View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 [253] 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Steel plate on stainless bench
  2. Are these tools or scrap?
  3. Logan lathe model 922
  4. Anodizing de-smut?
  5. Hello! ....and Multifix sizing
  6. Allen Wrenches
  7. Single phase motors available
  8. Stuck endmill
  9. Difference between Jet 9 x20 and Grizzley 9/19 lathes
  10. OT Outdoor wireless security camera
  11. Michael Morgan Scraping tools and information
  12. ER Collet Advice
  13. Muffler for air compressor
  14. Machinist's Worksop...Shop Tips From Readers...Tap Tips
  15. Leblond Cross-Slide Screw and Nut Build
  16. Bread Slicer, Mixer and Other Kitchen Utensils
  17. Plaza Machinery
  18. Not quite the last days of enco
  19. Small Boring Bars
  20. Pratt Burnerd
  21. Boring bars
  22. OT Harbor Freight JUNK
  23. Centroid CNC, Anybody use it?
  24. WTF ?? wallet attack
  25. Drum Switch Housing - Plastic/Steel
  26. OT: Apple Invoice Phishing Scam Making Rounds Again
  27. A little excitement
  28. use of bearings in rotary broach
  29. Has anybody read "The Virginian"?--O.T.
  30. Never a HF 20% coupon when you need one
  31. New auction site for surplus items - anyone interested?
  32. OT Sound Barrier Wall for Genset Shack
  33. Need a few ideas, O.T.
  34. Made a stand for my new 30" X 48" granite surface plate
  35. Form tools for aluminium..
  36. Chinese gear cutter sets
  37. Dial indicator with plunger on reverse side of face
  38. New Northern Tools Store Here
  39. Guhring Cutting Tools
  40. Reamer grinding kludge tool
  41. Hardness of Chuck Jaws
  42. What is this used for? (square bench block with grid pattern)
  43. OT - SPEED Control for Brushless Radiator Fans?
  44. Chrome Stripping ?????
  45. Favorite Android Shop Apps?
  46. Prazi Lathe motor question
  47. Older Craftsman lathe
  48. Wanting build an addition to my sander as to be able to chamfer on it.
  49. Apoligies to George Bulliss
  50. O.T. Any thoughs on this tire changer
  51. the Kiwi accent
  52. IMTS Vendor Advertising Blitz!
  53. Decal Making!!
  54. OT- Small Battery Charger
  55. ot pressure pump question
  56. PSA: Beware of Trolls Dredging Up Old Threads
  57. OT: 40' Container - $600 from Shanghai to West Coast
  58. Turning a Parker Taper?
  59. Which cnc machine
  60. Klopp mill motor?
  61. Drain plug Gasket
  62. OT Access database help re linking strategies
  63. OT: Cyclist Paces Motorcycles
  64. Enco Sale 40% off plus free shipping over $49
  65. Hansen Series 3000 Quick Release Coupling: O-Rings
  66. Centering my 4 jaw chuck
  67. 250kg Anvil with lotsa accessories - Sydney
  68. Made that improved grinder finger support I wanted.
  69. OT - Diffusers and lights for microscope
  70. OT: Is this sump pump shot or repairable? Needs spin to start.
  71. Low Tech EDM boring machine
  72. OT; Android phone
  73. OT: Refrigerant Reclaimers re: R134a
  74. New to the scene
  75. long winded tool grinder question
  76. Chinese power feeds
  77. Balancing Grinding Wheels
  78. OT- Hydraulic Hoses
  79. O.T. - Where in the world is Evan?
  80. How To Track Your Vehicle On The Cheap, Using Your Smartphone?
  81. Atlas 7B shaper 3 phase question
  82. Dealing with CA glue (superglue)
  83. Good book: Practical Ideas for Metalworking Operations Tooling and Maintenance
  84. Advice from an electrician
  85. Reaming small diameter hole (2mm)
  86. permanent markers and pc boards
  87. SB Lathe Motor Issues
  88. Pricing question for the pro fellows on the forum.
  89. Sharpening Small Tools by Ian Bradley
  90. Baltimore's oldest blacksmith shop
  91. OT: UBoat 576 explored by mini-sub off coast of North Carolina
  92. Better description of grinder
  93. question about .25 cal primer strike
  94. Slightly OT - Getting motion from a stepper motor?
  95. 45-Degree Chamfer Cutting Improvement
  96. A gloat, for me anyway.
  97. OT?: Pen for older WACOM Bamboo tablet...
  98. OT ( electronics, electro-mechanical) Selsyn synchro signals?
  99. Bridgeport Series II 4J 4-HP Vari-Drive Bushings
  100. Rivett 608 change gears
  101. Tool Gloat, except that ...
  102. Way off topic: Radio controled brushed motor "timing"
  103. Tis but a scratch
  104. Need to add air cooling...
  105. Jack Campbell, head of H. Gerstner & Sons has died
  106. Another Craigslist Bargain ????
  107. Tried new blades
  108. T.Taylor Lathe Survey
  109. My new rotary broach
  110. How do AXA tool holders fail ?
  111. OT: This just in!
  112. Router Spindles
  113. Collets
  114. What's this shop-made tool used for?
  115. Espresso & Alzheimer's?, the VIDEO
  116. Making An Espresso ... Pot!
  117. MS Excel question
  118. What Is A "Noga Arm"?
  119. Shop made rotary broach for the Rivett
  120. semi OT - homemadtools.net
  121. T-nut dimensions
  122. Locks for digital dividing heads - ideas?
  123. What are 3x and 5x drills?
  124. Replacing a thrust bearing... but what is the modern replacement?
  125. Need some real machining help...Wohlhaupter and cutting a taper on the mill
  126. Spindel Bearings / Total Loss Oil System Question
  127. My ArtPrize entry
  128. Shaper found on craigslist
  129. O/T: My testicals hurt.
  130. Automotive Vee belt problem
  131. Sub-table for a Bridgeport
  132. How to ID soft vs hard Chuck jaws
  133. How Would You Figure Out This Angle ????
  134. Millrite Need Parts
  135. Desk top water jet...
  136. A bit naive about YouTube--O.T.
  137. OT ? - Body Mass Calculator
  138. Who Makes The Best, Most Accurate Tape Measure?
  139. Chinese act drive install
  140. O.T. "in technology we trust"
  141. Late night machinery move
  142. Milling machine near me
  143. A Question about voltage for Sherline Lathes & Mills
  144. Found this OLD lathe
  145. Tool Gloat (production)
  146. 50cc 4 stroke electric start model airplane engine.
  147. Paging Gazz, Gmax 37, ds_park
  148. Hardinge Cataract Headstock Info
  149. OT Garage Door Opener acting weird
  150. Delrin leadscrew nuts in practice?
  151. Which dividing head?
  152. Anyone make an Arbor Press ?
  153. Explain to me about dividing heads vs rotary tables please
  154. Carbon fiber
  155. Enco 7X12 woes
  156. Blatent copying of saw(mill) by Chinese
  157. Belts and pulleys
  158. Hardinge Cataract Restoration Log
  159. My replacement mill
  160. Squareness comparator
  161. toolgloat
  162. Spindle design - seals
  163. Atlas shaper parts
  164. Northeast Ohio Show
  165. Which galls less O1 or W1?
  166. OT, sort of, play in bearings?
  167. Black Pipe question
  168. OT: My blind dog working sheep
  169. OT-ish: Building benches for the shop
  170. Questions on building a vibratory de-burr / polishing machine.
  171. Silly question, scraping vs milling
  172. mismatched tread depth on AWD
  173. Rong Fu RF 45
  174. OT Winbook question
  175. BTI Brand Taps....... Issues, Problems, Questions...... Anyone ????
  176. Atlas lathe complement
  177. Forum Feature Suggestion/Request
  178. Asian Carbide Tool holders
  179. Photo Trial do nto read
  180. Nice little flea market score
  181. Mini Gloat- Arrgh
  182. Chemistry question about rust
  183. Winter is coming time to paint the bottom of the trailer
  184. Dangerous trailer bearing design
  185. Needed: some Atlas Mill parts
  186. Universal Bender (VIDEO)
  187. Stupidity is expensive
  188. OT: Washing machine recommendations
  189. table power feed Bridgeport J head
  190. Goofing around in the shop, first time machining known stainless alloy
  191. Time for an update
  192. spindle bearing adjustment SB 10" heavy
  193. Alistair Hosie - any news from there?
  194. Chinese Stainless?
  195. Mill rebuild: A month of progress
  196. Bending drill rod
  197. Kind of like dividing plates - but notches on perimeter - where used?
  198. Tool and method to remove butcher block trunnion caps/nails
  199. Precision Mathews PM727M milling machine
  200. OT: ebay bargain [not]
  201. Can someone explain this diagram of gears on my lathe
  202. Right angle drill attachment rebuild
  203. OT: Harmful USB drives found in letterboxes
  204. Shortening swingarm
  205. O.T. - Maytag Neptune probem
  206. Washers With Key Tab .....
  207. Black Hills Model Engineering Show
  208. Any guesses on when Asia starts selling us cheap CNC?
  209. Tap 7/8 BSW out to 7/8 UNC
  210. Expand ball bearing jounal
  211. two Free tool posts (Rapid Original clone)
  212. That "dead radio" Winbook...... followup
  213. Drill Press Vise
  214. Way OT Outlawyering realtors
  215. OT: Anyone near Chicago?
  216. Boring chatter
  217. Keeping it flat
  218. Yahoo hacks in relation to Yahoo groups like Millrite, etc?
  219. O.T.--From my "Year with the Hippies" --The Rubber Tree
  220. OT: Chevy and more Gm going to china
  221. Pest control in the shop?
  222. OT looking for dual fuel generator
  223. pressure test pump repair
  224. Is there an EASY way to remove the black scale from the surface of hot rolled steel?
  225. T&CG work head - please educate me in full compliment bearing practices
  226. "Weak link"
  227. Need help with tool-setter hack.
  228. OT-Safety quiz.
  229. New milling machine.
  230. In Search Of - a few people with Kurt vises for group purchase of rebuild kits
  231. How do you hangum? your clamps that is
  232. OT waterproofing canvas
  233. OT Wellington OH engine show pics
  234. That tap thread debate
  235. Bolt hole layout
  236. [OT?] Soldering Litz wire for high frequency tranformer (1500W DC-DC converter)
  237. Out of the woodwork...
  238. MSC Clowncar: Dishonest or Incompetent?
  239. My old friend, the Kerzel
  240. Stepper dirive for Arduino...?
  241. Yet another odd penetrating oil
  242. OT-Mirror Plating?
  243. Weird 180hz generator help
  244. Best method to make a counterbore for a bearing?
  245. OT: anyone know the Tecumseh setting dimension for carburetor float?
  246. Australia's "super-science" ship
  247. Problem with R8 spindle
  248. 'TINY' a vertical water cooled hit and miss engine
  249. Show me your Z axis scale installations on your Bridgeport Head please.
  250. Gloat worthy?
