View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 [258] 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Planer gauge angle questions
  2. carbide vs hss question
  3. South Bend Tailstock info needed...
  4. Help identifying/setting up a lathe
  5. What to do with this
  6. Alternative galaxies - WAS Antikythera mechanism
  7. First use of my new mill.
  8. Really amazing sundial.
  9. OT: Magnet wire Qs
  10. How much $$ to have a worn out Bridgeport professionally rebuilt?
  11. What made you guys first?
  12. OT: Charging a car battery
  13. 30 Minute Swarf Separator / Cyclone for the Shop Vacuum
  14. OT-Vintage Ultralights NOT A FOR SALE AD.
  15. Before there were MACHINES
  16. Ever need a small motor cheap?
  17. New Bench Grinder in the shop
  18. WTB
  19. Help Identifying Surface Grinder
  20. Carbon monoxide from 3D printing???
  21. Metal fire starting sticks. Proper use?
  22. Let's talk about built up flywheels
  23. Hydrogen has been turned into metal
  24. Scraping questions please.
  25. Anyone have that machine you don't know how you did without it!
  26. My Bridgeport has suddenly become magnetized
  27. VIDEO: Making a miniature boring head, part 2 of 2
  28. Curious About Walmart Drill Press
  29. Your favorite spot to buy HSS?
  30. Wanted: Factory Workers, Degree Required (NYTimes)
  31. Machine name tags badges
  32. First Robotics?
  33. Sharpening Carbide Tipped Saw Blades...... Grinder Set Up Ideas
  34. Worlds smallest quarter inch ratchet homemade sort of
  35. NEWBIE (Home Hobbyist) - Looking For Advice/Direction
  36. The blankety, blank HP printer ink deal...
  37. Rust Removal Taig Lathe
  38. Any Good Floor Mat Buys?
  39. Anybody know what this material is ?
  40. Mini mill/lathe combo Cnc conversion?
  41. Metallurgy and springs
  42. Shop vac recommendations?
  43. Searching for post in long thread
  44. Reaming hole
  45. Slightly Off Topic -- ShopSmith Woodworking Stuff
  46. OT... Hmph... GM brake lines.
  47. Logan 14" disassembly
  48. Who was looking to buy 7 x - lathe
  49. Drill chucks and engine brakes
  50. Garage insulation ?
  51. See Through Engine in Slow Motion-Smarter Everyday
  52. Add plain extension to threaded rod?
  53. Experience with Birmingham Lathes?
  54. Machining perspex
  55. Lathe Back Stop
  56. just got a Enco 110-2034 lathe
  57. Need some ideas on dismantling 3jaw chucks
  58. off topic george but non political Alistair
  59. Mounting a limit switch
  60. Pallas horizontal mill, help required please
  61. Electrolytic Capacitor help
  62. Help identify thread size metric or un
  63. Intro and my machines
  64. Craftsman Commercial Lathe: 101.28990?
  65. Imperial/Metric Fastener Equivalents Chart
  66. OT: New Robot's Amazing Agility
  67. [OH REALLY] "We have replaced your mercury switches with Hydrargyrum switches..."
  68. All American Die Filer
  69. OT: bought a Win10 laptop......
  70. McMaster Carr.. manufacturer info or country of origin for items?
  71. How to find out what insert an auction find uses
  72. parting tool for brass
  73. Oiling a Logan Gearbox?
  74. new grinder
  75. OT: Autonomous car progress.
  76. Advice for replacing mill lead screw
  77. Loosening work
  78. Need electronic help
  79. Thread Gauges
  80. Armstrong and Allen brand hand tools being discontinued
  81. Congratulate me.
  82. Belt Grinder Speed
  83. O/T: Sorry. A Train question.
  84. OT: Post Pounding and Damage
  85. Help salvaging a Kurt D40
  86. Can runout and or shaft deflection cause kickback?
  87. Question re: 15db car radio amplifier
  88. Central machinery HF 14 X 40 gears
  89. Advice needed on using ceramic turning tips.
  90. 4 x 6 Band Saw Decisions
  91. Chinese elect motor help
  92. OT - A little personal nostalgia - Enterprise CVN65 Decommissioned
  93. 1018 or heat treated 4140?
  94. Enerpac P80 10k
  95. what do you whish you had done long ago?
  96. O.T. Canada Geese heading south in droves
  97. Using a wall switch for motor power?
  98. Free to a good home that needs it
  99. Fishing lure jig
  100. Lucky shot
  101. Centering stock in 4-jaw
  102. OT Motor magnetizing transition currents
  103. Excel PL 918
  104. Self centering vices-- a gimmick or useful tools.?
  105. Podcast - Episode 3!
  106. What name is given to this joint?
  107. Sort of OT: Merco Marine products
  108. OT voltage rating for full plastic transistors
  109. A bearing travel rest for Atlas Craftsman 12 inch
  110. Getting A Machine Up On A Pallet
  111. You guys cal can know everything about 'chenery!
  112. OT: TwinTundraTrak
  113. Ideas for cutting this tool
  114. Tool Oil Recommendations
  115. 'Grammium' and the making of the Grammy Awards (NYTimes)
  116. wiring 230 volt motor
  117. How close is "close enough" for work in a collet chuck?
  118. OT- Over the air Antenna
  119. Convert for LED bulbs in the shop
  120. Phase converter help
  121. New to me Cushman Truckster, Great for around the farm & just what I need!
  122. Odd effect of LED light bulb
  123. Turning 4140HT lead screw
  124. Project report: Machined a mold for bucktail fishing jigs
  125. Anyone else enjoy vintage magazines?
  126. Cylindrical square questions
  127. tell me about D3 tool steel
  128. OT: software that does a COMPLETE drive backup...?
  129. Coil Springs
  130. Need a source for I.D. and O.D. splined shaft
  131. What happened to IASCO-TESCO?
  132. HSM/MW back issues
  133. Lenz LPA S-2, Boring Head manual/info required please
  134. Bomey old German lathe
  135. Frustrations with a computer! Windoze10, Ubuntu, EUFI, BIOS
  136. So, I built this turf roller out of an old air compressor tank.
  137. Struggling with carbide scraper polishing
  138. Clausing Cooling Pump Wiring?
  139. OT: 30 foot Wasp & Hornet spray
  140. OT: Not entirely off topic, electronics
  141. Shop Crane suggestions
  142. Perhaps a dumb question but I just wondered if?
  143. I have a request to make pretty please type of request.
  144. why not both on alternate days of topic
  145. OT: Help Finding Part For Kobelco Micro-Mini Excavator
  146. Amazing, beautiful, relaxing video for the true craftsman in you. Enjoy!
  147. Distinguishing cast Aluminum from Zamak
  148. Needle valve for waste oil heater needed.
  149. DRO Happiness
  150. Inlay & Engraving
  151. Extra Fine Feed For Mini-Lathe
  152. Any Onr Heard Of Some Sort Co. ????
  153. LMS 3990 mill table thickness issue?
  154. My Library
  155. Simple lathe tool height setter
  156. Yes OT - Stink bug question
  157. need help reversing rotation motor rotation
  158. Drafting Pencil Sharpener
  159. Linley jig bore...
  160. Rivet snap machine
  161. Craigslist = flat spot
  162. Affordable and decent quality DRO?
  163. Tempering 01 steel
  164. Oroville Dam disaster
  165. OT: "Service" or lack thereof....
  166. Swivel angle plate. One hinge or two?
  167. What is the factory finish/coating on Aloris tool post & holders?
  168. Shortening a digital scale
  169. Looking for Tripan 111 dimensions
  170. Bandsaw is now running on vdf
  171. Growing up
  172. Eagle #66 oil can clones.
  173. Alternative to VB collets
  174. 1932 Pierce Arrow Club Brougham 53 part
  175. The expensive dibble broke, so I built a new one.
  176. Pipe threads on a manifold block?
  177. Bijur Bridgeport oiler rant
  178. McMaster-Carr catalog available
  179. OT Chevrolet Pickup Silverado Engine Failure
  180. OT - Shopsmith converted from crushing dreams to grinding meat.
  181. [casting] Aluminum melt and PLA-resin cores
  182. OT: What's up with brittle polypropylene food containers?
  183. OT Dell laptop battery wierd isues
  184. Thinking of upgrading to a larger lathe
  185. Locomotive horn CAD drawing
  186. OT: Kubota engine parts interchange?
  187. OT - Turf roller - ground compaction vs aeration
  188. Cylindrical Square Project
  189. OT - phone scam call - never say Yes
  190. 5C End mill Angled Grinding Fixture.
  191. spindle swap
  192. DRO install question
  193. Boring head on steroids
  194. I dont think this is you suck worthy but still a good craigslist catch
  195. Surface Grinder OD Grinding Fixture
  196. OT: Learning to Fly
  197. Congratulations to This Old Tony
  198. Missing some Thrud words of Wisdom
  199. OT - How to deal with email scammers (BEAUTIFUL!)
  200. DIY Collet
  201. Building the Trent Pinion Mill
  202. Impact drilling revolution
  203. on topic engineering accident could have been worse warning stupidity on my part.
  204. Edge finder measuring problem
  205. for the guitar guys here I have to check with you?
  206. reassembling 12x36 lathe
  207. NEMES Annual Show 18 February 2017
  208. An introduction to my Grinding Rests
  209. Press fit bearing hole
  210. Make a Large dia precision spindle using engine bearing inserts...with no scraping ?
  211. Chemical Resistant Gloves
  212. Acme thread form...
  213. Taylor Dunn
  214. Rivetr squeezer
  215. Waaay O/T MP3 player
  216. Bench master horizontal dimensions needed
  217. Fixing Household Appliances?
  218. W-32 model engine
  219. DIY air compressor
  220. HHIP or Gator chuck for rotary table?
  221. Best adhesive for steel to plastic?
  222. Heat shrink insulation
  223. Problem with 1340 lathe countershaft
  224. Protector plastic(?) on cutting tools
  225. Logan 816
  226. garage ceiling
  227. diy cold saw ideas.
  228. OT? Wild Idea That Needs Really Inexpensive Speech Recognition
  229. Stepping backward? Woodworking
  230. A new CNC project begins!
  231. New Harbor Freight Lathes and Milling Machines, including Geared Head
  232. FTPA leads to karma
  233. [idiots, everywhere] How NOT to hire an employee...
  234. Contrasting Finishes
  235. Dial test indicator finger adjustment
  236. 21st Annual NEMES Model Engineering Show Photos
  237. Kudos to McMaster Carr - great customer service
  238. Well... I ordered a 3D printer
  239. Steel to cast aluminum adhesive?
  240. Machine screw help please
  241. Converting speed controller from foot to hand
  242. Fusion 360 shortcomings
  243. Maybe OT; NASA to make major announcment tommorrow
  244. 17" Whacheon lathe spindle nose is not L or D what is it ?
  245. helicopter in New Zealand 1974
  246. Kinda OT, GM Aluminum heads?
  247. linear bearing help
  248. SORT OF OT: straightening stainless coil
  249. OT? E-bay's Petition For Keeping Postal Rates Low
  250. Why the delay in LED shop lights?
