View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 [240] 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281
  1. 36th Annual Straw Hollow Engine Works Show
  2. how to tip bridgeport column casting on its side?
  3. Adding A "DRO" To Lathe Tailstock
  4. Old time garage machine shop
  5. anyone with a knee mill and tenths indicator please try this
  6. Mud/slab Jacking Pump
  7. Gear train calculation.
  8. OT: Sense Of Humor, Lost On Most People These Days
  9. Using the wrong tips
  10. any good references to the old-style cold-stitching crack repair
  11. OT: What a Way To Wake Up On An Early Sunday Morning
  12. Logan Variable Speed Drive
  13. Mounting 3 jaw chuck on milling table
  14. Stainless machining question
  15. Grinding - frequency of dressing?
  16. OT - 2006 silverado brakes dragging and getting hot.
  17. Boring head with arbor welded to it?
  18. no pin spanner, no strap wrench, no problem
  19. Repairs by so called professionals
  20. help im drowning in grease
  21. Roll Forming Edge
  22. Loose 1/4" and 3/8" NPT Threaded Holes
  23. is this DC motor setup lame?
  24. After I get my linear scales mounted, what do I do to ensure accuracy ?
  25. My take on Harbor Freight rotisserie, with some machining..
  26. Where to purchace an American motor for a ZX 7045 gearhead mill.
  27. ENCO 20% off, no minimum, Today only!
  28. Need an HF Coupon
  29. Picture of Motor Plate or specs. for a 1 HP 3 Phase Bridgeport Please
  30. Chuck issues :-(
  31. Question from a newbie
  32. Its Brian Rupnow's fault
  33. Scotchman Glide In Vertical Bandsaw Know How
  34. Idler motor for phase converter question
  35. EXTENDED: 20% Off Today Only! No Minimum Order Requirement!
  36. Pitch error and you, lets get all warm and fuzzy
  37. Extra Long End Mills....??
  38. How to run a stepper motor faster??
  39. New England Weekend Events for August 15 and 16
  40. Newall DP7
  41. OT: Persistent crapware and Windows 8/10
  42. Louisville KY Lathe for sale
  43. making tee nuts on a metal shaper
  44. anyone make their own precision axis nut for a bridgeport?
  45. Caswell plating - 20% off nickel plating kits
  46. OT- Roku and bandwidth
  47. Electronically challenged - need some DC motor inductance advice
  48. real world consquences of hand-grinding threading tools?
  49. messy shops are depressing
  50. ACDC motor
  51. Clean shops are depressing.
  52. Can-Do Machinery?
  53. Greenard no. 5, 12.5 ton arbor press, is it worth ?
  54. 3141backhoe part shaft tear out
  55. Surplusshed.com $50 off $75 orders + $6 shipping!
  56. Clamping strength of a 4 jaw over a 3 jaw chuck when holding round stock ?
  57. OT Unforseen danger of oxygen
  58. OT- Quality washing machine
  59. Controlling machine animation with Xbox 360 controller
  60. Do pancake motors on bridgeports draw the amps they say or do they draw more ?
  61. Clausing Lathe
  62. Honestly OT: My favorite lathe
  63. "Windows 8 On a Stick"
  64. South Bend Turn Nado Lathe
  65. Anyone powering an entire home shop with either one BIG VFD or a BIG rotary converter
  66. Making custom tools from 1010 with carburization?
  67. Clamp on soft jaws for the minilathe
  68. Rohm 10" 3 jaw chuck parts
  69. Quality of products sure has changed!
  70. Mitutoyo Quantu Mike worth the extra $ ?
  71. Old (I mean really old) milling tools
  72. Any SB heavy 10 experts here
  73. Another gloat......
  74. Customers and their projects
  75. Who has a PDF or other source for service manuals, for the Comet Mill and others ?
  76. Finally Finished installation of X scales
  77. 1/4 scale Merlin build from castings
  78. Funny craigslist lathe posting.
  79. OT: What's going on with Windows Defender?
  80. WTB Wilton Vise
  81. Homebuilt Self Propelled Grain Auger & Bin Crane 4 Million Bushels 600 hrs. labour
  82. Oversize metric taps - stockist?
  83. Mystic Seaport Engine Show
  84. How to tram mini lathe toolholder for drill-milling long parts?
  85. How to DIY burnish electropolished stainless steel
  86. 4 Jaw Chuck (body) runout question
  87. Interest in 127 tooth gears?
  88. centre drills
  89. cylinder rod question
  90. Head Vacuum Tester
  91. Have back gears . . will ship . . if you can use 'em?
  92. Centers
  93. Ot, cnc
  94. Question for phase converter gurus etc.
  95. Sheared roll pin on leadscrew - need help to remove the leadscrew Grizzly G9729
  96. Dividing head
  97. ENCO 15% OFF, Not a biggie but if you had to order anyway save a little
  98. Maybe Gloat? (see en see!)
  99. welding table - ground?
  100. Cutting oil advice
  101. broke a gear in my headstock, got some questions
  102. flat belt comes off at high speeds
  103. Making D-bit type slot cutter?
  104. Armstrong hand threading
  105. Benchmaster V-head disassembly
  106. What's the difference between a 1 piece & 2 piece cross feed nut on a bridgeport ?
  107. OT - Windows 10, again. Suppose you download the installation...
  108. case hardening experiment and questions.
  109. Hardening of drill rod /silver steel.
  110. Micrometer Standard/Gauge Block - Apparent Error
  111. Enco Free shipping and 20% off.
  112. Making Gear Cutters HSM Article
  113. Tool grinding advise
  114. Material Sticker Shock
  115. Good job McMaster Carr!
  116. Steam Powered Line Shaft Shop
  117. Deutsch crimper
  118. Old lathe with just one half nut?
  119. Need help with drill press
  120. Never throw anything away!
  121. Design and machining of cams
  122. Cabinetry 101
  123. Do nothing machine
  124. Need help identifying older Enco tool holder model Q 35
  125. Dropped my 8" Caliper&%$#
  126. I was wandering ??
  127. The Black Hat Engineer's Guide To In-Press Mold Repair And Polishing
  128. boring bar stickout for boring head
  129. If I bought this would it be a gloat or what what a bargain !
  130. HSM
  131. Metric Threading with an Inch Lead Screw
  132. Morkaiko lathe
  133. South Bend 13 back gear eccentric shaft and bushings
  134. Ball Cutting
  135. Lin Huan, David or Select lathe from the late 70's
  136. OT: American servicemen save Europe from another terrorist massacre
  137. OT - A Pool full of Bears
  138. BP Right Angle Adapter Reference Line Accuracy
  139. Making a Dive Torch
  140. OP Surface mount de-soldering and soldering
  141. Rotary shaft to transmit power
  142. Lathe manual
  143. Arbor Press
  144. Tool grinding service
  145. Poly Vee Belt on buffer
  146. Cutting a fuel bottle open with a cutting torch
  147. Jacobs Drill chuck with 1 1/2 x8 threaded back
  148. Is the HF TIG welder much good for light welding? Your thoughts???
  149. Can anybody tell me anything about this Wells saw?
  150. A bit OT - Retardant bomber in the Okanogan Fire Fight
  151. Speed Control for Small Tool
  152. Tooling Up The Sherline CNC...
  153. Atlas/Craftsman lathes and half/split nuts
  154. OT: any good books on resistance welding sheet metal?
  155. Just the tool you've been looking for
  156. Help ID'ing motor
  157. Enco vs. Grizzly bandsaw
  158. Belt and/or Disk Sander Reccomendation
  159. Enco code for today only
  160. Hiding, but where ?
  161. YouTube Mill/Drill Review?
  162. Bandsaw blades for home shop use
  163. Fun Comparison
  164. Anti Back-Flow valve
  165. key in drill rod
  166. Need some GOOD tweezers
  167. Roller machine for the manufacture of pipes, cones and rings
  168. Converting tool box friction slides to ball bearing
  169. Assembly / welding table
  170. Atlas 618 treadmill motor conversion
  171. Need data on Clausing lathe model 111 (MK3)
  172. 3D Printer meets Art
  173. Strain Gauge
  174. Steady rest rollers v/s brass
  175. Heat straightening smallish shaft help
  176. Recommendation for a good cushioned mat for the shop? Doc tells me to get one.
  177. Drill press vises
  178. The Lowley Follow Rest and Its Uses on a Lathe
  179. Disassembled indicator stand, hydraulic locking
  180. weld/braze of leaded steel
  181. Interesting Stuff About Tapers
  182. OT deep well pump system
  183. What is missing on this Gorton mill?
  184. Dive Torch 2 - The Anchor
  185. Bending 316 SS tubing and fab. question
  186. Sherline speed control replacement.
  187. Wanted: Piece of magnetic grade stainless tubing
  188. Now I wonder what this lot of micrometers will sell for?
  189. external threading tool holder.can't find the size I need.
  190. What Material Do I use?
  191. Machining with Annular Cutter Internal Bore
  192. OT Quality smoker, who makes one?
  193. Snowmobile Brake & Flange Mount conversion to Belt Drive Milling Machine
  194. 12" Atlas/Craftsman
  195. OT - Help with 4 HP Kohler K91 Gasoline Engine
  196. O T: How Alternating Current Evolved
  197. Anyone know this lathe.
  198. Delrin ?
  199. Dressing Diamond Cup Wheel
  200. QUESTION: Plaque for Meuser lathe
  201. InterRapid bezel removal?
  202. calling all paint ballers
  203. Making an indexing plate for a dividing head..
  204. First Law Of Hardware Stores --
  205. 14x60 lathe for sale near louisville KY
  206. Materials ?: 12L14 comparison
  207. The Thread In Which We Explain Stuff Wrong [humor]
  208. parting tool blades
  209. scarred old table now my new welding table
  210. How would this DRO be for a starter
  211. Vise clamping problem
  212. Paint gun flow problem
  213. Maybe British threads
  214. Advantages & disadvantages of six jaw chuck & types of jaws to consider
  215. Gearless Mechanism--4 stroke i.c. engine
  216. Making thin circles
  217. Differential Spreader for the School's Automotive Shop
  218. More fun with Winderz and computer stuff.
  219. Chips on the floor
  220. 10% of'n all V-belts
  221. OT Steel Stair Structure with Concrete Treads
  222. Hey---B.F.--You're needed
  223. OT: 70 Years ago
  224. Resistor question
  225. Motorcycle engine , internal capscrews, no locking provision
  226. Takisawa lathe.
  227. How to make silicone molds for next to nothing with stuff you already have.
  228. steel handrail to look like brass - ideas wanted
  229. Way OT melting with forge
  230. Modifying a weed trimmer rack for a trailer
  231. Long running CNC router table project.
  232. Mini lathe gib question
  233. Silver solder or spot weld
  234. If you're going to get a DRO for your mill, why you want a nice one...
  235. Score: Bought 2200lbs. Bolts at Auction
  236. O.T. New Drone
  237. OT: firewater and tornado in Kentucky
  238. Somebody scored nicely In Milan OH
  239. 3D Printed Shop Hardware
  240. Book: Machining for Hobbyists - Karl H. Moltrecht
  241. HSS part off blades
  242. New Hacksaw for my shed
  243. Favorite Cordless drills?
  244. My milling catch 22
  245. Tormach or benchtop cnc
  246. Found a Le Blond Regal Model 149
  247. Fuel Line tools.
  248. 120V split phase motor with start capacitor.....???
  249. lathe convex and concave radius turning attachmnet
  250. Lathe radius turning attachment
