View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 [281] 282 283
  1. Monday Monday... Da da. Da da dda.
  2. a fairly wide cut
  3. I have a Dalton lathe that I want to make reversable again
  4. CNC Plasma Table Build...?
  5. Tig welding suggestions
  6. My 7 x 12 bandsaw mods
  7. Gear cutting and end mills
  8. Ever see a tap with 3 sizes ?
  9. Coatings for Machine Tools... Going Nude?!
  10. emco v 13
  11. Help needed in identifying Atlas lathe.
  12. Cast Iron
  13. Robo calls:
  14. Single-tooth broach geometry?
  15. Tom Senior light vertical.
  16. Tramming and measuring setup for my mini mil
  17. @D printing plastic that is intended to be springy? Does it work?
  18. TV Show: Impossible Engineering. Episode 6:2. Railroads.
  19. What did you watch today? (favorite youtube channels)
  20. Devcon Or JB Weld...... Too Many To Choose From
  21. Electric 4 wheel buggy
  22. What do you prefer? Gage Blocks or Height gage? or Both?
  23. Is there a way to block entire threads?
  24. Lube a freshly rebuilt distributor?
  25. Center and follower tools
  26. Motor starters/contactors/heaters
  27. OT: Pilot's View of Airbus A380 approach and landing at San Francisco
  28. Grinding Errors - Why?
  29. Sheet Metal Brake ID
  30. Compressor Drain Routiing
  31. I need some nuts
  32. Wait? What? - What is that?
  33. Why no shipping details when ordering from McMaster?
  34. I Must Have Got Behind In MIG Welding Technology
  35. Whitworth: Father of precision and one COOL cannon
  36. Arbors : ?? shell mill vs shell reamer
  37. airless resin mixingq
  38. Walmart sells mills?
  39. OT: Building Spruce Bi-planes
  40. Newbie needs help with mini-lathe
  41. Tools You Didn't Think You Would Use Much, but You Were Wrong
  42. Carriage lock screw - Any reason not to
  43. 1942 Curtiss Wright aircraft engine factory video
  44. Tools you think you would use but don't.
  45. First time to make a spur gear
  46. BP Table Power Feed Lever
  47. Cast Iron (repair)
  48. Repairing patio door glass seal
  49. OT: Starting a 350HP 2400 volt synchronous motor with rotating 'stator'
  50. Little Machine Shop prepares for second round of import tariffs
  51. Couple of questions about my new mini mill...
  52. Weigh Mill Head
  53. 40taper horizontal arbor I don't need
  54. trailer axle U-bolts - what steel?
  55. searching for a viscous dampening fluid
  56. Greenard 3 1/2 questions
  57. OT: Best Way to Buy A Used Car Today
  58. NC Viewer simulator
  59. Where tool post grinder flat belt??
  60. What non-machining hobbies did you do today?
  61. diy thread forming taps
  62. Moving a machine / wood shop any suggestions?
  63. Rules - Rigid vs flexible?
  64. Lathe Flat belt supplier
  65. Precision Blind Hole in Aluminum?
  66. ot: the redefined kilogram, etc, to take effect on Monday
  67. OT: Firefox slow to load home page
  68. Whats the difference between,,,,carburizing, case hardening, color case hardening ??
  69. OT: A less rosy view of "driverless cars"
  70. Varco HSS Referce Chart
  71. Totally worth it yard sale day
  72. Vise Square - HOW Does It Work?
  73. Home Made Tool Holder
  74. Help ID chuck
  75. DIY thread rolling head - thoughts
  76. Anyone have personal experience with a 1940's vintage Leblond Lathe like this one?
  77. Bought a steam cleaner for the house!
  78. Where to by D mount Studs
  79. Improvised Barn Roofer's Brake
  80. Super adjustable trailer hitch not for the road
  81. drone catcher
  82. Newbie looking for knurling info
  83. Recommendation For Coolant For Mister
  84. OT - differene between Fluke 73 and Fluke 77 series II?
  85. Anyone built a zip line for the kids...??
  86. Ebay English Wheel
  87. Threaded chuck back plate advice needed
  88. OT- Shower Base
  89. How would a guy make this clip/bearing holder thingy?
  90. Enter the Shaft Diameter Not the Pilot Diameter - DUMMY!
  91. Fluke 87 battery drain
  92. New Craftsman Hand Tools
  93. Anyone know what happened to projects in metal page ???
  94. Static Balancer
  95. Alistair,Flylo,Eddy Curr not seen them for a while
  96. How to sharpen a zero flute countersink
  97. filing machines
  98. How about a "chat room" section for OT posts?
  99. Made a new spindle gear for the Rivett 8" Precision
  100. What should I offer for this Atlas TH54 6" lathe
  101. Does anyone have experience with a Hardinge BB2V mill?
  102. Made a pair of Webster Whitcomb (watchmaker) collet drawtubes
  103. Belly Button Lint
  104. 3/4-5 ACME leadscrew nut.
  105. Loktite ... which to use when ?
  106. Is Blacksmith Stuff OT?
  107. Ford 1952(?) fire truck
  108. Machining brainpower
  109. trav-a-dial find
  110. lets see your home made trepanning tools please.
  111. This Weeks Curb Find
  112. MT 4 collets
  113. A/C in the shop
  114. CNC wiring: how to intregrate on/off, contactors, e stop etc
  115. preasure washer current draw question
  116. Water Pump Jack
  117. This is also sad.
  118. Chasing My Tail Squaring Up V Block
  119. First attempt at lost foam casting
  120. So who needs a mill or RT to cut splines?
  121. Laser rust removal - Wow!
  122. Sometimes, you need a fixture
  123. A footnote to model exhibit vandalism
  124. MLA Andy Lofquist
  125. More on the Tom senior.
  126. A neat chart/table on steels & treating
  127. Well, Adrian. 3PH
  128. O: Our daughter grilling for the first time!
  129. What did you bore today?
  130. Grinding Oversize (Length) Parts
  131. Sandvik's tuned mass damping cutting tools
  132. Parting off to lenght
  133. Dial Test Indicator Holder for Sherline Lathe
  134. Propane gas connections from kitchen stove to 20 pound bottle
  135. Any EMCO Maximat Mentor V10 owners out there?
  136. Help with gear needed
  137. Car fuel door repair
  138. Your Old Time Bookstore (Lindsay Books) business shutdown sale
  139. 3" Bench Grinder -> Toolpost OD Grinder?
  140. OT? dunno - have you tried to re-arch a leaf spring at home?
  141. Looking for a manual pop rivet gun of a good quality. Can you suggest any?
  142. Modify a pop rivet tool for use close to a flange.
  143. Arbor Press ID
  144. O.T. so you climbed everest - so what...
  145. On Topic? Off Topic? It's about an addition to my machine shop...
  146. I'm really struggling to tap straight holes...
  147. OT need headset for radio
  148. Turning B&S 9 to R8 question
  149. Tramming the Mill question
  150. DRO... New digital readout recommendation.
  151. Making Colchester lathes
  152. Air compressor timer
  153. Why does my H/V bandsaw cut a cup shape
  154. Need Information on Shenwai Lathe
  155. Computer Issue Boot Disc OT
  156. O.T.--Riding Lawnmower Spindle Bearings Heads Up
  157. Long, narrow plastic containers? Electrolytic De-rusting
  158. Band saw blades
  159. Nice Material Gloat
  160. Old video (early 90's) of an older NC machine (late 60's)
  161. Carlton lathe help wanted
  162. Reference Book for Milling Machine Course
  163. Door Lock
  164. Needed a 19.05mm shaft.
  165. Time to grease the green monster
  166. A Covey of carburetors
  167. Release Agent for Five Minute Epoxy
  168. Tell me about Shapers
  169. OT: It is official. I am an old man!
  170. Jacobs taper. Enough contact area?
  171. New DTI On My Mind
  172. Dumb machining questions. The jig that an engine gets bolted to for machining called?
  173. Checking Squareness, Methods, Stands, Indicators Etc.
  174. Another carburetor story
  175. can DRO scales "fix themselves" ?
  176. Cheap Miter Clamps
  177. Coating Recomendation
  178. LED lighting recommendations?
  179. Math. I love numbers :)
  180. Little Free Libraries
  181. OT - The REAL Definition of Success
  182. OT: Pallet jack, removing large hydraulic piston nut.
  183. Countersinking 304 stainless--many flutes?
  184. OT - Material Search (bathroom repair)
  185. Spinner Handle for 5c Collet Fixture
  186. Cutting a spline
  187. scrounge of uncertain composition
  188. X axis travel extension for 6x26 knee mill
  189. The second best way to fasten handwheels to the leadscrew
  190. Story Time O.T. No machining content.
  191. Machining The Body of an Eight Inch High Explosive Howitzer Shell (1917)
  192. Corundum as a core-drilling abrasive used in ancient Egypt
  193. Wiring up the VFD on the lathe
  194. The Interns are nice, dumb but nice,
  195. Di Acro Manual Shear Part Info
  196. Shop lights converted to LED's
  197. Metric Translation Gears, An Idea
  198. O/T: Ebay and its subs.
  199. Cylinder Head Spring Seat and Valve Guide cutting
  200. Bodine gearmotor
  201. Taps and Dies.
  202. Adjust pinion gear on dial indicator?
  203. Faux Cylindrical grinding
  204. Yet another use for a 3D printer
  205. Dowel Pin Tolerance's
  206. TIG cooler pump motor making noise
  207. OT - check amazon before ebay purchase
  208. Switching the output of a VFD under load..... instant destruction... or not?
  209. Olden instruments
  210. Telephone Tricks-kinda machine related
  211. DIY DRU for small lathes
  212. I blew up my VFD!
  213. Hit and Miss engine question
  214. 3D printing strengths and weaknesses
  215. quick Q - sizing wiper seals for a reciprocating shaft
  216. well there you go OT sort of
  217. mixing concrete
  218. Keeping Brass Clean?
  219. OT- Truck Bed Slide
  220. Been to an auction today
  221. OT- Computer back up - Similar to Joe Lee's topic
  222. OT Model train electronics
  223. OT: Ladder lift or hoist for shingles or other items
  224. inverting air-over-hydraulic jack?
  225. A Blast from the Past--Radial Engine
  226. Sort off OT: Problem disposing of magazines, the reading kind
  227. Does any one make a cordless drill only
  228. Looking to build a IC engine, and radial
  229. Keyless Chucks
  230. Three stooges lifetime super duty hose reel
  231. Is this some kind of beveling tool?
  232. Large End Mill for Bridgeport
  233. Why grease on cross slide screw?
  234. How fast does a home-brew EDM machine cut ?
  235. Hardinge Wedge-Type Toolholders
  236. I broke these off. Sad face.
  237. swaging wire rope
  238. Milling math
  239. Ot- semi w 40k lbs of bees
  240. Puller for plastic wall anchors
  241. Who's our resident antique outboard motor guy?
  242. machining iso 40 tapers.
  243. Finished VFD mod to my lathe
  244. Recommend SIMPLE single axis DRO
  245. Storage cases for single end mills and drill bits?
  246. OT - Stud Finder Recommendations
  247. Old Central Tool Catalog
  248. toolcutter and lathe question.
  249. Sheldon Model O followed me home
  250. OT: Oil Mixup for mower
