View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 [276] 277 278
  1. Need Formula help for figuring the correct depth when milling at an angle. Please
  2. 50 ton press, pad at end of ram?
  3. Warner Swasey Observatory
  4. OT: Lowes closing 27 stores (Canada), 20 stores (US)
  5. graphite rod as a bearing material
  6. Lathe Stand completed
  7. Precision Matthews pm932m mystery oil leak
  8. Speaking of "belt tracking"....
  9. New Machinist tooling
  10. are all BXA tool holders created equal?
  11. Lining Pen, home made and cheap
  12. OT Stateside question for you U.K. blokes
  13. "import" pencil die grinder dissasembly/bearing replacement?
  14. Large diameter pipe tailstock support?
  15. Deta Milling Machine Has anyone operated one?
  16. OT, Totally OT: How Do Banks Slow Down Mail To You?
  17. Odd bridgeport m head?
  18. Steel Identification?
  19. Grinding 3 jaw chuck?
  20. ShenPRIDE instruments digital caliper
  21. OT, sort of....Old film of motorcycle manufacturing.
  22. NOSB Drawbar
  23. Aquestion on battery charging
  24. Fuel line fittings and hose where to buy?
  25. So what chuck do you use everyday on your lathe?
  26. I Think I Invented Something: Back Side, Bifold Door Pull
  27. OT: I need to power a UV light?
  28. Metal Supplier near Tacoma?
  29. Got My New Angle Plate
  30. Rusted end mills
  31. Old excellent film about how levers and gears work. And really, gears are levers.
  32. Down spiral end mills
  33. O T Camera I R Filter Question
  34. New member; worn-out phase converter question
  35. 4 x 6 band saw question
  36. Question About Solenoid Type Oil Pump
  37. The "M" on the base of Acer vertical mills
  38. How much do you think it's worth?
  39. In a read last night:
  40. Favorite or Odd places you’ve picked machinery at.
  41. Can you straiten vinyal tubing?
  42. Making gears
  43. What Is Your Tap Preference
  44. does silicon steel go 'bad'
  45. How to fix a pressed on plastic hand wheel. I fixed my 4x6 HF bandsaw.
  46. Need advice on sleeving a brake bearing cap on Supermax milling machine
  47. Cam on Bob Shores Silver Angel hit and miss engine
  48. MSC 6" carbide grinder switch
  49. Cheap? Carbide Countersink?
  50. On topic stuff! Milling X feed handle, the push to engage type.
  51. Search Error Message
  52. Suggestions for getting a benchtop lathe?
  53. Design and build Side-shaft hit and miss from barstock
  54. OT Does this ring true to you?
  55. Black oxide experiment
  56. HF Cordless Drill/Drivers (Hercules)
  57. Two piece chuck jaw question
  58. Got some Goose Neck Clamps-Thanks Mcgyver
  59. Tri-Ball Handle for Lathe Chuck
  60. Two piece chuck jaws. question about making them
  61. Help needed wiring water well VFD
  62. HELP with sticky federal guage
  63. RIP Wolfgang Zuckermann, a different kind of craftsman
  64. Machining Exotic material
  65. HSS Basic Lathe Turning Tool
  66. HES Turret Lathe
  67. Mystery item from the thrift store
  68. WAY OT :I need a battery powered leaf blower
  69. Bendito Brake Press
  70. Squirrels Find Nice Metal Home, Until . . . . .
  71. If a steel is called W-1 is that water quenched? Why oil quench instead of water?
  72. What kind of drill bit sharpener for 1/8" and under?
  73. Basic breaker panel anatomy
  74. OT: Wildfires in Cali
  75. Early Myford MG12 Work Head Spindle Collet Seat Angle
  76. Seems Like A Good Deal For An Aventor 6" Caliper
  77. Rocky Mountain Twist -Drill Bits made in USA
  78. Belt sander belt slipping
  79. OT - Interesting take on buying a used car
  80. OT what gain is practical from an op amp non inverting amplifier?
  81. Making lathe tools out of 1045 key stock
  82. Interest in metal working declining?
  83. Scraping ... various thoughts and questions including making an ersatz Biax
  84. tool steel question
  85. Tailstock Turret
  86. Press bottle jack release valve mod
  87. How much was this lathe new?
  88. what are your ideas on those nonspill oil cups, shop made of course
  89. Who was he?
  90. 90 degree V-Slot cutting
  91. Gerstner Tool Chests - TOTALLY INSANE!!!
  92. Adding gauge to press
  93. Repairing broked plastic
  94. Indexing 4 way toolposts.
  95. Precision matthews pm 932m dro install
  96. What in your shop is a great value?
  97. OT: medicare insurance supplement cost
  98. OT- Ice Maker Issue
  99. Older Lathes with handy features for threading
  100. O.T. Why Parcels Take So Long To Arrive From China
  101. OD of threading dial gear
  102. How to make this washer/shim?
  103. Sheet metal benders, the bad, the mispelled, and the ....
  104. OT: upcoming FCC anti-robocall plans & spam texts
  105. Good tools for cutting soft sheet metal like copper
  106. Oops! Need Help Reassembling Wood Saw Fence
  107. Shaper table (or cnc tomb stone maybe)
  108. craftsman life time warranty ?
  109. OT I'm building a red iron building; have caulking questions.
  110. Acme Thread Question
  111. OT PID controller questions and help.
  112. 1968 Ultra Van
  113. Shop made machine
  114. Making new stanchion brackets for a sailboat
  115. Old bucket into new bucket
  116. Converting 230V 6-20 outlet to 120V 15A
  117. Shopping for lathes
  118. DRO install question help please
  119. OT: Hope you had a good Thankgiving
  120. Duplicating key for Honda Fit
  121. Seeking manual, or copy of for ancient Acu-rite DRO
  122. Drill Doctor collet needed
  123. Thermodynamics question (I think) possibly OT
  124. OT - Help with doorbell camera
  125. Interesting Piece On 3D Printing With Stainless Steel
  126. WAy OT: Question for SYFY geeks. Non geeks need not look.
  127. OT Chromebook vs Apple iPad or Microsoft Something.
  128. O/T: Jupiter. Why no metal or rock?
  129. Alibre Atom 3D
  130. OT- Heat Pump ?
  131. Teledyne Gurley DRO situation...
  132. Now I'm worried... what's the catch?
  133. Paintball co2 tire inflater
  134. Moving shop Eq around
  135. Tie down strap winder
  136. Ever seen one of these?
  137. Another "what is it?"
  138. Plasma cutters?
  139. Drill Chuck Removal - No Wedges,Hammers or Press Needed
  140. How fast can I run vertical attachment on Sheldon miller?
  141. OT: Mars Lander reaches Mars today at 3PM EST
  142. Some Confusion With SS Color Codes
  143. CNC Taig mill?
  144. thread size help
  145. Shop smith 10er mill conversion
  146. Warping steel when milling?
  147. Dave Spens and his antique machine collection
  148. Enco 100-1597 Three phase to single
  149. diamond blocks
  150. OT: GFCI outlets in an old house
  151. Metric Shank / English Collet - A Tip
  152. Taig CNC Mill, round two
  153. OT Strange computer tones
  154. physics anonymous on you tube
  155. OT Speaking of tire inflation.... HF pump that runs but stops pumping at 30 PSI
  156. Press Forming Tips & Tricks
  157. OT. Mt. bike thread but bound to contain some machining in the long haul...
  158. PH-BZ spring wire ?
  159. well still kicking
  160. $2200 parallels ... on back order !!!
  161. Small Mill; Identify, Thoughts, and Opinions?
  162. This guy makes some amazing photo etched parts from .005 brass and .015 copper.
  163. OT Unidentified Gimbal Tool
  164. DeWalt/Milwaukee/Bosch Heated soft shell jackets!!
  165. 8 inch diameter x 1inch wide sanding drum
  166. Odd modification to my SB7 shaper
  167. Any hints for machining brass and steel wood screws?
  168. Has anybody used a Makita 9032 finger sander?
  169. OT-Gluing Glass Crystal
  170. OT - Off Topic Back up Generator
  171. Finally got the Monster Post Drill done...
  172. I applied for a patent back in January...
  173. Just found a new You Tube channel for machinists
  174. OT:need some bicycle help
  175. Porta Drill Chuck Made in Italy anyone own one
  176. Looking for Good Drill Bits
  177. dent removal from a brass cylinder?
  178. Column vs Dovetail for new mill
  179. New Experiences with Titanium..
  180. OT-7.2 earthquake nearAnchorage Alaska
  181. That Time of Year: Christmas Presents for Aspiring Machinists?
  182. Atlas Shaper Gib Issues
  183. Water pressure gauge OK for oil?
  184. OT. Partially plugged tub and shower valve
  185. Milling coolant, lubricant, rust, bacterial stink... what to do ???
  186. Choosing and End Mill Cutter
  187. OT - repairing woodpecker tree damage
  188. OT, sort of. What causes cast iron dust to bond to ceramic glaze?
  189. New generation of lathes ? Or ? KNUTH Servoturn 410
  190. A complaint about way-too-long threads...
  191. Good Information I found Deep Hiole Drilling In home Shop
  192. End mill holders for ER spindles
  193. Need Chart for Dividing Head
  194. OT odd request for help from a Canadian member
  195. Mini-split heater for shop
  196. No too OT for a change. Physics question.
  197. Monarch 10EE molested during transport
  198. Anyone bought from Equipment Tools Store
  199. Machinist Library
  200. OT working in the USA from Canada
  201. OT Bought a wooden watch for a Christmas present
  202. Ideas for Hi Pressure Coolant Pump?
  203. Calipers as Carry-On
  204. OT- What Feed Back Should I leave (eBay compressor part)
  205. OT, But Related: Convert Excel Spreadsheet to A Cell Phone App
  206. Electrical Questions - DC motor controller
  207. CNC Mill False Stops
  208. Air compressor cooling fins name needed
  209. This guy built a pretty simple and robust 2" x 72" grinder that tracks well.
  210. A More Ambitious, Awsomer 2 x 72" Belt Grinder
  211. Dynapath/Hurco CNC 14x40 Lathe
  212. solar panel to make AND save energy
  213. Tony @ lathes.co.uk
  214. O/T, very, very O/T, Help from TrumpLand?
  215. Mill dro demo videos
  216. OT- Bolting a small pipe in a bigger pipe
  217. Engine Flywheel Resurfacing
  218. Dial Indicator screws for the back cover
  219. JIS Threads
  220. How long does it take to program a thread cutting operation on a CBC ?
  221. Current situation shipping US to Canada?
  222. Storage of Shim Stock
  223. A puzzle: How to secure worms on their shafts?
  224. OT: Firefox, Do They Actually Listen?
  225. Bridgeport Head Tear Down - Backgear Lever Movement?
  226. Machining Steel and Aluminum on a Mill/Drill
  227. Taig CNC Mill Adventure
  228. Question about Lathe Chuck Jaws
  229. Oil Change - Jet geared head lathe
  230. Turnado freehand turning system
  231. small vfd driven engrqaving / milling spindles
  232. Morgan Wood Working Vise Restoration
  233. Atlas Clausing 4800 bull gear in search of
  234. Atlas horizontal bandsaw bearing opinions?
  235. An idea and a warning
  236. Comments on Precision Matthews Equipment
  237. Design of a machinist's tool chest
  238. Crobalt® square tool bits
  239. Dial Indicator “Body SIZES”
  240. Titans of CNC youtube
  241. Soft soldering Galvanized sheetmetal?
  242. Air Powered Chuck
  243. OT: VPN's
  244. Enco Mill Drill (RF30) starting issue
  245. Boring for a bearing race- interference?
  246. Sprucing up a 550-pound vise
  247. Turning a long taper
  248. Recommend an electronics enclosure?
  249. Speaking of vises...
  250. Wood Ripper 1 - An EL-CHEAPO Import CNC Router
