View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 [279] 280 281 282
  1. HSM site is blocked from viewing in Australia.
  2. Replacement Bezels
  3. Working a hardened file.
  4. YES!!!!!!
  5. What's Your Advice on Multitools?
  6. schematics for a Mitsubishi MDS B SP 220 Servo Amplifier
  7. Timelapse of raising the deck of the Bayonne Bridge 60 ft
  8. Shars KA counter linear scales REAL difference between 500 series and 300 ?
  9. Bandsaw electric blade welders ...the secrets ?...soldering as good ?
  10. Swivel eye?
  11. Registered with IMGUR today
  12. (my first attempt) Homemade "precision" hamster wheel
  13. Need help/advice please
  14. What is it (again)
  15. I want to play what is this item?
  16. Received my free Grizzly 2019 Catalog.
  17. Quick lil collet organizer
  18. Speaking of indicator crystals
  19. Boy did I ever grab the wrong tap...
  20. O.T. what's going on with the Canadians and their foot fetishes?
  21. Confusion re rotary table chuck mounting
  22. Freehand Turning Revisited
  23. I can't help myself
  24. OT: 438 Days: An Extraordinary True Story of Survival at Sea
  25. Milling Vise Size?
  26. OT: Windows 10 OneDrive and other cloud services
  27. DIY injection molding... plunger leakage?
  28. Sima Rossi VO milling timing pulley
  29. Motorcycle coil pickup
  30. Upgrading my boring head arbor (might be helpful for you as well)
  31. Old machine shop paint schemes
  32. 4140 and copper plating
  33. Here we go again- shop lighting
  34. Looking for flex polishing sticks
  35. Grinding O-1 blanks to HSS tools
  36. 10" South bend question
  37. OT: recruiting help to clean my shop
  38. OT A positive vendor experience
  39. OT - Train World in Brussels
  40. OT: Transformer Buzz
  41. enco 92010?
  42. Spin indexer VS dividing head?
  43. Valentines day treasures
  44. Any thoughts about tiny and odd sized endmills?
  45. VFD wiring strategy
  46. Rikon wood lathe doesn’t work in the cold
  47. Large end mills free to a good home
  48. Unibur gets bit by their own ads
  49. Daytona 500
  50. What is it? Small electrical or electronic plug-in thingie
  51. air bearing lathe
  52. Physics or chemistry question
  53. Is This Angle Special Made ??
  54. Weekend fun
  55. care / use of a resin diamon grinding wheel?
  56. File Organization & Storage?
  57. OT - Epoxy
  58. Need Advise On Toolmakers Vice
  59. Grinding Newbie Just Got A Surface Grinder
  60. Who knew that there could be so many parts in an indicator?
  61. Shop heater help needed
  62. ultrasonic cleaner.
  63. Alibre Design problem...solved...heads up
  64. OT Circuit Diagram Software (Free?)
  65. Alexander master toolmaker
  66. O.T. Drainage question
  67. OT: Oh Agony! I Broke The Macro Links In Excel Spreadsheet!
  68. Interesting engine for you model builders
  69. How to get 5 Moore jig borers into basement?
  70. Always good to see this show up in the mail
  71. Slitting Saw Arbor
  72. OT - does the General Forum get archived? How to access?
  73. Practical coefficient of friction question.
  74. OT Coil winding hints for very small wire?
  75. Loctite 638 strength? Can I bodge it?!
  76. OT: AMA Expo East
  77. AMC Marlin
  78. Breaking the Rules – Hardinge Tooling for Sale
  79. OT, Cable TV just went up $130/month..... Hulu?
  80. Building your own Ball/Clutch
  81. first ever micrometer?
  82. Why are files tapered?
  83. Deckel FP1
  84. making rubber washers
  85. How i designed and made endmill holders for TTS system (2x rigidity)
  86. DRO Quirk
  87. Cleaning Hand Files Easy Way : Opinions
  88. Coarse thread vs fine thread
  89. OT? Maybe not? Carbon Fiber construction
  90. DRO on a RF45 mill
  91. real machining... check out minute 4.xxx
  92. HSM machines outside the Rust Belt
  93. Antique lathe on Craigslist
  94. Jenix scale reader heads sold separately?
  95. penknife project
  96. Strip Door Curtains??
  97. Where to find used transformers?
  98. Tool Post Grinder Sizes?
  99. Names expo 2019
  100. Beginner tooling selection
  101. Experience with Ajax Tool Supply?
  102. Oddly satisfying
  103. Making a drive belt for a Hermes MV engraver
  104. Chip welding to endmill in aluminum
  105. Question about reversing motor direction
  106. Ot:using basic programming language with windows 10
  107. After the punch machine punches out all the dog tags, what's the leftover bit called?
  108. A guy builds a lathe with some I-beam, an angle grinder, a ruler, a welder, etc.
  109. Screw and Glue, or just Screw
  110. Rust spots on the sink
  111. Reversing an EMCO FB2 Mill.
  112. Speed reduction, universal motor
  113. Problem with Servo 140 on my Mill
  114. Brass versus Aluminum
  115. Any of you ever single pointed a crazy fine pitch thread?
  116. Borgward Isabella. Ein Deutsches Auto
  117. Hi All..Long time no chat... Question about using a 10hp motor on a 7.5hp compressor.
  118. Red Ants and Black Ants--O.T.
  119. Anchoring portable generator
  120. Picking up (literally) my new South Bend 13
  121. Need bushing/bearing advice
  122. So I bought this Taiwanese lathe. I've got the "you'll be sorry" going on in my head
  123. Mitutoyo bezel removal
  124. Quick change tool post QCTP for Wade 8a Lathe?
  125. OT - Another reason to despise photobucket and not use it
  126. Another entry for the “You Suck” award.
  127. OT Yellow Jacket Nest
  128. Mini lathe toolpost stud
  129. OT: The "Elephant's Foot" and the 3828 unsung Soviet Chernobyl heroes
  130. OT: Positive experience with insurance company!
  131. WANTED Lathe tailstock
  132. Is this what passes for "Cold Rolled" now?
  133. Mystery item (very nicely engineered)
  134. I hurt a good friend of mine a couple of days back.....
  135. Where is Boslab?
  136. Category 3 Machine Suckage
  137. Normally closed to normally open inversion?
  138. For Black Forest
  139. VFD and treadmill motor
  140. uses for old bandsaw blades
  141. acceleration/ breaking visual
  142. Spot Welder
  143. Aloris tool post questions
  144. Thank you GB and Gang.
  145. Tested: Shogun automatic center punch (Made in Japan)
  146. OT Congratulations to Space X
  147. Looking to buy Jr a Milling machine
  148. Surface Grinder Table Power Feed
  149. Bernay engine progress
  150. Hypothetical electric motor question
  151. One off the bucket list.. knife from a file
  152. Precision ground bench stones : what the hell !!!
  153. Ok... WHO RATTED ME OUT?!?
  154. OT: Machine work for hire,Bike heads?
  155. Manual milling offset calculations
  156. Please tell me about knee mills VS mill/drill
  157. Score for today howd I do ???
  158. Erasteel HSS grinding guide
  159. It's a new Supermax ball game now.
  160. Webb Series 3 vr Bridgeport
  161. Help with lathe I.D., and a possible score...
  162. Partially OT: Microsoft(?) Spelling Checker Anti Machinist Bias
  163. Pin vices and Valve lapping
  164. Solid carbide boring bar from China
  165. Mystery Indexer
  166. OT: A fun little piece of malware.....
  167. My Taiwanese Shenwai SW-900B Lathe Clean/Repair Thread
  168. Hypothetical: Custom milling machine
  169. Any recommendation for a filter for flood coolant?
  170. Froged in Fire - The Kid
  171. New to me doall.. questions
  172. Moving Bridgeport
  173. Free stuff
  174. End of metals era in West London
  175. OT-Survey if your fingers DON'T crack
  176. anti-heat coatings
  177. Knurling - how to?
  178. machine vise article in march/april issue
  179. 2 Post or 4 Post Car Hoist
  180. Axe factory in Maine 1964
  181. The alignment tool article- a question
  182. I think I may have solved a puzzle,
  183. "Newish" Kurt D688 vise with s sticky spot
  184. OT: modern semi-trucks brakes
  185. crashed my DRO scale
  186. I bought it
  187. How to remove paper from 20 year old plastic?
  188. Conductivity Question
  189. OT: Windows 7 & Google Security risk growing greater?
  190. Cutting a 27TPI thread on an Atlas 10F
  191. Face milling cutter uneven surface
  192. Electronic component availability
  193. K&T cat 40 tool holders
  194. The Home Shop mentality... make vs drive and buy...
  195. Broach Sets
  196. Tell me about making V blocks
  197. OT: Gamble on a Backhoe?
  198. Some test shots with Andonstar ADSM 302 HDMI digital microscope
  199. 2 year old grand daughters favorite videos
  200. OT - Ebay Home Page Crashing on IE?
  201. American Lathe in Phoenix
  202. Ok, go ahead and have a laugh at my expense.
  203. I got a shock from my Foredom motor, can't figure out whats wrong
  204. This old stuff fascinates me...............OT or no ???
  205. How To Avoid Machining
  206. Can anybody identify this vice?
  207. O.T. DIY battery pack BMS problem
  208. DC motor wiring, what exactly is the "field" in a motor?
  209. DIY EDM -Electrical Discharge Machining
  210. Electronic component availability post got me thinking.
  211. hazards of using epoxy
  212. Tuning and modifying a scissors style knurling tool
  213. I think Clickspring has been taking lessons from This Old Tony - machining content
  214. making Er16 collet chuck
  215. Ebay must have hired att to do its billing
  216. Slitting saw advice
  217. O.T. old chainsaw restoration and a mystery problem
  218. Spring floods!
  219. 3D printing........???????
  220. CNC Shaper
  221. Why it might become harder to spot quality tools.
  222. Dyeing traps
  223. Newb hydrualics system questions.. Doall table
  224. Anybody consider one of these spindles for a DIY mill build?
  225. Help with a gear?
  226. Smithy 1220xl 3 in 1
  227. Printing vs Machining.. your view.
  228. Short question: Thread dial with 5 divisions, what gives?
  229. I need to get a metric tatooo
  230. DIY drill chuck extender
  231. G&E shaper question
  232. Precision Bench Lathes
  233. The benefits of simple CAD drawing.
  234. Grinding precision ground tool room stones
  235. OT- Lasers
  236. OT - personal profiles
  237. Tip: A Quick And Dirty Gauge
  238. check out this restored shaper
  239. 3 hour damascus knife.
  240. Childhood shops.
  241. Mahr micrometers
  242. OT: Does anyone have the email address for Milacron over at PM?
  243. Power Hack Saw vs Horizontal Band Saw
  244. OT: Real life Mr Jangles
  245. Sideshaft i.c. Horizontal Engine
  246. Mystery high temperature material identification?
  247. The Definitive Guide To Who Is the Parent Company Of Just About Every Tool
  248. Project: Long road to a belt grinder
  249. Poor man's induction heater power supply question.
  250. Powder Coat:: Is it & Prep
