View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 [273] 274 275 276 277 278
  1. 1980's MSC Milling Machine Help
  2. Opinions on Compressor
  3. Happy 4th everybody
  4. RG-G 1/2 Scale Gatling Gun Build
  5. Line boring a vice.
  6. Craftsman wiring question
  7. DRO for BP Mill?
  8. New mill acquisition is dead.
  9. New member with a question
  10. New Maximat v10 owner
  11. What am I missing here.
  12. Drill Sharpening Bench Grinder Addon Design Idea
  13. Male 1/8 pipe thread stub dia?
  14. OT another e-bay question to the more experienced
  15. My shop electrical is firmer than my house. Lights blink when the frig fires up.
  16. Making Borax Wagon Wheels - Fascinating
  17. How To Knowl If Metal Is Stainless
  18. Question about Clic-R Hose Clamp Pliers
  19. identify grinding wheel
  20. Three score and Twelve--o.t.
  21. Cast iron plate
  22. look at this
  23. Darkening cold rolled steel
  24. Harmonic drive options - low cost for use with a stepper
  25. Small Boring head advise
  26. wHERE TO GET THREADING INSERT HOLDER
  27. Plaza Machine Still Around ???
  28. Small Parts & Vacuum Chucks
  29. Using a pavement breaker as a trip hammer?
  30. Cardboard baler to Hydraulic press ?? Advice please
  31. Sometimes You Have To Be Creative
  32. OT: Why 98.6?
  33. OT some mystery tools
  34. OT: Crags List !!!
  35. Trajan circular metal-cutting saw
  36. Anybody recognize this watchmakers' lathe milling head?
  37. turning problem
  38. link to a couple old mills
  39. off topic slightly
  40. A Little Humor For The Day.................
  41. How to do JIS taper square cycle crank pin on SB9A?
  42. T-Slot...Tool-Cutter Grinder
  43. OT Congrats to all involved in the Thai Cave Rescue
  44. relief grind on parting tool
  45. Surface ground stones, a new set.
  46. O.T. the oddest thing I have ever seen
  47. OT: ideas for cheap outdoor cover box for my electric smoker?
  48. A. Ottavino 24"x18"x3.5" Used Surface Plate Value
  49. OT How to dry a slice of oak tree trunk and avoid cracking?
  50. OT - Accurate Automotive Type Tire Pressure Guage?
  51. Turn bed end for end?
  52. Anyone going to the Syracuse Nationals next week? Semi-OT
  53. Turn to scrap, OUCH !!
  54. Fortner Lathe Indicator Holder Model 1110
  55. Help to identify a tool set
  56. Material for a H-D front axle
  57. O.T. Motion sensor switch question
  58. Drag knife experience?
  59. OT: Protective paper on Lexan
  60. New (to me) mill
  61. Building a chip pan for a 4.5ft South Bend 9"model A
  62. New Guy on the block..forum
  63. Drilling Large Holes & Sl;ow Speed
  64. what's the most effective way of making an offer on CL?
  65. Free restoration project
  66. Hand Crank For My Lathe
  67. Static phase converter
  68. WD-40
  69. What Tooling Do You Recommend?
  70. Tubal Cain or Twobekann ?
  71. Photobucket no longer allows videos, so now where?
  72. reinventing the wheel - or pedal - or whatever
  73. O.T. Braging A Little - Daughter Changed Tire By Herself
  74. Hit and miss running on propane as promissed
  75. Advice Needed and Gloat: Repair of Cub Cadet mower bags
  76. Digital Tachometers
  77. Opinions on shop tool cabinets...
  78. Big hydrauliclly powered syringe
  79. Differant use for cherry picker
  80. Spare parts for South Bend 9A
  81. O.T: What's a cubit?
  82. OT: hardware question
  83. Best way to weaken a shear pin?
  84. Spring making, coils folding over... help?
  85. New from Arkansas...
  86. OT: Phone number spoofing - now I'm not sure
  87. 25% Tariffs on various machines from China, effective July 6, 2018
  88. OT: Lightning strike nearby
  89. OT suitable epoxy for securing wire in hole
  90. Online O-ring Calculator??
  91. O/T: Today: $25 Off $119+ Use code PRIMO119 Ebay
  92. New member from California new to me lathe
  93. In Honor of Sir John...
  94. Looking for an Arduino program..?
  95. Treadmill motor conversion for a Grizzly 6x26 knee mill
  96. How fast can a small pulley system go?
  97. How to cut an engine in two?
  98. OT - Recovery is a PITA but it beats the alternative.
  99. OT: update on the sinking of the Confederate submarine H.L. Hunley
  100. Completely O.T.--Racing the Train
  101. Battery powered mastic pistol a bust!
  102. Unimat Sl-1000
  103. Anyone recognize this?
  104. Welding Very Thick Steel With Very Tiny Welder
  105. How to avoid "singing" and work hardening
  106. color of welding tanks?
  107. Sanou 4 Jaw Chuck Back plate Question
  108. Free to a good home...
  109. This must be a good time to buy used equipment. ( SF Bay area )
  110. OT - mold in the woodshop
  111. MT2 Collet set....what am I missing?
  112. Acceptable Runout For Internal Grinding Arbors
  113. OT-tool identification needed
  114. 10" 4 jaw chuck almost 4" center hole looks good to me
  115. Question - If You Keep Spare Parts Around Do You Patch Stuff Anyway
  116. 4x6 bandsaw
  117. Kent Industrial KMT-380 mill, who has one?
  118. OT-whatsit maybe soldering iron
  119. Off topic finishing a bolt through a car frame
  120. Small Things to Make Life Easier
  121. South Bend 9A Headstock Info
  122. Motor only runs in reverse
  123. Craftsman rotary table mounting
  124. Rebuilding an Enco Mill
  125. Advice on machining operation
  126. Gummy material?Grab a Sharpie..
  127. Box lid latches
  128. Internal Grinding Issues........ Where To Start First
  129. First Production Run with Heinrich Drill Press Vise
  130. OT Non Scratch Acrylic
  131. O/T: Solly, been watching TV. The Martian. Planet drag to "sling shot" around a Mass.
  132. Bushes.
  133. 400 lbs of titanium
  134. New head for a Bridgeport?
  135. Home heat treatment OT
  136. Really nice VS Bridgeport and Nardini 1440E auction ending soon on East Coast
  137. ... you might just be a collector
  138. 16.4mm x 1.5 thread, such a thing?
  139. O T Electrical
  140. Union Pacific 844 Departs Cheyenne, WY July 2018
  141. O/T : Free Sheet Metal Shop Equipment in the East SF Bay Area
  142. Question about PVC
  143. OT: Back Brace?
  144. OT computer hard drives.
  145. Better Drill Chuck for Lathe
  146. Hendey at HGR
  147. Question About Fake Machining Tools On Ebay
  148. Unimat tooling
  149. Steam Oxide Surface Treaatments or Coatings
  150. Pressure sensor display?
  151. MEM Corliss in .40 scale
  152. Sealing 3D printed objects?
  153. what is the brightest LED bulb I can buy?
  154. Recommend very small lathe for cutting Nickel Silver / Brass ? Harbor Freight ?
  155. OT - 30 years, same woman
  156. Any machining content groups that accept FS ads?
  157. Keyless Chuck on $50 Drill Press?
  158. threading question.
  159. Portable Drill Guide
  160. Strange angle on my lathe ways
  161. Pros & cons of various techniques to locate & hold a pulley/gear/etc on a shaft.
  162. More LED shop lights
  163. I phone 7 plus frame by frame video app?
  164. O. T.--Dog days of summer
  165. OT; computer problem
  166. What Is This Tool On Craigslist "Power Feeder"
  167. Cushman 3005 chuck jaws and tool post grinder questions
  168. Hand made lathes?
  169. High speed frame by frame chip formation pictures easy
  170. high capacity cells
  171. painting rusty steel
  172. Cincinatti 12-1/2 x 48 Lathe parts needed
  173. Form tool questions
  174. I bought a brand new, shiny clean lathe!
  175. 10% Off Coupon Code For Wholesale Tool- CUT10NOW - Until Aug. 8th
  176. Woodson vertical w/reverse
  177. Spray Paint, not really OT
  178. Using A Dial Twin Beam Height Gauge
  179. well out of hospital and feeling not well.
  180. Cutting through chrome plating
  181. Dumore Spindle Tapers
  182. Flat Belt Reversing Mechanism
  183. Stanadrd and metric collets
  184. Good Shopping at Dump
  185. OT - Worked on the old deck
  186. [OT]Ideas for split-level shed/workshop built into hill
  187. Archive for old parts/operation/service manuals?
  188. Sieg X1 / Harbor Freight Micro Mill chuck change
  189. Older Newall DRO repair help needed
  190. What is this
  191. KA counter form Shars....whats the compatibility with Mitutoyo KA linear scales ?
  192. Asbestos In Bridgeport Heads.
  193. AXA Toolpost Toolholders?
  194. Chain Pullers for you Farmers
  195. combining epoxies
  196. Drill press work stop
  197. Flex Tape...... Anyone Ever Try Working With The Stuff ???
  198. Speaking of rotors...
  199. OT: commie-puter had a stroke
  200. OT: a new Asian import you'll want to be on the lookout for
  201. Mill Vise Accuracy
  202. Port threads on Stuart steam engine....?
  203. Garden hose thread
  204. Clever small rod bender & plans.
  205. Anyone machined MIM parts? Did you notice any "smoke" from them?
  206. A trick I never thought of for fixing PVC pipe errors and clumsy assemblies
  207. Anyone use a dessicant air dryer?
  208. LED Tubes....
  209. Install a water drain spigot in an air compressor tank
  210. Help with an old planer motor (wood)
  211. Interesting thread on concrete lathe bench top
  212. O. T. Visiting the Big Apple....Any Tips?
  213. Where To Buy Single Drill Bits Online
  214. Variac
  215. 4 X 6 Metal Cutting Bandsaw Seized Up During Cut
  216. Hi all
  217. Unimat question
  218. Damaged brand new Dayton knee mill with DRO, Align power feed, VS head, etc.
  219. Find the Machining related item on my dry bar pic. Yeah, its a lame game. Dont click.
  220. Sink the Enterprise
  221. Where you are from... and how...
  222. Bandsaw coolant
  223. Shars Price Increase Announcment
  224. Gearbox work and some paint for the Monarch 10ee
  225. Where did mars-red go?
  226. Horizontal Hole Size In 3D Print
  227. Small cheap excellent boil out tank
  228. I bought a 3 ft.˛ Cast iron surface plate $200
  229. OT? - Edge jointing boards on a metal milling machine???
  230. OT: Airline maintenance worker takes an airplane out for a joyride and crashes it
  231. Delrin and threaded inserts
  232. Feasibility of building a "dyno" electric vehicle regen charger
  233. Machine switch
  234. Shars vs CDCO?
  235. a step closer to cheap hydrogen fuel
  236. OT: clearcoat on headlights
  237. Heating an aluminum plate electrically
  238. Uni-Hydro 55 Ton Hydraulic Ironworker for home shop?
  239. The Fred Dibnah Story.
  240. OT: Look What They're Doing Now!
  241. A fast compact tire inflater
  242. Why do my edits keep timing out
  243. insulation/sound barrier?
  244. DRO on Smaller Lathes
  245. Centrifugal clutch for a small block V8?
  246. OT SR-71 ground speed
  247. Buckley, MI tractpr/engine show
  248. Jet 1024 lathe... revisited
  249. Lectric motor, lube the bushings stuff
  250. Save your bacon grease and Leather/Serpentine Belt questions
