View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 [238] 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284
  1. Lenticular shaped diamond wheel???
  2. OT: What would you do?
  3. Whately Engine Museum Show and ATCA Show in Johnston RI
  4. Mercury
  5. Kearney and Trecker vertical head running hot
  6. Why do time sert tap sizes seem like a secret?
  7. Spring loaded engraver question
  8. Drilling roughly (200) 1-1/4" holes
  9. OT: the Large Millimeter Telescope & the hunt for black holes (NYTimes)
  10. dividing head , kind of
  11. Transformer size question
  12. Original receiept from 1952 micrometer lay-away
  13. Early Westinghouse motor info, anyone?
  14. Candidates for education and jobs from over-seas
  15. Upsizing a Set Screw
  16. Value of South Bend 9" A Model
  17. Introduction to steel and steel making
  18. Grizzly G9822 Chuck
  19. 1-800miner
  20. Way OT - Sending Videos
  21. ENCO SALE EXTENDED! They want your money boys!
  22. 30" to 36" PVC needed
  23. Grizzly lathe question
  24. Airgun guy that is a member here?
  25. Perforating 2" OD, .065 wall 6061-T6 tubing... Best method?
  26. Did I Just Trash My 6-Jaw Chuck?
  27. Macona I deleted to many messages.
  28. Hearing (not hearing) phone in shop - solutions ?
  29. I want to buy a new compressor
  30. Digital Readout (DRO) for milling machine
  31. Does anyone have a Bison 5" 6-Jaw chuck?
  32. Diamond Grinding WC what coolant?
  33. OT: startling 102-year-old autochrome images
  34. Really need advice on bushing retention problems
  35. Large bronze nuts, LH/RH?
  36. milling a curve question
  37. Real or CGG??
  38. new toolpost for shaper - a question
  39. Cosmoline or similar product
  40. Big milling vise for trade
  41. Hendey lathe
  42. First post, just to say Hi.
  43. Stomach-churning flight - new Boeing aircraft
  44. What has happened to my oil?
  45. how to balance dice?
  46. Small gloat on a large tool
  47. _ Do you think oil, in a Mill Heads gear box also dampens ?
  48. Newall DRO died
  49. EDM - good results would anybody be interested in a u-build kit?
  50. Link belt for flat belt drive? and those old popular mechanics mag. 1962
  51. Dividing Plate Calculator Software
  52. Clausing 5914 hydraulics rebuild
  53. Drilling holes with slot drills
  54. OT: OS comparison Apple V Windows
  55. quick clamps - but with a controlled release?, anyone know of anything suitable?
  56. Strange Ebay $100.00 giveaway.... Fake??
  57. Small Gas Engine - Weak Yellow Spark, with a twist
  58. OT? Thermistor temp. indicator
  59. Deckel KF 12 Pantograph any knowledge out there
  60. WAAY OT: Anyone from Omaha know what kind of trees are near Ameritrade Stadium?
  61. Even further OT, but probably no CGG or CGI
  62. Tiny internal o-ring cutter?
  63. Zildjian cymbal company., founded in 1618 (history & manufacturing)
  64. just started running a lathe again after several years
  65. Measuring in confined area
  66. OT- Balancing Tires
  67. Which height gauge should I keep?
  68. Hendey tool room lathe
  69. OT: Son Had Stroke; I Need An Intercom/Buzzer System
  70. Laser/Light Beam Sensor
  71. Modifying the 4 1/2" x 6" band saw
  72. Vintage Machines
  73. heat exchanger calculation
  74. Gauge micrometer servicing
  75. Rust
  76. What is it? (from Boston CL)
  77. Cow shearing machine?
  78. I need your expert opinions and practical advice if you can be kind enough to reply?
  79. Try this with standard vise jaws (reason to own # 8,649)
  80. Thumb surgery
  81. Semi OT: Waterloo - 200 years ago today
  82. Spring question
  83. OT: Yagi wifi antenna interfacing
  84. Sip turbo mig welder gas model 150 question re new tips sizes etc.
  85. Rotary Broaching Geometry
  86. Quick trick for working with soft jaws
  87. OT:Cracked Allis Engine Block
  88. VFD or no VFD Clausing 5914 lathe question
  89. Turning carbon steel with C2 grade carbide?
  90. interesting lathe on ebay getting parted out
  91. End mill speed/feed for max life
  92. The Last USA made Scroll Chuck Co tour
  93. To (thread) DIE for
  94. Tools4cheap: 20% off stock-cleanout and likely business shutdown
  95. 4 x 6 bandsaw in Yahoo Groups
  96. Manual for old Sheldon lathe- cleaning solutions?
  97. Tool Grinding
  98. Suggestions for small lathe spindle
  99. OT: flyby _through_ the hangar
  100. Free lathe to the right person
  101. Govenor on cordwood saw
  102. New Columbia
  103. OT electrical code question and aesthetics…
  104. Thanks for the Enco codes
  105. OT - '92-'99 Full Size Buick, Olds & Pontiac Owners take note
  106. Flasher Circuit Help
  107. Needle bearing fitment question
  108. LED shop lights
  109. Tool ID Assistance: 'Do You Know Me?'
  110. fofllow-up to older thread: Still able to buy used carbide at Midwest Industrial Met
  111. Oil Level in Lathe Box Sight Glass - At rest/In motion
  112. Air tank on fire!
  113. OT mostly - what's wrong with my lawn mower?
  114. Arboga - ar 4008
  115. Made my mill more user friendly
  116. Tip: Replacement Aerosol Spray Wands/Ext Tubes at Lee Valley
  117. OT: Where I am
  118. boring head test
  119. I think I've created a monster for myself
  120. ENCO Again!
  121. OT Clog Hog drain cleaner attachment for a pressure washer.
  122. OT: In the bullseye - wind, hail, rain, lightning, possible tornados in Cockeysville
  123. shaper
  124. OT Honda Lawn tractor hydrostatic drive
  125. Help wiring Anaheim Auto MBL536 driver board
  126. Quick belt drive question
  127. Educate me on milling machine collets
  128. Bonding steel to aluminum
  129. spray paint gurus: catalyzed paint - how much thinner?
  130. Dovetail Cutter Design
  131. flexbar for dial indicator
  132. OT: Auto Steering Vibration that Goes Away
  133. My Shop Pictures
  134. CX601 Milling Machine
  135. mag chuck question
  136. OT, unleaded petrol on paint
  137. please help me with this wow this is bad.
  138. OT: LED Filament Edison Bulbs; What Next?
  139. Bandsaw setter, works like it sounds like it should
  140. Need a BIG HV power supply
  141. Hand scraping precision square
  142. drill chuck removal
  143. DC motor vibration
  144. Key for battery isolator
  145. Solar. Photovoltaic (PV). Just had 26 panels installed.
  146. can someone explain to the tightwad why this is a bargain? I just don't get it
  147. OT driver's license expired
  148. Acme leadscrews
  149. Interesting handy tool on CL
  150. Rethreading
  151. OT - Jupiter and Venus joining up...
  152. OT: Black & Decker Thermoelectric (Peltier) refrigerator repair / upgrade
  153. OT: Drama in the work place (Warning do not do this!)
  154. ENCO Again!
  155. a great gloat or maybe not so you guys must help me decide.
  156. Weekend Shows 27 & 28 June
  157. Moving a shop
  158. Help finding a post.
  159. Best way to build this part for future lubrication question
  160. Has anyone ever seen this type of thing and what it is, or was used for?
  161. Grit for grinding end mills
  162. electric motor problem
  163. Teco 7300 VFD wiring question
  164. OT- WD40 allergy
  165. Cincinnati #2MH Mill Questions.
  166. OT: Cell Phone Users - How Is Data Stored in Device Backed Up
  167. friction material
  168. North Bay Cutting Tools?
  169. need to make a square hole
  170. Downsides to a large boring head?
  171. Anyone have a #1 Hossfeld??
  172. New Machinists (Hand) Book for Hobbyists from Industrial Press (USA)
  173. Trying to figure where to put the bracket for my digital readout.
  174. Nicholson -"The Guide To Files and Filing"
  175. OT: Setting fence posts the easy way!
  176. 5 axis desktop cnc ... this is cool
  177. Another Thread Chaser, by Charles McCullough
  178. need internal key way but have no broach
  179. New, looking for where to find spindle speeds and feeds
  180. Thread dial question
  181. OT: Repairing a broken sump pump outflow line
  182. Any great ideas on DRO scale position?
  183. Totally OT: Why would anyone build a building like this?
  184. CNC lathe missing steps, figured it out
  185. Jacobs Drill Chuck 633C
  186. Timing belt motor drives;
  187. Surface plate covers.
  188. _ Timing Belt versus Ultra-Flexible J-Section V-Belts, less slippage ?
  189. Natural or Synthetic Felt
  190. Inserts for cutoff tools?
  191. Grease Fittings: Common Nipple Size ?
  192. Voice controlled machines?
  193. Quickest way to clean mill lubricant off hot rolled steel
  194. Happy 4th Fella's - U 2 Bazooka :-)
  195. A small gloat for a small machine.
  196. Hemingway Kits (UK) -worth a look at
  197. OT: 105 degrees today in Germany!
  198. Supermax milling machines for sale
  199. Snake oil recomendation
  200. alien abduction
  201. OT: Wife wants a fitness center in the house!
  202. Some small old machine questions
  203. Grinding wheel questions
  204. Need suggestion for gears wtih specific keyed hub..
  205. Are There Special Arbors For These Cutters ????
  206. OT: Seasoning Cast Iron Cookware
  207. Please give me the low down as you guys see it.I always like the advice , from you .
  208. Clausing 5914 variable drive parts. Anyone need anything before it heads to fleabay
  209. Un heat treated silver steel
  210. OT: Question for wounded veterans
  211. Baffled by metric threads
  212. What would be "Acceptable Tolerance" for Travel in X
  213. Minor "Pressing" Gloat
  214. look at this video it is great
  215. Cheap r8 collet from Enco
  216. Lathe spider - how to match threads to spindle?
  217. Kennametal Kenloc face mill parts?
  218. New England Events for July 11 and 12
  219. Fusion 360
  220. Paul Kuhni Great True story! Read if you haven't you'll enjoy it!
  221. OT: Used tires for my old truck
  222. Type of Wood used to make Casting Patterns
  223. Help, Compressor motor stopped working.
  224. AR15 DIY parts?
  225. Hardinge UM/TM table nut question.
  226. Storing acetyl rod
  227. OT: Amazing Grace, featuring Condoleeza Rice on piano
  228. The Chicken or the Egg? What!!
  229. What are the best materials to make machine tool slideways from ?
  230. ENCO 30% off Today only!
  231. spindle wrench
  232. proper name of shaft adapter??
  233. woops unwound my tailstock spindle too far now it won't retract
  234. Help replacing lathe rack and pinion.
  235. cold forming
  236. German lead screws ? Stefan?
  237. Manufacturing Plastic Part - Injection Molding People?
  238. Edge Technology
  239. 14x40 low range selector inverter gear slipping
  240. OT land line phone power
  241. Pratt 3-jaw runout – is it for scrap?
  242. Reversible Electric motor starting
  243. Parting off
  244. My Latest Creation...Cannon
  245. OT: AC questions
  246. Milling machine table lead screw
  247. Mini lathe test bar question
  248. Tool Cart, Drawers , or both ?
  249. Any Knowledge on Doall 3612-3
  250. Facing question
