View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 [269] 270 271 272 273 274 275 276 277 278 279 280
  1. Metric threading issue on an old South bend 9' without quickchange
  2. Milling inserts differences
  3. Yet another VFD question ;) and on my first post!!!
  4. Sharpening TC Cutter Bits In Face Mill Cutter
  5. Which side for Dial on Boring Head?
  6. Machine Jerked with Stick Slip on Way, Now repaired
  7. Fixturing an odd shape
  8. Finished My Gage Pin Cabinets
  9. Clystal clear thick oil recomendations?
  10. Holland & Holland Gun Making a Good Mix of old & new Tech
  11. Falcon Heavy launch in 3 min
  12. South Bend and Logan parts manuals
  13. OT: Solar farm, do I want one?
  14. Fixing a POS 4x6 bandsaw
  15. Question about determining tap and drill bit size
  16. Question About Magnets
  17. Applying fillets to a foundry pattern
  18. New toy coming, PM-1236
  19. How do you re-tune your precision stones?
  20. OT: Historical non-fiction books about significant manufacturing / machining projects
  21. Scientific Paper on Scraping and Measurment
  22. Do You Still Use Your Abrasive Saw(s) ???
  23. Handy tip
  24. What is it...
  25. Won a Kurt 6" Vice in a plant closure auction $112
  26. Coolant For Mister
  27. Power drops for machines on the floor
  28. Does this mean we'll have to make "nice-nice" with those other guys?!
  29. Case hardened mounts for security chain
  30. Score:Mo-Max HSS,18" Chuck&Shop built holder for HSS
  31. Strange lathe question.
  32. OT? Glass forming over a machined mandrel
  33. Building a fallow board to aid in molding
  34. Elliot 10Mshaper
  35. Spark trap for shop vac?
  36. Plasma cutter?
  37. OT: How come I never find anything like this?
  38. How do I adjust quill spring tension on LMS 5500 minimill?
  39. Shop Security Camera IR Cut Filter Issues
  40. Atlas 12" gears FS
  41. There is a new way to describe disappointment, Stanley baily
  42. I must'nt have been thinking---
  43. Selling stuff...
  44. Scherr-Tumico 0 - 6 Inch Micrometer Set On Craigslist
  45. Providers of fine machine tooling and accessories
  46. Moving on up, to the east side
  47. Propane powered model Engines help needed.
  48. Tapping 3" Deep in Mic-6
  49. Solid carbide laydown threading bar
  50. My new Sheldon!
  51. Warped Southbend Bed...
  52. drilling oil hole in mill
  53. Craftsman tilt head band saw tear down
  54. Radius on TC Cutting Edge?
  55. Chuck size for a 9' benchtop lathe
  56. OT Need Sun Electric Distributor Tester Expert(s)
  57. Half Dead Centers
  58. Engraving options
  59. OT - Everyday hero
  60. My replacement has left to be a stunt man o.t.
  61. OT: Growing family (cute)
  62. Tribulations of working on an old lathe
  63. Rohm lathe chucks...
  64. New video on YouTube
  65. Insert tooling for threading
  66. OT Light bulbs inside of light bulbs.
  67. Setup 2 shop vises
  68. Be Sure To Lock Up Your Shop!
  69. SDS bits what are they made from
  70. Quick question mandrels
  71. MSC free shipping code
  72. Hardige sold to an investment group
  73. Fixed My Grinder Switch
  74. Brian does Ridders flame eater
  75. Expensive rust.. someone explain how this is worth 150$.. Ebay sale
  76. Cobalt Drill Bits..
  77. semi OT - powering a 460V 3P Synchrowave with 600V service.
  78. Printed circuit boards
  79. Inexpensive DRO
  80. Grinding Wheels and Surfacre Finishes
  81. 10k Rpm motor. What could I use this for?
  82. OT: Intercom systems
  83. OT: a woman, a handbag, and check-in at a Chinese railway station
  84. Water-cooled router cooling questions
  85. Bridgeport 6F power feed petentiometer?
  86. Now I've Gone and Done it - BP Mill Specialist Needed!
  87. The Shop Wisdom of D. E. Johnson
  88. Mill spindle bearing oil wick
  89. Any news on the Acorn CNC board...?
  90. How Long Have Machinists Been Working In Tenths ???
  91. Lathe Spindle Depth Gauge for cutting various repetitious peices
  92. OT I just had an earthquake (tremor)
  93. How do I know my lathe straight?
  94. New addition to the shop
  95. New tool.. Multitool for grinder
  96. Spin fixture set-up problem
  97. Bench Grinder Setup.
  98. New image hosting
  99. Interesting historical article on Chinese Machine tool Industry
  100. flea market find
  101. Hydroforming In The Home Shop
  102. Dog problem, need some ideas OT
  103. ot: battery booster
  104. Buying my first MIG welder
  105. Are Aluminum and Brass compatible as bushings ?
  106. Sahrpening and Polishing Oil
  107. Electronics question
  108. Lathe bits available to first person to contact me
  109. TALON GL-1108 CNC Lathe
  110. RPM's SFM Translations When Grinding
  111. Drop deck trailer drawings? any sources?
  112. UTUBE Greats
  113. OT: Skill Saw
  114. Grizzly GO 727 Horizontal Mill.
  115. Reboring existing hole off set 1/2 diameter
  116. Do all Digital Calipers have glass scales
  117. diy soldering tip
  118. Ceramic Grinding Wheels
  119. renovating leadscrew nut
  120. Train Whistle article in HSM
  121. 13x40 headstock removal
  122. Pipe thread tapping depth?
  123. Calculate required level sensitivity
  124. Bellows For Lathe Lead Screws ???
  125. OT: AMA Expo East
  126. OT: Dual fuel generator
  127. Precision pins
  128. Wadkin router parts free if anyone knows a home for them
  129. Neat Cl lathe.... vintage stark #4
  130. What is it?
  131. free standing sonic damping curtain
  132. Uber-Cheap 1610 CNC Mill (Engraver) ... "Rounter"
  133. Do you center your table when you are finished?
  134. Steel selection advise
  135. A salient reminder on lathe safety
  136. Electrical question
  137. Dust Collection home built & 3d printed.
  138. OT: Selling Vintage Audio Equipment
  139. OT - PEX durability demonstrated
  140. Bandsaw Blade Advice Please
  141. Shop lighting follow up
  142. Plastic Welding HDPE
  143. OT-Speaking of Old Audio Stuff
  144. McMaster Catalog #118 Free for Shipping
  145. Best Plastic for 3D Printed Part in Shop Environment
  146. 60 Degree Milling Cutter for 303 SS
  147. Electronic power feed touble shooting?
  148. Sharpening Countersinks
  149. "Asian" drill press options question
  150. Speaking of 3D print materials
  151. can i silver solder cast iron ????
  152. Took a trip to Grizzly the other day.....
  153. Roots of Automation in Electronics
  154. 3D printing other, other materials - like SS
  155. metal castings for stanly plane
  156. does a car battery need to be specific to the car I say not.
  157. Beginner 2-axis DRO
  158. OT: Another super inefficient thermal motor (Electric)
  159. OT- browser issues this blocking site
  160. OT - Ray Gun
  161. I need some special fixturing items
  162. Learn To Rebuild and Hand Scrape your machines
  163. OT Laser Level
  164. what tool to mill a v grove in the foot of my Bessy F clamp
  165. Modified paint cups.
  166. Self THREADING machine screws
  167. OT: Green Bananas
  168. Mounting older B&S Bestest
  169. Spin Indexer
  170. Orbital cnc lathe
  171. Fitting a backplate and making a chuck key for a 4 jaw chuck.
  172. OT combi boiler affected by snow
  173. Norton Blaze grinding disc.
  174. OT Gravity Light
  175. Starrett Micometer Disassembly
  176. Disassembly of Jacobs 7B Chuck
  177. Seeking information for MIG welder purchase
  178. Camelbacks straight edges at HGR
  179. How do I dress.... these pin punches?
  180. A pot into a guard
  181. Wet Belt sanding recommendations?
  182. OT: Storm damage (Wicked Winds of March)
  183. Unknowen tool
  184. OT: Ban diesels for pollution? It's legal in Germany...
  185. Looking to learn more about metal working
  186. OT - struggling with Windows 7 colour change
  187. Machining while seated
  188. MSC Big Book
  189. BAY Area Shop needed to host Rebuilding Class May of 2018
  190. way out there-
  191. Tormach 1100 owners, educate me
  192. Manual Mill to CNC Conversion
  193. O.t.constant spark buzz box for a riding mower????????
  194. Can I gain a few thou by shimming one side of a drill bit
  195. Care and feeding of rarely used inverter welders
  196. looking for "a"size link fan belt
  197. Making a New Index Bracket for an Old Rockwell Unihead, pg.1
  198. Free hardware (bolts, self tapping screws, washers, etc) for locals in MA
  199. I want to make a 5C strp collet closer for the 2 and 3 inch collets I have.
  200. OT: Help fixing car battery charger
  201. Antique motorcycles
  202. Hit and miss engine glass oilers
  203. Plastic whatzit?
  204. How Do These Bolts Work ???
  205. Rotary table Needs a vise
  206. question, about one bit drill/reamers
  207. Illinois: Nardini 17x40 lathe w/DRO and nice Bridgeport VS 2HP, DRO, PF
  208. Speaking of Calipers
  209. HI-PRO Key removal
  210. Ideas for Greenlee C-frame punch?
  211. Steady Rest Needed
  212. youtube channel
  213. O.T. quick electrician question, what are these called.
  214. OT: Cool innovations in furniture
  215. Vacuum for Vacuum Table
  216. ER32 Holder Runout - Badly Ground Holder?
  217. tank of fluid- what rpm
  218. machine-blacksmith work
  219. Night light question:
  220. dimmer as power supply
  221. Workplace distractions
  222. South Bend Heavy 10 Logan 10/11 interchangeably
  223. Bridgeport feed reverse knob drawing
  224. Need help: drill press chuck/spindle
  225. Special grease for ceramic bearings?
  226. Cutting leadscrew telescopic springs.
  227. Anyone close to Norfolk, VA?
  228. Diesel that has been sitting 4 years - what could go wrong?
  229. Converting Spindex to indexing head
  230. Techniques for transferring holes in (from) thin material?
  231. Would anyone in SF Bay Area like to host a Scraping class in May?
  232. Unhardening chainsaw chain
  233. If not a Tormach 1100, then what?
  234. OT: Proton Battery..... looks interesting.
  235. 115VAC Electrical Connector for Mounting IN a 4x4 Box
  236. Shop Time vs. Computer Time?
  237. Red Rust Bluing - The Quick Way
  238. A 1984 Bosch drill, Wow!
  239. Angular Contact Bearing Installation?
  240. New Bandsaw
  241. air Cooled Case Boring?
  242. OT; computer. What is this please?
  243. Best gearbox style for torque?
  244. OT: Major Power and Internet Outage on East Coast
  245. Tariffs and our hobby
  246. DC motor for a Benchmaster mill
  247. 3D Printer Opinion Needed
  248. 4 Jaw Independent Chuck for Drill Press
  249. A question about china
  250. Import Steel Quality
