View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 [278] 279 280
  1. My first engine build
  2. The "craigslist find" thread.
  3. Making your own rolling element bearings
  4. Rockwell rebuild
  5. I want to buy a hobby vertical mill.
  6. OT diy stitches.
  7. Old lathe recognizing
  8. O.T. anyone else have trouble with your shoelaces coming undone all the time?
  9. Need Rigid drill press arbor taper size
  10. OT Powder Coating Question
  11. Schraader Valve Tap
  12. Non-standard threads(?)
  13. Gloat
  14. Professional - Imports Not Included?
  15. OT article on device to keep voice-controlled home assistants from listening in
  16. OT Need Opinion on Removing Emissions from 1985 GMC S15 4WD Pickup
  17. Here's a guy with WAY too much money.
  18. Old ceramic inserts for hard materials
  19. manual for Induma 2U mill
  20. Home shop solution for a reasonable master square for the surface plate?
  21. OT: Alan R. Pearlman, inventor of the ARP synthesizer
  22. I think I see the problem...
  23. Oxygen concentrator for shop use
  24. A scraping project
  25. OT: help me explain why this Hudson River Pedestrian Bridge idea is ridiculous
  26. Tool honing machines
  27. VFD question
  28. Polishing plastics
  29. OT – Can my phone really hear me?
  30. Resolving salt corrosion on ratchet straps
  31. New uses for old Pliers
  32. Chinese pole saw is better than Stihl
  33. Finding an old post
  34. Correct tension for quill return spring?
  35. Folding Utility Knives & Saws
  36. What weight oil n Rotary Table
  37. My cordless drill will not hold small drill bits any more????
  38. DIY 2x72 belt grinder build.
  39. Is this still a machinist forum?
  40. Taig Mill Improvements
  41. First micrometer?
  42. Cutting an Oxygene tank
  43. Early Atlas shaper database
  44. Tool honing
  45. Abom79 Out on his own.
  46. Cylinder Square - how good can you make it ?
  47. dro question.
  48. I don't think it is OT machining juniper
  49. Floating a Sun gear...
  50. Humidifier Help If Possible
  51. Can anyone advise what these are?
  52. Test Photo
  53. Differing amp readings from 2 meters!
  54. Lathe motor centrifugal switch adjustment help
  55. Cyanoacrylate adhesive (gel) and activator -- best buy?
  56. Thread Dial Indictator for Emco Super 11
  57. Great forum! OT slightly
  58. Score. Sort of.
  59. A “what is it “ question
  60. Slip roll question.
  61. Level your lathe!
  62. Slap it on a grinder - Sacrilege!!!
  63. What's up with MSC/EBay?
  64. Starret 93c 50 Subscriber Giveaway
  65. radios in a shop
  66. Question about non sparking tools.
  67. Twin insert tool on ebay
  68. DRO scales Magnetic vs glass
  69. cable sheath
  70. Bernay Engine machining content
  71. Rupnow Vertical first run
  72. Metal Selection
  73. helix how to,,,,,,,,,,
  74. OT: Tooth Brushes
  75. Hour meter for 24 VAC furnace
  76. Drill size calculator for tapping holes
  77. Setting up a K40 Laser Engraver
  78. Ya! Another “what is it”
  79. Modern Machine Tool Design
  80. 1930 1940 large Rockford Lathe
  81. The home shop punching machine
  82. Odd grizzly G0602 lathe problem help please
  83. Tools to make tools to make things.... WHY! ? ! ?
  84. Lathe Repair. What You Do When No Options
  85. Atlas 12 vs Heavy 10
  86. old eyes and test indicators
  87. hardening question
  88. po pholk splines
  89. 3D printedParts
  90. Looking for a milling machine
  91. Posting photos
  92. Please help me find this switch
  93. O.T. Paddle to the sea (whittling content)
  94. New Precision matthews pm 932m dro problems advice please
  95. 3/8 dia x .150 T slot cutter
  96. Norton Surface Grinder Identification Help Needed
  97. OT: Yahoo Spam filter not working
  98. Handy Oily Rag Applicator
  99. OT: So I guess that they will be going after shop vacs next?
  100. How frequently should I screw?
  101. “Bin@way a lot:
  102. Dial test indicator range question
  103. Heavy 10 Update - Purchased! (Pic Heavy)
  104. OT: Min Max Thermometer
  105. Sorting Carbide vs. HSS vs. Cobalt
  106. Drill chart for length of point chart
  107. turning small M1.4x0.2 threads (127TPI)
  108. For those that like O scale train stuff, I go to church with this guy:
  109. changing variable speed belt on bandsaw
  110. New Member Hello
  111. Cleaning Question - White Growth On Plated Steel
  112. Asphalt Floor Tiles For The Shop
  113. 10$ carbide tipped scibing calipers
  114. Carbide sharpness and other favourite fairytales
  115. Don't put the brown end in your mouth
  116. centrifugal fans
  117. "Perfect handle" Phillips screwdriver?
  118. Sir Johns CD's
  119. Slightly scary machining
  120. Rochester, NY Area Help
  121. I wanna tap that !!!
  122. Which aluminum alloy for a bushing
  123. New member, with a "new lathe" an some questions
  124. OT: Electric motor problem
  125. Press-Fit Sanity Check
  126. Shop time.
  127. Gantry is fully functional!!
  128. Somewhat OT. Software for Organizing Photos
  129. Peddinghaus iron worker hydraulic system problem, semi OT
  130. I miss ENCO!
  131. Straightness of rod
  132. flush riveting video
  133. Mis-heard but still machining
  134. Need help troubleshooting a DC motor controller board (rocker platform) - fixed!
  135. 1/4" Air Tubing
  136. Someone's Ferrari engine modifcation - lots of aluminum welding and machining
  137. Shop Made Pedestal Feet
  138. interesting cranes
  139. Wife wants to move...
  140. I need to make 200 button style drawer bumpers, here's my ideas
  141. made a fun gadjet to play with :)
  142. Another photo test, I hope.
  143. Turning turmoil
  144. Convert gasoline engine concrete mixer to 3 point - very slight machining
  145. Kurt powerdrawbar shear pin
  146. Anyone have old Record Vise info ? Have a 632.
  147. OT PC trouble - ghost in the machine?
  148. Adjustable parallels, Starrett v Chinese - Which is "better" ?
  149. Drilling a 3/8" drive socket
  150. Can one hand scrape granite?
  151. Wade 8a owners - collet list?
  152. If you had to purchase just one Village Press book, which one?
  153. reverse voltage protection section
  154. Lathe Recommendation
  155. Cold saw vs horizontal band saw
  156. Making copper sealing washers
  157. Power supply for LED light
  158. Analysis of mystery metal
  159. Gear material choice
  160. Finding exact centre height on lathe
  161. Smithy Parts
  162. OT - Need sparky for tecnical question - florescent lamp ballast
  163. Do you find this a lonely business?
  164. Delrin for Bushings ?
  165. How To Remove Plate Glass Mirror From Wall ..... ot sort of
  166. Sharpening Hand and power scraper carbide
  167. Vacuum holder cup choice
  168. Shop-Made 123 Blocks
  169. H/V Band Saw Bearings
  170. OT - How to stop a big train on a dime
  171. Kalamazoo 7AD Hydraulic Feed
  172. Well i go tuesday back to hospital . Just for a check.http://bbs.homeshopmachinist.ne
  173. BC Ames Triplex Lathe Anyone ever use one
  174. OT; Windows updates.
  175. Rookie lathe user needs some advice
  176. Setting to hide "This message is hidden because (the fool) is on your ignore list."?
  177. Work Holding in Vertical Bandsaw
  178. threaded insert
  179. Cleaning buffing wheels ???
  180. The wonder insulation material
  181. First Milling Machine
  182. More help with ID from you guys please
  183. OT Somewhat- Mower Blades
  184. What is this,
  185. OT: The European governing body for horse training licensing.
  186. Air Coupling Mfg. Question
  187. New work bench for the garage
  188. unusual lathe
  189. Shop press winch mod whatcha got. pics if ya got em !!!
  190. Bought a ring gauge on ebay
  191. O.T. Art people are just plain loony
  192. K. O. Lee S618 surface grinder
  193. JMS4 D collets?
  194. EVO 9" Metal Cutting Circular Saw
  195. OT: Flickr is deleting user photos
  196. Taper grinding on a T&C grinder
  197. OT: Crazy buildings in NYC......
  198. Shop Spring Cleaning
  199. Modifying a perfectly good press
  200. Wire termination crimping tool?
  201. Guess what's coming tomorrow?
  202. Carriage top removal stuck 13 “ clausing
  203. Somedays I sure Wish I had A CNC Lathe
  204. Need help with Atlas 12" belt tension lever
  205. Maker Synergy... 3Dprinting Ronter Drive Belt and Pulleys
  206. I need to make 200 (actually only 96) button style drawer bumpers UPDATE
  207. OT Chinese Legos
  208. Carbide insert securing screws
  209. Acceptable spindle play, Logan 825 10” lathe
  210. Old time workshop
  211. Etna tool
  212. Shop print reading exercise
  213. The perfect shop floor print
  214. OT: Disappointment: No Look Door, Get Key (Black Mirror: Bandersnatch)
  215. combination band saw- which blade?
  216. Upcycling! Actually not OT
  217. Unknown Motor Speed Control I think?
  218. accuracy drilling small holes
  219. OT - Source for solvent and cleaner friendly pump sprayers
  220. Replace my Chinese AXA parting tool holder
  221. adapter to mount a Bridgeport head on a Clausing 8540 mill
  222. OT: Site blocked
  223. Machining related: Lathe motor rebuild
  224. treadmill controller question
  225. Colchester Student MK1.5 original color
  226. OT: Buying Firearms (Long Arms) in the US & Export
  227. Realigning a rebuild bandsaws' wheels?
  228. New wheels for the tool grinder- suggestions please?
  229. OT: Your dorkiest picture contest :)
  230. Any Vectric or Inkscape users?
  231. What are the common triangles, OT, laying floors ??
  232. OT: The destroyer Fitzgerald's collision with a container vessel
  233. Got a surface table at last.
  234. Best wheel for re-surfacing magnetic chuck?
  235. Smart phone apps
  236. My new Devil Dog!! OT
  237. OT: Interesting new automation problem?
  238. Bigger vert bandsaws.. opinions
  239. 1938 Pontiac Master Cylinder Sleeve
  240. antiquing some chain
  241. threading on jet 9x20 lathe
  242. Is it OK to post OT (on topic) machining stuff?
  243. I may not post attachments. Why?
  244. Hub Repair
  245. Grinder mod
  246. Backup electrical generator question about loads
  247. Lathe unloading
  248. Lathe unloading
  249. Mill vice back saver stand
  250. Gage Block vs. Space Block
