View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 [259] 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. OT: Motion Mountain physics text available in new edition
  2. Buffalo metal cutting bandsaw gearbox lube??
  3. OT: Trouble with adapting PC output from DisplayPort to HDMI
  4. Paint for utility projects
  5. Cerrobend revisited
  6. OT - Harrison Ford pilot error
  7. Daimler at the Rose Garden
  8. OT doctor on call MIA
  9. Lathe Knife Tool and Boring Tool Sharpening
  10. Anyone their own make Diacro 'teardrp' tubing dies?
  11. Manufacturing in the USA. Plastics seem to be something widely available.
  12. Teach me about interlockling labyrinth seals (please)
  13. Po' man's mag drill.
  14. Burgmaster model #1D collets
  15. [LASERS!!!] Photographing Lasers In Action
  16. OT: sort of - missing socks and rulers
  17. OT: Warning... <rant> eBay is a joke.
  18. Shrink fit question.
  19. In Need Of 3 3/4" Or 4" Dia. Brass
  20. Quick change tool holder modification.
  21. tailstock question also large Hoffman dividing head?
  22. riviting parts and rust prevntion
  23. OT: Dymo1000 labels
  24. hydraulic thumb
  25. A different kind of makers club in New Zealand
  26. What kind of way lube is this?
  27. Heat treat furnace control install problem.
  28. Burnerd Chuck: Cracked Operating Screw
  29. Tool & cutter grinder workrest update project
  30. Nuts!
  31. Electric question on 12v and 24v?
  32. Knight Foundry
  33. Looking for an Air Filter for my Gast.
  34. Drill batteries
  35. Why don't 4-jaw chucks have better centring graduations?
  36. Spotting paste??
  37. Bridgeport M head Quill spring
  38. Can Anyone Identify This Vise?
  39. Shaper happily whirring away and cutting........Finally
  40. Shaper happily whirring and cutting........Finally
  41. D'Andrea Boring Head
  42. Mystery Lathe???????
  43. New shop equipment?
  44. 4140 Question
  45. QCTP questions
  46. OT understanding colors ...
  47. Shapers - relaxing or boring ?
  48. Syringe for Coolant
  49. Chevalier QP1620 Machine Review
  50. Choice of steel
  51. Ot Maybe- Another what is it
  52. Lube ? for knee mill vari-speed
  53. OT: Located in Miami Beach at the moment.
  54. Engineers level recommendations
  55. Setting up with insert tooling on small/medium lathe for budget (less than 100usd)
  56. OT: Solar electric questions
  57. Electrolysis, and cast iron.
  58. OT: PayPal/Ebay question
  59. My tool gloot
  60. Grinder modification idea.
  61. OT found an Iphone on my property
  62. Wanted: Ammco shaper guards
  63. Another showing off the Shaper thread
  64. Indicator Stand Articulated Arm Retrofit
  65. CNC gizmo in salvage. Worth picking up?
  66. Anyone need a big LeBlond lathe
  67. OT: $6K???
  68. Help with P&W 10" engine lathe
  69. Scotch-Brite / Bear-Tex pads
  70. Slowing hydraulic feed on Atlas bandsaw?
  71. Metrology & Precision Drilling
  72. Cleaning silicone off S.S. to weld.
  73. What have I done ? OMG, what have I done ???
  74. Looking for prints/drawing of M25 pedestal mount socket
  75. Buyer's remorse????
  76. O/T: EBay is Harmful: To My wallet.
  77. Making videos of machining related stuff
  78. Expo update 2017
  79. How can I REDUCE the range of a garage door opener?
  80. Coffee Pot Warming Plate ????? OT
  81. Model Engineering shows
  82. Mig tank refill question
  83. Metal in a microwave?
  84. Quetion for the Brits about paint.
  85. You folks really cause trouble!
  86. Can anyone identify this plug?
  87. Photo heavy welding turntable
  88. lathe bar support question
  89. Scrap bin warning
  90. Lathe test bars
  91. I went to Radio Shack and...
  92. Setting up EMC2 on PC.........??
  93. Do split/spring tool holders work well in a shaper?
  94. Tooling ID needed
  95. Unknown lantern
  96. Great Source for Machine Shop Techniques
  97. Cleaning silicone to weld. FOLLOW-UP
  98. Lathe is leave an very odd surface finish
  99. A single cooling/lubricant product for a hobby machinist?
  100. What happened to the post where the fellow reached in and caught the endmill?
  101. New To Forum - Need Lathe Advice
  102. Left hand drill bit advice please
  103. Slightly OT, Hall effect sensors and absolute encoders.
  104. Lathe lamp on CL
  105. Your machine weigh over a million pounds?
  106. OT: 3-wire service, 4-wire device
  107. New Zealand hearse
  108. Spindle lock question
  109. Things you should know, but probably don't.
  110. Canadian Stainless 18-8 Threaded Rod?
  111. What are they?
  112. Klaiber T&C Grinder - Spindle oil
  113. Starrett Combination Squares
  114. 1-wheel cut knurling tool
  115. Slitting Saw and Dovetail Cutter, sharpening.
  116. Home Built Aluminum Boat Trailer
  117. 42% OT - Making Springs and Making Ketchup
  118. method for making a dome
  119. Capacitor Calculation for Steinmetz Connection
  120. Any one need a shaper ?
  121. OOPS! ........ one way to hide your mistakes
  122. OT - Photoshop Problems
  123. Copper sulfate solution help
  124. Cant figure why lathe tool is grabbing while facing
  125. OT- Random Playlist Program
  126. Odd grease fitting
  127. Freebies for local in need?
  128. Tripan question for Stefan
  129. OT: RIP John Surtees
  130. who to drill and tap Reynolds "531" need help on it
  131. Looking for a CNC tech in CT
  132. Where to Buy Small, Three Phase Motor
  133. OT: Anyone own / ride a Lambert?
  134. Machining new hubs for Pallet Lifter
  135. New machine
  136. Free treadmill motors
  137. New shop saw
  138. Cutting stainless sheeet panel - realm of the unreasonable
  139. Cheap/Free Hub & Rotor Case
  140. Needing parts for Harrison / DoAll M300
  141. Round peg in a round hole (but that same size)
  142. Help with pronunciation of a german to English translation.Please? Alistair
  143. How dangerous is this?
  144. disassembling angle grinder
  145. Shop made custom punches.
  146. How not to store quenching oil.
  147. Hello
  148. The most pristine Myford Super 7 on the planet? - on CL
  149. WWII-era 525,000 pound upsetter returned to US from Russia for rebuild (March, 2016)
  150. 3/4" ingersoll rand super duty impacts. Keep or sell ????
  151. OT-adhesive remover better than 3m?
  152. Discussion on making/assembling a pressed one-piece crankshaft
  153. front wheel drive- powering only one half shaft
  154. Help with used ultrasonic cleaner
  155. brass or bronze
  156. Compressor motor - high current draw
  157. Broken drill save.
  158. Four Facet Drill Sharpening and Grinding Wheel Dressing
  159. Help: what are welding cable connectors called?
  160. Building a mill vise parallel bar storage box
  161. Mathinh Die to project, metric.
  162. OT how do i record a tv show?
  163. OT: electronic contact cleaner on ram memory...?
  164. Help Needed With a Tail Stop Issue
  165. Model engine flywheels
  166. OT: Volvo Sun Visor And Dykem Blue Layout Fluid
  167. Dry Ice weight calc
  168. Rivets and hand tools
  169. Just to shame those folks who have larger power machines
  170. Forking a Bridgeport with a case 1840 5C skid steer
  171. Buying a used Lathe
  172. OT Strange power supply configuration
  173. Craftsman metal band saw drive gear
  174. HF Mini-mill Runout
  175. Machines needing rescue near Charlestown IN
  176. Hardinge with cool old semi-auto controls
  177. using welder to power motor
  178. Should I have bought a smaller vise ?
  179. Good morning & Hello
  180. Lathe tailstock centering
  181. Can this SS be soldered?
  182. Logan 210 spindle collar thread size?
  183. Phosphoric acid for freeing rusted threads?
  184. New to metal lathe concepts....what or how were these made
  185. Should I have bought a smaller vise ?
  186. Benchmaster Restore
  187. Forklift based bench press
  188. Clean up time, theraputic, or evidence of having OCD?
  189. Nothing going on around here
  190. Happy St. Patricks day to you all!
  191. OT; email problems
  192. OT winch remote
  193. need information regarding making or buying sector arms for dividing head hoffman?
  194. Looking for gears for Monarch 12ck
  195. Rear mounted quick change tool post on 70 yr old bench lathe
  196. Enlarging gear bore
  197. Jet Bandsaw
  198. OT CPU at 100%?
  199. OT-Motor Oil?
  200. Introduction
  201. OT: semi update re my work
  202. spin casting and coriolis effect
  203. OT- Help me understand GFIC in a garage
  204. Semi-OT: Another round of "What's this aircraft part?"
  205. Cleaning out Bridgeport table ways?
  206. Mill/Drill Modifications
  207. Collet holder in small Lathe?
  208. Password Reset ?? How to ??
  209. Small project for POS boring head
  210. Synchronous induction motor?
  211. DSG spindle taper
  212. Band Saw rescue
  213. P Type Parting Blades & Aloris Tool Holders........??
  214. Need to add friction to tool holder nut
  215. How It's Made: (Starrett) Dial Indicators
  216. Prep before painting
  217. I've been cooned!!! o.t.
  218. OT: GrassRat, a.k.a. muskrat
  219. Horsepower for South Bend 13" lathe?
  220. For the collector
  221. Has anyone heard of the go-well manufacting company Taiwan?
  222. Should I Worry About These Weights Flying Out ????
  223. Maching
  224. 2" stroke dial indicator on tailstock
  225. OT: New battery technology: fiberglass matrix + metallic sodium
  226. Cutoff/Parting Holder Info needed
  227. April-May MW cover photo..... April Fools?
  228. Travers 1 day sale 30% off
  229. O.T computer deal gone wrong
  230. OT: TEFC motor air flow
  231. Service life of infrared heaters?
  232. evidence of a nice tram
  233. Friction nut results
  234. A pair of interesting documents from Barden Bearings
  235. Holding Knurled Aluminum Rod In Mill Vise
  236. Best source for LPS 3 in gallon?
  237. CNC Machinist noob
  238. OT Rotab indexing
  239. How to test Treadmill Motor
  240. Lubricating rollers for saw infeed/outfeed
  241. Downsizing from large machines.
  242. OT Wood-fired boiler (furnace?)
  243. Free Lathe
  244. What can I do with a motorized wheelchair?
  245. Atlas lathe question
  246. OT - How would you clean these grills/grates?
  247. Thinking about donating machining services to Disabled Vets, any thoughts?
  248. Belt grinder plans?
  249. I Can't Believe Cored Bronze Round Moved
  250. Substituting 6201 sealed bearing in place of metal shield units
