View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 [254] 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. 2016 Estevan Model Engineering Show
  2. Panic! Rust!! Panic ! ! ! !
  3. Grizzly Mills
  4. question about tolerances
  5. Wax In The Shop? Comments? Suggestions?
  6. Tramming Ring for Mill - Tool Gloat
  7. This is one for you model builders
  8. Freelance Design--Working form home O.T.?
  9. M2A1 ... endmill, not the MG
  10. Question about Bridgeport quill travel
  11. Semi OT: Anyone here with Briggs 17.5 Intek experience?
  12. Additional Glass scale Rip-off Racket ?
  13. Vortex Tube - Build Video
  14. I Need Some Thoughts On These Parting Blades
  15. Types of multi groove belts?
  16. OT: Another little update
  17. Milling a radius, horizontal vs vertical
  18. How Mercedes makes crankshafts in China
  19. Wood working fly cutters
  20. DoAll DG24 drill press parts/user manual needed
  21. Doall bandsaw parts give away.
  22. US Giving Up Control Of The Internet............ What It Means For This Site & Others
  23. Will brake rotor iron make a good lapping plate?
  24. OT: Ever Start A Cut And Suddenly KNOW It Is Wrong
  25. OT - Echidna rescue
  26. Drilling a small hole at the bottom of a deep larger diameter hole.
  27. making whitney punch dies
  28. Stamping An Internal Keyed Flange Washer
  29. Which thread insert is best?
  30. Bailingwire fix
  31. Detailed ACER 1440G lathe instructions?
  32. Possible cure for Quillhandlitis
  33. Threading on backside of lathe
  34. OT: Bank Vault
  35. OT: Considering getting paypal account
  36. Slipping arbor on slitting saw
  37. OT tach probe for otc 3391 meter
  38. O/T: My favorite chilhood food, and yours???
  39. 11/16th Hole
  40. Wat OT----Tilt up garage door install
  41. Open House at Rollies
  42. Minor Tool/Storage gloat
  43. lathe chuck questions ( from a newb)
  44. Line-Shaft Clutch
  45. OT: Facebook....???
  46. Southbend 9A Spindle Shim Removal
  47. Material pulling out of 3 jaw chuck during cutoff operation.....Why?
  48. VIDEO: Shop made cutting tools
  49. Silverton mine machinery
  50. Anyone here a member of The Hobby Machinist?
  51. How the mighty have fallen
  52. OT: Required Video For Those That Tow
  53. Had to happen: "Craftsman" name on the block
  54. How to use a ENCO boaring/facing head
  55. Studying a Griz lathe, any feedback from users?
  56. Studying a Griz lathe, any feedback from users?
  57. Baileigh PL-1022VS lathe missing parts - thoughts on how to proceed?
  58. Antique Lathe ID
  59. Where besides MSC
  60. Mitutoyo quill readout?
  61. CDCO Schipping
  62. Scale for rifle sight
  63. Threading problem on 9X 20 lathee
  64. More fun building a up a new shop than using it ???
  65. need information on camel backs
  66. OT: Question for retired folks - Social Security tax withholding
  67. HM Lawn Edger
  68. OT- lens choices for cataracts
  69. The container in which we place machine tools
  70. Apron removal on 9X20 Jet lathe
  71. Apron removal on 9X20 Jet lathe
  72. old DP question - what is this called?
  73. Anyone use old forged-type tool holders in a turret-type tool post?
  74. Model Air "Steam" Engine with Plunger Type Valves?
  75. OT Corrosion Currents
  76. Clausing 4900 10" Lathte Information
  77. blow-up mirror
  78. CNC Mill as Lathe
  79. Taper Attachment for Manual Lathe
  80. A HARD Lesson
  81. Is Grizzly dropping the Southbend line?
  82. OT power steering problem
  83. OT: My dog is spending too much time in the shop!
  84. OT- Vacuum Pump Oil
  85. axa 250-102 XL tool holder question
  86. Most general purpose blade for 4 X 6 metal cutting bandsaw?
  87. Transit from China to USA in 20' Container - amazing OT
  88. OT: Is 1/4" pegboard made any more?
  89. ENCO coupon code?
  90. OT Need 1500-2000 ft. lbs. torque Hyd Motor 5-15 rpm
  91. Another use for CNC
  92. Power Feed Tripping GFI
  93. question specific to Jet 13R drill press (old)
  94. Band saw conversion
  95. Proth PSGS-618 Operations and Parts manual for 1985 manual surface grinder
  96. Don't Slide Down the Sawdust Pile--O.T.
  97. Way OT: Question about hacking.
  98. OT: Microwave oven plate.
  99. Maybe OT, maybe not. Hoist hanger on two-post lift for holding wheels
  100. Fixed my 9 X 20 lathe apron.
  101. Fire in and and recall of Samsung Galaxy Note7 mobilephones
  102. VIDEO: Making some tiny screws
  103. Shimming up 1" toolholders to 1.25"; any problem there?
  104. brass dragonfly
  105. OT: interesting rediscovery re Lyme disease
  106. angle plates
  107. Eclipse 180 instrument vise
  108. Threading 4140 HT question?
  109. OT: Fascinating Website Showing Earth's Ocean and Atmosphere
  110. Thread Help
  111. Soldering Iron Tip Cleaning
  112. Walking Beam Conveyor
  113. This is My Machine. There Are Other Machines Like it But This One is Mine
  114. Grinding Carbide Tipped Cutting Tools
  115. Tool or machine to cut moss efficiently?
  116. Live/Rotating Center - Medium Duty, 1800 RPM
  117. Excello 602 right angle milling head assessment
  118. Shoe material for external hone?
  119. How should I go about loosening knurled knob on centrifuge that's been overtightened?
  120. A question for Black Forest
  121. Emco Maximat Super 11 (green) w/ Milling Attmnt & Bench
  122. Manual Firewood Splitter (some machining involved)
  123. Blackening Steel Parts
  124. OT - Is this USB application too good to betrue?
  125. Solid State Hard Drive ??? Slightly OT
  126. OT - locating a multi-dimensional hole
  127. Wire mesh basket for burning pellets in woodstove (Pelleteer)?
  128. PhotosI'm
  129. Jacob's tap collets - how to use
  130. I Pads and Photobucket
  131. Acrylic for sight class window?
  132. Feeds and speeds for 4140HT ?
  133. Taper Attachment in Latest HSM - spring tension
  134. Box rail & trolley for moving machine accessories?
  135. Upgraded Transport System for Battery Charger
  136. Hi Bothers wait till you see my new Car/restoration project what a beauty. Alistair
  137. OT: RIP Leo Beranek of BBN: birthplace of the Arpanet
  138. How I do it
  139. stellite 1
  140. Anyone make a cutting tool out of a small diamond ?
  141. Guess where I was today?
  142. Are R-8 shank/arbor surfaces hardened?
  143. What Could Have Moved Here???????
  144. OT: design for a 3/4" gravel screener?
  145. OT: Score ... sort of. Workshop cleaning find.
  146. Choices of CAM software for a CNC Router.
  147. Hookup and parameters for Hitachi wj200-015lf
  148. Reloading Press Work
  149. Samsung - recall history
  150. OT? How Come I Never Have The Tool I Need?
  151. Converting from T12 to T8 LED.
  152. Van Norman Drive Pulley Size
  153. What size/model chasing head takes these dies?
  154. Centering to k in a
  155. Easson ES-8 lost led segments help
  156. Naming Tools
  157. 3d print lathe dog
  158. i think i might have a photo this. time
  159. analogy of CW/CCW threads (R&L)
  160. Hoisting with two post lift?
  161. Squaring stock in the mill - Now with more VIDEO!
  162. Pairing up two milling vices
  163. Swarf got me
  164. Accuracy of typical digital gear calipers
  165. Calibrate old Starrett level?
  166. Way way OT: Why do we have to put up with this?
  167. enameled copper wire, or magnet wire
  168. Looking for HSM article on coloring aluminum, or how do I use the HSM index?
  169. OT -- Any of you guys use a straight razor ?
  170. source for small face dial tenth indicators
  171. OT: Adventures in troubleshooting and repair - mini SW radio
  172. Milling Machine Table Covers
  173. stellite filler rod for TIG welding. A use?
  174. SEM 39681 primer
  175. Spindle Runout
  176. OT moving a shop
  177. OT: Determining Whether Core Drill Severed Induction Heating Cable
  178. CNC Power supply/toroid question for the non-electrically challenged fellows here.
  179. Chinese collets
  180. Need a 8" x 26mm OD tube of AL or composite to repair a kayak paddle
  181. Home made Penetrating Oil
  182. Looking for Plans for a Small Diesel Engine
  183. What is this called?
  184. Fire Fox Browser Help OT
  185. rfc question, can't find a large motor
  186. 3D Printers Opinions
  187. My go to drills
  188. Been a while, new shop started
  189. Sterling machine as school project
  190. How can this possibly be??? cheap Hardinge tooling
  191. Move compressor to outside building
  192. Questions Regarding Combination Lathe Mills
  193. Interesting Book
  194. OT: gas fireplace problem
  195. Bought a small ruby stone from China
  196. How do you dead centre drilled holes? (Sieg X2)
  197. Ot: Another small update
  198. OT - Toilet Plumbing Question
  199. OT: Pumpkin Carving
  200. Not facing
  201. HDPE plastic recycling. How to avoid voids?
  202. Arbor support for right angle milling attachment
  203. Automatic rising bollard design
  204. OT - Dry age beef at home ---- UMAI
  205. holding down to grind surface????
  206. Allen-Bradley power supply
  207. VIDEO: Shop Tour
  208. Precision magnets!
  209. Hardness of splined shaft
  210. That driverless car thing
  211. Anyone ever cut Rubber with a bandsaw ?
  212. Truing Up Starrett 8" Level
  213. Any cheap or free CAM with 4th Axis function?
  214. OT: Recent changes in forum behavior
  215. 3d print lathe chuck spider
  216. Chuck backstop
  217. Starting as Machine Repair Apprentice soon, what could I make in the tool room
  218. Brazed Carbide Toolbits Wearing Prematueley?
  219. No touch paint removal
  220. drill press restoration question
  221. Asian Made Rotary Tables
  222. Anyone know what DoAll blade guides are made of?
  223. 100 lbs propane tank Qs.
  224. Depressing Or A Sign Of The Times ??
  225. O/T: Solly. Nice read. "What Is The Mid-Ocean Ridge?" Article link below.
  226. OT Woodworking: Advise For A First Plane
  227. Surplus Canadian Ranger Lee Enfields to be Sold to the Public
  228. strange electric problem
  229. Gear Hobbing
  230. Shell Mills...... The Rules Of Engagement
  231. Mill table top vise?
  232. Some insight into Eric Smidt, owner of Harbor Freight
  233. OT: Looking for info on internet thermostats
  234. 4140 reamer???
  235. CNC parting, such sweet sorrow.
  236. Babbitt bearing stock??
  237. HDS milling cutters
  238. On carbide tooling and spindle speed
  239. Smart Kid Build IC Engine Without Machine Tools
  240. Designs for ratchet pawl in tool post?
  241. How are presses rated?
  242. Slow down and go faster??
  243. First gloat (and questions about a step belt B'port head I just bought)
  244. Electrical ants discovered
  245. O.T. Need some electronics help.
  246. improving compressor
  247. O/T Working Wth Micarta
  248. Ind Ins Toolholders, any source of reas. used ones besides Eboo?
  249. 3D Mouse.
  250. Slightly O/T - Water in Diesel Systems
