View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 [256] 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Bright ideas for fitting in a fuel filter?
  2. digital mic's?
  3. Reducing the diameter of a flexplate/ring gear
  4. Good news-Bad news
  5. Cutting ss tube.
  6. Magnetic Sweeper recommendations?
  7. Removing Mold Skin On Grinding Wheels ?????? Really !!
  8. OT what kind of wire shoud I use for a throttle linkage?
  9. lubricant for hoist chain?
  10. I would like to make a nice unchinese sawblade sharpener
  11. well he doesn't know and I don't can any of you guys figure it out? SORT OF OF TOPIC
  12. Forum record OT post: Rain barrel freezing question.
  13. Reliance drive wiring question
  14. OT: Legos.....yikes
  15. Lathe Readout Idea, Shoot holes in it.
  16. Conveyor start stop motion control advice needed
  17. Clean air for an air compressor
  18. another DRO Cheapie question from OLD ISH Al
  19. OT: Replacing a beam supporting concrete block wall?
  20. Metalworking Videos, new.
  21. Homemade Tools Forum
  22. OT donor car for electric conversion
  23. Acceptable y-axis backlash on a LMS 3990?
  24. Phase Converter discussion continued from homemade tool thread
  25. What is this
  26. OT; eBay down?
  27. Clickspring has finished his clock project
  28. Best Christmas card ever for a machinist
  29. replacing quill and spindle bearings
  30. Interesting little project
  31. OT-Insulating Window Film
  32. Trav-a-Dials on a Chinese lathe
  33. New DRO install
  34. Black Granite Surface PLates
  35. Can I run 230/460 motors with 240/480 power
  36. Straight edge needed.
  37. using a tool grinder as a surface grinder (hack?)
  38. OT? Tip: Marking Hole Locations Under a Counter Top
  39. Machine painting advice DSG
  40. Chinese 10x18 Lathe Spindle Noise - I think I know what's wrong?
  41. Spindle issues and questions
  42. Brown & Sharpe Angle Blocks
  43. dental-lab -type drill need info made in Chindia
  44. Case 1845 skids steer will pick up Bridgeport
  45. OT: computer overheating causing strange problems...?
  46. OT Where to find a new circuit card
  47. After years I finally got one!
  48. Help Identifying my South Bend Lathe
  49. Looking to get a custom gear made
  50. Waste oil heater question
  51. MSC free shipping and Ebay gloat
  52. OT: how to ship small heavy awkwardly shaped items?
  53. HSM member get together?
  54. Linuxcnc and a Holbrook Minor
  55. OT Calibrating Hygrometer
  56. what do you guys make of this?
  57. Threaded spindle variations
  58. Steam engine project.
  59. Alignment Problem on SB Lathe
  60. My Latest Flare up of Iron Disease
  61. What would this be used for
  62. Franklins sanding disc cement
  63. 123 Blocks... why?
  64. Any Other Methods Of Indicating This ??
  65. need help yet again engineering sort of question. ?
  66. What are you using your 1-2-3 (or 2-4-6) blocks for?
  67. Johnson Model J Bandsaw
  68. Anyone tried this type of LED shop light
  69. Modified Sunnen External Hone.
  70. Shell mill recommendations for smaller mill
  71. Tool and Die Guy
  72. know anything about these? They look neat!
  73. Another new little toy (CNC)
  74. is this a real GRETSCH guitar or a Chinese copy.The abuse to this iis unbelievable !
  75. DSG compound slide angle indicator.
  76. Ghost ring sprocket
  77. Problem with eBay aloris axa-8. Blade threader
  78. Fly Cutter Position For Pass
  79. Chinese 5C Collet Chuck Problems.
  80. Compressor Switch Anyone Ever Take One Apart???
  81. Brush On A Battery
  82. 45 acp cylinder
  83. OT Just get out & fix it!
  84. NOS lathe
  85. What kind of tool is this?
  86. Windows 7 Desktop Icons Disappear OT
  87. New thumb pump oil can?
  88. Mig welding help
  89. Use/Origin Of The Word "Off" in Machining
  90. GM truck brake line rust inside story ?
  91. Inexpensive tooling - a JOAT's perspective
  92. Colchester student 6inch mark 2
  93. Millrite MVN quill feed slop z axis
  94. Chinese plan for failure?
  95. OT: you live long enough you'll get your heart broken many times
  96. Millrite MVN quill bearings lubrication
  97. Interesting Furnace Option for garage Heat!!
  98. Sand blaster cabinet suction filter
  99. On Making Level Vials...
  100. OT- GFI Wiring
  101. OT: Expansion Of Underground PVC Drain Pipe A Problem?
  102. Anyone seen this screwdriver/bitholder around anywhere?
  103. Farrel sellers 1 g not grinding right
  104. Dimide clamps, better than Kant-Twist?
  105. OT buying from AliExpress
  106. Alberta has just issued a "Moose Licking Car" warning--o.t.
  107. Quick way to cut a cam
  108. Parts For Old Mitutoyo Dro Parts ? Or Off Brand Recommendations ?
  109. Shop press sheet metal Shear. Anyone have a design?
  110. I am a tool guy, love tools. Not a Machinist. I dont like the BS with calling out "X"
  111. OT- what is this chuck worth?
  112. Fusion 360: Exporting to Mach 3 Turn?
  113. A new one for Brian R.
  114. All American Die Filer Magnifier
  115. So: Who is a "machinist" and who is not?
  116. Help wiring a VFD to motor
  117. long-term rust protection of bare metal
  118. Need advice from electronic guru's (again)
  119. Hi. New guy here
  120. 5C Collet Chuck that can use a standad lathe chuck
  121. Bucket List
  122. How often do you run into oddball thread sizes?
  123. Get your Popcorn ready!
  124. The Award for Biggest Junkyard Power Hammer
  125. Ancient threads...... avoiding
  126. Electric hand tool exposed to the elements, rain, etc for a while..?
  127. Lincoln Pro Cut 80
  128. Problem comprehending metric fasteners...
  129. OT....and kijiji just gets worse
  130. Silverado hubcap fix
  131. Atlas lathe, never used only admired.
  132. 1000 Hour Clock build in 12 minutes!
  133. A simple question where we do not need to argue.!
  134. Spindle recommendations for a lathe toolpost grinder?
  135. Strange taps, a question for, maybe, railroad historians
  136. Press fit on a sleeve bearing?
  137. Ring Roller
  138. Not seeing images - using IE 11
  139. OT Links to "Much Too Interesting" Stuff
  140. 18th century mechanical swan - amazing craftsmanship
  141. Mobil Beacon 325 grease?
  142. Gears, harmonographs, drawing machines, watchmaking, automatons interesting link imo
  143. OT: Replacing rubber strap on (cheap) wristwatch with SS band
  144. VFD Question
  145. OT- Durable Rattle Can Paint
  146. Monarch for 2k
  147. Dyno specs
  148. Hmmm...something is a bit off with that All-thread rod
  149. OT - Banned from PM
  150. Now THAT'S a power hammer...
  151. J-B Weld ungluing
  152. Press fit dowell pin
  153. Looking for a love joy type spider
  154. electic workshop heat question
  155. Shaper help
  156. Just for fun
  157. OT- OBD P300 Code
  158. "High Collar" lock washer???
  159. Where can I find out how to decipher ISO milling tool designation codes?
  160. Strange Thought - Semi OT
  161. Identify this toolbit please :)
  162. Whole Sale Tools
  163. Another "which VFD" for MSC bridgeport clone
  164. I made my wife a square drive vise handle for christmas (VIDEO)
  165. ER collet nuts
  166. Orac CNC upgrade
  167. OT, How does this fan work? Any ideas?
  168. OT Merry Christmas vs Happy Holidays
  169. Basic Drafting Software with Dimensions
  170. A sort of survey. MAybe OT
  171. Surface grinder shaft question
  172. Christmas Gift Idea
  173. Lathe Damage In You Tube Video
  174. New switch on my lathe
  175. Ho ho ho! Santa is coming tonight!
  176. Chipping carbide end mills/spindle backlash?
  177. Thought I Got Hacked Today..OT But Beware !!
  178. This year's kids Christmas present for the wife
  179. Enerpac P39 hand pump tear down, tool and Qs
  180. Victor lathe chatter
  181. A lathe is not an anvil
  182. Sheldon carriage lead screw removal advice.
  183. Atlas 7B shaper owners? Question about feed screw.
  184. Holiday Greeting
  185. My diy home shop anodizing setup
  186. Cam profile mania
  187. New guy dumb question full profile thread insert
  188. Modifying an insert tool holder??
  189. Mildly OT, nice article on the Big Boy 4-8-8-4s
  190. Making a Maker... anyone succeed in getting their kids interested?
  191. Fair Price for a 1936 Sheldon 11" x 24" lathe (model WFM - 24Q)
  192. Lazer Rust Remover
  193. Old posts
  194. Labels and tags
  195. I need an engineer.
  196. The Other End
  197. Cheap Chinese TNMG surprise
  198. Atlas/Craftsman 12"
  199. Finally beat my new 5C collet chuck into submission
  200. Swarf Art
  201. How about a carbide insert index sticky?
  202. 8x12/14 lathe mod
  203. PM Research #1 - Flywheel Casting - Machining Advice Needed
  204. Machining Nostalgia: One Of My First Projects
  205. Surface Grinders: To buy or not to buy?
  206. Glass Head Briggs Engine
  207. Threading on a Victor 1640B Lathe
  208. OT: We may not be alone
  209. Why no "For Sale Or Trade" forum on HSM?
  210. Stripping lathe paint. Tools???
  211. Another day in the shed..
  212. What mill to buy to match my 12" lathe
  213. VIDEO: Making a gyroscope
  214. Servicing an indicating micrometer
  215. OT somewhat as there is machining content. A very good movie!
  216. Old Sheldon Lathe
  217. Tool makers grinder
  218. Which metal lathe for my home needs?
  219. QC tool holder rack
  220. flange nuts
  221. Chuck Jaw Covers - Improvements?
  222. badly overdrilled DP table and a cast iron repair
  223. elliot-burdette surface grinder info
  224. Any machining or shop New Years Resolutions?
  225. Pros/Cons Of Oxalic Acid Rust Removal
  226. a mill followed me home
  227. What's that for?
  228. Steady rest
  229. Boring & Truing Hole In Grinding Wheel ?????
  230. Lye in the shop
  231. Central Drill Press Speeds
  232. Continuous Welded HO Scale Rail?
  233. Help with kayak rack
  234. Quick release nut.
  235. OT - Batteries Stuck in Mag-Lite Flash Light
  236. OT: Frontier Internet Speed
  237. Easy way to get 1-3/8" 6 spline (540 PTO in Farm Language)
  238. can I run my dc mig welder off my dc stick welder??
  239. OT: Fireworks over our city
  240. GT7D Greenfield Tap Handle
  241. Christmas firearm for #2 grandson.
  242. Anchor 2200# lathe to concrete floor or not?
  243. Pacemakers and the shop???
  244. shop light replacements
  245. A handy simple tool for polishing hole IDs
  246. Bestline Mill is this a good deal?
  247. Semi OT: 3D Warehouse
  248. What did you do in the shop today?
  249. Which way to take worm gear making?
  250. Question About Thread Class Applications
