View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 [277] 278
  1. the nevada triangle
  2. Looking Forward To Cabin Fever
  3. I’d like to make some 1-2-3 Blocks similar to Robrenz. How do they link accurately?
  4. Glue For Neoprene Rubber
  5. An interesting take on the self-reversing nut.
  6. Tool Post Grinder Stone choices.!
  7. Learning a new machine
  8. OT ^%$#@! box stores
  9. What is a good friction couple with walnut?
  10. A sign of the times:
  11. Metal Shapers Book
  12. LED light for DP or Mill/Drill
  13. Fusion360 vs Solidworks
  14. Speaking of Index: Here is the Index for the General Forum. Its easy
  15. squirrel cage blower
  16. Worm Gear Oils
  17. BP Way Wipers
  18. B-Port Mill Power Feed Unit Chinese?
  19. Going to try some chuck jaw grinding
  20. Milling Vise Quality: Kurt, Bridgeport, etc.
  21. Question on stainless alloy
  22. Off-topic: telemarketers
  23. Finally fixed my vise...
  24. Spinning or gearcutting on a machining centre.
  25. making vice jaws.
  26. Forum mulfunctions
  27. My first lathe
  28. Grinding Wheel Stuff
  29. That Atlas bandsaw bearing....
  30. OT..Looking for origin of odd noise in the old S10
  31. OT: Free stuff in MA (All or none)
  32. Air Filtration for Welding / Fabricating
  33. Longer bed for taig mini lathe
  34. Skillos I'd Like to Acquire
  35. Rockwell mill drawbar wobble
  36. Advise on Biax scraper pruchase
  37. Laser cutting acrylic... plexiglas?
  38. Need Repair Kits for Welding Regulators
  39. Getting a better grip?
  40. Large Nut Defastening.
  41. Burning mulch?
  42. Flashlights
  43. Magnetic machining
  44. 3P motor, need to determine voltage
  45. A recipe for yall.
  46. Yet Another Grinding Wheel Question
  47. OT Miss Universe
  48. Pink Floyd in the background as you run the Machines.
  49. Motor Failures
  50. O.t. Bit coin down to about $3100
  51. vfd question.
  52. stripped spark plug holes
  53. mechanism, possibly for Brian.
  54. Fire extinguisher service: scam or needed?
  55. JD2 Model 32 Tubing Bender
  56. bench mount meat grinder re-purposing
  57. Tip for putting out carb fire
  58. Bought a new machine yesterday---
  59. First project with my converted dividing head
  60. O.T. thought on auto stop/start systems
  61. O.T. One word, Plastics (caution - depressing)
  62. Where to get extra fine thread rod and nuts?
  63. Battery, (Cell,) Chemistry
  64. One Of MY First Milling Projects
  65. O.T. Can I have one, please, please?
  66. O.T. "I love this kind of human interaction."
  67. Where to donate machinery?
  68. Smallest model true diesel?
  69. Adding an aux. jack to radio??
  70. DRO lead too short?
  71. Lets say somebody just dropped $10K in my lap... Can I get into good CNC ???
  72. anyone own a Precision matthews ultra precision 1236 lathe
  73. O/T: Made some Sourdough bread today.
  74. Problems with brake pulley assembly/fitment of new bearing on SUPERMAX mill
  75. Got a source for toothed belts and pulleys for approximately 1/4 to 1/2 horsepower?
  76. 9 MM steel tube
  77. Precision Mathews making good on purchase
  78. Key steel selection.
  79. Flylo?
  80. Divider Controller Module
  81. Ways on Harig Super 6x12 have Teflon?
  82. Dec=Jan Machinists workshop
  83. Is this worth 30 bucks?
  84. Site problem
  85. Rotary phase converter motor
  86. Roskelley 1440 lathe
  87. Spill Proof Oil Cup......The Real Deal
  88. Tap Video - Interesting
  89. Mitutoyo .0001 test indicator
  90. Monitoring molten steel by laser
  91. Antique Savings Bank Book Key
  92. Cool Machines you own or have owned.
  93. So a long time ago I bought a face mill, now I bought an arbor to stick it on.
  94. Quality of these chucks
  95. Steve Lindsay shop tour
  96. OT DSO Nano Digital Oscilloscope
  97. as the world turns OT
  98. Homemade Indexable Dovetail Cutter
  99. Engineers Black Book - Opinions?
  100. Using a rotary encoder on a DRO?
  101. OT - Christmas Music Stream For Your Shop Listening...
  102. Temporary shaft coupler I made today.
  103. Home shop lasers: use and safety
  104. Bainbridge Model 101 Bandsaw - Leak or self lubed blade?
  105. I Think I Made A BIG Mistake
  106. A high level of anxiety moment......... not ot.
  107. Newb rockwell affordable calibration
  108. Mills and lathes straight from China
  109. Help me setup a 6x26 mill, please
  110. Hossfeld hyd. attach. info needed
  111. 'Twas the Night Before Christmas (home shop machinist style)
  112. PM 932 height
  113. Merry Christmas to all from Ontario, Canada
  114. friction welding assembly process
  115. Lathe dovetail
  116. Merry Christmas from Yuma az .......
  117. Merry Christmas for Germany!
  118. Merry Christmas from Arkansas
  119. OT:Do any of you all also suffer from ADHS or Assbergers?
  120. Torque of milling machine bolts, head, draw bar, even locks?
  121. Garage door opener
  122. Anyone dissassembled one of these centre finding microscopes?
  123. Different machine job
  124. Mori Seiki lathes
  125. Oil Hardening Tool Steels what oil
  126. Circle compass that will take a fine point sharpie
  127. Multi-use airtight booth
  128. Cheap DRO
  129. Pantograph Ratios
  130. Converting Clausing 8520/30 to R8 Collets?
  131. Why even bother anymore with manual machines?
  132. Help with ID on Millers Falls Level
  133. George Thomas "Universal Pillar Tool" on the cheap and easy?
  134. Size Of Stepper Motor needed?
  135. Old Brown and Sharp Dividing head
  136. Screwy Situation!!
  137. OT Some one took my idea
  138. Biax scraper refurbish
  139. My wife came through for Christmas... got me something I like
  140. 8-axis milling Thor race engine crankshaft (youtube)
  141. collet set and blocks
  142. Beryllium: "the metal that never tires"
  143. question on bushing materials....
  144. Little late for X-mas but interesting ring making vid
  145. Back to Turning a Barrel
  146. Craigslist: "Exporter coming to new england"
  147. Those sewing machine motors?
  148. How do you go about brokering freight on equipment?
  149. Shipping to far away places
  150. Here's what happens when you forget to take your down feed out of gear!
  151. Atlas 618 w/ crappy alignment
  152. Update to spill proof oil cup....the real deal
  153. Oil for a Sunnen Hone Machine.
  154. Make it Extreme hydraulic puller
  155. Assembly practice - from the 60's
  156. anyone hear from Forrest lately?
  157. Owens Corning 500824 Garage Door Insulation Kit
  158. Does anyone know about these plans?
  159. electrifying a hydraulic jack
  160. Chainsaw chain for ripping
  161. Stainless steel color anodizing experiment
  162. New Skinner Special chuck
  163. Machinery missing from the lathes website
  164. Automatic compressor drain kit - free for postage
  165. Avoiding corrosion between iron and copper plumbing fittings.
  166. Happy New Year to Everyone
  167. Which 4 inch Rotary Table ?
  168. In search of index plate ideas for lathe chuck
  169. Anyone have Teledyne Gurley DRO experience?
  170. Plane iron is soft
  171. Anybody interested in Sargon dro parts?
  172. Need Tough Face Mill - Advice?
  173. Engraving
  174. O.T. Anyone have any ideas on saving / restoring old boxes and papers from toolbox
  175. Some old live steam movies.
  176. Backlash Eliminator Question
  177. anvil-vise combo
  178. OT. modern replacement for wire resistor?
  179. Old Carbide Toolbit Using Face Mill
  180. Job opportunity in central Illinois
  181. Steel pipe roller design
  182. Hydraulic pump PSI correlation with Hydraulic Cylinder Ton
  183. Silver solder flux?
  184. HF Reversible Tapping Attachment
  185. Shars 60 Degree Indexable Dovetail Cutter
  186. My first assortment of carbide tips of the year
  187. Recommendation: Victor or Smith for LP cutting torch?
  188. SAE J512 seat cuter
  189. New Cars And Blinding Head Lights
  190. China lands on dark side of the moon ot
  191. Working Wobbler Engine with Interesting Material Choices
  192. Lathe interchangeability
  193. DOM tubing and types
  194. What Collets do I have ?
  195. Just want to put in a good word for a fellow tool sales person.
  196. ER32 chucks
  197. Snowmobile Spline
  198. Tetrahedral Drilling Jig for Molecular Models
  199. Ebay help Out for a few day
  200. Would I, Should I, Could I... Buy an Atlas and "CNC" it?
  201. OT: password protection
  202. Non flammable chip shield
  203. What paint? Lathe and Mill
  204. What speed for buffing wheel
  205. The Spline Adventure Continues.
  206. Free Hardinge DV-59 lathe on CL in MA
  207. Sort of OT - Nail Guns
  208. Opinions on height gauges...
  209. Dragged Away From the Shop
  210. TOTALLY OFF TOPIC - Well some metal content
  211. OT managing personal finances
  212. McMaster Cut Me Off
  213. Logan 9B spindle bearing preload belleville washers
  214. South Bend 9 owners, a question please?
  215. Buck chuck in search of ID hard jaws.
  216. Your Shop and the Hereafter??
  217. Enco Lathe Parts - Grizzly Interchange Perhaps?
  218. Belt sander/linisher - good or bad?
  219. Where do you all go for end mills?
  220. Scraper blades for Biax power scraper
  221. [OT] Windows 10, Ubuntu Linux, dual boot, HDD partitions, and virtual machines
  222. Pm932m RF 45 style square column mills shaking
  223. Plastic Air Lines
  224. Anybody with first hand experience with this black magic paintless dent repair?
  225. Anyone??
  226. Get me over the hump
  227. Tinker's Guild
  228. museums
  229. Self reflection on our hobbies
  230. Corded .25" straight die grinder recommendations
  231. DRO for a lathe
  232. What Lathes have HELICAL Cut Gears?
  233. Where is the Best place to buy Taper Shank Drills greater then 1.2"
  234. Punch grinding machine
  235. Shortening MT-3 arbor
  236. 2000 Hitachi Seki TS15 CNC Lathe $1000 on East Coast
  237. Shop inside the house
  238. What's the difference in these 2 tool holders?
  239. Mini-Mill Improvements, A Companion WIP
  240. Surface Grinder worth what he is asking?
  241. Homemade tool box drawer thickness
  242. Thermite Welding
  243. Shop trick of the day
  244. OT, how to fake a carburetor for a small engine with a jug and some tubing.
  245. Diamond wheel differences
  246. Model A enthusiasts?
  247. Do you have a self centering vise on your lathe or
  248. How to ream 1" ???
  249. Wade 8a collet draw bar
  250. What did I machine today?
