View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 [243] 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Aloris Boring Bar and Insert Style
  2. Core drilled granite in ancient Egypt
  3. Week-end project
  4. Newbie Checking In
  5. gun drill bits for sale.
  6. the infamous jammed gib stuck table problem strikes again
  7. Er style type b 25 collets
  8. Parting insert tool for my AXA Aloris type holder
  9. Oil or chalk on files
  10. Enco again!
  11. Unimat SL1000 buying advice
  12. Tapping case hardened steel?
  13. Need recomendation for book on understanding CNC machining
  14. Hydraulic shaft cleaning question.
  15. idea for surface grinder
  16. Aluminum Industry going through changes
  17. Mill rpm RPM for a Dummy
  18. OT transparency of a moose
  19. Got in some rotary table action today.
  20. Diamond lapping scraper carbide
  21. fly cutting vs surface grinding
  22. Antares Explosion Report Released
  23. Three Phase Wire Color Code ???
  24. Small tig welder
  25. What is this thing (automotive?)
  26. Bridgeport 815 surface grinder manual
  27. Colour case hardening.
  28. best bench top mill to buy
  29. Tool Gloat!
  30. Lathe size vs. quality
  31. Another "what is it" post...
  32. OT Printed Ckt Board Question
  33. O/T- Stainless steel protective plastic film removal?
  34. machining an arc.
  35. Acorn Thread Die
  36. Direct drive servo gloat
  37. Bridgeport Mill dial division increments
  38. Anyone know "tattoomike68"?
  39. Impressive lathe demonstration, or just marketing hype?
  40. OT: A video of my blind dog working sheep
  41. Lathe motor problems
  42. Well I got one - now what should I build with it?
  43. OT: Should I be miffed about my PHD?
  44. Seeking opinions on this lathe (Colchester Bantam 1600)
  45. OT- could use some suggestions for a shadowbox displayfor a old friend's WWII stuff..
  46. Help Pick First Metal Lathe
  47. put me out of my misery guys.
  48. Another flycutter question
  49. another great deal on ebay or not ? so do these buyers have money to burn or what?
  50. POS Bridgeport with POS CNC for sale... have question.
  51. Not sure what these are or how they are used
  52. Engineering is hard work - furnace update
  53. Semi OT: The Man in the High Castle machine shop scenes?
  54. autodarkening welding helmet won't stay dark. Theories?
  55. Socket Holder for the Big Dake&Greenerd
  56. In the event yours is malfunctioning...
  57. VIDEO: Fixed Gantry CNC Router build
  58. Great ENCO sale! 25% Off plus Free Shipping!
  59. FS 24" metal cutting band saw for sale
  60. adjustable chamfering milling cutter
  61. How to turn an angle - NOT a taper
  62. Threading a cone
  63. Where to mark centers
  64. Mystery Thread
  65. Best place to cut this beam
  66. Got me a vise
  67. Help identifying this metal
  68. A short DRO story---
  69. What type of Boring Head is this!
  70. OT... Could really use som help with hybread Lexus
  71. Grind Tapers, Centreless Grinder
  72. Mag Base: Grip Strength Restoration / Enhancement
  73. Enco
  74. Horizontel Band Saw Blade Question
  75. OT: Another reason to hate Windows 10
  76. small gloat
  77. Brown & Sharp No 2 Horizontel Mill
  78. Snow Blades who plows and what do you use ?
  79. Question about unknown model "TREE" milling machine head
  80. help understanding drill rod dimensions
  81. Hub Puller Design
  82. 7xXX MAX Work Diameter
  83. lathe chuck jaws
  84. Waltham Pinion Cutter
  85. Retaining nut wrenches, or how to save wear and tear on the cold chisel
  86. OT- Web address prefix
  87. OT Credit Card Scam
  88. Which SS sheet will machine and form best
  89. Mini shop
  90. OT Enjoy your friends, my best died this morning!
  91. Die filing machine
  92. Can you believe this $&$#@@!, I had a STROKE!!
  93. Stick with AC motor or go with DC motor and controller?
  94. Level adjustment problems
  95. GRIZZLY 10x22 G0602
  96. 8" wide wood plane, a little distraction OTish
  97. Band saw blades and Wellsaw 8M
  98. Are we the last of the buffaloes?
  99. Slightly OT - sheet metal bend allowance
  100. ER collet questions
  101. Radial arm saws revisited
  102. OT: Pressure washer saver
  103. Recommendations for surplus/scrap/scrounging in Portland, OR.?
  104. TG vs ER collets
  105. A blast from TV lands past for the older members in the US and Canada
  106. OT led efficiency
  107. OT: New TV off gassing
  108. OT The Beck's Machine Shop interpretation of a high bay LED shop light
  109. OT: windows 10 spyware fix
  110. Beam and Trolley in home shop
  111. Specialized depth mic
  112. Truck bumper repair - 1989 Toyota 4WD pickup
  113. OT Wooden Gear Clock
  114. Locating Hot water tank leaks
  115. OT Facebook wants you to send them a governemnt issued photo ID?
  116. Steptoe Shaper 14"
  117. Looking for plain steel Whitworth hex stock
  118. Magnetic cloc kescaperment
  119. OT Machines and Armed Forces
  120. Test bar thread followup
  121. Craftsman / Atlas lathe
  122. Centering on existing holes in "adverse" conditions?
  123. stainless bending
  124. Tons & tons of fun! Volunteer welcome!
  125. lathe headstock alignment.
  126. Some stuff I recently completed BEFORE having the stroke.
  127. Phase Converter Question
  128. Enco 15% OFF & Free Shipping!
  129. More stuff completed BEFORE the stroke
  130. Asian HLVH clone??
  131. Inherited my fathers lathe but I need help
  132. OT Internet connection
  133. The mysterious properties of red mercury
  134. homemade parting block.
  135. immigration
  136. 14' Rockford Lathe Parts
  137. Question about milling machine and end mill
  138. Holding ball bearings in a lathe
  139. Mobil dte heavy medium?
  140. Holding a thin bar for shaper work.
  141. Bridgeport 815 spindle taper?
  142. I won the bid for this lathe. I think this quals as a you suck
  143. OT almost; Paul A's battery article
  144. This Week's Auction Suckage
  145. Milwaukee abrasive chop saw, happy ending
  146. OT: Drilling CS Holes Near Edge of Plywood for Screws
  147. My 1st project, AFTER the stroke.
  148. OT: HP printers and ink.....ripoff?
  149. Ras mod
  150. A sincere thanks to you wonderful people.
  151. Machine manuals
  152. American Pacemaker apron rebuild
  153. OT Free scan.
  154. Gang Drill 60" Swing
  155. Quick change tool post size for 1024 & 1340 lathes.
  156. Accurate Small Hole Machining!!??
  157. What Are All These Processes ???
  158. Steel selection
  159. Tripan 111 QCTP
  160. School me on micrometers
  161. DIY Waste Oil Heat
  162. OT Tractor Batteries 6V Series vs 12V Parallel
  163. replace bronze bushing with delrin ?
  164. I don't know what it's called.
  165. Enco free shipping, truck & ups
  166. OT- Browser for Mac
  167. Site Outage
  168. ENCO Milling Machine Parts
  169. Finished my slip roll....
  170. Looking for a replacement compressor
  171. sold works
  172. Please help me price this lathe
  173. Happy Thanksgiving
  174. Publication: Shop Made Tools - 2015
  175. Reducing Lead Screw Backlash
  176. Blue Origin landing?
  177. Starboard HDPE foam board?
  178. The madness... it begins.
  179. Machine Rebuilding class in Vermont
  180. Honing a bore
  181. Opinion on two DROs
  182. Digital readout for hinge type joints?
  183. Help identifying collets
  184. Propane/Gas generator deal!
  185. enco 25% and free freight
  186. Finally got around to it...
  187. what's it wirth?
  188. Summit 20X80
  189. Wellsaw M8 paint and rebuild
  190. What Dial Indicator spec. is best for tramming ?
  191. Holding 6" heavy disc on lathe
  192. Blower fan design help!
  193. DRO is in pieces...
  194. Internal (or infernal) gear info needed
  195. OT- Virus Protection for Mac?
  196. Who is a clock maker?
  197. Bread Ties................. The Next Generation ???
  198. Another project finished
  199. O.T. Suzuki 660 engine in Cushman truck
  200. Help me buy a new DRO
  201. OT- kiln brick
  202. RF45 clone help please
  203. Tons & tons of Fun!
  204. ot: t8 light fixtures
  205. Mounting 4 jaw to rotary table
  206. Fancy candlesticks for Christmas?
  207. Work bench material...
  208. Another ENCO 25% off & free shipping!
  209. I needed a surface grinder today.
  210. Lathe Tool Post Fitment Question... She don't fit!
  211. Indicator attachment help
  212. Value of Past Issues of Home Shop Machinist & Machinist's Workshop
  213. Spider bites, in the uk! Very very OT and odd
  214. QCAD Any thoughts?
  215. Zoro up to 30% off & free shipping!
  216. Surface finish on annealed steel
  217. Plastic cutting boards as stock
  218. Horror fright rapid pump floor jacks - anyone have one?
  219. Tachometer for Manual Milling Machine
  220. Sad News
  221. help with powering my new lathe please
  222. Compressor Repair Advice Sought
  223. Tribute to an ole friend
  224. Replacing Wipers
  225. Impressions/add-ons Mini/Micro mill [long]
  226. Hydraulic jack question...
  227. Larger lathe = better finish?
  228. Layering and galvanise...
  229. Electrical Connection Help ???
  230. Moving a Series One Bridgeport with a pallet jack
  231. OT would you, can you powder coat M/C spokes?
  232. Brass plating????????
  233. g0704 dro question
  234. Aluminum Threads
  235. diamond wheel recommendation for making carbide reamers
  236. Hendey Songs of WW2
  237. Hendey factory tour 1943 link
  238. OT No slam high tech toilet seat hinge
  239. OT No slam high tech toilet seat hinge
  240. Holbrook B 8 Lathe
  241. JMay lathe purchase
  242. Scraping and Rebuilding class Near Washington DC in Oct of 2016
  243. Pennzoil Synchromesh
  244. Disassembly of One Shot Lube System
  245. https://www.glacern.com/deals
  246. K-1 Kerosene alternative
  247. Now the mill motor needs repair
  248. A gear cutting question
  249. Nachi Drill Bits Any Good
  250. Screwless vise fixed jaw threaded holes
