making a multi-disc high voltage homopolar generator or motor
  33. 4 yr. old and machining is fun again (project)
  34. Picked up this sad old milling vise
  35. Lathe hand wheel graduations..weird!
  36. _ Brazing broken bench vice, will it work ?
  37. Cheap Live centers what's your tought?
  38. Wire Bending a Crankshaft
  39. Hydraulic help again
  40. well well , if I win these I win the best tool buy gloat.
  41. Holding a tapered part for milling
  42. Orion; Absolutely Fabulous!
  43. Vacuum Fixtures for CNC Router
  44. Sligthly OT Wireless network questions.
  45. Source for replacement parts on Birmingham Lathe
  46. interstate chuck review and making a adapter
  47. Internally splined hubs
  48. Semi-OT -- information about all th elements
  49. XLO 602 Mill cap bearing removal
  50. Picking up a Cincinnati 16" shaper, need some info please
  51. What is it and tool gloat
  52. 1913 Dreis&Krump Box&Pan Brake Rebuild
  53. Semi-OT Thank {deity} for Trade Schools
  54. Atlas reverse gear box repair, cheaper and better than oem parts!
  55. OT: New to me oscilloscope... not bad
  56. There used to be a fellow...
  57. another tool gloat!
  58. Want to make a tapered reamer
  59. Black forrest - plasma
  60. reducing a morse taper from a larger to a smaller size??
  61. Any optics people out there?
  62. Lift-gate machine delivery. Your new Mill is here!
  63. How to polish Cast Iron
  64. Gearmaking without an indexing head- let's go!
  65. Interesting cheap tools and things from China
  66. Sort of Off Topic ... but tool related; Anyone have any experience with Mitre Trimmer
  67. O.T. For you British bike lovers!
  68. lathe identification
  69. Homemade tap
  70. solar or wind turbine?
  71. OT: What Are These Types of Joints Called?
  72. B&W Spotting Drills "Jewels of Tools"
  73. What machine is the best for small parts?
  74. Slo mo of tipped tools
  75. OT: search engines, was tired of goo
  76. OT: simple repair of bearing and seal
  77. Gorton Grinding Machine in Langley at federal government surplus site
  78. I hope the machines like us...
  79. Making a tapered D bit.
  80. 20% off Lincoln Electric with promo code
  81. OT knee surgery
  82. OT: Leaf Pick Up
  83. Help wiring a transformer
  84. What is it quiz!
  85. Select technical docs from the Historic Naval Ships Association
  86. Micro-V belt suggestions needed
  87. Stepper motor help needed!
  88. Abrasive Sticks
  89. More on stepper motors?
  90. Anyone use one of these machinist type tool boxes from HF
  91. Who made this milling machine?
  92. DIY heat treat: cast-iron?
  93. Any Magic removing spiral rivets on Badges
  94. Small Plastic Gears
  95. Shop lighting -:(
  96. Pneumatic Metal Graving or Engraving Tool,
  97. How much cold roll steel can harden over time?
  98. OT: new window glass in my house...compared to old glass....
  99. Textbooks
  100. Indexed mill head
  101. Shaper rings
  102. _ What to do with a some what broken microwave (pics inside) ???
  103. is it possible to make a cheap bench grinder run vibration-free?
  104. Bridgeport Power Feed
  105. OT - Sending Computer Video Files
  106. What the hell did the paid monkeys do to EBay? OT, but not if you buy machines etc
  107. Mystery Metal Stamp ? Welders?
  108. OT tardis
  109. A question about "Sweating"
  110. Triumphant Day!
  111. Multifix threading holder conversion
  112. Schedule 40 schedule 80 Pipe question
  113. Basic Newbie Lube question
  114. r8 collet sizes?
  115. Z axis opto probe for a CNC lathe.
  116. How Can I Bore This And Avoid Another Mill Set Up
  117. OT: Make your razors last for a year!
  118. 5/16- 18 thread compared to 8mm 1.25mm pitch
  119. Tool hoard
  120. OT Reversing 120 V capaciitor start electric motor
  121. Building small carburetor with throttle
  122. RPC idler Motor bearing question.
  123. Restored A. F. Prentice treadle lathe with associated history (Connecticut CL)
  124. Viceroy Sharpedge Honing Oil
  125. Auction find Acme Taps
  126. Pharmaceutical Castor Oil as a Seal Lubricant
  127. Ball and Plate PID control with 6 DOF Stewart platform
  128. Unusual sine bar - advice on gage blocks
  129. Anyone hear of These CNC mills?
  130. What to do with all those files?
  131. Axle shafts for stock material
  132. Chuck wrench, where to find
  133. RIP Byron Boucher
  134. STANKO 1A6161 Lathe
  135. Digital height gage died
  136. ATCO Precision Tool ???
  137. Need a carbon, gun propellant solvent for the untrasonic tank.
  138. 3 phase motor blowing circuit breaker
  139. reg. cheaper than E-85
  140. What dosen't stick to silver solder
  141. Part cleanup after Evaporust
  142. is there a garage sale forum on here?
  143. OT: Now would be a good time to drive a stake into the heart of the ethanol industry.
  144. CNC project! Past point of no return!
  145. starting and stopping electric motor?
  146. Millrite vs RF-30
  147. ENCO One Day Savings
  148. Lathe cleaning, getting the shine back
  149. Evan
  150. I broke my rotary table (worm gear) - what to do/build with the remains?
  151. OT: Busted today with a DUI
  152. Source for a 5/16-20 LF tap?
  153. lathe chuck
  154. Starting in on my spare welder
  155. A Machinist Wraps Presents
  156. Hi guys
  157. Interesting mill on cragslist
  158. Making a set of chuck Jaws
  159. OT- Adding a Second Pressure Tank
  160. Idle RPM of single cylinder engine
  161. Holding small dia. parts.
  162. Posting pictures direct from iphone
  163. GFB Lathe Chuck
  164. Lathe chuck choice
  165. Starrett 196F Hole Attachment - Usage ?
  166. The right used Lathe?
  167. somewhat OT - This really has to be a joke
  168. Re-restoring the mini camelback drill (Canedy Otto no. 28)
  169. Fear not, Tubular O/D micrometers.
  170. Getting rid of red flux stains on brass
  171. Universal Pillar Tool: Arm Castings Suitable To Adapt A Drill Press As A UPT?
  172. A humble bench grinder
  173. programming question need help.
  174. Primitive worm gear hobbing in a lathe
  175. brass or bronze??
  176. Helac rotary actuator installed.
  177. _ Remember that Greenerd No3 your neighbor tossed in the woods 30 years ago ?
  178. Anilam DRO
  179. Tom Senior M1 h-mill: Motor Location
  180. OT Thoughts for moving a Safe
  181. Made my first steam engine, it runs! Pics, video.
  182. kepping superglue etc,from going hard????
  183. Turning Rubber Round Stock ?????
  184. Bought a Clausing 8520 Milling Machine
  185. Bleichert Rope Joiner
  186. Christmas comes early
  187. Magic!
  188. LeBlonde lathe info needed
  189. Hello to the Forum! New Prazi SD300/ Hobbymat 65
  190. SpaceClaim vs. Alibre/GeoMagic
  191. Threading set up
  192. Me and my very handsome three sons.
  193. new lathe
  194. What is a variac?
  195. Cheap shower door alignment. Think I saw someone post this exactth ing here before.
  196. Bought a PRAZI SD300 Lathe for small work...Modifications
  197. old machinist tips/tricks - please chime in :)
  198. what is this?
  199. _ The Black Stuff after Home-brew electrolysis rust removing.
  200. Prazi SD300 / Hobbymat 65...Need Gear Chart
  201. Shop computer
  202. Laminating Copper Sheet to workbench?
  203. A variable-frequency drive (VFD)
  204. Made a cut off holder block for my quick change post
  205. End mill gloat
  206. Small Christmas present for the wife
  207. Only six hours to wait!
  208. Aaaand another one..
  209. Have a safe and happy holiday season!
  210. small drilling
  211. Brandless 4 inch dial indicator opinion,=question
  212. Electrical circuit help
  213. Hitachi SJ100DN VFD inquiry
  214. Patience & Evolution (Not O/T)
  215. VFD help... Was given a doner
  216. _ The resurrection of a Greenerd 3 1/2 Ratchet Arbor Press begins.
  217. OT: A.K. Boomer this is for you!
  218. New toys
  219. Those Old Surplus Center Treadmill motors ????
  220. eggsellent!
  221. A totally irrelevant laugh and a half
  222. Who is going to be the first to have one of these machines in a home shop?
  223. OT, trailer light wiring.
  224. Leadscrew drive questions...???
  225. Tardis project pics
  226. kind of dialindicautor?
  227. The gift of steel!
  228. FOUND: Good Source for DC motors
  229. "DECKEL TYPE" Cutter grinder with 5C COLLETS
  230. Delrin vs PET-P
  231. Lathe chuck backplates
  232. Overarm Die Grinder
  233. *** George Bulliss: your inbox is full
  234. OT: A Christmas story, no not that one, a different one.
  235. Late Christmas present for you guys
  236. Kwik switch arbors
  237. Caliper2 pc anyone used this ?
  238. Lets see your shop related Christmas presents!
  239. Electrolytic rust removal
  240. Harbor Freight calipers. No thanks.
  241. OT: How do you read this voltemeter? Divisions make no sense (to me, anyway).
  242. Between two machines. Your Opinion
  243. tapmatic 30x
  244. glue chuck??????
  245. Home made Hammer Mill Steam Accessory
  246. New HF tool I say is a jewel.
  247. Not just in the USA - here in OZ too
  248. Seeking Jarno 12
  249. OT: The 'father' of modern dental implants has died
  250. KBAC Hybrid AC Drive... anyone use one before?
