View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 [245] 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Arduino indexer problem
  2. WTB Kurt D60-4-SA Swivel Base
  3. Brutish 4 jaw chucks and/or more creative workholding in the lathe
  4. It's New Years Morning
  5. Dies for manual punch press-Di-Acro#2
  6. Opinion Of Bolton 3 in 1
  7. Hardinge turret lathes?
  8. Mini Lathe Tailstock Alignment
  9. O/T Engine hoist mod.
  10. 3D models for free
  11. ISO 4" no. 3 Phillips screwdriver
  12. wooden molds for casting aluminum ??
  13. LUX-Matter 1640 Lathe Front Panel
  14. Any New Year 2016 Plans, Resolutions, Etc?
  15. Common tool feed rate
  16. Servo 140 Repair
  17. Retiring my Bridgeport - Deckel FP1?
  18. Bandsaw blade speeds...
  19. Numbered drill bit stands
  20. OT- LED tv issue
  21. Bodgers Lodge.
  22. Cheap shop press...
  23. Contour Sawing 1-1/4" Plate with power feed on 1950 Doall
  24. OT use for projection tv
  25. Help with Hendey
  26. A bit pricey?
  27. Enco 109-1005 Combo Question
  28. Bandsaw rpoject (again...)
  29. First Event of 2016
  30. OT New year's project
  31. Small 3D printer on sale cheap
  32. Source for flanged square head screws/bolts?
  33. HSMXpress anyone? (2016)
  34. Question about plastic gears
  35. Cabin Fever
  36. FrogLube
  37. Adjustable Angle Block & Mill Set Up ????
  38. How to get metal id'ed?
  39. How to securely fasten handle
  40. Need help choosing a VFD for vertical mill
  41. OT: RIP David Balme, recovered an Enigma from a U-boat in 1941
  42. DoAll Blade Guide Modification
  43. ACME Insert
  44. Wooden rubber band guns
  45. Anyone familiar with motors for Victor vertical mills?
  46. Heated Stair Treads?
  47. misting systems
  48. Help with aluminium casting
  49. Stock storage - horizontal or vertical ?
  50. Any one ever see these Gardner Disc Grinders
  51. Bandsaw project
  52. another project - poshin' up an old drill press
  53. Drilling to radius point on curved surfaces.
  54. Recommended Seller of Niagara End Mills?
  55. Milling machine rotary cam switch
  56. questions on tooling up a sherline 5000 mill
  57. Outside Jaw Info – 5” Cushman Chuck
  58. Identify Albrech chuck
  59. Walker Turner Drill press electrical Help needed
  60. Boring with an Emco FB2.
  61. Abrasive cabinet in the shop?
  62. Friction Drilling carbide steel?
  63. OT, sort of: an amusing solarmotor from over on PM
  64. Weldon shanks on milling cutters - all inch sizes, or some metric?
  65. Installing 42" Backup Spar Question
  66. Why so many threads!
  67. Switching timer
  68. Threading die question
  69. Passing the torch
  70. metal supermarkets?
  71. starrett oil harding steel how to mill
  72. I get all the good jobs!
  73. OT: remotely resetting a gas central heating system
  74. ot: remember me
  75. Making new lead screws and nuts for a mill
  76. Anyone have the EMCO Maximat??
  77. Change wheels for metric
  78. Used for?
  79. BLDC & Micro drill project.
  80. Anyone Want some vacuum Tubes? Free to a Good Home
  81. Windows 7 Professional Arduino won’t upload
  82. Alternating end mills?
  83. Interrupted Cut Parting
  84. Heat treat oven
  85. Milling machine, what is it?
  86. Tool Gloat
  87. OT: a welcome surprise
  88. DIY pulley balancing?
  89. OT: For those interested - Comet Catalina
  90. ER 32 collet chuck or draw bar style for my bench top lathe?
  91. Bush fires in Australia with entire town of Yarloop destroyed...
  92. Suburban Tool Video Series
  93. Installed a Tachometer on my mill
  94. Sturtevant Richmont 20 Nm torque wrench.... wanna trade
  95. OT- what to do with cable box
  96. Maximat V10-p follow rest
  97. 3D print Quality improvement
  98. Lap arbor/platen design help
  99. Problems parting-off, solutions
  100. My CNC Router VS Steel
  101. Arranging a New Shop With All My Crap
  102. Shop Windows and Security Issues
  103. Advice on hooking up Teco FM-50 202 on mill
  104. OT: Slightly off topic, SAD lighting
  105. Pre-bent brass tube source
  106. Lubricating a mill spindle? Oil? Grease? Seals?
  107. Mill lighting
  108. value of a south bend 10K w/ underdrive
  109. Adding I-gaging DROs to x and y axis of HF round column mill/drill
  110. "Can't stay logged in" gets weird...
  111. Good write up on the ole SR-71
  112. Dealing with heat treat scale
  113. Y Axis Lock on My Lathe?
  114. Key question Please:
  115. What steel should I use for an automotive king pin?
  116. OT - useful units converter
  117. Steel plate welded to aluminum T-slot extrusion
  118. Mystery metal post - what is it?
  119. VFD?
  120. Pillar drill return spring
  121. OT- LED Tubes?
  122. Small table saw cuts metals - excellent results
  123. Enco 15% off
  124. Solution time for A356 to T6
  125. Can a Barber Coleman #3 or 6-10 cut a worm gear
  126. Powering small squirty tubes
  127. Anybody been inside a Logan lathe spindle?
  128. My new rotary table came in!
  129. Material Supply Source
  130. solar panels
  131. Induction Bearing Heater Idea
  132. OT- A Little Mac Help?
  133. 3d printer machinable wax lost wax metal casting
  134. Enco free shipping code for January 2016?
  135. Harrison L5a
  136. junkyard belt grinder build (2" x 72")
  137. Hf qctp
  138. OT-Switch Wiring
  139. Reducing T-slot Bolt Shank (without a lathe)
  140. See what's possible with 3d printed gears. guy makes a tourbillon "watch" movement.
  141. OT- I found Boslab a job!
  142. OK, now I bought it what to do with it?
  143. Can't find a thread - plasma table build
  144. O.T. what is this ?
  145. Albuquerque NM March Rebuilding class looking for Host Shop
  146. Mill vise evaluation
  147. quality M3 collets
  148. Atlas 7B Shaper part needed
  149. Broken oxy gen machine
  150. First try at thread cutting
  151. OT - Sears 1 hp Compressor Motor Bearings
  152. O/T Would like an opinion, fact. Full frig or empty. Whats more efficient?
  153. Lathe Power Cross Feed
  154. Help Identify "Metal Removal" Brand Endmill
  155. C-C distance gears. Pressure Angle
  156. Cutting stainless
  157. cutting a drive worm gear on a lathe
  158. Help Identify a dividing head
  159. Clutch on lathe power feed shaft
  160. Question about inertia effect on impact???
  161. OTish - Wood Mitre Saw
  162. Have there been intermittent site outages?
  163. OT: Goofy NiMH batteries
  164. Problems with Gould Motor
  165. Table Top Milling Machine Recommendation?
  166. I need steady rest help
  167. Way O/T
  168. Lathe Bearings Leaking Oil
  169. O/T: TV show. wood carver Mary May shows some cutting tool sharpening.
  170. ER40 collet chuck followup
  171. ER40 collet chuck followup
  172. Good 60-degree Double Angle Cutter Recommendation
  173. plastic machining melting problem.
  174. 2016 N.A.M.E.S. Expo, info flyer
  175. OT: 3D printing forums
  176. OT: European expression of measurement
  177. Chuck material holding question
  178. High quality small upright metal [steel] band saw?
  179. Beveled Angle Width & Depth ???????
  180. Looking to have a small milling job done.
  181. SouthBend 9A collets
  182. Element wire
  183. This site specifically blocked and ONLY this site?????
  184. 3D Printer People! Click Here!!!
  185. Help needed to identify vintage wrench
  186. Bridgeport rattle in head when taking heavy cuts
  187. Where is that wrench??
  188. Deckel lubrication
  189. Compass binnacle
  190. Learn Me About Diamond Nibs.. Everything I Ever Wanted To Know But Was Afraid To Ask
  191. OT.... Any good ideas for organizing pieces and chunks of wood?
  192. 4-Jaw chuck for rotary table
  193. Penetrating oil
  194. NSK Spindle Gloat
  195. Milling Attachment for Lathe
  196. Rubber belting
  197. Problem with new 7x12 TurnPro bandsaw
  198. Cabin Fever
  199. OT: Toilet tank sealant question
  200. How do I reduce the end play on my compound slide screw?
  201. Oversized bronze bushings.
  202. Cabin Fever Photos/Video
  203. Dividing head question
  204. A case for made in USA tools
  205. Belt sander. Which one to get?
  206. Hardinge DV 59 Lathe Worth it?
  207. OT: Computer art - photos of old computer hardware (much of it mechanical)
  208. ot Hydraulics, water in them, get it all out now.
  209. OT: Having a Nice Day (Rubbing It In)
  210. OT: Star Wars, the movie, did you like it..?
  211. Another take on the quality of tools.
  212. 20% off ENCO Today only!
  213. Troyke DMT-18 15" x 15" Cross Slide Rotary Table questions?
  214. Counterbores
  215. Semi OT: Incredible model
  216. SW MI Home Machinist Club Meeting Notice swmichhomemachinists@gmail.com
  217. Enco 15% OFF & Free Shipping! Today only!
  218. Removal of Wheel Flange on a Baldor Tool Grinder
  219. Mold Star -90 Material
  220. southbend Lathe 9"
  221. drilled holes out of place
  222. Spindle Nose Thread on HF 12x37 Gap-bed Lathe
  223. solar panel ideas
  224. Looking for a particular article from many years back
  225. outboard spider for my lathe
  226. what is the best stuff too lap gears in with
  227. An interesting tiny tool vendor
  228. Drill chuck with slight burr in taper
  229. PC starting system, any comments?
  230. T&C grinder way oil??
  231. Air compressor run capacitor
  232. O/T improvising
  233. Spotting Drill Lesson Needed
  234. the effect of heat on steel
  235. The use of a fixed steady.
  236. Easson DRO Question
  237. Sort-of-Review: XHC Manual Pulse Generator
  238. OT. DIY telescope question (Evan, Macona ?)
  239. Kawasaki keyless chucks
  240. Battery question?
  241. Atlas cross slide malfunctioning
  242. Broown and Sharpe #7 Tool Holders
  243. They Make Them Tight in Sweden
  244. Buffer, my lastest project
  245. Holder for those pain in butt allen wrenchs
  246. ENCO 20% OFF Today Only!
  247. NEWB Question Trueing up a compound base?
  248. Home made screwless vise drawnings?
  249. Somewhat off topic, Just NOT businesslike !
  250. Enco horizonta lbandsaw
