View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 [247] 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Added springs to an old smoker trailer
  2. Atlas Press Company, Kalamazoo, Michigan
  3. Some local 15 minutes of fame and recognition
  4. Cheap $8 induction heater and Cherry Red case hardening compound
  5. CAD - What Co-Ordinates to use?
  6. Gasket Ideas
  7. My son, the inventor
  8. Pratt Institute Power House Visit Yesterday in Brooklyn NY
  9. BIG Power Outage: Off Topic, OT
  10. O/T: Inexpensive shipping. Not looking for advice.
  11. What the heck happened to the forum yesterday?
  12. Making wood chisels from scratch?
  13. Cut a key way inside small bore?
  14. Motor fully size for Craftsman/Atlas 12 inch lathe... I want to make one
  15. California Air Tools
  16. Anyone sharpen their own endmills ?
  17. 304 Stainless
  18. Linux Mint hack
  19. Printer repair experts? HP C7280 issue
  20. O/T Automotive relay
  21. micrometer accuracy
  22. "Lumber liquidator" and "60 Minuts"
  23. Drill presses for sale!But not to you guys.
  24. OT Shipping Container Hold Down Pockets
  25. O/T squawking a fake ident?
  26. ENCO 20% OFF Today Only!
  27. Any idea what this is?
  28. New lathe - Photos and thanks!
  29. Tooling
  30. The Effects Of Knurling On Small Machines
  31. My Minute 24 of fame
  32. OT- Holy crap, I won't be buying these fer a bit.........
  33. RC aircraft/drone registration
  34. Adapting an Overdrive to Four-speed
  35. Installing AN386 Taper pins
  36. Max-Turn turret lathe?
  37. Help a total noob with his measuring technique (rebuilding vintage turbo Porsche)
  38. Magnetic filters for coolant
  39. Going To Try Parkerizing - Will this Work _ Possible Gloat
  40. Layout of equidistant points on the out circumference of a workpiece
  41. Verifying accuracy of a dial bore gauge after a short drop
  42. propper roughing mill use?
  43. ENCO 20% OFF Extended!
  44. Recommendations: 2 piece Jaw vs Reversible
  45. Left handed twist drills
  46. Ceramic ABEC 5 Bearings - Nice right?
  47. Brass angle iron
  48. Crazy Imperial Thread
  49. what bronze is best for a bearing
  50. MN and MA Scraping Seminars next summer - 2016
  51. A tap and die set for discrimating Machinists
  52. Size progression when drilling large holes on a lathe
  53. OT large storage/transport container
  54. ENCO 20% OFF Extended Again!
  55. Lathemaster: belly up?
  56. Couple of door handles (machining content)
  57. KO Lee surface grinder ??
  58. Mini Multifunction machine < $300
  59. MSC Customer Appriciation Day up to 30%off/Free ground shipping on $299+
  60. Toolmaker's angle plate question
  61. Shop vac/cyclone question
  62. Brass stock in the Philadelphia area?
  63. Extra holes in drill press head?
  64. It was way past time for a new stand.
  65. New SB 10K Lathe <$4K - worth it?
  66. Indicating quad flywheel for lightening
  67. New To Me Hammond #4 Grinder
  68. Idea for automotive "Stop/Start" system
  69. Expanding mandrel sets
  70. Help to ID. DECKEL
  71. IS ANYONE SUCCESFULLY POSTING USING TAPATALK wITH AN IPHONE 5S?
  72. Reeves Drive Types
  73. Up for trade - Brown Sharpe 3-4 Micromaster outside micrometer
  74. Shepard Lathe Co.
  75. Drilling a 6 sided hole
  76. Learn about Slitting saw
  77. Motorcycle Dyno Run
  78. O/T old craftsman power tools
  79. Boring bar geometry - increasing rigidity
  80. Brown & Sharpe #2 Surface Grinder ??
  81. 4140 annealed - how is it?
  82. what is it? (toolholder)
  83. Found a Mill
  84. Thoughts On Truing Up Vise PT II
  85. OT: Rope hook welding
  86. Pittsburgh Digital Micrometer
  87. Beverly shear stand
  88. Fun with homebrew induction heater
  89. Rolling tool cabinet project
  90. What's next?
  91. Hyd press accessory question.
  92. Rambaudi milling machine
  93. Motor drive for lathe feeds?
  94. WTB Logan 6565 Lathe if anyone knows where one is for sale!
  95. South Bend 9J Carriage lock
  96. Do BALAX taps have a good reputation?
  97. Hex Broach through plastic
  98. WHY?? Or Why Me
  99. _ An Arduino control tablesaw sled powered by an air piston...
  100. Vortex Cold Air Guns ??????
  101. OT- Serpentine belt with high friction OD?
  102. OT - Photobucket Problems
  103. Enco 25% OFF & Free Shipping! Today only! This is a good one!
  104. Pen plating
  105. Pressure Cabinet Blaster up and running- Thanks CCWKen
  106. Oil metering fittings?
  107. Heidenhain VRZ - anyone familiar?
  108. No mar work holding idea for lathe , etc
  109. Shars
  110. Sine table out of a magnetic chuck
  111. Clean End Milling
  112. interesting vid on how to build a magnetic chuck
  113. New-to-me Schaublin 13
  114. Help with magnets
  115. Moore Jig Borer Model 1
  116. Shop made parts for a Dixi mill
  117. Cylinder Boring Machine
  118. If you like gears and levers, and a machine that plays music with ball bearings...
  119. Hard drilling old cast iron vise for new jaw.
  120. 5/32 end mill with 5/32 shank??????
  121. Need Help with Harold Halls Grinding Rest
  122. A question about steel classifications for the Brits.
  123. Note to George: Novakon addvertisement has bad link
  124. Optimum Lathe Speed Range?
  125. Make a female thread for a 2 liter Pepsi bottle male thread
  126. my mentor passed
  127. Some Days...
  128. Looking for a good machinist vise for my lathe....
  129. Dynamatic Variable Speed 1 ph. wiring info help
  130. Atlas lathe again
  131. Ne member presentation from Bulgaria, Sofia
  132. ENCO 20% OFF & Free shipping!
  133. Schaublin 13 owners? - need help disassembling
  134. OT, switching ISP, how to keep old email address....
  135. Question about Glycerin filled gauges
  136. Buffalo drill press refurb
  137. Sharing a VFD between two machines or more..
  138. Slot Screw with Lathe Cross-slide/Hacksaw Blade, Atlas 618
  139. Lathe Chuck Backing Plate Problem
  140. What's Up With Copper Wire These Days ????
  141. how to buy a surface grinder
  142. What to do with mystery metal that is too hard?
  143. Threading upside down with threaded spindle
  144. OT: Atlas Robot
  145. Alibre / Geomagic got better
  146. OT, Anyone familar with Dell laptop chargers?
  147. berring supplier?
  148. Help with identifying French made tool grinder
  149. Measuring Threads
  150. OT door bell
  151. How Long Before Carbide Cutters Chip for You
  152. Small carbide end mill speeds
  153. OT: Winter Brush Burning
  154. how to dismantle a keyed supreme drill chuck?
  155. Rotary Table Help...
  156. "Lighting for your Mill" What do you have ?
  157. Lathe/hand slotter
  158. It: re anti freeze
  159. Resurecting a Worthington pump from Civil War ironclad, the Monitor
  160. Face Plate Setups
  161. glowforge
  162. Carbide end mills, again but different question.
  163. Just for comparison
  164. Is a 5C collet chuck too heavy for a Southbend 9" lathe?
  165. Howdy, new guy from Central Texas here
  166. Largest Lathe Appropriate for Apartment?
  167. Enco 15% off
  168. Using backgear locked to remove chucks.
  169. OT keep seeing it. What is Tapatalks advantage?
  170. Wiring a 3 Phase Motor
  171. Over the Top Ball Turner
  172. Gearbox for rotary table
  173. Adding front table support to an Atlas shaper?
  174. Rockwell 21-100 No Brakes!
  175. Drum switch and motor wiring question
  176. Possible tool brag incoming.
  177. Broken compound
  178. Odd chuck
  179. Tom Lipton's day job - Lawrence Berkeley National Laboratory - NYCCNC
  180. OT: New camera
  181. Digital Caliper feature questions and possible Ebay counterfeit Mitutoyos
  182. ferrous chips and magnetic bases - SHEESH.
  183. Schaublin 13 - VIDEO
  184. Broach 1.25 Hexagon Internal through 3 inch thick UHMW????
  185. OT Speed Limit Sign
  186. WAY OT: Where are all the temple oranges this year?
  187. A light for my welding helment
  188. ENCO The more you buy, the more you save sale!
  189. Vintage Mystery Lathe ID?
  190. OT Win 7 memory limits in 2 processor system?
  191. Tool Post
  192. OT? I HATE Painting
  193. Good, second-tier measuring instruments?
  194. MSC Wonders Why I don't Buy From Them
  195. Sump pump
  196. Another what is it (Skully Jones? MT3 collet?)
  197. Bridgeport clone lubrication?
  198. OT somewhat. Reality TV & Electrical generation
  199. Shop made way covers?
  200. Recommended things to see in or near Green Bay Wi.
  201. Slitting Saw Feed and Speed
  202. Paint removal recommendations ?????
  203. Gain Pitch Thread article - HSM March/April 2016
  204. Need help getting authorized
  205. Help me set up my bench grinders.
  206. Five lug spacer how to darw it in fusion 360?
  207. Need Help With Fusion (non-nuclear) (Fusion 360 troubleshooting)
  208. Looking for decente deal on R8 Keyless Chuck
  209. Tundra drain plug repair...
  210. Compound Slide Screw Pitch For Webb/Whacheon Lathe
  211. Hardinge Friday torment
  212. Show me your T... slot covers!
  213. Homemade Metal Brake Plans
  214. Addictive Hobby # 3, sewing machine taps and dies
  215. Atlas lathe stuff question
  216. hydraulic piston slipping
  217. drilling D2
  218. H6 tap question
  219. broken 4-40 screw in a Starrett height gage
  220. Running in reverse with screwed chuck.
  221. Shars Universal Cutter Sharpener: Any Good?
  222. Farrell 90T lab press questions
  223. Did Walter Mueller publish an article on surface grinding attachment for SB7 Shaper?
  224. Can you identify this Radii Cutter
  225. Attn: Rich Carlstadt and anyone interested in shallow draft steam vessles
  226. APKT 1003 vs 11T308
  227. QCGB Belt drive intall
  228. OT- leds again
  229. Where to find way wipers?
  230. Making key blanks
  231. ENCO 20% OFF Today Only!
  232. What is a Rockwell Univise?
  233. Gear Noise
  234. tiny robots for rearranging your shop
  235. Ball bearing selection for drill press
  236. Dissimilar Metals and plasma cutting questions.
  237. Score? Overbeck Sensitive Drill Press
  238. Magic, anyone??
  239. OT, cable kits
  240. Improving the Mazilli quasi-Royer induction heater circuit (A bit techie)
  241. Looking for a good coaxial inidcator
  242. Another co-axial indicator question
  243. Dividing head is splitting mine
  244. Gloat: two hydraulic hose crimpers
  245. Looks like a deal...
  246. New way to remove rust
  247. Cutting a 57 tooth gear
  248. Quorn grinder spindle pulley - do I really need a key?
  249. interesting video on flap disks
  250. Found use for neutral position in two-speed tailstock
