View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 [252] 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283
  1. replace nicad drill battery with lipo
  2. Name these inserts
  3. Lathe bore to small for stock need to turn ends Help?
  4. Extension for penetrating oil spray tip
  5. Anyone here familiar/used/have a Heckert FU 250x1000 milling machine?
  6. Outboard Question??
  7. Show your support for our police with light!
  8. Oli can * oiler
  9. Milling Finish, Tramming Issue? Vibration?
  10. Stuck ring gear in 3 jaw chuck
  11. lathe oiler - what's good and where to buy?
  12. Irregular single point thread
  13. Sheet metal shear
  14. newb question. I need to put a center in my 3jaw chuck what are my options?
  15. a visit to Frank Ford's guitar shop
  16. Bronze for way bearing surface instead of turcite?
  17. Face mill. What size?
  18. Turret tool holder tool height
  19. Proxxon MF70 experiences or alternatives?
  20. R8 Quick-change tooling?
  21. Bought a 16" G & E Shaper Yesterday
  22. OT: Air hose fitting types for Europe
  23. 2"npt X 2" fire hose adapter
  24. Yesterday's Tool Holders - Catalog/Specification Archives?
  25. New Zero Turn mower problem, need help!
  26. truing a scotchbrite exl deburring wheel?
  27. Outrageous Acts of Science: The "digital" Sundial.
  28. MSC owners manual
  29. OT Remote access software
  30. some fun with ribbed belt and a flat pulley wheel WHY?
  31. What do you guys make of this I would have thought it would be more complicated
  32. OT: Free Windows 10 - I Figured It Out
  33. Stop me if I'm wrong
  34. What to Glue That Perforated Foam Drawer/Shelf Liner to Base
  35. OT: A new low for robocallers
  36. Lathe support ballast
  37. Source for a drill press table cam hold down?
  38. can I buy an undersized 1/4NPT die?
  39. O-ring reference chart
  40. Fluteless Tap... rolling vs cutting threads
  41. Use a smaller tap as a rougher?
  42. Unloaded a CY Monarch like never before
  43. Ultrasonic cleaner
  44. Meet a total nut case selling my mill
  45. Alternative use for VCGT tip
  46. My shaper made some chips
  47. Who's made their own head tram? Similar to edge
  48. For the love of old machinery
  49. How do you determine the size bit and or radius or chamfer after drilling a hole ?
  50. First time turret run
  51. Considering anathema ..
  52. Shop built universal micrometer (UniMike-Clone)
  53. Three Jaw excessive runout
  54. What type of felt to use for lubrication
  55. I"ve got a dumb little problem---O.T.
  56. parts for a woden vise -OT
  57. Anyone use and leave coolant in their machines?
  58. OT: My new Toshiba Satellite laptop with Win 10, and my borked Win8 tablet
  59. OT: New Use For Shop Staple, Hand Cleaner Stops Itch Of Mosquito Bites
  60. OT - photohosting sites - current recomendations
  61. HSS Tap and Drill sets
  62. OT possibly: Very early toolmaking
  63. OT, belated: New addition to the family
  64. sloppy BXA tool holders from CDCO?
  65. OT galvanic corrosion , dissimilar metals corrosion Question?
  66. XY table - mounting a indicator
  67. Vertical mill suggestion box
  68. Toolboxes for DIE HOLDERS
  69. Die cutting problem
  70. Two ways to balance a grinding wheel
  71. Boring bar as fly cutter?
  72. Craigslist Ad Burk #4 Mill
  73. Vibrating Media Polisher Thoughts...........
  74. Feet for burner grate.
  75. Simple physics question re hot and cold air.. Brayton Cycle engine.
  76. What kind of collet
  77. 3 Phase Questions
  78. Questions for First Time Shaping Flat Bar
  79. particularly dishonest marketing, p***ed me off
  80. Unusual Use of a Shaper
  81. Auction accross the street.. bought something on impulse and dont know what I have...
  82. Ower Wes is famous.
  83. Semi OT; RR & Metal question
  84. VFD just quits
  85. OT? Siting and photos of the extremely rare ringless Goldenrod
  86. Minor tool gloat:
  87. Craigslist Ads Lathes
  88. I made a part for the shaper yesterday.
  89. Winchman is famous!
  90. 18 wire 2 speed dual voltage motor puzzler
  91. belt sander versatility
  92. A man with 2 micrometers never knows the time
  93. Hacksaw baldes Lenox/Nicholson/Bahco
  94. Clock type motors
  95. Another motor wiring question...
  96. Some Non-precision Fun (Aww, Nuts!)
  97. Model sawmill plans or??
  98. gravity feed lube tube
  99. OT skydiver without a parachute!
  100. OT - string trimmer won't run
  101. Need some help identifying a motor
  102. Trim-Sol soluble oil dries to sticky on my cold saw
  103. 3 phase set up question
  104. Flycutter extension
  105. Tool grind for turning a 304 stainless 'octagon'
  106. Magnetic Indicator Base Preference and Why?
  107. I made another boring shaper video.
  108. Noob on the mini mill
  109. What Do You Guys Do For Painting?
  110. OT- An absolute blast!, totally legal at least here, cheap to shoot & so much fun!
  111. 14" Bandsaw trunnions
  112. sheet metal bending question
  113. Electrical pot switch help
  114. cute little shaper on CL
  115. Can we spot beryllium copper by how it responds when machining it? What to look for?
  116. MSC
  117. Plant tour, How 22 Rimfire is made!
  118. Modification To Center...... Best Option ???
  119. 303 v/s 304 stainless How will I know ?
  120. Built a "Franzinator"
  121. Anyone use Cigar boxes for Micrometer or other storage ?
  122. Massive backlash in lathe cross slide. Can this be tightened up?
  123. OT- Nitrogen Bottle and Regulator
  124. Big Auction coming in PA
  125. Bandsaw Blades
  126. Painting Tip: Put Drying Time On Lid of Paint Can
  127. Kind-a OT, for the foundry users
  128. Shaper Frenzy Continuation
  129. Trigon insert identification
  130. Drilling stainless
  131. Standing on concrete
  132. Junk yard finds!!!
  133. Question about the cold saw in this video.
  134. 2016 Sumer Olymipcs!!
  135. Thoughts on a table top lathe for small parts?
  136. Ceiling Mounted Adjustable Lamp: Suggestions, Help, Discussion
  137. Atlas shaper
  138. homemade scraper
  139. Dow 321 Dry Lube?
  140. see this engineering wonder wow !
  141. or even this new carthingemijig. carplane
  142. Question about using a boring head on Aluminum
  143. Rainy Saturday afternoon project
  144. Waht are they called!
  145. best way to renew threads in old castings?
  146. Quick way to tell lead from low melting pt metal?
  147. O/T: Gas giant or rocky core? Jupiter
  148. Need a little help welding a 120 year old gear.
  149. Square threaded rod source needed
  150. OT Battery life.
  151. Newest Additions to the "Family": Cincinnati 2 MH, Bridgeport and Bandsaw
  152. Power drawbar project (TTS system)
  153. Seems my life will not be complete without a toolpost grinder
  154. Clausing Colchester 15x48 change gears
  155. I am back!
  156. Tool grinder base from other thread
  157. Internal chamfer lathe tool
  158. Import Steel & The Chances It Contains Traces Of Radioactivity
  159. Dumore Tool Post Grinder
  160. OT gravity lens solar concentrator?
  161. Online source for length of 4140?
  162. O.T. 22 LR reloading
  163. Sorta OT, but related: Best LED color in daylight
  164. 3D printing a circuit board
  165. Making a valve for model I.C. engines
  166. Auction in Australia
  167. Is it safe to weld galvanized steel
  168. OT, Sorta: A Splendid Project - Router Sawdust Control
  169. inserts explained
  170. OT (Video): The Horrors of Working with Wood
  171. calcuting total thread depth with insert cutters
  172. Enco Boring Head - MT to 1/2" Straight
  173. Quick Q - making the gear on the end of my spindle pulley
  174. Eureka Form Relieving Tool.
  175. Asia made Chuck quality
  176. I get mixed opinions on lathe drilling tailstock taper protection
  177. Portable Air Conditioner ?????
  178. OT - Cable Tie Guns
  179. Great Captain Dia-Bowl 8 Surface Grinder
  180. OT. Electrical, small fan motor question
  181. Dissimilar metals question.
  182. Ideas for hoisting my 650 lb mill/drill from joists?
  183. We got this beast moved !!
  184. Screw Threads for Constant Adjustments.
  185. Rusty Kant Twist clamps
  186. LeBlonde lathe on Mississippi Craigslist
  187. Stepper Motor Education
  188. Manual for an Adcock Shipley 1ES
  189. auto-almost self balancing bench grinder arbors
  190. Safety reminder! Man caught in lathe - video. GRAPHIC!
  191. laying holes out on a bolt circle
  192. Saw, welder and shop scraps toe jack design
  193. Anyone use their mill to sand with instead of buying an oscillating sander ?
  194. Youtube on machinery that changed the world! *WARNING firearm content*
  195. OT: What kind of boat engine is this?
  196. Starting lathe on rotary 3ph
  197. Video for you G&E Shaper Fans
  198. OT- Need help with unusual Youtube Problem
  199. new to me drill press photo test
  200. OT: anyone know anything about abating industrial A/C noise?
  201. Outboards Older Ones?
  202. Wales Alternative Games?
  203. OT Cleaning Espresso Machine
  204. Need advice from fellow MILLRITE owners.
  205. OT saving rattle cans
  206. Wanted - Maintenance info SIP PD-4 Rotable
  207. What do you use between your vise and mill table?
  208. steel strapping
  209. Ddumb Question
  210. Drill press table flex
  211. Degree wheel?
  212. Picking the "right" thread
  213. Interesting vet documentary OT
  214. Congrats Mattthemuppet!
  215. Plasma Cutter Purchase Questions
  216. Tony's Step Stool - Part 2
  217. The Infamous Jet Mill-Drill, revisited.
  218. Copper tube work hardening
  219. Downriver turret
  220. I'm liking the power hacksaw article in Sept-Oct 2016issue a lot.
  221. Block plane frame crached along it"s left side on the mouth.
  222. Machinist's Bedside Reader - 3 books - Sold for $5
  223. Insulation stripping of small wire
  224. Hammer Drill Repair Suggestions (SDS)
  225. Free horizontal milling machine on craigslist
  226. Another metalworker playing with wood
  227. Home Shop Small Lathe Build (Link)
  228. Toledo vs Rigid manual pipe threader handle
  229. cheap DRO fix
  230. buy on impulse?
  231. Sintered metal repair
  232. Made a Collet; Didn't Work
  233. Inside spline
  234. How to make a fine point stylus for a tablet
  235. my box and pan brake was missing its counterweights
  236. Scissor Lift Cart: 1,000 lbs to 54-1/2"
  237. On Dividing Heads, and how they can improve plates
  238. home made etchant
  239. Looking at building a 12 Disk sander
  240. Tool holder holder.
  241. Column Buckling Load Calculation
  242. American Model Engineering - gone
  243. Black Forest did you get my pm?
  244. Hydraulics question.
  245. Craigslist heads up, vertical mill, NE Pa
  246. Machinist Training
  247. newbe looking for advice
  248. More on dividing and indexing etc..
  249. Deutz diesel liner replacement?
  250. Steel plate on stainless bench
