View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 [248] 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Do you know what this means (lathe plate symbol)?
  2. OT- Mac Bandwidth Monitor
  3. Forum Question
  4. OT: Telemarketers and Cell Phones
  5. Coupling, How would you build it?
  6. A question for the metallurgists
  7. OT, maybe: Backup camera for my truck or car...?
  8. Vertical Turning on a Mill
  9. Ez Weld tig wire for cast iron
  10. Is cobalt is a carcinogen?
  11. Homebrew CNC: What about limit switches?
  12. Happy St Patty's Day!
  13. Enco sales
  14. ENCO 25% Today only!
  15. I see that Scrapbinium™ is trade marked...
  16. trying to match up a small spring
  17. My air compressor has diarrhea
  18. Waaay OT garden hose
  19. Luna's revolver build
  20. 3D printable material question: Any electrical grade materials printable?
  21. Re: "...abusing...the noob"
  22. OT: Wind Farm Transmission Lines?
  23. Your old pal BIG AL
  24. OT, Portable Two Post Lift Dimension
  25. Gloat maybe?
  26. OT - Forward or counter rotating tines on rear tine tiller.
  27. Grinding wheel
  28. Need lower speed on 5 speed drill press
  29. Clumsy B*stard Is Me
  30. Slightly OT: Scaling up material
  31. material for axle shaft
  32. DRO glass scale question.
  33. O/T: TV show. Big fix Alaska.
  34. OT Jack shaft or cross shaft or ?
  35. OT: Death and taxes
  36. Cheap-o brazed carbide boring bars....
  37. Thoughts On How To Cut These Tapers
  38. Keller Die Filer question...
  39. Paint removal from knurling
  40. Good place to buy single pin gages
  41. Grizzly insert cross reference.
  42. D1-6 plate and chuck woes
  43. Portable Mini Bandsaw Station
  44. Heat bending steel question
  45. a spindle taper question
  46. ENCO Again!
  47. Milling - Depth of cut...
  48. OT: Rooting Smartphone
  49. Need help identifying an electrical component
  50. Old Blaisdell Lathe, about to get scrapped, in Tilton NH
  51. Bad Motor or Capacitor?
  52. Locking up a scooter/cycle
  53. OT: RIP Andy Grove, the 'father' of Silicon Valley
  54. Newb question Profile tool relief angles?
  55. OT? cold traps for vacuum systems
  56. Do all full-size machine tools take the same size tooling?
  57. Question for the clock-fixers & watchmakers out there.
  58. CLAUSING 5913 5914 Vari-Speed Drive REBUILD Q's <---
  59. Small, Quiet Canister Vacuum??
  60. Are small lathes dangerous? Do I need training before operating one?
  61. Surface grinder prices
  62. OT: Read/Program Arduino (Pro Mini) using AVRdude or Atmel Studio
  63. repair an oiling l port??(ball bearing on a spring type)
  64. Enco 15% OFF & Free Shipping! Inscudes Truck Shipments
  65. Odd little gap bed lathe - anyone recognize it?
  66. Does anyone use any particular tool suppliers on ebay ? Not happy with vise shipment.
  67. OT: a very minor tool gloat (almost), but interesting anyway...
  68. Looking for learning...
  69. DROs from DRO Pros
  70. Whoops... I neglected to label some of my steel stock
  71. Neat suggestion for swarf control
  72. Carbide Insert Suggestion Request
  73. Rockwell 21-100 Mill Chip Gurad
  74. Method for machining mirrors
  75. Wire size drills
  76. Clausing Badged Enterprise L made in India lathe?
  77. my bench grinder? Question
  78. Dearson tooling tips carbide ?
  79. Education
  80. Cast iron, first time machining question.
  81. Small tap users
  82. OT- birthday party
  83. New Lathe / New Dilemma
  84. O/T Shaping plywood
  85. Button tools
  86. Using random carbide inserts in a home shop
  87. Flywheel press RPM
  88. Help with this mandrel...
  89. TV in garage ??
  90. Parkson Mills any good
  91. I'm in the market for a Swivel Base for my Kurt 688 I'm in Indianapolis IN
  92. Need a few more tool holders for CXA
  93. Cutting threads on Craftex CX701 lathe
  94. Need to cut 27 tpi threads, and my lathe doesn't offer that.
  95. Home shop metalworker sells these for $45K - $400K
  96. HELP building a TIG setup for welder
  97. OT? Skid steer project.(soon to have machining content)
  98. fabricating new way wipers from F1 felt (McMaster-Carr)
  99. OT casting bells
  100. Plain bearing machine spindles - maximum speed?
  101. Every One use Master Pinion when tighten 3 Jaw Scroll Chuck
  102. OT - Computer Assistance
  103. Interesting adaptable products
  104. Interesting find - What is it??
  105. Calibrating Vacuum Test Gauge
  106. Carriage Bolt holes in 1/8" steel how?
  107. An Artisan Gap Bed Lathe Followed Me Home!
  108. OT, painting galvanized, what is the best way, experiences, tips
  109. ? about air comprendo's
  110. Semi OT: Neat clothing item
  111. ENCO 25% off & Free Shipping! Oh Yea!
  112. "Online Carbide" Any Good?
  113. What aluminum for air compressor con rods?
  114. Gate lock fab
  115. Old South Bend spindle bearing scoring questions
  116. OT What is a washing machine tub made out of?
  117. 3-1/2" striking wrench?
  118. Tiny Gloat
  119. I need a lesson on tap wrenches...
  120. Enco-MSC???
  121. Big Gloat
  122. Tata Steel leaving the UK
  123. Anyone heard from Flyby?
  124. JB weld and stainless steel
  125. Looking for colchester causing parts
  126. Who's going to N.A.M.E.S.?
  127. OT: Fools errands
  128. Tooling score and help with indentity
  129. Shop air line drops
  130. my youngest son is soon going to be thirty and my eldest son forty, advice from Ewen
  131. Built A Radius Turner - Steve Bedair's Design
  132. Question Of Value Of Older Tap And Die Set
  133. Gear replacement fun!
  134. This artist makes mechanical beasties that walk along the beach by wind power.
  135. Question is this a dilema ? or should I just be delighted ?
  136. Can't win can yer
  137. Newbie here- question on old-school locknuts
  138. Shipping Bridgeport Series 1 Mill without Strapping to Truck
  139. boring for a good fit
  140. LCD module test and repair A bit OT , it's a VFD on a machine
  141. Re-purposing Turret Lathe Knurling Head
  142. transfer screws
  143. Vernier scale layout ?
  144. Just found one of my first trade school projects.
  145. (VIDEO) Multimeter Tips & Tricks
  146. Tables of collet dimensions
  147. Snap On now majority owned by HF
  148. Excellent multimeter tutorial
  149. Smash Palace
  150. OT; Windows 10
  151. CW or CCW Direction?
  152. Motorbike choke
  153. Blasting cabinet question...
  154. New Lee Valley Precision Rotary Tool
  155. How do you Make Templates?
  156. A tiny score
  157. Spindle Break-In Process
  158. Reamer Gloat!
  159. What do I call the thing?
  160. OT Are they trying to cram Windows down out through?
  161. O.T. Electrical panel question
  162. poor quality V belts at Canadian Tire.
  163. Using a Morse taper drill to modify a 2-4 Morse sleeve
  164. Power steering noise?
  165. Mac computer with windoze also
  166. Drones Delivering Packages......... Really ????
  167. Two recent welding/fabrication projects
  168. Popular quartz kitchen counter-top risks
  169. OT: problems with self-driving vehicles......
  170. "FREE" WIFI/"hot spots" - problems? Hacks" - how to avoid and recover from them?
  171. Boslab emty your message box!
  172. Heavy flywheel engine for Lawnmower???
  173. Machinist Loses Mind (WARNING: graphic and very sad)
  174. DoAll Table Extensions
  175. Drill Set Suggestions
  176. OT: anyone migrated from Android to Windows phone?
  177. drill chuck arbors - threaded vs tapered
  178. ot Homemade sewer camera.
  179. OT: Camera control software for free
  180. Who has experience machining Titanium ?
  181. 5C emergency collet - hmm .. ???
  182. Adding VAC to Blast Cabinet
  183. 'Tiny' an air cooled hit and miss engine
  184. How to get dents out of round aluminum pontoons?
  185. Everyone always says you will eventually want a bigger machine.
  186. Grizzly g0602 10x22 lathe noisy ?
  187. Stupid Mill question (about cutting a square hole)
  188. Home Shop Hot Dipped Galvanizing
  189. Cut gear rack on 8" shaper.
  190. Painting Hot Dip Galvanized with White Corrosion
  191. What type of plastic do you keep on hand for general purpose repairs?
  192. Glass Scale DRO encoder questions
  193. Herbert Marx, early HSM'er
  194. ENCO 25% Today only!
  195. Hand Tapping Holder
  196. Blanchard Grinder
  197. End Mill Sharpening Fixture
  198. O.T. McMasterCarr
  199. Silicon Lubricants and Grease: OK or Trouble in Shop?
  200. [Automotive Troubleshooting] Do you know what I hate --
  201. metric chucking reamers straight
  202. you take full advantage of your DRO? (sub datums)
  203. Issues turning O1 tool steel
  204. OT- Poly Wheel Barrow?
  205. OT Fake Semiconductors
  206. reduced shank stub drills - exist?
  207. lather man
  208. OT? Sanding Belt Breakage
  209. Type of aluminum for a fixture
  210. Indicator holders
  211. Backplate castings
  212. OT: Just saying hi
  213. How do watchmakers locate for hole drilling?
  214. chromoly 4150 for tool holders / arbors?
  215. Organizing my 5C collets
  216. OT..."Private Internet Access"?
  217. OT SpaceX lands on ship
  218. adjustable reamers
  219. Home brew close quarters grinder
  220. How to put a keyway on an id
  221. Servo mod 80 powerfeed
  222. mcmastercarr
  223. Can anyone explain non-independent 4-jaw lathe chucks to me?
  224. Dayton Alternator power plant.
  225. RPM is good
  226. Properties of Zinc casting formulas
  227. Has Anyone Used These Drill Bits
  228. Small chuck and rotary table
  229. OT: What is it
  230. D1-4 Lathe Chuck Parts Question
  231. How to calibrate a vernacular surface gauge
  232. OT Brag
  233. Stick around folks, the topic is GLUE.
  234. Making holes in checker plate
  235. Semi OT: Have new house with shop
  236. Cut my first functional gear!
  237. Material Storage
  238. Alistair Hosie
  239. Rebuilding an Albrecht chuck with the integral R8 shank
  240. clausing parts
  241. Auction score
  242. 10%/15% sale at Heimingway Kits
  243. Cheap thread milling tool
  244. OT Natural Gas Line Purging
  245. WD 40 Banned In California................
  246. OT: "Fun" with new HP desktop computer, XP Pro, and Win7
  247. Use of Naval Jelly
  248. ENCO Save 15%-20%-25%
  249. Abrasive Belt repair/making
  250. New to The Forum
