View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 [255] 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. threading problems
  2. OT: Table saw bearing id different from what it's number says it should be.
  3. OT: OBD2 scan tool or software options
  4. OT: Was this saw made in China?
  5. Another tired post on LP infrared heaters... new shop
  6. slowing down scale-model engines
  7. Using toe clamps with serrated feet?
  8. Owner's Instruction Manuals "Notes" Section
  9. Problems Running 7.5hp 2 Speed Motor on Lathe
  10. Centering a threading bar
  11. 1905 pat. B&S dividing head-use or put in museum?
  12. Help with an Atlas 7A shaper.
  13. BP Mill... Knee Wear Or Saddle Wear ???
  14. MSC 40% off and free shipping, first time ever.
  15. OT: New Phone At Reasonable Price
  16. Copper sheet and strip - use for DIY high current PCBS? - and good source
  17. VIDEO: Threading on a plain turning lathe
  18. OT: Value of old coin-op riding animals?
  19. Drilling error, what to do different next time?
  20. Stock material design standards
  21. sad but true - a story of scrap metal prices
  22. What a difference !
  23. Large Machine Tool Auction
  24. OT? Interesting Woodworking Tool
  25. Tried some home anodizing
  26. are these called "lifting tongs"?
  27. DRO bliss
  28. Low quality tools
  29. OT: I now have a video to show
  30. transformer anomalies OT
  31. OT Is it electric or hydraulically lifted trailer?
  32. Crocus Cloth Supplier
  33. What's wrong with this picture?
  34. Making springs, Thanks for the help.
  35. 303 Tractor Hydraulic Oil Use
  36. Link belt direction
  37. question for CamBam users
  38. Cincy 1C Toolmaster
  39. Need to face new faceplate?
  40. Advantage if any of these huge TNMG 666 inserts?
  41. Totally OT, Software Defined Radio (SDRs).
  42. Drive Link Mystery
  43. Semi OT: Can Openers
  44. Cutting 1” Aluminum Rod
  45. OT - How times change us
  46. who sells reground end mills
  47. Enerpac single acting cylinder question
  48. Home shop metrology..
  49. Uneven finish with power feed on Jet lathe
  50. OT: We don’t need a forward windshield - self-driving car
  51. Jacobs Rubberflex Collet Lathe Chuck Official Instructions
  52. Advice on repairing a shattered hollow shaft
  53. Concrete Lathe Bench (with video)
  54. Taking curl out of UHMW
  55. One micron Plunger dial indicator
  56. Need help identifying a lathe attachment
  57. Learned a new 3d CAD trick---
  58. Photo Hosting Site Recomendations
  59. Late 70's JET 1024 Standard Change Gears, Imperial and Metric
  60. Hossfeld Bending Arms
  61. CDHB Inserts
  62. Slitting saws
  63. DIY Lathe DRO Suggestions?
  64. Bridgeport Series I
  65. A question about grinding lathe cutting tools on a belt sander
  66. Metric threads on an imperial lathe.
  67. Sledgehammer head toolpost!
  68. OT: I Had An MRI Today
  69. Protecting from rust
  70. Milling machine resuscitation
  71. Surface plate mounted on five points?
  72. Obscenity of Canadian pricing
  73. got an angle grinder that runs backwards!
  74. compressor
  75. OT plumbing issue
  76. New "forum" needed...
  77. Washer under a bolt head or not? What is your opinion?
  78. How would you attach it? Small workshop lifting device.
  79. Question for the encoder-savvy folks on the forum:
  80. Stubborn Stainless
  81. Fun with mechanisms
  82. John stepper motor gear hobber.
  83. Can I/I Toolholder shank be cut with HSS flycutter?
  84. yet another "what is this tool" question
  85. Reclaiming sheet steel- paint removal
  86. Surely this is not beyond the possibility of most reasonably efficient engineers?
  87. Whatzit, tool, gauge, ???
  88. 90 degree joint in rotating shafts
  89. Need a South Bend thirteen expert
  90. Blocks for removing&installing Lathe Chucks
  91. Project - 7.5 Gage Ride-on Train
  92. Pinion Gear
  93. Little Machine Shop Transfer Screws?
  94. Grizzly gunsmithing lathe(s)
  95. Press fit bearing to shaft or housing?
  96. RF45 mill bearing removal help
  97. Do you use an air scrubber in your workshop?
  98. Brass Feeler Gauge. Why?
  99. Face mill, details missing.
  100. OT: 1600 Whats?
  101. Take Lathe Chuck Apart After Threading Cast Iron?
  102. the on off switch on my enco lathe went out I need help
  103. Unique project from the last couple of days.
  104. Casting
  105. king canada fm1236 lathe
  106. What could I do with an Emco CNC lathe?
  107. Tap Drill Size ????
  108. Geeze - all I wanted was to be able to lock my front porch from the outside...
  109. Dressing Resin Off Diamond Wheels ????
  110. Newbie Questions
  111. Old Sheldon lathes-source for half-nuts?
  112. 3in1 oil long term
  113. OT - Little known favorites
  114. Brazed carbide tool bit question.
  115. Best way to clean Inside Propane Bottle
  116. Saving parts from Miner's fire
  117. Is this surface plate worn or dirty?
  118. A bit confused on gauge pins...
  119. 1hp 3 phase motor noise
  120. Oil seals
  121. Oil bath without seals?
  122. A second shop at the cottage. How do you cope?
  123. Metric threads possible on imperial sized brass rod? Hints please.
  124. First year high school students
  125. Lead screw question
  126. Vertical Vise - Doozer's Shop Update
  127. OT: time for another update (and some about programming)
  128. Screwed up and put aluminum grinder parts in the dish washer
  129. OT: Electric Pipe Heating Cable
  130. OT fuel pump systems
  131. Three easy questions.
  132. OT- Airless Paint Sprayer
  133. Boring a hole in two blocks?
  134. It's a cold and miserable day--o.t.---
  135. Introduce yourself!
  136. Trouble find a 3/4"-16 female adapter
  137. [VIDEO] - CNC Basics - VERY basics
  138. Looking for a bit of info on CNC router/wood mills
  139. Help with reverse engineering
  140. First time spring steel experience question
  141. Large Blade (1/2") Screwdriver With Handle
  142. Machinist Tooling and Supplies
  143. Help opening up small holes in titanium – Solved!
  144. OT Broken Leg needs help
  145. Machinery's Handbook CD
  146. Saw kickback causes fatal injury in Duxbury, Mass
  147. Shop lighting design
  148. Universal Joint
  149. Materials supplier in Sydney
  150. Best Bottom For Homemade Tools on Surface Plate?
  151. Drilling Holes for M5 Bolts
  152. New DSG lathe owner
  153. Kinda new, looking for advice on parting.
  154. Help! G0602 problem!
  155. New class of material
  156. Small holes - deep...
  157. Next Major Project: wrTie (with Video) Mechanical Pencil Build
  158. Need pancake help
  159. Scale Hardware?
  160. Question about the level of technology in your shop
  161. OFF TOPIC Recycling Christmas tree lights
  162. Brass on Surface Plates?
  163. DSG 13-1 leadscrew thread question
  164. Melonite
  165. O.T. Is the check any good?
  166. Interesting Japanese Scraping Video
  167. End Mill Gash Angles ???
  168. OT Kinda, Can you love a machine & if so which one? Pics if possible please!
  169. Poulan Pro 4218 chainsaw woes
  170. Drill Press for Automotive Use - Radial arm or standard
  171. DRO glitch
  172. RotoZip?
  173. Anyone buy from Ali-Express?
  174. Happy Thanksgiving to all
  175. OT: When Robot Cars Kill
  176. Suitable replacement for a Jig Borer?
  177. VIDEO: Making a Dixi mill clamp
  178. Surface plate care
  179. Semi OT: We have a very basic problem with physics
  180. MEM?
  181. OT - Humidifier recall...
  182. Johnson Modle J Band Saw
  183. I am looking for a cheap source for racks.
  184. New lathe owner tooling recommendations
  185. HHIP 3901-5032 ER-32 Collet Chuck
  186. A Steampunks Dream
  187. It was just a mater of time!
  188. Gear Tooth I.D.
  189. Tricks for work holding in the milling machine vice
  190. Cutting gear racks on a vertical mill
  191. Another use for drones sort of OT
  192. Sili kroil
  193. Another lathe destroyed.
  194. Ready for winter---o.t.
  195. Starrett Digi-Chek Height Gage - Trouble Shooting, Disassembly, and Zeroing Tutorial
  196. Somewhat OT: Inkjet printer leaks.....
  197. Atlas 7 shaper vise questions
  198. what does a maintained drum switch meain
  199. Parts for Ettco 4B tapper
  200. OT help me check out an electric motor.
  201. How To Finish A Bench Top
  202. Masso CNC controller any opinions?
  203. DC drive sources
  204. A skill testing question?
  205. What is this, sensitive drill or what?
  206. magnet orientation
  207. Gear Train Calculator
  208. Recommendation for a practical machining book.
  209. Ambient Oxygen cosumption and cutting torch.
  210. Milling workstop
  211. Should I worry about 460 volt machines?
  212. Favored Kant-Twist types & sizes for an HSM'er?
  213. Philipson Contour Sander would it work on Metal
  214. Threading questions
  215. Another transformer question for shop power
  216. Holding Tenths Cutting Threads...........
  217. VIDEO: Quick one, custom stainless steel bolt
  218. Heavier flywheels for the Kerzel hit and miss engine
  219. LF help selecting steel for special bolt
  220. Low profile clamp for 4” Vertex RT
  221. No Power - Want to see a milling machine run.
  222. HELP! My laser is printing patterns out of square!
  223. New Amateur Machining Podcast!
  224. Would this Baldor 10 h.p. 3 ph. make a good 6 h.p. output RPC?
  225. H&G Die Head adaptable for home shop?
  226. OT- driving hell bent for leather
  227. can anyone help with a name for this guillotine.?
  228. Collet id. help
  229. Cincinnati #2-MH mill manual?
  230. damping a test bar
  231. Help me pimp out my lathe
  232. Miter Saw Fence
  233. π tape question for gurus
  234. OT: Anti-seize on sparkplugs?
  235. Clever old time oil delivery mechanisms?
  236. Radial arm saw
  237. Horizontal Milling: I pushed it harder and I'm impressed!
  238. Residential "hydrofracking"
  239. Using an Amazon Echo in Your Shop
  240. To Pound or Not to Pound a part into the vise so it seats good ???
  241. Best Way to Cut Aluminum Angles
  242. Measuring torsion spring rate.
  243. Setting a Precision Taper Without a Master or Angle Blocks
  244. A Slick Way for Removing a Rusty Nut!
  245. Another Android phone/"glitch" - or not?
  246. American pickup truck help needed.
  247. Adjustable reamers
  248. My Coomber engine all dressed up
  249. OT - Need a quality replacement battery numbered 18650
  250. OT: Johns Hopkins study of "Magic Mushrooms" as treatment for addiction & depression
