View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 [242] 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. My $50 Hamilton Milling Machine and Other Auction Scores
  2. Richmond milling machine universal ?
  3. Enlarging a Hole in Metal U-Joint
  4. What to do with a stripped lathe bed?
  5. semi OT - Microscope photography - adapting the camera to the scope
  6. Home made steady
  7. Cutris air compressor pump E- 57A
  8. Some days you just get things back asswards...
  9. Measuring Welded Load Chain Stretch
  10. Woodstove Project - some metalwork involved
  11. off topic do you guys suffer from this?
  12. Get'er out job on a simple drill press - how to reverse the spindle direction?
  13. Lathe power cross-feed question
  14. Air Punch/Flange Tool
  15. Moore & Wright - current production quality
  16. Please explain how back gear works.
  17. CX701 Lathe Report
  18. Measuring a splined shaft
  19. clausing 5914 cross slide gib ?
  20. Electric 68 Mustang Fastback 0-60 in 1.94 seconds...
  21. Fast aluminum removal??
  22. OT: Problem With My Living Room Ceiling
  23. Trying photochemical etching, for making instrument dials
  24. OT: Pressure washer problem
  25. OT: Sneaky, tricky, underhanded Microsoft
  26. Roller for bending flat bar
  27. Lathe Spindle Center Height to Floor..What Works for You?
  28. Looking for Machines
  29. Gloat worthy?
  30. Mill climbing question
  31. Rebuild Lathe is it worth what they want?
  32. Looking for source of snap on 10-32 nylon ball joints
  33. m4.5x5 or m4.5x7 ?
  34. help identifying thread specs
  35. Adding a bigger muffler to a generator
  36. Palmgren Vise Paint?????
  37. How many Fusion 360 users on here?
  38. Bridgeport round ram repair
  39. Explosion welding
  40. brazing welding hearth question?
  41. OT, - Dr. Science question
  42. Monarch EE sold at metro Detroit auction - NOT mine
  43. OT: Expensive drum switch on ePay
  44. OT: Scott paper shop towels on sale at COSTCO.
  45. Will kerosene melt a plastic bucket?
  46. Drilling aluminum
  47. Small Halogen Shop Task Light
  48. Pulleys
  49. OT: Found While On A Woodworking BB - SolwMo Animated Hummingbird
  50. Cross Slide / Compound Threads
  51. 7" Hole in .030 SS Sheet
  52. OT- Found a site that lists counterfeit items
  53. Photos of recent engine repair
  54. Powr-Kraft/Logan Lathe
  55. Oxalic acid for derusting
  56. The apprentice and the motor
  57. Question for Logan experts?
  58. drill press columns- useful to re-purpose?
  59. Collets and collet holders questions.
  60. Mystery collets, odd reamers, for ID if possible
  61. Arco saw, model 444
  62. Sheldon lathe for sale
  63. OT: A music video that will bring tears to your eyes!
  64. thread cutting question
  65. OT - Wife wants a wood chipper
  66. Enlarging hole in HSS mill
  67. 24'' Max Disc Grinder in Action
  68. Lathe bed wear amounts.
  69. "The Most Modern CNC Machines In The World" video...
  70. Hey, you overunity fans and pulse/motor/generator inventor types, watch this hokum.
  71. I made my first tap!!
  72. Oscilloscopes again
  73. Drilling .043 hole in Stainless ??
  74. O.T. polishing old claw foot tub
  75. Looking for Puget Sound, WA, rebuilder.....
  76. Kool mist, which one?
  77. Acceptable runout
  78. A bit of a puzzle.
  79. Table saw for bulk material removal (aluminum)?
  80. Shop furnace question/problem
  81. ENCO !0% off & free shippng Oh Boy! Oh-Boy!
  82. PSA: Spontaneous Combustion: Another person learns the hard way
  83. Monarch for sale
  84. MT2 Taper in Vertical mill
  85. Hard!
  86. bevel gear depth of cut
  87. Dovetail cutter from Randy Richards
  88. Midwest Ind Metals closing Troy facility
  89. Fixture plate
  90. OT: Heads up on latest MS Windows 8.1 updates
  91. Advice on lathe.
  92. OT? How Do You Handle Cardboard in Your Shop?
  93. OT: Interpreting win7 task manager data?
  94. Lawn and Garden Tractor Battery???
  95. What to chooose? o.O??
  96. Bandsaw for Metal And Woodwork
  97. Dismantling a Bandsaw Gear Box
  98. Union 3 jaw Chuck with independent jaw adjustment
  99. Busy Bee site blocked by security software, bit O.T.
  100. possible gloatage?
  101. Wiring questions for a 110/220 motor running on 110.
  102. Someone stole the tailgate off my friend's '85 F150, so...
  103. Interesting US made weld tables
  104. Fletcher capstan table, somewhat OT but a fascinating mechanism
  105. OT cleaning carbon from automobile EGR valve passages
  106. W.B.Knight 20 Jig Borer help
  107. BIAX Power Scraper model new / old reference
  108. OT? Please Quit Posting Links To Those Videos - I Have Work To Do
  109. Bandsaw Conversion
  110. You ever buy something accidentally?
  111. Turning a paintball CO2 tank into a crude stationary fire-extinguisher setup.
  112. Ceramic wool. Is it safe?
  113. Tiny RC Truck
  114. metal cutting saw?
  115. Welding cast iron
  116. Finally...A Video Unlocking the Secrets of Accurately Boring & Honing MC Cylinders
  117. Band saw table
  118. A small gloat & tribute to a friend.
  119. Lincoln Ranger Gasoline powered weder idle problem
  120. DIY Hydraulic Press Repair?
  121. New England Museum of Wireless and Steam Show
  122. Adding a bigger muffler, yada,yada,yada
  123. OT How to test a capacitor?
  124. Coventry die head thread range
  125. Looking for a postprocessor SolidCAM --> Roland MDX540
  126. OT: Wilton Shop King Vise - any good?
  127. ENCO 20% Off Today only! No Minimum
  128. What's it called?! (must be googling the wrong thing!)
  129. What sort of coating is put on lab benchtop?
  130. More Furnace Woe's
  131. Hossfeld bender
  132. Its time for me to build the lathe quick change tool post
  133. O.T. What brand off tire for medium duty pickup
  134. Turning to a shoulder- Shoulder ends up tapered
  135. OT: Knobs at the end of the vise handles?
  136. Tapping using a butterfly impact wrench
  137. The Black Hat Engineer's Guide To Additive Manufacturing Troubleshooting
  138. Researchers figure out how to put a nano layer of tungsten on steel.
  139. New to me "Do-All 16-2", keep 3 phase or go single ?
  140. Can anyone Identify this Vise
  141. South Bend 10x18- Value And Suitability?
  142. Dynamic pricing
  143. OT: PSA - Dodge Spare Tire Winch Maintenance
  144. 3 Phase control question
  145. Babbitting Tools
  146. OT: But useful PIC project, peak/phase fired SSR with time delay and duration
  147. OT - but interesting material science demo - Prince Rupert's Drop
  148. [ot] Publishing a pay-per-download PDF
  149. Old school machining
  150. Run out of breaker spots in your 100 amp service box? New "lead in" kit for sale!
  151. Grizzly 7x12 vs. Grizzly 7x14
  152. Gerstner value...
  153. Way OT tire liquid
  154. OT - truck coolant leak-fix additive?
  155. Ever heard 'crocodile' or 'alligator' associated with an ironworker tool?
  156. Hey Evan
  157. Walworth Parmalee No. 1 5 pc wrench set
  158. Cutting tool question
  159. Proposed New Forum Rule
  160. Rolling a cone?...I made an Excel spreadsheet for the flat stock..
  161. I need to replace some bushings.
  162. Bridgport right angle head, how to rebuild
  163. When you need to drill a hole ... on Mars
  164. Nuts! To me! (and springs, washeres, bolts, threaded rods and so on so forth)
  165. where do you buy HSS end mills?
  166. Working Hands. Mine got beat this week.
  167. Help identify this South Bend lathe
  168. Acute Tool sharpening
  169. Dial caliper out of whack...
  170. Getting rid of some stuff
  171. Electrical help...need help with grounding..
  172. Check your nuts (slightly OT)
  173. Shop Pictures
  174. My new mag drill, what lube and how to get spindle off?
  175. [I hate wires] Heating Element Question And Heater Circut Education Requested
  176. I want a thread dial
  177. Cleaning up the shop
  178. Annealed W1 drill rod for shaft material?
  179. Polishing Cast Iron Parts
  180. Making very small, oddball thread, flathead screw
  181. casting lead weights
  182. Grade 9 bolts any knowledge out there
  183. Somewhat OT: Infrared heat for a shop
  184. Accidently mixed motor oil
  185. How much does your spouse know about what you do ?
  186. Loupe advice needed.
  187. Congrats DICKEYBIRD!
  188. OT- Roof Ice and Snow Breakers
  189. The HSM magazine for Nov/Dec 2015 is excellent
  190. Anyone have a Lisle 91000 Drill Sharpener? Need dimensions for a part.
  191. Oil for Oilite bushings/bearings?
  192. insulating block garage help
  193. OT: Changing Engine Oil
  194. Supermax YCM-40 CNC Mills
  195. Building a tapping arm
  196. making a humble shaper crank wrench
  197. John Foster
  198. Interesting videos of clock and tool making
  199. machining spiral threads in the face of a rod
  200. What do you do whenthmach e ine shop is closed?
  201. super spacer question
  202. [I hate wires] Further troubleshooting assistance needed -- 3D printer circuit
  203. 3phase
  204. Dumore grinder Brush Holder Fix
  205. OT - Freddy Fabris: If the Old Masters were Painting Today
  206. Lathe identification
  207. Need quil return spring Grizzly G3617
  208. OT: Those dual plunger epoxy dispensers (that don't work very well)
  209. Unusual Grinder
  210. Older machines gone to the great scrapyard in the sky
  211. £5m in Bobcats/JCB's
  212. Follow rest question?
  213. Test bar is it worth it?
  214. Broke the Bridgeport
  215. Hmmmm... that's one way to do it!
  216. cheap high pressure fluid pump
  217. Gear Tooth Finish???
  218. Anvil base ( stump) questions
  219. Where to obtain delrin
  220. OT: Gargage door torsion springs
  221. I need some 1/2" and 5/8" TG&P.
  222. Spreadsheets for Machinists
  223. Question: Moulding recycled HDPE.
  224. End mills--2 Flute vs. 4 Flute
  225. O.T. do induction motors run hotter than regular ones?
  226. manual - a comment
  227. Made a backplate for the ER40 collet holder
  228. Ot Water.
  229. DoAll Air Pump/coolant line "adding coolant to the air" ???
  230. Food Safe Sealer
  231. OT kinda gloat
  232. Advanced Math question
  233. Motor failed
  234. Adding a gantry to my fixturing table
  235. forsale postings?
  236. Way, way OT: incident at St. Pancras Station (London)
  237. Tapping for pipe thread
  238. Epiphany - I should get a lathe - which one?
  239. Semi-OT; enclosed trailers
  240. vfd help
  241. the All Blacks are the greatest!
  242. Modifying my small power hacksaw
  243. [I hate wires] DaVinci JR RFID Chip For Material Spool
  244. dual reading micrometer
  245. Getting organized with my weekend auction score.
  246. carbide tip clamping styles
  247. Anyone have an extra set of 1" blade guides/blocks for a DoAll?
  248. O.T. of GMO's
  249. Pinging: R.Bolte.Jr
  250. Clapper box wanted for Drummond hand shaper.
