View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 [257] 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. OT - A Perversity of Nature
  2. Hand held Mechanical Tachometer or Speed Indicator.
  3. OT but fascinating video - Prince Rupert's Drop Shot With .22
  4. Milling on Sieg C3 Attachment from LMS
  5. CNC Crash Compilation
  6. DSG worm gear I.D and manufacture
  7. Identify these tool bits!
  8. Lathe Carriage Position Indicator
  9. Lathe repaint and questions about saddle.
  10. Very Nicely done Power Quill Feed
  11. Reeves variable drive expanding sheaves type belt sizing basics needed
  12. I thought I'd seen it all...
  13. Great Machinist/Metalworking/Model Club in Chicago : Northwest Model Eng. Society
  14. OT? Clean Up Battery Leakage
  15. Motor Capacitor died :( have a question
  16. HSM magazine projects, archive of back issues? (George)
  17. Steel, cast iron, weld up ??
  18. LeBlond lathe help
  19. I Have A Crazy Idea .......
  20. Question on 440v VFD's for UK market
  21. Taig Lathe ER16 Spindle
  22. Need ideas on how to machine a exhaust manifold
  23. Why don't taps have triangular or hex heads?
  24. wow what a cheap great way to mark your metal tools.
  25. OT: HSM travel agency for California, advise needed
  26. A rather strange feeling.
  27. What is it? drill stand?
  28. End Mill Sharpening Question......
  29. Metabo Bench Grinders?
  30. Some more DIY LED lights
  31. Question for our Canadian cousins
  32. OT? Fastest cars (and other vehicles) in history 1894-1914
  33. I need to have a 3D model made
  34. Video: Tool Post Lock Nut and Handle
  35. Interesting (and awsome) cutting technology
  36. Calibrating Homemade Precision Level - A Complication
  37. Drill Press w/ Dual Range Side-Shift Transmission
  38. Pressure Req'd to Roll-Emboss Wrought Iron Strip
  39. Opinions on this cheap bender?
  40. OT - Recovering gold from Pentium Pro chips, fascinating if not very economical
  41. New to me dividing head questions
  42. OT Craftsman brand being sold by Sears
  43. bought an LED lamp
  44. Does MSC offer a free shipping and no minimum as Enco did every so often?
  45. Internal threading
  46. OT video card
  47. OT: Fishing rod repair (some machining content)
  48. How to adjust lathe gears (straight gears)/
  49. OT: Smart Phone Memory Usage/Size?
  50. Fusion 360 for Absolute Beginners: Videos
  51. Bandsaw cylinder refill
  52. ER50?
  53. Rifle question.
  54. OT: Completely OT, NEW CAR RITUAL
  55. OT: Tablet - Samsung Galaxy Tab A 10.1
  56. atlas 618
  57. Nove type Woodworking Chucks?
  58. OT: Propane gas dryer venting
  59. GOLDENROD Oilers w/ Plastic (weep-proof) Body
  60. Interesting industrial places to visit in England
  61. Update
  62. Supermax mill checkout procedures/tips?
  63. New kind of wood chopper. Yes, welding and machining involved. Mind your fingers.
  64. Help with D1-3 camlock dimensions
  65. Taïwan lathe spindle taper & center
  66. Dies for threading OD stock
  67. can anyone and remember off topic no machining input whatever ?
  68. bridgeport on myth busters
  69. Large tool holders
  70. ot: replacing an electronic ballast
  71. Lifting/handling Bridgeport mill types?
  72. Podcast - Episode 2!
  73. Bosch Power Draw Bar
  74. Info on a Carroll dividing head
  75. can anyone help me yet again please?
  76. Excello 602 deep thoughts
  77. as O.T. as O.T. can be: stupid horse
  78. Ontario Guys--what tax did you pay on machine tools brought in from USA
  79. Taig Mini Lathe or CX704 from Busy Bee (Newbie Question)
  80. American tool pace maker late 16"
  81. My very steep gradient driveway? Engineering content within.
  82. Boring Center Hole in Chuck
  83. Jacobs No7 Drill Chuck rebuild kit
  84. air valve & cylinder freezeups
  85. OT: update on my work
  86. Special Lathe belt grinder
  87. What are your thoughts on this tool grinder?
  88. Edelstaal Lathe
  89. OT - Wet roads vs. tire wear
  90. Cheap Small Quantity Chemical Resistant Coating
  91. Is this written by idiots?
  92. Who is going to Cabin Fever this weekend?
  93. I so need one of these!
  94. Grizzly GO768
  95. 6" Long Gage Pin Source
  96. OT, anyone want to settle an automotive spindle debate?
  97. Remember I saw this first! any takers out there no affiliation.
  98. Follow Up on Milling Attachment for the Lathe
  99. Nearly OT: What is the correct way to set aplit adjustable thread cutting dies ?
  100. Bending Stainless
  101. have ever used Savogran Wood Bleach oxalic acid to remove rust
  102. iam doing a bicycle rebuild and to get to bolt can I bend a wrench to fit
  103. Square/Hex 5C Collet Block Recomendation
  104. Jones and Shipman 540 Washer
  105. Tempered Glass Screen Protectors...... ?? OT
  106. hydraulic pump for press question
  107. Help With Polishing & Sealing
  108. OT:Any Wood Cookstoves out there
  109. Taper on internal boring?
  110. Lightweight Steel Stronger, Cheaper Than Titanium
  111. OT - Garage / Shop Electric Heater and PID Temperature Controller
  112. This Old Tony on grinding HSS tools
  113. Tricky Bearing Removal
  114. 3 h.p. Single Phase Compressor motor question
  115. KO Lee B600 advice needed.
  116. Help wanted on L00 chuck fitting
  117. Spindle Stop for Round Column Mill Drill
  118. Your go to inventory is..
  119. How to Hold Small Drills in Albrecht Chuck
  120. OT: How To Sell A New Tool Idea
  121. How much new?
  122. OT Yard Sale Find
  123. One for the gun gurus..
  124. must see but of topic brilliant
  125. New Old School Lathe, what lube do I use
  126. Cutting down a bearing race
  127. Dividing head fixture
  128. O/T: A term? Balls to the wall or Balls to the wind.
  129. Battery Tab Spot Welder
  130. love my new little addition to my lathe
  131. Improving the bulldog trailer coupling
  132. Maybe OT but I have 110 V MIG welder question.
  133. Which lathe- and what might be important
  134. OT- Ham radio
  135. Grizzley toolpost grinders any owners or opinions
  136. Three phase motor testing
  137. OT: D.B. Cooper search with new evidence
  138. Wilton drill press 2015 question
  139. I need to design and build a sheep release pen
  140. How does Starrett do this?
  141. Common for scrap yards to sell to public
  142. OT Old folk song from the USA
  143. Heavy Armor for DRO cables
  144. Using Woods Metal
  145. Drill bit gloat... and questions.
  146. Height Gauge Depth Arm
  147. Dropped another clanger !
  148. Good cheap variable speed motor with true feedback
  149. Posting video link?
  150. Quick Change Tool Holder
  151. OT? DIY moldable or castable ferrite using iron powder and room temperature ceramic?
  152. Do you like your bump knurling tool?
  153. Small magnetic LED Light $6
  154. a couple of small spray painting discoveries
  155. Swivel heads for shop made machinist jacks?
  156. Milling carbon and mild steel on small mill with no coolant system?
  157. Tips for Drilling Small (0.4mm) Holes
  158. For those who have watched Tony's diy fly cutter vids.. discussion.
  159. DRO mounted to "chuck side" of cross-slide
  160. VIDEO: Making a miniature boring head, part 1 of 2
  161. MSC Free Shipping Code
  162. Wells Index 745 weight?
  163. My Photobucket Account Not Working
  164. indexer
  165. What are your "alternative" material sources?
  166. OT: hex key shootout: Asian imports vs. Unbrako, W-Germany Stahlville and AMF
  167. I think I have a toolpost grinder
  168. Using a VFD to power multiple 3Ph items. Remote control question
  169. Cabin Fever Expo 2017
  170. Repair Cafe: Volunteers Repairing Misc Items for Neighbors
  171. OT. Car tire chains protection from rusting
  172. Uss north carolina
  173. Nov.-Dec. Home Shop Machinist magazine
  174. Phase Converter for my 1 HP Bridgeport
  175. Cam Pin Stuck on Insert Toolholder
  176. On Netfix: 'Plane Resurrection'- restoring WW2 warbirds
  177. Steel storage help needed
  178. rotary filing machine??????????
  179. saber saw, what's best?
  180. Software for engraving dials...?
  181. How deep to expect holesaw to cut?
  182. Annealing Question
  183. 0T is this a motor speed control breakthrough
  184. I am looking to buy a rotary table?
  185. Has anyone here ever cannabilized a good running machine for the variable speed motor
  186. H.P. gas cylinder regulator
  187. Round column mill drill anti twist mod ???
  188. Z Axis Pnuematic Counterbalance or can I safely put a hole in this cast iron
  189. Does anyone make nuts for self-drilling sheet metal screws?
  190. Tricks for dial engraving?
  191. Gearbox seals
  192. What is 260 brass like to machine?
  193. Auctions for used machinery?
  194. OT: Cold Saw Motor and Gearbox
  195. Best inserts for finishing gummy 1018?
  196. What that holesaw question was about....
  197. Woo Hoo! A Bridgeport!
  198. OT- Snow Blower
  199. TIG Welding Micro Heads
  200. Powered hacksaw!
  201. treadmill teardown for dummies
  202. Self Setting Parallels for the Drilling Vice
  203. Indexable cut off?
  204. Model project in mm want to convert to inch question?
  205. ID of drill rod
  206. Bit for a homemade carbide scraper??
  207. Question On Diodes.............
  208. VFD's; digital vs analog
  209. ugh, painted over nameplate!
  210. Did that lever feed deal again..... it worked acceptably
  211. Source for micro butane cartridges....
  212. England and EU Model Engineering Shows
  213. What is happening to us ?
  214. My Sons new car making it dog friendly??
  215. youtube video 50 ton shop press build. Question
  216. OT: small update
  217. Painting old machinery
  218. w/tb grizzly owners manual -gh1860
  219. Political Posts
  220. Serial numbers and dating Bridgeports?
  221. Got My First Drill Press
  222. lathe work on stainless
  223. UV LED questions!
  224. buying mobil vacra #2 ????
  225. OT: Paint roller washer.
  226. Jet 1024 lathe change gear pressure angle
  227. American tool pace maker lathe
  228. Scraping-another marking material quesion
  229. OT Paypal ?
  230. Any reviews on American sun products?
  231. Tempering drills
  232. [3D Printing] 3D Printing Superthread!
  233. Rupnow Overhead Cam-Air Cooled
  234. Cutting with a round cutter on the lathe
  235. My first wheel cutter
  236. A brass & aluminum pen
  237. OT: Did the DNA test thing
  238. My compressor blewup tonight.
  239. Lathe Drawbar Project (with video)
  240. Trip to western US
  241. My $175 opener for a roll-up garage door
  242. OT: Lethal pellet rifles?
  243. Air Regulator Question..........
  244. Buying a granite plate for scraping???
  245. Chuck jaws
  246. Experience with Weiss Machines?
  247. looking to replace 8" chuck with a 10" or 12" thoughts on size and make
  248. Rust inhibitors
  249. MSC: "A single user account can only be used on one computer at a time."
  250. Straightening Armature Shaftt
