View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 [268] 269 270 271 272 273 274 275 276 277 278
  1. OT: New Years day polar bear swim...
  2. 'Plastic' bearings?
  3. Need help with lathe motor question/problem.
  4. Glass knife maker (Boston CL)
  5. how does this motor come apart?
  6. OT: Building a traditional Finnish log house video
  7. OT: another Firefox question
  8. OT: RIP Kenichi Yamamoto, father of Mazda's Wankel Engine
  9. Two Piece Milling Vise: Good? Bad? What?
  10. O/T Finish Clean? Carb Bodies??
  11. New Copper Shop Air System Done (lots of pictures)
  12. Press fit aluminum in aluminum ?
  13. A different type of mag drill press
  14. How to calibrate a level
  15. Buy AMD stock NOW.
  16. New to this forum, short bio and a link to shop picture.
  17. Six Jaw Chuck Question
  18. OT West Dubuque High School Technology Club
  19. Interesting CNC wood and metal project for the home baker
  20. First 3D printer projects
  21. Lyre Harp Tuning Pins
  22. Kurt Vise on E-Bay: What Happened To It?
  23. Annular cutter for milling locating pins?
  24. Totally OT Stastnov cestu..
  25. Repeatedly Melting Nichrome Heater Wire
  26. OT: Snow Comming
  27. Some More What's Its
  28. What's it?
  29. Tip for letter stamp spacing.
  30. Enlighten Me On Wiss Scissors
  31. Functional 3d print.
  32. South Bend Rocker Lighthouse Toolpost
  33. Opinions on a servo feed for a Lagun
  34. O.T. Chili (cold weather comfort food)
  35. Looking at getting my first Variable Frequency Drive (VFD)
  36. upgrade console for old dro glass scales?
  37. Old sawmill arbor
  38. Safe max speed for typical motors in VFD use?
  39. Free - drive dog center thing, possibly B&S #9
  40. Hi, my name is Matt and I'm a scrapaholic
  41. Barkas van
  42. My hardinge addiction
  43. OT: Looking for specific book about weather written in the 1970s
  44. Any tips for boring Magnesium
  45. OT yahoo groups question
  46. Sorta OT, snowblower impeller mod...
  47. No spindle lock on my mill
  48. cold snap
  49. Parting or cutoff tool modification for a small lathe
  50. rockwell mill wiring help.
  51. Victor Journeyman Welding/cutting set
  52. TV: A Craftsman's Legacy. Gerstner boxes. PBS
  53. Help, Grizzly or Precision Matthews bench top mill?
  54. Press Fits in Nylon
  55. Turning Tapers Between Centers
  56. Snow Holly Works double acting internal combustion engines?
  57. Silver solder flux
  58. Cold Saw problems
  59. OT Rattlesnake ridge cracking up
  60. Single Pointing, It's Like Riding a Bicycle
  61. Rapid return lathe?
  62. OT: Would You Believe: SIP Vacuum Tube
  63. Tool Size for Mini Lathe?
  64. Bench-Master . Wanted
  65. Milling Machine Help
  66. Building A Two Cylinder Reversing Steam Engine from Bar Stock - by Brian Rupnow
  67. Possible to bend glass in home shop?
  68. What are these tools and what are they for?
  69. W&S #4 Lathe For Sale Locally -- Have A Question
  70. EDM current
  71. Rutlands 'Furnace' Cement, A Warning
  72. Hardware failure, what am I doing wrong?
  73. Never borrow tools!
  74. Help with 1340 tailstock
  75. balancing multiple carbs...
  76. Cabin Fever
  77. Adventures with used VFD's aka what can go wrong?
  78. New member with first Milling Machine, Weiss VM25L
  79. Tigging away the moments That make up a dull day
  80. Broaches
  81. Time for something new?? What does it do?
  82. Grease and grease guns.
  83. OT - Robotic Sex ???
  84. That flexible metal conduit?
  85. OT - Ignorance Knows No Bounds
  86. Boring Head Adapter
  87. Craftsman 12" lathe acquisition. Rare model? Looking for info.
  88. who has a Tormach 440?
  89. Rough idea how hard and what type of steel?
  90. Sand Blasting
  91. OT- Do you know IVO?
  92. Mythbusters: Their 3in1 Machine.
  93. Metric thread dimensions :-?
  94. Precision Lathe work
  95. O.T. Summer Food (Hot weather comfort food)
  96. Sort of OT- Educate me on small CNC routers
  97. Nine year old is interested in steam
  98. Help needed diagnosing problem with variable speed router motor.
  99. Dead Center Mfg. Dist ??
  100. Which 4" mill vise is good and not to costly?
  101. Building a transmission to drive 3 hydraulic pumps
  102. OK... it's pretty, but $7k?
  103. Internal threading tool LH - a sanity check please
  104. RIP, Dan Gurney
  105. Ultra-rigid adjustable mini-lathe base
  106. Stupid project I picked up
  107. OT: Whatever Happened to Dating Things?
  108. Fastrtrack please check your PMs
  109. OT HP 5335a frequency counter - help with test equipment repair
  110. Any neat tricks for flattening enamel paint?
  111. Dressing a surface grinder
  112. New TOOL; Quick Change Tool Post.
  113. Bad steel ?
  114. Noob question about gear combo
  115. 3-ph motor poles
  116. English Wheel Adjuster?
  117. Hardinge horizontal on the Bay
  118. Welding Damascus
  119. Novice milling experiment
  120. Head cold from Hell and maybe a Stirling Engine
  121. OT: ceiling fan light with remote control is dim, controller problem?
  122. Black antiquing fluid
  123. That google and firefox deal....... still going on.
  124. Cleaning a chuck for the first time. BTC Zero Set.
  125. Tormach style TTS Tooling System...
  126. Need QCTP Adjusting Screw Source
  127. long files, the metal kind.
  128. OT Great Tombstones
  129. O.T: Boating Accident
  130. Question about vises
  131. Source for Bevel Cutters
  132. who makes 2 1/2 Inch Long 3/32 Inch Radius Left Hand Convex RXL Style Radius Cutting
  133. Grinding Wheel Help
  134. Boring Head with horizontal square hole?
  135. Fixtures and Setups. For machine tools. Lathes, Mills, Shapers and Grinders.
  136. depth stop pattern for a stanly 78
  137. How to find scrap metal stock?
  138. ID Moore and Wright measuring instrument please
  139. OT but relevant to this site.
  140. 7" or 9" side grinder?
  141. Modifying a South Bend Lathe Spindle
  142. Any mold makers on the forum? Looking for go kart body fabrication ideas
  143. Limits of thermal expansion
  144. Cad for linkages
  145. Sometimes you need 3 hands
  146. Rolling tool box/machine tools
  147. Seneca Falls lathe, is this potentially a good deal y/n
  148. OT: New technique for dealing with sobriety tests
  149. 3d printing in the workshop. Yes it does have its place.
  150. Pressing 2 cast iron pieces together
  151. OT: Lubrication for Shoe Stretchers
  152. OT: Electronic Rolodex with NO Possibility of any Internet Connection
  153. How to power a 12v DC motor from house current
  154. Faux Suburban Fly Cutter - Almost finished
  155. Micro drilling burr free
  156. Robotics competition on Saturday
  157. Nut cracker
  158. Nylatron?
  159. Craftex CX601 Digital RPM readout goes blank
  160. What do you call them?
  161. Youth welding
  162. VFD Moeller DF51 340 3KW
  163. Carbon Monoxide Dectors
  164. Shop Air Filtration
  165. Sourcing and making Poly-V belt/ ribbed belt pulleys
  166. Dead start cap
  167. I need help sizing a hydraulic power unit
  168. Very small, left hand threading tool or 06 style inserts
  169. Electrolysis for rust removal
  170. Primitive worm gear hobbing
  171. How Does Noga Fine Adjustment Base Work?
  172. 3 jaw lathe chuck jaws
  173. Replacement inserts
  174. OT --non interference engine, bent valves
  175. Drill chuck needed
  176. Ball Nut Holder - Manual Machining
  177. OT, computer related..
  178. McMaster-Carr catalogue
  179. Tips, tricks, and ideas?
  180. Cabin Fever 2018
  181. gloves for use with kerosine
  182. mill spindle speed?
  183. What do I have here?
  184. Auction find
  185. OT: Cool video of Chinese coal mine steam locomotive spitting embers
  186. OT: Another Tesla accident, and the reasons for it (maybe)
  187. Genuine Sherline lathe!
  188. Is CDCO a one-man band?
  189. OT but I need a bronze casting
  190. Fowler 8" digital caliper.
  191. Over night Drain
  192. Motor pole designation?
  193. OT - Heads Up - Harbor Freight Plasma Cutter on Sale
  194. 3 jaw lathe chuck
  195. Chuck Assy: Miller Falls Hand Drill, #308 0-3/8" ("Buck Rogers Series")
  196. Those tapered end mills how to calculate deg.
  197. Holding down thin slabs on mill
  198. OT: Kind of a long train
  199. Best broom for metal swarf?
  200. O.T. Building shed on cement slab
  201. Why Is The Windows Spell Checker So Lame?
  202. Nice Site for Lathe Tool Holder and Bed Turret Plans
  203. Indicator holder for AXA Tool post
  204. OT: New (old) source for lightweight concrete
  205. Steam Rover
  206. After a year hiatus, it feels good to make chips on the mill again.
  207. OT-New dryer won't run, gets 240V from outlet
  208. Stator support mounting in the lathe
  209. Strange 3D Print Problem
  210. Building foundry patterns
  211. Great service from Chinese Ebay seller cheap DRO
  212. Pay Pal Security ??
  213. O.t. Useing hit and miss buzz box for lawn mower ignition ?
  214. A new type of bench vise (Homemade prototype)
  215. OT; Speaking of Tesla accidents...
  216. Kalamazoo Bandsaw -- dashpot seal installation
  217. lathe motor problem, sort of
  218. 8" Staggered Tooth Slitting Saw Advice
  219. Single speed 2 X 72 belt grinder/sander
  220. Milling round piece flat/square
  221. Stories for the wife
  222. File Racks&Oil Brush for Drill Press
  223. OT Project...
  224. Morse taper's do not come apart by hand
  225. Questions on using 50hz motor in US?
  226. Micrometers
  227. PVC air lines
  228. how to build foundry patterns
  229. best footprint size for 700 sq ft shop
  230. Got a new belt grinder
  231. Bench grinders and bench buffers on bench or pedestals?
  232. Building a bridge!
  233. BXA tool holders interchangeable with AXA?
  234. First go with Flynn Boring Head&Shop Built Boring Bar
  235. Troubleshooting Compressor Motor
  236. OT: Or Not? Lubrication For Thread On Shoe Stretcher?
  237. metals & alloys info & comparison
  238. Help identify this vise
  239. Flex Tool Post Holder, Comments..
  240. Will this hold that ?
  241. O.T: Getting ready for the BIG GAME
  242. Cherry Picker, Engine hoist. My HF unit has saved my bacon.
  243. Tip: Parting tool point
  244. Purchased a Bostar AXA wedge QCTP from CDCO
  245. Hello Again, Need Machine Rebuilding help?
  246. Good demo project?
  247. Bandsaw tires for aluminum
  248. O-Ring advice needed
  249. OT: 1099-K From PayPal?
  250. OT: Buggies/Parakeets
