View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 [262] 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Wood top for lathe stand?
  2. Boston Gear 700 with a stuck motor.
  3. 0T never sharpen a lawnmower blade am I the only one
  4. The gas bottle cart is back again...
  5. Horizontal milling arbor has .013 runout - bushing, bearing, or new arbor?
  6. OT-5 vehicle pileup - i was in the middle of it! Some metalworking content...
  7. OT My unfortunate auto accident....a donkey
  8. Bending And Threading Stainless Rod ??
  9. I need an education outwith metric training , i've had so far
  10. OT New linecord for an old drill
  11. removing JT33 chuck
  12. Surface Grinder motors choice.
  13. Accurate drilling - received wisdom
  14. OT Aircraft related
  15. Coalbrookdale foundry (England) ceases operation
  16. O/T weather
  17. Confusion with finding correct rake angle on lathe bits
  18. Compact R8 drill chuck
  19. Threadlocker For Metal Nut On Plastic Screw
  20. Capacitive sensor to water surface for slideway measurement
  21. Question about painting metal stuff...
  22. How is it Done ? Pebble grain on molded plastic .
  23. Mold/pattern release material
  24. Way OT - Traveling with HSM :)
  25. Possibilities for Torque Multiplier design without the anchor
  26. ON/OFF Button Placement Convention
  27. Key way broach designations...
  28. Mounting Hole: 20.2 mm ?????
  29. RFI "Ettco" British made 3/8 cap Tapping Head (Pollard & Co. Leicester)
  30. sinpo vs easson glass scales, compatibility
  31. New history of Brown & Sharpe
  32. DB Museum in Halle, Germany
  33. What have I got
  34. "I'm no angel..."
  35. Small compressor problem
  36. copper buss bars plated with what?
  37. switching from soluble oil/water to straight cutting oil?
  38. Old surface grinder table: Scrape to improve action?
  39. Measuring force
  40. anyone have a Wiedemann R-2 turret punch?
  41. Welding ground placement
  42. What is the Purpose of this Grinder?
  43. OT-Floor Jack
  44. can someone point me to a good source for arc welder oil filled ?
  45. Grinding Length of HSS
  46. Lets see your arbor press stands.
  47. VFD convert lathe - where should i begin?
  48. OT: video of what is likely the world's heaviest weight
  49. Cheap Inserts with Full-Length Cutting Edge
  50. Need help with disassembly/assembly of Cincinnati no. 3 ? Center
  51. O.T. Water slide accident
  52. flickr or some other suggestion for a hosting site where the URL is easily viewable
  53. Where can I buy arbor shaft adaptors for a 3/4" shaft?
  54. Need Plans For Acetylene Cutting Torch Guides
  55. A diifferent LED
  56. can I trust threads on the end of a hydraulic cylinder body?
  57. How to remove oil cups on lathe saddle ?
  58. Color Choice for Lathe Power Control Box?
  59. Unknown Cutter mount
  60. Can you get the same arbour to hold. End mill face mill and boring head?
  61. Make your own water jet cutter?
  62. OT: Do you think the Stratolaunch will ever fly?
  63. Brainstorming lathe CNC conversion
  64. Getting back into the swing - machine thoughts
  65. Welding in water?
  66. Eccentric turning - not intentional
  67. Lag Bolts & Epoxy For Concrete.
  68. Power Hacksaw.
  69. Large power hacksaw
  70. Intentional lobe turning on a lathe
  71. Carbide selection help
  72. three phase motor has no data plate...how to know volts, amps, horse power???
  73. Precision Drilling with Reglus Drill Jig
  74. Machined a new anemometer mount for sailboat mast
  75. Chip breaker, concept.
  76. Are these DRO junk help from Electronic Experts
  77. Verticalised 4x6 bandsaw
  78. Custom soldering helping hands
  79. Brake lathe repurpose
  80. albrecht keyless chuck stuck
  81. O/T battery charging
  82. A problem area on the CX601 Mill and like machines.
  83. Need filler material for high density rubber that can be sanded ??????
  84. What uses for Bent Shank Tap
  85. Kennametal fix perfect shell mill info required
  86. Who has a TREE Taper Boring Head ? I'd like to have some user info on it.
  87. Armite Tapping head anyone else have one ?
  88. Anyone else have Precision Machinist Jacks ?
  89. Lathe "practice" stainless steel rebar???
  90. Annular Cutters & Search function
  91. Surface grinding finish, does grit size matter?
  92. Hitachi L100 VFD Error Code
  93. Waaaay OT: "Machinist" not what I thought it meant.
  94. O/T Power inverters from dc to ac.
  95. is there a better solution than GITS oil cups?
  96. OT: Fleeting window image on monitor
  97. Cetus3D printer
  98. Some machining actually happened today
  99. What do you think of these I-beam splices?
  100. OT- Scamming tech support scammers
  101. Query - Anyone know the width of Harbor Freight English Wheel Dies?
  102. a small crane scale and a moral dilemma
  103. OT - garbage disposal repeatedly jams
  104. OT: free solo of El Capitan
  105. "... known to the State of California to cause cancer ..."
  106. toxic stainless
  107. Boring Head Shank Mounting ???
  108. Need Advice: trouble milling arc on small mill
  109. 20 ton MECHANICAL PRESS
  110. OT: Copper corbels
  111. Advice please
  112. FNG Here
  113. OT - removing overhead phone line drop?
  114. Carbide Tipped Recip. Saw Blades, Anybody Using Them?
  115. New (to me) machine
  116. Campbell Hausfeld airless sprayer
  117. Way OT: Smooth cut can opener
  118. Metal chop saw - non abrassive-- wow
  119. Welding Helmet Shade
  120. Easy Shear Lathe Gear Shaft Key
  121. 3 jaw scroll chuck with individually adjustable jaws
  122. Ever wonder why copper, brass, and bronze has gotten so expensive?
  123. Iron Mountain iron ore mines and the Cornish Pumping Engine
  124. O.T. Question for Fly Low
  125. O/A Welding Tip?
  126. O/T: Ebay Q. About buying HSM type tools :)
  127. Band saw blade sharpening
  128. New Youtuber with a big shaper.
  129. O.T.--Just spoke to a guy who died two years ago---HuH???
  130. Rod or no rod?
  131. Holster for shop vac hose.
  132. Fire eater engine book 2
  133. CNC router kit, open source and the work space is 4' x 8'
  134. Bridgeport spindle balance problem
  135. Campbell Hausfeld airless sprayer:
  136. Best Heat Treat Alloy For Minimum Distortion After Hardening
  137. OT Pilot charging phone may have caused crash...
  138. Bad regulator?
  139. OFF TOPIC! Positive? OFF TOPIC!
  140. Spindle brake on a mill question...
  141. is this extra ordinary or normal off topic Dog question?
  142. slightly off topic Vic Edlebrock jr. passed away
  143. First hole with Tree Taper Boring Head
  144. Machinex 5
  145. O/T: Carbide VS Aluminum re: E=mc^2
  146. best way to clean tools
  147. Handscraping basics - Video
  148. Strange looking parting tool
  149. O/T Pipe bending strength
  150. mass vs heat storage ability
  151. insane in the membrane?
  152. Engine hoist hydraulic disconnect
  153. Where is the best place to find on line books
  154. making ahome made crucible.?
  155. Interesting project--Machining content
  156. Any Networking Experts Around ??? OT a little
  157. automotive electric power steering assist for mill knee lift?
  158. How do I lock the spindle? Monarch K
  159. 1150rpm vs 1750 rpm- any significant difference in torque?
  160. Powering A Sheldon MW-56-P lathe
  161. what does fireclay cost near you?
  162. Is my torch a ticking timebomb?
  163. Compressor Reed Valve Material?
  164. best place to find on line books today
  165. How do I Blast rust off a surface without damaging a scraped surface on another side?
  166. Ground Toolroom Stones: New Idea To Me
  167. Homemade Lathe?
  168. Boring bar rake.
  169. Variable flute and variable helix carbide endmills for small milling machines?
  170. Help with dowel pins
  171. KERRY 11 - 24 lathe manufactured in England
  172. OT: Old air conditioner - needs dual run capacitor 17.5/7.5 330V
  173. Shop air: Black pipe on ceiling, do I drop my lines from there or black pipe half way
  174. fan upgrade for my car
  175. New life for a neglected bandsaw
  176. Another new guy ( long introduction)
  177. Spindle straightening and repair?
  178. Zippy Shaper
  179. Powering a motor
  180. WTB Bison 10" Rotary Table
  181. Machined stuff today!
  182. Way OT: What's this root for?
  183. Investment casting
  184. Poll: Would you buy reground import tooling?
  185. Any Vertex BS-0 Dividing Head Owners?
  186. Diametral threads? School me...
  187. Tool gloat ! ! Milling Attachment
  188. off topiic you have been warned I have fallen in love all over again !
  189. Help with compressor motor problem
  190. OT: 3D Systems no longer owns Alibre/Geomagic Design.
  191. Help with my mill-drill
  192. 1/16" - 27 NPT Tap ???
  193. Help ID an older Castrol cutting fluid
  194. First visit from Forum Member
  195. Sheet metal roller(?)
  196. OT: New farm
  197. How to check Harig Super 6 x 12 surface grinder
  198. Hss 18%
  199. Tool Cart build
  200. Cleaning A/C drain line?
  201. Visiting HSM members, Great Topic Tundra Twin Track
  202. Happy Father's Day
  203. Coolant on T&C/surface grinder?
  204. WAY O/T ... But worth the watch in my opinion
  205. New project video available (hydraulic press pins/drifts)
  206. How to machine this?
  207. OT - adjustable hinge for Tortilla Press (thickness, not diameter)
  208. O.T. sea kayak propulsion
  209. Anyone ever install a Ratchet mechanism for an Arbor press that didn't have one ??
  210. OT: Excavator temp gauge is going to full extreme hot on startup of engine.
  211. How can small parts be held for milling
  212. Building a Miniature Tailstock Turret
  213. OT dangers of modern refrigerants.
  214. 3D Printer For Making Prototype PC Boards?
  215. I'm excited
  216. cutting gears
  217. Aviation hydraulic pump/motor unit question
  218. Gmail down for anyone else?
  219. Why do my lathes drill over sized holes?
  220. Granite Surface Plates
  221. Generating SLI (3D printer) files
  222. OT: Teleprinter of rare German WWII Lorenz encryption machine found on Ebay
  223. Cincinnati Airport Display
  224. Got a new tool for me!
  225. What to do with some of this stuff?
  226. Which lathe? Lathe Cord still pulsing.... IMPUT NEEDED!
  227. Me again another help me question, all accompanied with Brotherly love too. not O T
  228. One year later. PROGRESS!
  229. OT Female Aviation Mechanic
  230. VERY happy with a 'cheap' tooling purchase
  231. George, shut me down if this is a bad thing.
  232. Another big (for me) welding/fabrication project finished
  233. Building a patio table
  234. New member issue uploading images
  235. Way way OT: New sniper record
  236. best photography of machining processes
  237. Need some help with some furiously stuck screws...
  238. Not a gloat but quite interesting, but what is it part of?
  239. Turning Brass
  240. One good thing about getting married...
  241. Corrosive gas from lead acid batteries in storage?
  242. Check my math re: lye solution
  243. OT: Odd Metric Weight; WHY?
  244. off topic definitely off topic not on topic you have been warned.
  245. Allison collet chuck
  246. O/T: Target rifles and handguns. Maching story inside.
  247. Nut will not stay on the bolt.
  248. Swap Meets/Auctions???
  249. OT: White globs of snot-like gunk in mower carburetor?
  250. Free to a good home
