View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 [232] 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276
  1. KBAC Hybrid AC Drive... anyone use one before?
  2. Bench grinder improvement
  3. V-8 Solenoid Engine
  4. Oddball shaper on Worcester CL
  5. Sony QX100 review, night pics included
  6. O.T. Who's driven one of these?
  7. sold my bridgeport, i have a question
  8. Turning tools for bench top lathe..
  9. Pratt and Whitney no 3c lathe
  10. Need some advice on Keyless chucks
  11. Need Help With DRO Installation
  12. Grizzly 2015 offerings
  13. BVB25L/BB2227/PM1027 Size of hole in casting
  14. Pockets on a manual mill?
  15. Davek0974
  16. Ditron dro
  17. Quick JET 13 X 36 BD video
  18. How to present an engagement ring (NOT off-topic!)
  19. new project completed yesterday.
  20. DC Variable Power Feed for a Metal Lathe
  21. Rivett eccentric toolpost, round shank insert holders?
  22. screw machine drills
  23. Surplus Shed 50% off sale
  24. OT:Mamod Centurion Steam Traction Engine on DIY Rolling Road
  25. Back to work??
  26. emachineshop
  27. Those holes on the back of outlets... the ones not to use.....not all the same
  28. hsm cnc turning center
  29. First model engine?
  30. Tennis elbow.
  31. OT: Best Movie Editor for Windows 8
  32. 2015 Wish for all my friends on the HSM forum
  33. How the dickens,,,,,
  34. small scale steam locomotive engines
  35. What are you talking a boat? What sort of hinge for rudder? And a boat of a gloat!
  36. check this out!
  37. Help determining Baldor motor h.p.
  38. Any G0704 owners?
  39. Military Grade Aluminum ??
  40. Bridgeport Noisy Back Gear and J Head over heating Problem solved
  41. Sold a Bridgport
  42. AT1 - AT11 taper tolerances?
  43. Laser engravers/ cutters, aka china variety
  44. got out of hospital late last night wow!
  45. Helicoil, Import or Genuine?
  46. check this out number 2!
  47. After you twist off the drive dog on your mill....and the crying stops...time to fix
  48. myford super 7 stiff apron
  49. OT Help me fix my printer
  50. OT: But Shop Cleanup; Can Mold be Removed from Books
  51. Drill size for press fit 1/8" pin?
  52. rules are made for bending
  53. Razor blade preservation
  54. How NOT to throw your lathe chuck key through the windshield
  55. Is mercury OT? It is a metal.
  56. Noise from a 3kw 3phase motor in star?
  57. Grinder Mandrel
  58. Wood Band Saw conversion to DC Metal Cutting
  59. 4r/5r/16r
  60. Way OT: For T-Bird lovers...
  61. Its all over but the plating!
  62. Here I goOt again-fiberglass bumpers
  63. Procunier tapping had Manual?
  64. "Civil War Era Lathe" on Boston CL
  65. south bend 9 riser blocks?
  66. FYI - TORMACH Mill listed on Dallas Craigslist
  67. New Year's Resolution. On Topic.
  68. New bearing installation on surface grinder.
  69. Laser head to mount on mill for engraving, etc....
  70. Find my screw
  71. WAY OT: How to linux network?
  72. 8" grinder wheel recommendation needed
  73. Engraving
  74. VDF on Emco Maximat Super 11
  75. OT - best type of sealant for valve cover gasket?
  76. OT: Laptop Charger Repair
  77. Mill head position question.
  78. Please explain climb milling.
  79. Ahh, but -which- constant current power supply for small type II anodising
  80. OT: World War 1 Naval Photo Collection
  81. Toolbox gloat
  82. OT: Nice private car collection in the Netherlands
  83. Made a new QC toolholder rack for the ORAC.
  84. Excello 602 mill show off
  85. Project: Oil fired furnace for aluminum smelting and steel heat treating
  86. Cross slide play? How to get rid of it?
  87. Non magnetic knife?
  88. VFD going into fault.
  89. Toolbox ideas
  90. Bearings, sheaves and related questions
  91. A simple gas cap for model engines
  92. Downriver Tools
  93. Canton floor crane
  94. Spindle Swarf Blaster®
  95. Demagnetizing a part
  96. Stark Lathe, on CraigsList Louisville.
  97. Hole milling question
  98. Collet Racks
  99. prevent milling machine head from tilting / untramming, bad idea?
  100. And now for something completely different - makeup mirror makeover
  101. A2z quickchange tool post
  102. Frank Ford shows us his stuff
  103. plastic bottle material
  104. Spring spacers/sliders on King shocks
  105. Turning a taper 2" - 3" over 27"
  106. One shot oiler/lubing a bridgeport?
  107. OT - oven hood venting
  108. OT- using a catalytic heater indoors
  109. Darn Z axis
  110. Why do I promise to do these things?
  111. Anyone use Cor-Ten steel??
  112. This BOOK will answer ALLOTTA questions!
  113. Enco Free Shippingenter promo code: JANFS25 prior to checkout, and you'll get free UP
  114. Book to read
  115. 25% Off Enco today only, Maybe it will stack with the free shipping code below?
  116. 5/8" Arbor with 5/8" arbor hole cutters vs 16mm hole cutters
  117. Turntable for 2 ft gauge loco
  118. ER collet holder. which one?
  119. Shop lighting
  120. OT- What's The Real Story On 2-Cycle Mix Ratios
  121. After 37 years...
  122. No 6207 A Study in Steel 1935
  123. need a part for a milling vice?
  124. I Have To Many TOOLS
  125. Copper covers (caps) for 3-jaw chuck
  126. Painting galvinized sheet metal
  127. O.T. Classic Vintage Mptorcycle Auctions, 3 days worth!
  128. Benchmaster arbor/collet issue. Very scary!
  129. one knurl too to rule them all?
  130. Gear pump
  131. Cleaning linear bearings?
  132. My stand for a Mill Drill
  133. OT: I weep for Esther Boateng
  134. OT: suppling electric to a VFD
  135. KBIC 120 Motor control board
  136. powdered aluminum
  137. Solvent Tank (parts cleaner) dilemma
  138. Protecting equipment in unheated areas
  139. O.T. hostage situations
  140. Homeshop cast Aluminum properties
  141. Can waste heat from an IC engine be used all year round for creature comforts?
  142. Merits of DA collet holders... for Home Shops.
  143. Wood splitter for my firewood processor
  144. Split Brass bush
  145. treadmill speed control
  146. trepanning stainless
  147. Help identify inserts to find a holder
  148. led strips
  149. Musings whilst working....
  150. 9 led flashlight power supply help needed
  151. Any "line of sight" effects in anodizing? What happens to the inside of a tube?
  152. Template for fingerscrews and threaded handles
  153. OT- Truck Tire Size
  154. Repurposing a cheap fluxcore welder
  155. designing a wooden tote type box cabinet for storing metal on wheels
  156. High Temp Magnets
  157. slightly OT?: "Plasticmake" plastic moulding material.
  158. i'm two balls short...
  159. Furry companion in the shop question
  160. Help required
  161. Authentic ? I have my douts.. Anyone over there Know?
  162. Horizontal Bandaw Cutting Fluid Question
  163. Anyone need a CAD file of the infamous Atlas carriage handwheel gearbox?
  164. Interesting table-top antique lathe on Boston CL
  165. Handy mod for gripping in tight quarters.
  166. Circlips
  167. Large Radius Cutting question
  168. Decent lathes too big for the Home Shop seem to be a bargain
  169. Dovetail cutting suggestions
  170. Lubricating ways???
  171. OT Oil Changes in Seldom Run Equipment
  172. Accurshear hold down clamp
  173. DIY Rotary Broaching Redux
  174. Heat Treat furnace problems
  175. Another New Guy...
  176. Replacing Ryobi NiCD battery packs with DIY lithium
  177. Burke #4 Horizontal Mill
  178. Rotary Table Tail Stock ?????
  179. My home made milling machine bench
  180. cheapest facemill possible with tpg inserts, what kind of finish can one expect?
  181. OT - LED illumination
  182. 6" scales without fractions?
  183. My home shop, help needed
  184. Boring head indicator
  185. Washing machine motor re-purposed as a stepper.
  186. Bending metal with a slot
  187. 6F drive removing the unit
  188. A different take on ... ... ... Obsolescence
  189. Horse and chariot....
  190. Computer won't turn off.
  191. 7" White AO Wheels for Bench Grinder - Mfrs
  192. Small Lathe Choices
  193. Abene in a basement? Sure!
  194. Considering this purchase...advice?
  195. Jensen 35 converted over to run on gas
  196. O.T. Can I bypass the dimming portion of a dimmer switch
  197. Your go-to machines?
  198. Tool grinding fixture?
  199. The Dangerous Mindset of .... Justification.
  200. Lenze servo
  201. Need Some Help
  202. Lost your pliers again? Make your own in seconds!
  203. Scraping
  204. Test Indicator Opinions
  205. Can I do this?
  206. Power of One: Calmar, AB Teacher Darren Roth
  207. Hardinge dv-59
  208. Converting an old oil free compressor. Help?
  209. Inside Calipers/Micrometers Questions
  210. Webster at Work
  211. OT: A new definition of "close"...
  212. OT: What can you glean from the flight 8501 voice recorder?
  213. All old tools tell a story
  214. Lathe work on a bridgeport
  215. Rpm indicator
  216. Slightly OT- Has anyone seen this vid? Humans Need Not Apply
  217. Wow somebody is surely making a lot of poppy on this ? Alistair
  218. working with rubber
  219. Mounting Outlets to Concrete Walls
  220. OT: Video camera
  221. Ream hole size
  222. BP Boring Head Shank Removal
  223. HSS Tialn Tip Drill Bits
  224. 1934 South Bend 9" lathe with V belt head?
  225. OT Americas gun laws.
  226. Homemade tap
  227. Shop Press !! Cost for Home Buildt !!!
  228. Another "What did we do before we got a shop full of tools" story.
  229. How many tool boxes are too many?
  230. Intesting page on Edwin Harrington, Son & Co. Lathes
  231. VERY Interesting Machine
  232. Temperature controller
  233. Another “Why do I promise to do these things” thread.
  234. scribing a scale on round stock
  235. What is it toolholders
  236. Pissed
  237. Truely thanks Guys, but I wanna go back.
  238. Couple of cheap lathes on ebay ;)
  239. Poor man's metrology flat granite table
  240. Best pin vise/chuck?
  241. Video on German forging: not HSM
  242. Want to repair the table feed bevel gears in my Atlas MFC Milling Machine
  243. Need to put a 2" hex hole in a 3"X8" A36 steel blank. Ideas please
  244. OT- Spontaneous Combustion Danger?
  245. Variation on a scam with me/you starting by replying to an ad
  246. d-5 collet?
  247. OT: How much metal would you expect inside the first filter on a new engine?
  248. Choosing Cutting Oil (Compatibility)
  249. Left handed calipers
  250. Help identifying HSS bits
