View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 [266] 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281
  1. HF 2 Ton Shop Crane
  2. A powered Z-axis for my bench top mill
  3. Recomendation for carbide insert and holder
  4. Industrial artifacts awaiting re-discovery [AKA Junk]
  5. O.T. strange little critter...
  6. deburing holes
  7. Looking for Kiwi Suppliers
  8. Moving thing into & around the shop
  9. Pressure Turning
  10. Boring hole tapered
  11. 3hp, New GE 3ph motors $49 @Surplus Center
  12. Help self holding tire inflating Chuck
  13. ER Collets and Drill Bits
  14. Help for an Apprentice
  15. Bolt Grades...for sure?
  16. OT-Cheapest to run-5HP pony motor or Vfd.
  17. A Tiny 3 cylinder Holt based engine
  18. Bridgeport Mill - Clatter when backgear (low speed) is engaged. (Series I - J-Head)
  19. The Great International GIANT Robot Battle - hand to hand!
  20. OT: Yahoo "Add New Account on This Computer"
  21. O.T. Spotted a praying mantiss on the back of my house
  22. Sir John
  23. drill bit jump
  24. Banggood juice
  25. U-Bolt Rolling Chart Specs
  26. A thought for a new subforum.
  27. advise for upgrading my electrical panel.
  28. semi OT - honesty on eBay about ball screws ?
  29. 3-in-1 sheet metal machine ~30" 16ga?
  30. Suggest some parts for an Acorn Lathe build?
  31. Cutting threads with a HandyBot
  32. Building your own bike frames - anyone here ever done it?
  33. New Replies to My Posts
  34. Bison, "South Bend", Gator or other 4 jaw chuck?
  35. The long tale of a vise tail...
  36. OT- Motor Oil
  37. OT; free or cheap photo editing
  38. Parting off relatively large diameter stock
  39. history on Sir John
  40. Hand Reaming and Drilling
  41. No For Sale Thread?
  42. Instead of a "newbie" area, how about a subforum specifically for PROJECT threads?
  43. Battle Shaper - coming to clutches with the power drive
  44. unheated seacan: stopping condensation
  45. Double check a hobbyist
  46. Bridgeport Mill - How do you know what speed to run the new(er) table feed?
  47. Die Starter Ideas
  48. Hot Chips...... Anyone?
  49. 9x20 Lathe on CNC Bridgeport
  50. 3/4" cam follower bearings
  51. tinker toy log splitter
  52. 52" 16ga 3 in 1 Sheetmetal machine first impressions
  53. Harbor Freight 20 Ton Press
  54. Other model engine machining forums?
  55. The Great Lump of Stupid
  56. O/T: Chemistry. Why two naming systems(or more). CNaO2/COONa.
  57. Making a replacement pulley for a mower
  58. OT - Made in the USA, NOT!
  59. Bucket Pumps
  60. Gages?
  61. Shell mill made from aluminium?
  62. Can Teflon be machined to a very fine finish?
  63. Projects: Machine shop, storage, work areas, computer and electronics lab areas
  64. painting a heat sink
  65. building a leather splttir?
  66. building a leather splttir?
  67. Quick mill cutter speed question
  68. Indexing a large prime number, 127 for example.
  69. OT- But Important. Camoflaged tools.... WT... ?
  70. DD socket
  71. Happy halloween (I guess?)
  72. Is this knurling tool any good?
  73. Mishap with angle (?) grinder
  74. Tolerances For My Die Holders
  75. OT: Thunderbird Date Display
  76. Lockheed L1049 Constellation
  77. "Rockford MV 100" mill on CL
  78. Small, Worm Gearbox for Project
  79. Anybody heard from Evan lately?
  80. large drills - taper shanks - pros & cons
  81. OT: Disposal of carwash chemicals/cleaners?
  82. ? on heat treating 1045
  83. My first Knife
  84. OT: Pressurized Water Setup
  85. Granite, Glue, Sandpaper, Emery, and Silliness
  86. Made 25 of these little wigets
  87. OT Dish Satellite Hopper Comments Wanted
  88. Question on Chinese 10HP VFD...
  89. DYI hydraulic press metal brake guide pin clearance
  90. Easy mill scale removal from hot rolled steel
  91. OT: Photobucket embed fix oddities.
  92. Looking for a Berkroy clamping head
  93. Angle grinder bike..
  94. Machining content. Tesla turbine.
  95. old Servo type 50.. how to disassemble?
  96. Single phase small electric motor from graduate wood lathe ?
  97. An answer as to Evapo-rust and springs breaking
  98. Went on a tour of local machine shop.
  99. Power supply question
  100. My new YouTube channel "Hill Top Machine Works".
  101. Buffing moves material around - yeah right
  102. Another carbide shank boring bar
  103. Cutting a Spring
  104. Squaring a small blind hole
  105. Penn Tool Co.
  106. Power out - surfing on batteries
  107. Grinding a channel
  108. Threading on a King 10x22 (same as Grizzly G602)
  109. OT: buying a used/new cellphone and the unlock/compatibility nightmare
  110. Machine shop auction buy --- and a MYSTERY
  111. John Stevenson's gear cutting writeup
  112. Gasket cutting 2.0
  113. Anybody know if a good minimill CNC-conversion thread?
  114. Decisions,decisions.
  115. MSC online catalog & website SUX
  116. fresnel lens
  117. Making Split Plain Bearings Sleeves?
  118. Automatic tool changer for my mill
  119. Starting small.
  120. OT: Choosing smartphone???
  121. True roller timing chain
  122. Propane shop heater install.
  123. What lathe to buy
  124. OT: 2500 plastic cups
  125. Horizontal Mill?
  126. Is carbide heat treatable?
  127. Anyone near Oak Ridge TN?
  128. Strongest for bending strength?
  129. OT: gmail and multiple email addresses
  130. OT: Blew out both lungs
  131. ON topic: feed and speeds tutorial;
  132. Milling Angles, How Do You Do It
  133. A Small CNC Mill - A Huge Education
  134. best plastic for a bearing compression nut/ inner bearing race
  135. Free Machines
  136. O.T. pilot light on oven goes out
  137. OT – Handy Tool De-Magnetizer
  138. Ot carbon fiber pull start cord ?,cant find
  139. Need some advice on press fit
  140. OT Looking to Build a Model of Some Sort
  141. Replacement screws for V- Block
  142. [IMG] Turning threads in steel: badly torn finish with ground and honed HSS
  143. Cheap DRO
  144. What plastic...
  145. What spindle taper does a South Bend heavy 10 lathe have...?
  146. 16 x 1.5 MM and the Atlas lathe
  147. Watch maker lathe collets???
  148. Grizzly G0776 - 13" x 40
  149. Flattening Bar Stock
  150. O/T: Sorry. Dropbox? The online storage "cloud" type service. Anyone use and like it?
  151. OT, convert 6V vehicle to 12V
  152. Boring! Lunacy or genius?
  153. OT:ish Different kind of shopping and sightseeing in Thailand (picture heavy)
  154. Stronger Quill Lock Handle
  155. Jacobs Taper Chart & Question
  156. OT How many Home Shop Machinist does it take to change a light bulb on the HSM forum?
  157. Rotary Table opinions
  158. Internal Taper Measuring Question
  159. USB endoscope camera disappointing software
  160. Cheap (~$200) DIY 3500 watt induction heater for melting Al, brass, etc.
  161. suggestions to repair broken knee lock on Bridgeport j head mill
  162. Schrader "tire" valve thread size and tolerance ?
  163. Any opinions on Grizzly 6" rotary table.
  164. Fusion360 Question: Moving a Sketch Element
  165. Dremel Tool Arbor Thread size? Replacement Screws?
  166. OT: Double slit experiment
  167. Goofy shop purchase - big paper cutter
  168. Matching (Mirroring) Up Two Cheap Spin Indexers
  169. Water resisting with Caulking
  170. Electrounrusting New question,old topic
  171. How do I know what this Sheldon is?
  172. OT: RIP Thomas Hudner, medal of honor recipient
  173. SHARS Black Friday sale
  174. Advise with a Big problem ???
  175. HVAC Shot myself in the foot
  176. OT: Has Firefox "updated you" yet? Do you like it?
  177. Cheap drill chuck arbors vs Jacobs
  178. O/T: Thinning epoxy for use.
  179. Cool hard turning video with sort of shear tool
  180. Care Package from Mikem
  181. Sometimes the simplest, easiest trick can be really useful
  182. Milling LONG parts, and an update on the Battle Shaper
  183. Coveralls or shop coats?
  184. champion post drill restoration
  185. 1901 Locke twin steam engine
  186. 4x8' Shop Bench Idea
  187. Perfect self holding air chuck I made
  188. OT - AT&T Network Problems
  189. tin
  190. Is this spindle missing a bearing?
  191. FireFox Help Please.....OT
  192. End mill storage.
  193. Machinable Non Compressable Insulator And Other Materials Choices
  194. tool gloat?
  195. Babbitt question
  196. .pdf to .dxf conversion utility?
  197. OT STL Post-Dispatch reports "Techshop" has closed up
  198. Shopmade anvil...
  199. Anybody here on the island need a shaper vice?
  200. OT help with direction on a 'for sale' web site.
  201. Funny Story--some tech content.
  202. Cle-Line Bits Princess Auto
  203. Making a Lathe Toolpost Grinder
  204. Phase Converter Question
  205. Whipp Shaper
  206. Hardinge tm mill vertical attachment
  207. OT: how to get rid of Bing newsbar!
  208. New shop tour Video of Centroid's in house CNC lathe test mule Threading and Tapping
  209. Sizing a Quick Change Tool Post for a Grizzly G9249
  210. my mill just let out the magic smoke :(
  211. Lathe up for auction in the Des Moines area
  212. O/T Post Flooring? Need help!!
  213. Little reference cone in drawings - whatsit called, whyzit there ?
  214. welding stainless steel with ac stick weldler
  215. Setting stock onto parallels - brass hammer, lead hammer, dead blow ???
  216. Converting Head on BRIDGEPORT TYPE mill.
  217. Manual operation of a CNC mill?
  218. A neat machining trick
  219. Machining related!
  220. Totally OT: Killer AI drones
  221. 3D printed fixture for milling
  222. Marginally OT: I wanna be a spaceman too!?
  223. FISHTAIL DRILL BITS What are they for?
  224. OT: Router throttling available throughput on pc
  225. OT: Can articles for the magazines be sent as files instead of mailed?
  226. Seeking input - Lathe purchase
  227. ID'ing carbide insert seat shim
  228. Model Engine Plans
  229. Roll-In Band Saw Restoration Project
  230. Metric thread dial obsession (going nowhere)
  231. well what do you think of this guys tips he's surely is hot stuff??
  232. OT, sort of... That "PB fix" deal again....
  233. OT maybe? Net Neutrality?
  234. best value drill bits today
  235. Happy Thanksgivng to eeryone on HSM!
  236. Fantasy Engine Build
  237. OT just how accurate is a computer's clock?
  238. can't find a straight 7" CBN wheel
  239. So internet speed
  240. Drill press mounting
  241. why I know the human race is doomed
  242. why I know the human race is doomed
  243. BATTLE SHAPER ... Pics at long last. Pics of CHIPS too !!!
  244. Expanding on the "Fantasy engine build" thread
  245. Atlas craftsman lathe restoration the apron
  246. Thinking about buying a new 45x135 CNC metal lathe for under $200 ~ What do you think
  247. Tailstock left hand thread
  248. eBay CNC router?
  249. Looking for TNMG 222 insert tooling
  250. HVAC Thermostat
