View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 [236] 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284
  1. BP Clone missing forward/reverse knob help!
  2. turning a cast iron break disk in BP clone vertical milling machine?
  3. A Math and Mechanism problem
  4. Is Delrin Stong Enough/Suitable for This Application?
  5. A couple of Friday 'whatzits'
  6. chinese carbide lathe tools
  7. ENCO Code: Today only: BACK25 for 25% Off
  8. Broken wood screw
  9. Gear Technology magazine (links to selected articles)
  10. OT-but applicable-Bluetooth serial terminal for Archos 70 Internet Tablet (Android)
  11. Swivel mill vise or not?
  12. Gast $ motor air compressor help needed please!
  13. Amazing and unusual machines
  14. Need recommendations for internal thread tool
  15. 3ph motor & VFD: keep fan spinning at full speed when htz are turned down ?
  16. I am a dumb @&$;(/$!!!!!!!!!
  17. What tooling do these inserts fit?
  18. Ot Dc element
  19. 3 rounds of "what the heck is this"
  20. variable speed transmission?
  21. OT Time for a new drone?
  22. Another Of Topic Thread pardon me Guys!
  23. Some What OT - Problems with Photo Shop
  24. Lathe choices
  25. Home / Shop Surveillance System........ My Consumer Report
  26. Lineshaft machines in Lowell Ma.
  27. Made some progress on that old Metalcraft lathe
  28. My new addition to the family
  29. _ Looking for opinions, suggestion, experiences and insight for a project...
  30. I am in Germany for 2 weeks
  31. Another machine-pricing thread.
  32. Please dont "upgrade your look"
  33. Finished new tool post
  34. Remove Chuck From Rockwell Drill Press
  35. Finished Delta Model 20 VFD Installation
  36. Does HSM magazine still exist ?
  37. Enco Double Offer! 20% and Free Shipping (Tuesday Only)
  38. OT Suggestions for Cataloging Software for Books
  39. OT: tracking list for package from USA to Germany
  40. Enco Codes, Stackable, Today Only 4/14/15:
  41. Rotary Table Handheld Controller
  42. Cabin Fever Expo 2015
  43. 1" collet or .75" r8 arbor for gear mandrel
  44. OT: Inexpensive or Free ISP in San Jose, CA
  45. Basic notes on fit and tolerance
  46. Cutting very fine threads
  47. Trivial, but I love this tool!
  48. Remachining dead centers
  49. Who needs a welding turntable when you can get one from your junk box?
  50. Coming Machine Revolution..
  51. Lathe gears - how loose ?
  52. Tramming the mill using a rotor question.
  53. Machining PVC... a little odd, but OK.
  54. half nuts
  55. Rotten brass?
  56. OT: Removing Charcow from Aluminum Pressure Cooker
  57. Heat Resistant Paint - How is Stove Paint different?
  58. OT - too much oil in the truck
  59. Cole drill
  60. USN WWII aircraft carrier found 'amazingly intact' after 60 years on Pacific floor
  61. tube bending dies.
  62. beltgrinder belt glueing on tube
  63. Once in a while you get a deal you can't refuse....
  64. OT Stuck on Alloy Wheels
  65. OT- Mower Transaxle
  66. Boring Head taken apart broken screw question.
  67. _ High class bearings for mills pulleys ?
  68. Leather Belt splices
  69. Question about phase converters?
  70. Ballistol
  71. Enjoyed N.A.M.E.S.
  72. Unusual Mill Attachment VOLSTRO Rotary Milling Head for Bridgeport
  73. OT; reading old 3.5" floppy on newer sytem...
  74. Finish Stoning/Polishing HSS tooling, please explain.
  75. Made my own narrow sanding belt
  76. GMC GML-1640 High Speed Precision Engine Lathe
  77. Rebuilding tapping head, lubriation?
  78. Unusual cam-lock bench vise on Boston CL
  79. Paging metalbender
  80. Removing a bushing.
  81. What to Do?
  82. Cutting Oil?
  83. Repair Ideas for mill ways?
  84. Surplus Shed 50% off Sale
  85. looking to buy first insert tooling kit
  86. 4X6 Metal Bandsaw Fast Production
  87. Clean Hole In Metal Pipe
  88. Netbook CAD
  89. Bit Holder, Adjustable height, Atlas 618
  90. HELP! w/an Acu-Rite ll DRO
  91. O.T. any hope for droped camera ?
  92. 3D print an asteroid
  93. Atlas lathe dead center question
  94. Changing color of flexzilla hose. Anyone tried it?
  95. grizzly/craftex 12x36 lathe feed & threading poster
  96. Nice machine auction in Va
  97. Made a handle for an old milling vise
  98. OT: Chain hoist manual garage door opener spring adjustment questions
  99. hardness of glass
  100. How Would You Countersink This???
  101. Any reason I can't remove the index disc on the bottom of this chuck?
  102. Help identify this engine please.
  103. How to test run a 3 phase motor?
  104. Current HSM is best one in quite a while
  105. M head bridgeport mill, does the head slide forward?
  106. !5% off ENCO SALE
  107. Non reversing tapping chuck with clutch
  108. Changing Gears for Threading
  109. inside camfering
  110. Stainless steel ball joint?
  111. Gear pressure angles
  112. 25% off today only Travers Tool Co.
  113. Enco
  114. The gremlins are at it again
  115. another bushing removal question
  116. Lest we forget 100 years later...
  117. OT: No internet/email/WIFI for a week - Just saying I'm OK and will soon be home
  118. Brass Escutcheon Pins
  119. Palm fit torque wrench
  120. How flat is polished granite work top?
  121. "FREE" Electric Motor
  122. Permalac Lacquer Finish
  123. Foam rubber??
  124. Logan co-founder passsed away
  125. Phase converter idiosyncrasies
  126. Annular Cutter Holder for Drill Press
  127. Dewalt 18V cordless tools?
  128. How to fill this Hydraulic cylinder
  129. Has Anyone Made a Beam Trammel Set?
  130. Anyone used Bondic
  131. Way, way OT, about the "original" Donald...
  132. belt driven lathe, belt keeps running off when taking but the lightest cut
  133. Miniature Block and Tackle
  134. OT: The strange presence of liquid mercury in Mesoamerican tombs
  135. Any refrigerator techs on the board?
  136. updates to shop gantry
  137. No tools?
  138. Cabin Fever tool gloat
  139. OT: paying via fingerprints
  140. Oil filled submersible pump. Which oil?
  141. gear cutting fun
  142. OT,Tool Gloat
  143. New mill! My first! I so excited!
  144. OT - Mechanical Drawing Device Identification
  145. New S.W. Michigan Home-Shop Machinist Club
  146. Double Headed Coin
  147. Drill Sharpening: General Tools #825 Attachment
  148. Phase Converter to power forklift charger
  149. RFQs from China
  150. Collet closer for a rivett 1020 lathe
  151. Moore dividing head find and question
  152. ENCO 1/2 price & Free Shipping!
  153. An oil question
  154. Obscure tap ID - super taper!
  155. Best place to sell some timing belt pulley stock?
  156. electronic question
  157. Round vs Square post Mill Drills
  158. Seeking operational and parts manual for Summit geared-head drill press (59R)
  159. bending machine.
  160. ENCO 25% off Today!
  161. Dynamic VS. static torque
  162. Logan 2900
  163. Does anyone have Scherr-Tumico micrometers ?
  164. hydraulics question - ID this valve?
  165. BEST and Cheapest way to Miter 4130 Tubing
  166. reversing a degree wheel on a spin index
  167. Dovetail Cutter Selection
  168. Deep hole drilling on lathe - tips?
  169. lathe shakey....
  170. Project done
  171. Enco 1/2 price granite indicator comparator stand - worth getting?
  172. Extension to leadscrew- finished
  173. Colchester Master Original - help required
  174. OT. Electronics, Hall effect sensor in small AC motor.
  175. Plague - "Black death" - seems its not entirely gone after all
  176. Shrink fits and retaining compound?
  177. Industrial battery
  178. VFD choices for a small 3ph grinder
  179. Closing my shops, my machines are going
  180. NEW LATHE final decision I think.
  181. WAy OT: phone problems
  182. "The Spirit Behind All" Treating machines and people w/respect, love & understanding
  183. Hamilton round-way hobbyist lathe on New Hampshire CL
  184. QVEA Show featuring Allis-Chalmers tractors
  185. mounting VFD for knee mill.
  186. L-W dividing head... what did I just buy ???
  187. Once an HSMER,always an HSMER?
  188. Connecting rod bearing clearence
  189. Preis collet needed.
  190. Well, I am having to re arrange my garage/shop for a new project..
  191. What TPI on leadscrew of 6" Atlas lathe?
  192. hydraulic crimper question
  193. What did I do?
  194. eMachineShop - UTube
  195. Very O.T. cast iron lead melting pot
  196. Bulk threading advice
  197. Worn degree marks on compound.
  198. 2.25" x 10 tpi
  199. Hendey Lathe
  200. Fishtail Guage Markings?
  201. Is higher education better than less of it - or not (very "tongue in cheek")?
  202. Automatic Boring/Facing Head
  203. Do you often fall or fall over?
  204. Indexible tooling question
  205. one more hydraulic question
  206. Dividing head tailstock alignment.
  207. Help selecting ceramic resistor for a LiPo discharger
  208. McMasterCarr catalogs
  209. Heavy lifting in OZ
  210. Nadeau surface plate
  211. Enco 15% OFF
  212. Way OT: Day job possible math related question.
  213. Does anyone know any info on this lathe?
  214. Rosie the riveter has passed
  215. VFD Power question for electrical peoples...
  216. How many vise jaws do you have?
  217. Dimensions of both pulleys Atlas Mill Horizontal MFC
  218. This Looks to be a Handy On-Line Reference
  219. OT. Tom Hoover
  220. Chinese VFD's?
  221. Enco Discount Code, 15% All Month Long
  222. End mill surface finish
  223. OT: Dissection and partial resurrection of an LED lamp
  224. Stainless surface finishing.....
  225. Non detergent oil questions
  226. 60 Degree V's vs 45 Degree V's and Centerless Grinding
  227. I Did It. You Can, Too ! SMD Circuit Board Repair
  228. appears to be a high quality document teaching auto painting
  229. My tool gloat of the week.... month....decade maybe.
  230. On topic and fun
  231. i got lucky and bought myself a vertical Kondia and a horizontal Pederen
  232. Emco unimat sl1000 chuck removal
  233. Box truck with beam crane
  234. Weird Lathe Problem
  235. Metric acme thread?
  236. O.T. - GM seeks to make it illegal to repair your own vehicle
  237. Recycling HDPE
  238. OT: Pallet jack pump
  239. Off Topic. HELP How do I copy and paste Craiglist add to this forom ?
  240. Tpac Tools DRO for the FrankenMill
  241. O.T. - High pressure plumbing question.
  242. Looking for Jaws for a 5" Kurt
  243. Shop Made Fly Cutter Or Something Adaptable ?????
  244. Removing head flange gear form Ex-Cell_o 602
  245. poor speller- Aspell cx?
  246. Calculate 'length of engagement' for Thread Pitch Diameter Tolerance ???
  247. Treadmill motor question
  248. DV59 Hardinge lathe spindle bearing question
  249. Mill tool racks, carts, shelves, and whatnot. Lets see them!
  250. There's going to be some more delay's with the flying car thing - sorry
