View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 [282] 283 284
  1. I Wonder Who Made This Pulley Assembly
  2. Boxford "C" Lathe Longitudinal Feed Rate Math
  3. Negative crankcase pressure
  4. Just another reason to have a shop, making whay you don't have available
  5. mechanical advantage lever/gear?
  6. Biggest Abrasion for the Buck
  7. Destroyed some End Mills?
  8. oil.
  9. Hardening.
  10. OT- Any MAC Gurus here?
  11. Vertical hit and miss engine
  12. Colchester / Dickson quich change toolholder storage
  13. Tool grinder Darw-in Attacment
  14. Fanuc 10M Servo Motor Repurpose
  15. Will VFD work with old Induction Motor
  16. DP table for faceplate
  17. OT: Cat bite is nothing to ignore!
  18. OT , How do they make money by harvesting emails?
  19. Presshear, hole punch question.
  20. Looking for scale cannon plans
  21. I am a lil confused. In welding class, dont we start with Brazing?
  22. Spin Fixture for the Surface Grinder
  23. Video for Brian Rupnow (side shaft/face cam)
  24. Question about av gas buying
  25. 8 x 32 or 8 x 24 ?
  26. homemade tool and cutter grinder.
  27. Collet Chuck's? Closers?
  28. a interesting puller set
  29. Diesel Wrist Pins For Cylindrical Squars
  30. Material for lug nuts
  31. Mill an Up Stop, 3 Point Control, Ford Tractor
  32. OT: It's All Gonna Be Better When We .........
  33. A good ELS video
  34. Hardinge HLVH Lathe Question
  35. Tell me about.......wood lathe benches
  36. liquid metal terminator knife ?
  37. Have a 3d printer? Print your own cable glands
  38. How does our wife get rid of all our 'stuff' ?
  39. VIDEO---How Haas Builds A VMC
  40. Excellent Mallet for Lathe or Mill
  41. Life Span Of Coolant
  42. Vintage Kearney and Trecker on the Milwaukee-matic NC machines
  43. Toe Jack
  44. X/Y stage inspection scope
  45. Favorite cheap dial bore measuring gage?
  46. Theft of trade secrets and Dura-Bar
  47. Why is this switch hard to find?
  48. ID compressor Pump
  49. OT- Wiring a Fan With Two Switches
  50. Starrett Protractor Head - Proper Fit of Blade
  51. Power oiling system for a 1916 Cincinnati Mill?
  52. Need VFD advise
  53. Atlas Lathe Headstock Bearings?
  54. OT- Wireless Hot Spot That Isn't Mobile
  55. pinging vpt
  56. Understanding machine screw sizes
  57. Electric string trimmer repair - machining content
  58. Wire Bending
  59. Quiet compressor
  60. keeping outside storage dry, 10x20 "carport"
  61. Tool handle inspiration?
  62. Hammer Handles
  63. Threading with Retractable Dies on Lathe (Dump parts used)
  64. Is their anything stronger than steel in the "real world "
  65. cylindrical square - how used?
  66. Bought a very used KO Lee BA860 universal grinder
  67. mill power feed problem
  68. Hack Job Air Hose Repair
  69. Help needed for cutting hardened steel with carbide tools
  70. what grade stainless for ice machine drive shaft
  71. Emco v13.
  72. Funniest Machine Shop Experiences
  73. DRO axes direction convention?
  74. Pressure washer, $250. Heated pressure washer, $4000. ???
  75. Photo Bucket Message
  76. Spline broach
  77. can I superglue a shim onto regular hot rolled steel flat bar?
  78. Want to extract Excel data OUT to DWG or DXF or directly to CAD
  79. on the subject of lathe leveling - a funny story
  80. Air Hose PIPING in the SHOP using galvanized EMT from FINLAND must see.....
  81. OT Car Top Carriers -- Toyota RAV4
  82. celing fan motors
  83. Is this safe?
  84. O/T: Plumbing help. One inch gate valve or a ball valve.
  85. OT - Another Ceiling Fan Issue
  86. Removing Flanges from motor armature shaft
  87. A useful painting tool
  88. Shortened Morse Tapers
  89. Hey Boomer I found a present for you!
  90. Any experience with Toolinghouse.com?
  91. Tips for working on material longer than my x axis travel?
  92. Dry clean air for Plasma Cutter, minimum
  93. News Yamatokoki Mfg Co
  94. Metal Cut Off Saw (drop saw) modification
  95. Drill and Tap suggestions
  96. New Gas And Brass Sending Unit Floats
  97. Stainless for outdoors in UK
  98. Wood saw with metal cutting blade?
  99. Paypal is making me CRAZY
  100. woops, can of paint apparently timed out
  101. Quick Change Tool Post
  102. Quick Change Tool Post
  103. Storage Idea
  104. defining an ellipse
  105. Reaming Hardened Steel
  106. Bore Scope Questions
  107. OT: Small LED Light Tip
  108. YUASA 550-005 5C Rapid Indexer.
  109. Who used DrufelCNC?
  110. Second Stage Dust Collection Ideas For Bead Blast Cabinet
  111. Gas engine up and running, reliably!
  112. Shop Towels or Rags ?
  113. .0005 Shim Stock Punching Holes
  114. Cad Suggestion
  115. Edge Finder Lubricant
  116. Does anyone use a cloud service like Carbonite?
  117. What is it, again
  118. Need Help on Designing a Small Beveling Device
  119. Correct stone for stoning burrs?
  120. Blasting
  121. Harbor Freight disappointment
  122. Collet closer tube length
  123. Vise handle carriage lock
  124. Pressure washer accident
  125. Ring roller
  126. Comfort Tools, not really OT
  127. A couple of questions I need answered.
  128. A question about steel automobile wheels
  129. Spade drill holder
  130. repost - please identify this item
  131. Any regular member here need a SB 9C lathe?
  132. Screwless Vise LMS, New Internals
  133. mill chuck jaws uneven
  134. Lathe Turnings Or Cable Armour ??
  135. How do you move a 10ee?
  136. Passivating stainless at home...
  137. OT- Removing Old Linoleum Flooring
  138. Why 68 Deg. for inspection
  139. Indexing Toolpost Disassembly
  140. Broken sliding glass door
  141. OT- Plastic Question
  142. O.T. Gould Shallow Well Pump Won't Start
  143. Cutting a BIG propane tank?
  144. Does anyone want a Lathemaster 8x14 lathe + some tooling? Tampa, FL area.
  145. Leaky ZX-45 mill
  146. Bolt force Equation - Why no need for Pitch
  147. OT - Hope Weirdscience can stay dry!
  148. Acceptable runout?
  149. Mighty Mag, Deceptive Advertising Or What
  150. Bending a Scaffold Pole
  151. synchronous motors??
  152. Looking for KO Lee Cutter Grinder accessories
  153. Getting ready for the big move
  154. O.T. You move 18 tons what do you get?
  155. Found a old Aklands Catalogue Mill&Lathe Pics
  156. Looking for inline holder for 12 v, 30 amp blade breaker
  157. Squeezing more power from a DC motor
  158. The Color Red - Outdoors
  159. Little press I forgot I had
  160. help fix 4x6 bandsaw "Packard Precision" gear worn out
  161. Need Cox 1/2A Engine Info
  162. 5C adapter for KO Lee Motorized work head
  163. Electrically Removing Rust
  164. Design for a Height Gage Centre Finder?
  165. Pneumatic Orbital or Vibratory Sander: Low Air Consumption?
  166. Removing a drill chuck arbor?
  167. Bearing Identification Help Please
  168. Cutting slots in 1/16" titanium?
  169. re-wire DC motor
  170. What the ... !
  171. how to get the top cover plate off of my RF-45 mill
  172. old DeWalt radial arm saw - cut metal with modern carbide blade?
  173. 10EE crosslide
  174. End mill corner radius (Bullnose), What is enough to make a difference.
  175. Melting and re-using scrap plastic
  176. Homemade lever indicator
  177. How often do you use a big drill chuck?
  178. Machining with Small End Mills
  179. Digital multi function gauges off ebay, how are they?
  180. Off Topic Overcomplicated radiator fan control
  181. Computer requirements to run Alibre 3D program on
  182. Disgusting socket unjointed fix
  183. 1/2" bandsaw blades on 3/4" saw?
  184. Lathe project -- About DC drives
  185. Digital Linear Scale Mount For Lathe
  186. On Edge Threading inserts vs. Flat threading inserts
  187. change gear problems
  188. annoying machine marks problem solved
  189. Weird shop injury - Argon injection
  190. Servo feed motor voltage
  191. OT sewage basin inlet seal
  192. OT - Amazon customer service
  193. Tell me about.......V-belt lathe speeds
  194. Record (vice) request
  195. Solid Aluminum Bar?
  196. Interesting Drill Press Project
  197. No time for tire kickers
  198. M25 x 0.75 thread
  199. print your own T-shirts
  200. light duty H-frame press table hoist
  201. O/T: Math. Again (I am trying to learn) :)
  202. Posting Photos
  203. Game: What will it be
  204. Lubrication advise on KO Lee Cutter Grinder
  205. OT - Help identifying unknown pewter item
  206. New to me Lathe
  207. OK, Convince me that A wedge Aloris type toolpost will work for me
  208. Off topic .now i know how the villigers at salem felt
  209. Looking for Information on Pratt and Whitney M-1803 Dividing Head
  210. I need magnetic stainless steel
  211. Need help with pullet diameter ratio math, please
  212. Quartz tube cutting in a lathe
  213. Has this Forum been Hacked?
  214. OT - Remember CarTalk and the Tappet Brothers' Puzzlers?
  215. Hello Round Ram Bridgeport help
  216. Miling machine wiring
  217. "Whats Wrong with this Picture?"
  218. Varnamo Mill found a new home,Thanks Darrp
  219. Turret Tool Post Question
  220. Skate Bearings Big Brother ???
  221. OT Indian tools on eBay
  222. Craftsman/Atlas wiring
  223. OT? Flying Sub
  224. Rapid Air Products / Maxline
  225. G0768 Lead Screw Removal
  226. Has anyone made a small bore piston ring expander?
  227. I think I got a great deal on a 9x49 milling machine.
  228. Work pics - expanding pneumatic collet
  229. Death of an endmill?
  230. Has anyone made a Tailstock DRO for their Hardinge HLV-H?
  231. Grinder to polish shaft
  232. OT? PID controller TC connection question
  233. OT hdraulic logsplitter pump repair or replacement?
  234. OT: Computer Power Question - When OFF
  235. semi OT digital microscope with a big depth of field
  236. KO Lee B942 Sensitive work head
  237. Percent Phosphoric Acid for Rust Removal
  238. OT Electronic question Video
  239. Any of you ever installed a window in a dish washer?
  240. Need help re-pulleying Logan 9B-17
  241. The current state of Chinesium Carbide tooling
  242. 5C collet for lathe
  243. Mitutoyo metrology class online
  244. Strength of 3d printed parts
  245. Another Craig’s List Deal ( no tire kicking here).
  246. Every once in a while I'll go to an estate sale....
  247. Backlash measuring and testing...
  248. Please Help me identify this metal lathe!
  249. Run-away Engine--sorta o.t.
  250. Lathe lessons on a Mill
