View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 [261] 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276
  1. FREE Large Lathe! Trying to save it from the scrap yard! Not mine BTW.
  2. Missing NAMES of my tool box
  3. Magnetic "oiltite" bearing in milwaukee multitool failed
  4. Is there a market for a better 7x14 lathe as a kit?
  5. Had not trammed the mill in a year or so...
  6. Welding or Brazing Castings?
  7. sanding belt material
  8. Trouble ofering free shipping on ebay
  9. Insert Identification for a Valenite Tool Holder
  10. High speed grease recommendation
  11. 1" 5 C Collet ???
  12. which is better for de-rusting, vinegar or phosphoric acid ?
  13. Tool blackening.
  14. Anyone around Indianapolis Indiana area have a surface grinder ?
  15. Guidance making a cam
  16. Hard Turning in a Knee Mill
  17. Vtwin engine/motor?
  18. Using an indexable parting blade - broke on first cut!
  19. Vintage Machinery Website (worth saving for reference)
  20. Do I need a capacitor start motor?
  21. Why is parting off such a pain?
  22. Grandma's Oxygen Tube
  23. home made solid carbide boring bars
  24. OT: New present for the wife.
  25. best way to clean lathe metal chips??
  26. OT? (but might need machining) $20 Mountain Bike!
  27. OT: How Is Antenna Mounted On Y2K Sierra?
  28. 100% solid carbide boring bars?
  29. Power Z Axis Lift
  30. 2017 NAMES - my experience
  31. OT: Wood board load limit
  32. Recommendations for a boring bar for flat bottomed hole?
  33. 3D printer Demo
  34. Clearing swarf away from the cut
  35. Stepper Motors power supply&controls
  36. Uncluttering the shop
  37. Oil type ID?
  38. Air compressor and VFD
  39. Warner & Swasey Co. (historical links)
  40. Colt SAA revolver in 1/2 scale
  41. single phase motor won't run when I tighten the vee belt
  42. Expanding mandrel type of wheel?
  43. I'm afraid some tooling has followed me home...
  44. Heavy 10 Hand wheel collet closer
  45. What material for making TAB's?
  46. I am amazed the difference a well adjusted mill makes
  47. Magic Bandsaw Blade
  48. Lathe Accuracy: Is it me or the screw?
  49. SIEG X2 CNC Build from Castings - Few questions for small mill owners
  50. Does anyone have one of the horizontal power feeds installed on a mill/ drill?
  51. 15MM Tap......Drill Size
  52. I love presents
  53. Warner&Swasey #3 roundhead collet clearance 50 to 70 thou over nominal
  54. John Alex 141r PM for you
  55. ideas on straight and tapered gib making
  56. OT: linseed oil spontaneous combustion caught in the act
  57. Tap Alloy, Which If Any Is Better?
  58. OT: Tip On Cleaning Truck Window
  59. O.t.anyone selling matresses out of the back of their shop ?
  60. Protecting knee mill table top
  61. Chinese ballscrews?
  62. Making a bolt slot hole.
  63. Small suckage today
  64. Picture from a local scrap yard a few years ago
  65. Grinding thin plates flat using paper towels
  66. Self-balancing centrifuge
  67. Geometric Die Head Chasers
  68. Hardening a tap
  69. Facing stainless
  70. need a 5/8-12 RH Acme tap
  71. PM Research Model 5A
  72. Looking for Inch Dimension Ball Thrust Bearing
  73. Locking hub to disc
  74. what is the differance between these two cutters?
  75. OT: Grrr! Problems with Verizon FIOS email forwarding after migration to AOL
  76. Minor Tool Gloat :)
  77. Wiring a 9 Lead Motor to A Drum Switch
  78. An interesting new project
  79. Podcast Episode 5 - Dragging Iron Home
  80. Curious-
  81. ID this mill - Dormac UF1? Any info?
  82. Made a new sprayer for my orchard. Even a tiny little bit of machining.
  83. Hardinge lathe back plate?
  84. Is it ok to move gibs to the other side of the compound?
  85. I need threading tools for the lathe... Anybody here used this kind of Aloris setup?
  86. Dm45 on the way
  87. Things that make you learn fast..
  88. Nut and bolt spitting out thin metal threads? Never seen it before.
  89. Episode 3 of Clickspring's Antikythera mechanism has been posted on YouTube
  90. Dovetail on outside of cross slide?
  91. I Just Bought A Rockwell 21-100 Milling Machine
  92. Anyone Know of Mechanical or Electric Surplus Places in Houston Area?
  93. Best Approach Sheared Bolt Removal
  94. Fidget Spinner
  95. Cutting Radius Without Rotary Table: Pivoting Workpiece?
  96. Mill Vise Sizing
  97. Motor shaft rebuild and pulley runout...
  98. Jobs that stumped you.
  99. build a dance floor
  100. What kind of bolt is this
  101. OT: gold bullion found in ex-Iraqi T54 tank
  102. A Few Questions About Enclosed Trailers
  103. Reconstitute anti-seize?
  104. Re-purposing after use of disposable gloves.
  105. Opinion from a Mechanic Please.
  106. OT Gorton 375
  107. wire feed welder trouble
  108. Removing and replacing data plate rivets?
  109. 3P motor switch - so what have I got here?
  110. Mounting Bison Set-Tru Chuck
  111. OT-Exterior Secuity Light Fixtures
  112. Question - threading dial for Emco Maximat 7
  113. Rotary Phase Converter, Variable Frequency and a question...
  114. Neat project I had last week
  115. Video on tapping under power
  116. Any recommendation for an insert facemill?
  117. Cutter for 9 tooth 16/32 involute spline
  118. New Richmond mill spindle
  119. Opinions for best flux
  120. Four lead electric motor wiring help
  121. At last, my arm is whole again - surprise EvilBay purchase
  122. Opinions on tools steels for general shop projects?
  123. collet type
  124. X37 space plane seems to work very well
  125. Aluminum "tin"boat issue
  126. Knife sharpener
  127. minor gloat and fishing for ideas
  128. Metric Epiphany
  129. most practical belt width for belt grinder / sander?
  130. sort of off topic but metal related IS this a con ebay?
  131. Metric question?
  132. Minor tool gloat II
  133. looking for a half oval single cut file
  134. Round Magnetic Transfer Parallel ???
  135. When the Inch turned.
  136. Nice Craigslist score today
  137. Bridgeport DRO X-axis Scale Question
  138. Harbor Freight "wet" palm sander?
  139. OT: Microsoft Security Essentials
  140. Double thread one shaft
  141. The price of brass---
  142. My shaft is bent...
  143. Tips for parting 2" 1144 Steel?
  144. best way to flatten a 1.5" sch 40 pipe?
  145. OT - Is there such a thing--Portable DVR with HDMI input?
  146. CVA Owners? Question for you
  147. Hello Everyone!
  148. Jacobs Chuck Problems
  149. Working for money, in Home shop.
  150. Oil for mill table
  151. looking for a new lathe
  152. Spacing Parts Off The Chuck Face
  153. Rosenfors Bruk Lathe Anyone have one ?
  154. bench mill help
  155. G4016 lathe Spindle Bearing Help
  156. A bit OT: How did this carburetor float "sink"?
  157. Homeshop EDM
  158. Wedge vs. Vee Type QCTP
  159. is this really a lathe? I cannot see it.
  160. Belt grinder kit
  161. Why doesn't water based coolant play heck on machine tools I see in videos ?
  162. I need someone to teach me the band saw blade twist
  163. Electrical question
  164. I think I got a deal on some drill bits
  165. LED bulb resistor??
  166. best D R O unit?
  167. Desktop Plastic Injection System
  168. OT - Finding a vacuum leak
  169. Oh Man that's not good!
  170. Squaring up a part within .0002" on a knee mill.
  171. OT: sawdust in gearbox, really?
  172. Dozer seal ideas
  173. WTB Liquid Mercury/Quicksilver
  174. TIG separation by This Old Tony
  175. Help identify hydraulic cylinder
  176. Grinding cup "accessory"
  177. Fusion 360 software questions
  178. Powder coat oven air flow question
  179. spindle use
  180. Suggested improvements for the next generation of the dial/digital caliper
  181. Oliver of Adrian die filer
  182. odd spindle
  183. Phase Converter choice advice & other
  184. WTB Die Filer
  185. Gallium and aluminium interacting.
  186. Do you lower the knee to to avoid rubbing the tool?
  187. Help identify this Toyo lathe
  188. Worst jobs you've ever had
  189. 3 phase motor guru's
  190. air conditioner pump use as compressor
  191. might be OT, but mechanical. hex head bolts with a tapered seat?
  192. Longevity of CFL bulbs.... surprising.
  193. Building A Steady Rest
  194. OK--- For youse auto gurus----
  195. What do you call this rolling circle curve?
  196. Garage Floor Weight Capacity
  197. What is this?
  198. Posts with just a link. Do we need more? I think so.
  199. OT: What's A Good Brand of Auto Battery
  200. Portable drill press
  201. Hager tool & cutter grinder
  202. 4130 Chrome Moly Steel Tube Seamless vs Welded Seam ??
  203. The first shop tour I've seen using a drone.
  204. OT - Live Steam Forum
  205. Cushman Minute Mizer Modded! Warning You Tube links below :)
  206. Drilling on Center: HF vs "Real drill bits"?
  207. A $97,000 tapered roller bearing ??? REALLY ???
  208. History of the Pencoyd Iron Works
  209. Hacked! a water filter
  210. Lang Chang Machinery Ltd., mill/drill
  211. Installing a Align AL500D power feed on a Craftex CX601 Mill
  212. Multi-diameter drill bit
  213. unreliable flow on mill coolant pump
  214. Tool Post Grinder Wheels
  215. A case of you get what you pay for
  216. a little OT- phase shifted transformer
  217. Volvo Shmolvo I saying,,, (machining content)
  218. Wow is this well made or what? talk about heavy duty!
  219. got a new lathe from grizzly ????
  220. Sold my old 13X40 Enco to a Darwin Award winner...
  221. Shop tool bateries. The button type for calipers.
  222. Face mill feeds & speeds. Am I going too slow?
  223. Millrite AND bridgeport for 300 bucks
  224. Drilling and boring phenolic?
  225. Machine operation characteristics
  226. Chipped Grinding Wheel - Use or Toss?
  227. Looking for 5C collets by 64ths
  228. OT, Nicky Hayden Accident.
  229. Anyone else have a Heck, Model VA 400 beveling/chamfering machine ?
  230. methods for building trailer walls
  231. Phase II 8" Rotary Table Manual Needed
  232. Lathe lighting
  233. OT: The Northmen build a dugout canoe
  234. Giant turkey baster/syringe for sump cleaning
  235. OT: Cutting a 1meter x 2meter hole in brick wall
  236. How Does An Arbor Get Like This ????
  237. A question for you electrical genius's!
  238. OT: Strangest bridge crane I've seen
  239. pool diving board, spring material ?
  240. I made some videos about tramming etc.
  241. Form Taps For Different Materials
  242. Sheep Shearing Machine is voice controlled!
  243. 1/16"- 27 NPT Drill Size ??
  244. Centroid Acorn CNC control, available...???
  245. Gorton Pantograph parts?
  246. OT: Proud to be a HSM'er and the road it took me on.
  247. Slitting Across A Hole For Expansion
  248. atlas with V-ways?
  249. Joining a band saw blade
  250. Surface grinder dust control
