View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 [275] 276 277 278 279 280 281 282
  1. DC spindle motor controller question.
  2. A plea to McMaster-Carr
  3. I think Ebay Is Scamming All Of Us With The Limited Time Coupons
  4. OT: Zinc-Air battery announcement, more hot air?
  5. Jet Mill/Drill Lube Questions
  6. 120 volage control
  7. Rare No 1 Vertical Becket Milling Machine
  8. Why are hard wire cutter always 2 "V"s rather than bypass?
  9. 15% Ebay Ends in 2 hours 6PM PT
  10. Question on inductor cores
  11. High speed drill press
  12. No 1 Becker Milling Machine
  13. Rubber Molding Setup?
  14. Worlds most powerful shop vacuum only $78
  15. cam rollers
  16. PM
  17. 3 HP Frequency Drive Choice
  18. What do I do with a herd of surface plates?
  19. OT Interesting idea for hydrogen transport.
  20. Russian innovation.
  21. To cover or not. Granite Surface Plate
  22. Nice video on flame straightening...
  23. Slightly OT: Golf cart battery conversion?
  24. Why would this happen?--Lathe turning
  25. my homemade foundry
  26. home laser cutting
  27. No markings on tail stock quill
  28. Something you don't see every day
  29. Screw sizing for carbide inserts
  30. R8 or 40 International taper?
  31. Help identify this air grinder
  32. OT- Insta Clean IC-4 Parts Washer Info
  33. killed, semi-killed, rimmed steels
  34. question on inserts and holders...
  35. what is it?
  36. What is this lathe worth?
  37. Watching Henry Rifles made in Rice Lake, WI
  38. what is it photo
  39. Finding the center of a radius
  40. OT-somewhat- digital VOM
  41. Surface Grinding Help Needed
  42. Tired of the coin cell dying in your caliper?
  43. Want Solidworks?
  44. GREAT Shop Project Website - (Practical shop tooling)
  45. Keyless chuck grip test
  46. Will bottle jack operate in horizontal position?
  47. hi / back an a question on Haas lathes
  48. Paint Can Rust - Why? (RANT)
  49. whats it worth?
  50. a little foundry work and machining
  51. Enerpac won't release
  52. HGR in Euclid OH (Cleveland)
  53. What lathe is better?
  54. What is it part 2
  55. Help, rounded socket in set screw
  56. need to know what size chuck to buy for a Vicoverrotary muti-tool
  57. Spacer for saw blades - how to make?
  58. Don't click on posted links !
  59. JET Lathe RH1860-RX
  60. O. T.--Grandma Catching Frogs
  61. Another nice video of heat straightening/shrinking a big panel, but with the tig.
  62. Addendum to "rounded socket in set screw"
  63. Anyone with 1um resolution Chinese DRO?
  64. Dumore hand grinder question
  65. OT: First cold day in the Black Forest!
  66. Home Shop Machinist issues
  67. E-Bay mill power feed???
  68. Rosie the rivlter mystery machine tool
  69. OT- F-150 alternators, 95 amp vs. 130 amp
  70. Lodge and Shipley
  71. GPS type technology for machine slide position ?
  72. Bainbridge 712 horizontal bandsaw
  73. Boat anchor for conversion to lathe chuck
  74. Cheap AltTernative VFD motor ?
  75. Uses for flourescent light ballast...
  76. Venting Bead Blast Cabinet Out Side
  77. Geeking out! Finally found my perfect laptop. Kinda OT
  78. Finsihed a construction project on the shop..guess what it was?
  79. "When Imported Steel Makes Sense, Despite Tariffs" - New York Times
  80. Hammer forging video
  81. OT: backyard automated storage of firewood
  82. Abom shows taking longitudinal measurements with rule and Mighty Mag as a stop
  83. Is anyone else still using the old Alibre CAD program?
  84. OT: New shed was delivered/built today
  85. Metal Craftmenship
  86. lathe rebuild
  87. Junk yard find
  88. OT: Entire lead roof of English church stolen
  89. Adding manual clutch to model engine
  90. Need mini boring bar recommendations
  91. Motor with clutch for home shop machines?
  92. Pan and box brake. Partially OT
  93. Re-Purposing a Broken C-Clamp
  94. Best method for repairing and deburring (external) threads on stainless?
  95. From the Last Man Standing documentaries- filemaker
  96. old school "flat drills" - information?
  97. Should I buy this surface grinder?
  98. Follow up on stuck chuck
  99. OT; lead acid battery storage
  100. Updating a old Allen-Bradley Start stop switch.
  101. How to remove ethanal for those who can't find ethanal free gas
  102. Cheap easy tool post grinder.
  103. Cloning an 1879 Adjustable Wrench (King Dick) video
  104. Grizzly speed control
  105. Iron - Carbon matrix
  106. Bainbridge 712 horizontal bandsaw
  107. Worm wheel lubrication advice sought
  108. Don't know what to call it or where I bought it
  109. Gravity Feed Sand Blasters Anyone Used One?
  110. Magnesium
  111. Aluminum Cleaner / Tarnish Remover
  112. OT. HF-Car dollies question
  113. Way OT old time wood working
  114. V4 engine, want to bore it out, tilt head or bob?
  115. it is sad to see sears go after 125 years
  116. Unknown item(s)
  117. Sherline, Logan, Southbend, Shedon, Atlas... Great hobby Lathes,
  118. BandSaw Question
  119. oldtiffie??????????
  120. OT: RIP Paul Allen, co-founder of Microsoft
  121. What happened to air tools?
  122. Shipping from Europe to USA
  123. That Bitcoin thing... rember that?
  124. OT: How To Remove Petrified Rubber Band
  125. Old Tool Catalogs
  126. About that electric impact wrench, that does not work very well.
  127. First time firing up wood stove, no fan.
  128. Gear question. How important is the diameter of the gear for thread cutting?
  129. metric threading gears
  130. My Mill Slipped Tram Due To Knee Sag
  131. Over center manual cone clutch
  132. Is it safe to weld or grind around your oxy-acetylene tanks? Assume turned off.
  133. OT, Someone ID this fitting
  134. General
  135. a link to my story of how I move heavy plate home and work with it
  136. Met a concrete post - car lost
  137. Where do I start?
  138. China sent me an almost entire height gauge.
  139. Another gear question
  140. cut off saw questions
  141. No more absurdly cheap shipping from China?
  142. square threads.
  143. roll your own tool post grinder bearings
  144. Recycling old batteries
  145. Rotary table id help please
  146. Machine Moving Question I
  147. Vacuum table for hold down
  148. Free nice shaper and very old lathe Aldergrove ..Craigslist..
  149. Albrecht chucks
  150. OT More dirt on electric cars
  151. OT: Free stuff located in MA (8 gas containers + oil extractor)
  152. Bandsaw roller guide chip brushes?
  153. You Think You Have A Toolbox?
  154. All-in-one flashing LED light for my bike
  155. Price of steel
  156. Compressed Files Or Zipped ??
  157. Spindle Bearings
  158. Carbide inserts for pull-threading
  159. Toolpost chuck
  160. OT- Maybe. Locking Double Gates
  161. Mill slot in carbon Fiber Tube
  162. Need advice on a big brazing job
  163. PAM Olive Oil Cooking Spray
  164. OT Idiocy hard at work
  165. universal bevels - what are their virtues?
  166. Sir John
  167. Seeking bevel gear help
  168. OT: An interesting insight into a potential cause of Alzheimer's disease
  169. screw threads and what are they nc or fine thread
  170. Couldn't resist this one
  171. Right Angle Drill Or Attachment
  172. OT- WiFi Range Extender
  173. CV joint blanks or CV axle repurposing
  174. Anyone know Köpings mills?
  175. Acetone alternative??
  176. OT ? - Want to start selling on other than ebay
  177. Granite Square, Tri Square - Anybody interested in bulk order from China ?
  178. Hertel Tap Quality ??
  179. Ebay 10% off sale - Good until 8AM Friday, 10/26
  180. can you read Chinese (I think)?
  181. CL: Excello Milling machine on East Coast w/ball screws for cheap $$$ (project)
  182. Use artificial intelligence to improve safety
  183. OT: In case you still care about Photo****et
  184. Baby Pacemaker at HRG
  185. ok ihave to top a 1/2x10 acme thread what is the dril for it
  186. This Looks Real Super Handy..... But
  187. Maxwell’s Demon
  188. Scaling up project dimensions
  189. SouthBend Heavy10 Gears Give Away running on Instagram and Facebook
  190. I Had To Get Real Creative Today....... Pressing Indentations Out Of Aluminum Tube
  191. In Search of Smalll Bearing Puller
  192. Got A Couple Surface Grinders - I Think Gloat Worthy - Maybe Even A You Suck
  193. Bearing quality designation
  194. Looking for ideas for variable small speed motor
  195. Frankenstein lathe for sale!
  196. OT...computer question
  197. KBC Tools
  198. Grinding Wheel for Cast Iron
  199. Adjustable Hollow Mill heads. Anyone use them? Preferred brand?
  200. OT: outmoded operations and equipment at UPS
  201. threading drill rod?
  202. Stankoimport 16k20 1980
  203. National Sales Tax ???
  204. Cutting oils
  205. Source for Model Gears
  206. How to calculate the mechanical advantage of a lever?
  207. accurate length shoulders?
  208. OT daylight savings time quit whining
  209. Decent but moderately priced wavy parallels?
  210. stripping chrome from brass.
  211. Diesel Fuel In The Shop?
  212. Victor tool company sure didn't impress me.
  213. O.T. ate a pound of chocolate and now i feel sick...
  214. Is there supposed to be any relationship?
  215. Close fitting parts
  216. Looking for Centec users
  217. Would You Keep It Or Send It Back ??
  218. worm gear animation
  219. Sheldon lathe question
  220. O/T Good Hands Insurance Issue for Shop
  221. Bushing machine for clock repair
  222. Dumore PD 2302 Sensitive Drill Press
  223. "The Making of Iron and Steel"
  224. Supreme reversable tapping head model 00 collets needed
  225. Problem with Lathe
  226. First try with 8"X 1/2" slitting saw,I have questions.
  227. Compressor acting up.
  228. Burnishing
  229. Brass sleeve bearing for knurling wheel
  230. OT- Smart Phone Apps
  231. something came in the mail....finally
  232. Candle shade carrier.?
  233. Unknown Lathe
  234. The cutout machine I built utilizing my swing arm
  235. R-8 stub arbors, 1 inch and 1.25 inch.
  236. homemade 2x72 belt sander wobble/vibration
  237. Flexible power shaft manuf. and power handling capacity? (project Binky...)
  238. Drilling and Pinning Hinged Molds
  239. Liberty ship steam engine
  240. Machining dovetail slide on my small shaping machine
  241. Battery life on CR2032 powered digital calipers? (shars or whatever import)
  242. Looking for more advice on a babbitt pour.
  243. Dual Fuel Generaters on Sale!
  244. Huang Shan lathe mill AT-280-1
  245. My daughter took the oath today!
  246. Mach Support forum disappeared?
  247. Anyone Here Run Adblock ?? OT Sorta..
  248. Lathe Test Bar - Someone's in error
  249. What lathe has a 2 1/4" - 8 spindle nose?
  250. Need Formula help for figuring the correct depth when milling at an angle. Please
