View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 [260] 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281
  1. Mounting a right angle attachment using shims
  2. OT. Tig water cooler pump question
  3. Drawbar material
  4. Linuxcnc Q and A
  5. DSG 13/30 oil leak
  6. Newbie Question: Lathe Leadscrew Handwheel
  7. back from Baja
  8. I brought home a new mill
  9. Introduction - New Member
  10. Best finishing steel
  11. Craftsman / Atlas bandsaw 108 ?
  12. Combination metric and Imperial hand wheel scales on our machines
  13. 15,000 of these things to modify!!!
  14. Need a tachometer for my motor
  15. A new tool made
  16. Collet Chuck - How does it work?
  17. Myford Lathe Motor Conundrum - help, please?
  18. OT Makita cordless drill'screw driver chuck problem
  19. Temperature finding question
  20. Need Face Milling Advice
  21. Good price on steel digital calipers
  22. Lathe Motor Question
  23. Wheels for classic old Delta 1 x 42 belt sander...
  24. Spur Gear cutting advice
  25. Repairing Broken Tailstock Lock
  26. High pressure rotary seal design, ideas welcome
  27. Tool score
  28. coating on brass
  29. Sjogren Speed Chuck- zero settable?
  30. dirty old pickhill arc welder looked too nice to ignore so I bought it. LOL
  31. Watt meter on my Mill
  32. Tach from VFD?
  33. Value of a Hegner scroll saw.
  34. Z-axis counterbalance air balance air cylinder?
  35. Zoro discount 2 days 20 and 25% off
  36. Gas lift strut question
  37. Incorrect dial on my Acra RF45?
  38. OT: Do you care if your ISP is tracking your computer usage...?
  39. multi spindle for those 15K pieces
  40. Bearings for fixed steady
  41. Pre sharpened HSS insert tooling from Arthur R Warner Company
  42. 1.5mm MGMN150 parting/grooving inserts, anybody dare to try?
  43. How to repair bottle jack
  44. Free triacs
  45. Rotary table help
  46. suicide doors
  47. Norman's concrete mixer adventure
  48. Way way OT: home town theatre
  49. Lithium battery question
  50. Strange Computer Screen Glitch.........OT Anyone See This Before??
  51. Pin Punches
  52. That new Sodium battery
  53. A small gear making task that might interest you
  54. Spindle Bearings Rockwell 21-100, Use Double Row 40BD6830?
  55. need help with oil specification
  56. Somewhat OT, concept for Selsyn driver, will it work?
  57. Free electric motors
  58. Huet drill blanks
  59. Lapping 2.5” diameter aluminum bore
  60. Back when I was dumb---
  61. Way OT Antibitic Warning!
  62. New Siege X2D mini mill rebuild
  63. OT: (DIY) Beef jerky
  64. Milling hard-ish steel
  65. Installing tachometer on my lathe
  66. whats a good VFD for 2hp 220V SP input
  67. Give it a try, or strip it down?
  68. RPM for lathe work using HSS tooling
  69. Need Worm Gear
  70. Clausing 8520 Table Lighting
  71. I'm blaming Sir John for good service!
  72. OT: Cool Mind Bender Video
  73. O.T. foldable smartphone???
  74. How to add drawing / change permissions?
  75. Semi OT need a gear
  76. The only way is up
  77. OT: Anvil mounting
  78. Several questions about my lathe
  79. Motorcycle machining work
  80. How to Corrugate Thin Stainless Steel?.
  81. Steady rest setup question?
  82. Work light around Machines?
  83. Really digging the article on accurizing an Arisaka.
  84. something wrong with this site?
  85. Bridgeport Tramming Mystery
  86. I thought there was an article and author index on the site?
  87. Did I get it close enough to zero?
  88. OT: shingles sawmill video and phantom pain on imaginary missing limbs
  89. Is it me? Bearing ID tolerance on radial ball bearings
  90. Getting to the correct forum
  91. OT Harbor Freight Settlement Scam?
  92. Drip vs. Wick Oilers for Lathe
  93. Wear resistant steel?
  94. OT, Am I the only one that thinks something is fishy in Atlanta?
  95. OT - This place looks like my house
  96. I couldn't do this again if I tried.
  97. L.S. Starrett Factory Tour
  98. Milling machine and value question
  99. It must have leaked since it was made...
  100. Dried grease in bearings, best oil to add...?
  101. Threading 1/4" stainless round bar
  102. seems like it should be easy to find - HELP! dual vee-belt pulley
  103. RF 45 clone for small engine work
  104. The design of electric motor brushes
  105. Wanna chuckle anyone?
  106. Rotary Weld Table - build video
  107. New member Introduction
  108. Gang drill update
  109. Machining a collet adapter for South Bend Lathe
  110. Belt grinder project; steel or aluminum?
  111. OT: You know you live in a small town when......................................
  112. 3.5" drill bit
  113. Yesterday was just "one of those days", not really OT.
  114. Best place to put a Bridgeport in the shop?
  115. OT: How To Fix/Hide Scratches In Auto Paint
  116. Machining heat treated 4130
  117. OT More auto finish questions
  118. Has anyone ever tried using the modern thermoplastic to repair or get out of trouble
  119. Horologically Speaking
  120. collets 1/8 inch
  121. Stabilizing 01 Tool Steel
  122. why does photo bucket suck so bad???
  123. Rockerblock I.C.--Something a little different-
  124. plastic lens making
  125. CNC Router: Lessons Learned
  126. Way OT some advice for whatever it's worth!
  127. Staggered Tooth Side Milling Cutters
  128. Difference between Diacro #2 and #3 bender tooling?
  129. Surface Grinders & Rear Column Dust Shields
  130. Good Finish on Ends of Thick Aluminum
  131. "OT" Rebuild or Replace
  132. Soldering
  133. Interesting use for CF nano-tubes
  134. Connecting 240v heaters to 3-phase circuit – is it OK?
  135. I had a good day at the swap meet
  136. Donate to Favorite Charity?
  137. Mystery collet
  138. Black Diamond drill grinder question, also need a part
  139. Electrical Connector Identification
  140. Interesting "Horizontal" mill for sale
  141. Syncrowave 250 welder question
  142. Wohlhaupter or Narex Boring Head which one best?
  143. O.T. really need Arduino code help
  144. Cylindrical Grinding
  145. 6" import milling vise thrust bearing
  146. Wanted: Idea For Drawer Dividers For Tools
  147. youtube creators on here ???
  148. OT: I ran into my barn with my excavator
  149. OT Torque tubes
  150. What would be the worst that could happen in your shop - by a power outage
  151. Solder gun - when to replace the tip?
  152. Is this fellow still alive?
  153. GEM vs Starrett Last Word DTI
  154. Introduction for the FNG..
  155. bought a nice rotary table with tilting sin table Russian made need help.
  156. Machining down to a small diameter pin
  157. How can I make this? HELP!
  158. Way OT! I went flying over the weekend...
  159. ISA 40 Taper any one heard of it?
  160. Paraffin Lanterns. You should own one (AKA, Kerosene Lantern).
  161. Collet Dimensions
  162. Tracking issues
  163. O.T. stranded, no/wet matches - now what?
  164. OT: best android app for international from abroad calling to any #?
  165. Using space in the shop wisely. Let's see examples of multiple use options.
  166. Oil sucker break bleeder excellent cheap easy homemade
  167. clogged rubber brake hose
  168. Look what followed me home - oh happy happy me...
  169. South Bend 14 1/2 versus 13
  170. Need advise on valve cutter set up
  171. The saw project is almost done
  172. OT: Can electrical wire insulation be repaired?
  173. Advice needed to choose QCTP
  174. Simple duplicator?
  175. OT: Do we have any C# programmers in the audience?
  176. I just started a Youtube channel. What do you guys think?
  177. Not a gloat, but a damn good buy.
  178. Boring Head 3/8 bars?
  179. Removeable Lathe Chuck Jaw Standards?
  180. Save a Tool from the Scrap Man
  181. OT: CamelCamelCamel buggy?
  182. Holy Crap! or, fixing screwups
  183. Marking Boring Bars out of HSS Round Blanks
  184. Ams dro
  185. Scroll roller, anything else I should consider before pulling trigger on a
  186. OT: Ideas for keeping wasps away from shop?
  187. Anyone out there with a PM-935 mill?
  188. Johnson DC motor
  189. Buying center drills
  190. OT: Service entrance wire size?
  191. Is a 220VAC replacement motor acceptable?
  192. Rong Fu MBS 71200M Band Saw- Any good?
  193. Any tips to get the back of this chuck off?
  194. knife sharpening kitchen knives nothing fancy???
  195. Drilling cast iron
  196. odd (to me) dti stand
  197. Just Can't Find Quality Hinges Anymore
  198. MEM down again?
  199. 5C collet linkage question.
  200. Turret lathe tooling is multiplying
  201. Somewhat OT Varmint Al's Dad
  202. I'm Starting a Home Shop Machinist Club in South Central Alaska
  203. walker turner disc / belt sander parts hunting
  204. Using the lathe turret and tooling for the first time
  205. OT: eBay snivel - customer side
  206. iGaging. This 'n that
  207. Yep I suck
  208. OT experiment with Kijiji and their Admarkt thing....
  209. Convert LMS mini mill to CNC?
  210. possible suckage
  211. Upping the start up torque of an electric motor
  212. Norman's Jib Crane adventure
  213. for machine light .. ?
  214. Can I pull one phase out of three?
  215. HSM Design for an electric bike
  216. OT - Carburetor Questions
  217. Errol Groff – A Great Loss
  218. fixing my yaskawa vs 606v7 three phase inverter wiring.? 4 kw
  219. Harbor freight coupon code?
  220. yet another "what is this tool" question
  221. First Post Here
  222. Can someone recommend me a decent TPG insert?
  223. Exposed electrical contacts
  224. Just something to beat on
  225. New Toy
  226. Sticky Quill Lock on Rockwell Mill
  227. Logan 400 chuck removal
  228. What are your go to end mills on a small mill?
  229. Question on Swivel Milling Table
  230. A trick for handling end mills
  231. Do I suck?
  232. Bearing seat rescue?
  233. 5c collet closer handwheel type fitment/bearing questions
  234. Micro Wet Belt Sander
  235. Inexpensive timeclock software for the shop PC?
  236. Rust season has arrived
  237. NAMES
  238. My current project series in Digital Machinist - a Bay City Backhoe
  239. Repair shop for old electronics? Recommendations?
  240. Grinding Tires........OT A Little
  241. Help with a Neal chaser head.
  242. Bridgeport z-axis chatters / hums when table is cranked up or down
  243. Amazon 82% discount on solid carbide boring bar
  244. OT - Most realistic Model Railroad craftsmanship I have ever seen
  245. OT maybe? Depends where the funds go. Might be tooling. :D Any guesses?
  246. MSC, 30% discount and free UPS....
  247. Horizontal Milling - Where to start ?
  248. Mitutoyo parts availability?
  249. Help with Fly Cutter: Near Instant Bit Dulling
  250. FREE Large Lathe! Trying to save it from the scrap yard! Not mine BTW.
