View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 [283]
  1. deburring and cleaning diamond sharpening stones?
  2. Some more newbie questions on mini-lathe
  3. Harbor Freight Better Quality?
  4. L0 Spindle Internal Taper
  5. Orbital Sander Repair
  6. 3 phase wiring
  7. It got away on me
  8. What threads are used on a stainless steel anchor shackle screw pin?
  9. OT - Bad idea for seperating water from solvent?
  10. What to do with 2 12" lathes?
  11. K40 $400 Ebay Laser Cutter
  12. Need an Electrical Enclosure....
  13. Broke my dovetail cutter
  14. Have you used the Design Spark CAD program?
  15. Advise on 5C Chuck type and size for cutter grinder
  16. John Deere vs Steam - This Is Great
  17. 10EE inspection
  18. plumbing/soldering help !
  19. Dividing or Indexing head
  20. bell made from compressed gas cylinder - harmonic content?
  21. 3 phase motor; did I just get sneetered?
  22. Question about motors 1ph,3ph or DC
  23. OT-- ACH Payment
  24. On/T: Your visual acracity for linear measurement? Seems like I get pretty close.
  25. Toolholder for negative rake carbide inserts - lathe use
  26. Going to re-wire the shop
  27. OT: House painting
  28. Repairing contactors, welded contacts?
  29. Boring bar issues
  30. Going for Inguinal Hernia Surgery- What to expect?
  31. steel MUSICAL gong
  32. Rotary Broach
  33. 1ph to 3ph Transformer Info Needed
  34. More machines followed me home!
  35. Some Awesome Inserts
  36. OT - Replacing Deck Stairs Handrail Post
  37. OT: Bacon and Microwaves = Tough Bacon
  38. OT Moving a 5th wheel travel trailer
  39. Way, way OT: product comparison, razors
  40. OT how to find an underground water leak?
  41. Adding to the crop of OT threads: Dad Brag!
  42. Scrap Carbide
  43. PVC or Poly Pipe or Rings ?
  44. Off topic. Fly killer 3000 PSI air pistol?
  45. magazine issues: release dates.
  46. Mystery Chuck
  47. O/T: Finding under ground (12") PVC water line? Is there a way.
  48. OT:HIt by a car while walking!
  49. Clausing 5914 Apron Interlock
  50. O.T. Radiator Fin Straightening
  51. First world problem... Laptop speaker problems.. Surprising not OT..
  52. leaking lathe spindle
  53. 3P Delta vs Star connection - have I got this right?
  54. School me on Toolpost Grinders Please
  55. school me
  56. More boring tooling...
  57. Sine Bar Sled
  58. 1.25” OD Plastic Tubing
  59. Two Questions
  60. Southbend spindle question.
  61. Diagnosing car issue - AC blower
  62. J Tiers MIA ?
  63. My "what did you do this decade" thread - poly-V spindle sheave/ pulley for Atlas 618
  64. Things are different these days with 3D printers. .
  65. lathe and mill oil???
  66. neutralizing sodium hydroxide
  67. OT: What Are the Computer Requirements for a 3D Printer?
  68. PC-Pathpilot won't load, help.
  69. 3 Phase motor noise?
  70. Machining 431 stainless steel
  71. What the heck is this in my car?
  72. Sheetmetal roller with soft platen
  73. Cadillac head bolts
  74. When Buba works in a machine shop! warning painful to watch. (no blood)
  75. DRO Help needed please thanks.
  76. Ethanol in pump gas damages 2 cycle engines..???????
  77. Grinding lathe tools - small concave form / radius
  78. Brown & Sharpe 599-579-4 caliper repair
  79. shars 10 inch 4 jaw D1-6 chuck
  80. Can You Weld on a ASME Tank?
  81. Oil seal questions.
  82. Vacuum fitting adaptor
  83. Dog bite story---O.T.
  84. 20 ton shop press paid itself
  85. goose neck
  86. Making the little move
  87. Boxford headstock spindle bearings?? Where to find?
  88. Accessories for KO Lee cutter grinder
  89. Chev equinox CARTRIDGE oil filter adding insult to injury
  90. New Bandsaw (NEW new)
  91. They gotta be kidding right?
  92. wide format printer
  93. Propane Model aluminum piston with oring dims needed
  94. I have a bolt that is 40 threads in. DI. is .339
  95. High Balling steam, loco restoration
  96. Tailstock Digital Readout Pictures
  97. The Holy Relic of Flat
  98. Boxford vsl 500 what is this screw for? How do i remove chuck?
  99. understanding gear cutters.
  100. Your experience with 6 inch Chinese rotary tables.
  101. Info ref CO2 extinguishers.
  102. Help Paul Alcatore get a surface plate !!! Transportation needed.
  103. Off topic car battery corosion nonsence
  104. Collet Question
  105. How to set an angle on lathe compound?
  106. Does anyone have a Hardinge Copycat Lathe?
  107. Titanium. What is the fascination with it? Watching Battlebots.
  108. Carbide end mills, short life
  109. I am bored out of my mind... Ideas...
  110. black stain under chuck - yuck
  111. Inserts to holders? How to put them to good use.
  112. Holex Corp. Trepanning Tool
  113. OT: Low voltage digital circuit and shielded cable
  114. Alibre trial of Atom 3D user question
  115. Sherline Tooling Plate article from HSM
  116. What "advanced" metrology gear do you have?
  117. O.T. Fluke Meter Leads.
  118. Shop computer...
  119. Help find 11/32 hex quick connect
  120. A strength of materials (steel) question
  121. Source for very small hex stock?
  122. Best Material For Making Scribe Marks Using The Mill
  123. Boxford MK1 vsl. Stuck spindle bearing? Back gear lever.
  124. OT - Making fish eyes
  125. OT - Email problems with Hotmail/Outlook
  126. Electronic Pest Repeller, Don't Buy These...LOL
  127. I need a supplier of werid taps.
  128. Bench Top Milling Machines
  129. The absolute best way to learn 3D CAD
  130. Good online spot for trading in machine tools and bits and pieces?
  131. Unbolting headstock from bed? Alignment issues?
  132. Learn me about super hispeed dental grinders for shop use
  133. Kinda OT - variac problem
  134. Computer Help
  135. Marine stern bearing design and material
  136. Any Kubota small tractor experts here?
  137. Noisy VS mill head
  138. Repeat-o-meter out of aluminum ???
  139. Cheap jack rebuild
  140. O/T: Engine Oil changes?
  141. TiN Coated Dies For Threading Stainless
  142. Making small bolts
  143. OT An American Factory Documentary
  144. 400,000 revolutions per minute air grinder first use
  145. Noob motor electrical question
  146. Hose fittings
  147. Cutting Milling Table with a Bandsaw
  148. Small lathe recommendation
  149. Heavy duty die holder
  150. Mill DRO - having extra scale(s) for Z axis
  151. Adding a two stage pump to a bottle jack press
  152. OT: Portable AM/FM Radio w/ Bluetooth
  153. Opinion on mill for sale
  154. Adjustable / Split Die Question
  155. Who uses a Hammer on their quill handle for small adjustments when Milling?
  156. Rust source - varnish or cutting oil?
  157. Dorian SD40CA Quick change toolpost
  158. OT: Jessi Combs Accident
  159. Converting single phase to three phase
  160. Is it common for a lathe bed to be very hard to remove off its cabinet?
  161. Shop Fox M1018 Change Gears - need specs
  162. Improving import co-axial indicator?
  163. Great Video!! - easy understanding of molecular changes with hardening & tempering
  164. OT: The Great Race
  165. What material is this cylinder made of??
  166. OT: Must we have Neighbors
  167. Who has a Hardinge TFB ?
  168. Having a disconnect/switch between VFD and motor?
  169. O/T: Electric toaster oven issue.
  170. O.T. Paddle Wheels (for mud)
  171. Controlling a VFD with a pressure switch
  172. unexpected gooseneck
  173. Break those edges
  174. Looking at advice for either upgrading Sherline mill or adding DRO
  175. Band Saw on 3 Phase thinking about changing to 1 Phase motor
  176. Tool for tightening/loosening a shackle pin
  177. What is this tool?
  178. OT: use.com closing down
  179. "Adaptive milling" by hand ???
  180. How Can I Slow This Motor Down a Little Bit?
  181. Restoring 13x40 Lathe.
  182. South Bend 27-B info
  183. OT hurricane Dorien.
  184. Bench Grinder Mod Question
  185. Need help with a Servo 150 power feed
  186. Getting Screws or Getting Screwed.
  187. Cutting Oil Identification Help Please.....
  188. Brian, something to build to drive with your engines
  189. South Bend Heavy 10 Chuck Problem
  190. OT, Auto: Bubbles When Battery Is Charging
  191. Help needed
  192. A question about hydraulic impact drivers
  193. Cadmium Plating
  194. OT-ish: Stoney Banksy
  195. Lift chairs/O.T.
  196. Quorn Mk3 - Universal Tool & Cutter Grinder
  197. bronze bearings on South Bend lathe spindle
  198. lathe levelling problems.
  199. Paddle Wheels Video
  200. Curb Find of the Week - 15,000 W Generator
  201. Problems with toolbit sharpening
  202. Finally, a new grinding room in my shop!
  203. How do I seperate the lathe bed from the cabinet?
  204. Neat old engine to model??
  205. Can't paste links on here ------- ?
  206. Surprise: Paper Cutter For 0.050" Aluminum
  207. OT: gyroscopic elimination of Parkinson's tremors
  208. Most used tool in the shop
  209. Model Auto-Reversing Winch
  210. Yet another Photobucket stunt
  211. Least used machines
  212. Reverse-converting CNC vertical mills
  213. Scotchman 314 Ironworker - Things to Know?
  214. Where's Jerry?
  215. My First Mill
  216. Feed and Speed for Garolite LE?
  217. "The Discovery of Strong Aluminum"
  218. Amount Of Force Needed To Shear 12Ga. Stainless Sheet
  219. OT: heros of your youth
  220. Removing rust
  221. HELP ... Old Sparky is sick and needs diagnosis and treatment
  222. Christen drill grinder model 05-8
  223. 5c collet fixture - name & use?
  224. c n c zone dot com Any members here?
  225. Need help identifying a taper
  226. Citric acid for descaling
  227. How to make an English Wheel
  228. Turret Lathe Tooling
  229. Off topic, Big Ant ATV cargo carrier
  230. Measuring Tapers with Combination Square
  231. how to make a nice hole in thin stainless sheet
  232. OT; You guys have to read this obit!
  233. OT - Drone hobby
  234. heat shrinking a blind bearing race -- good idea?
  235. Is JCHannum still around?
  236. 1018 Or 1144 ??
  237. Drill, Bore, Ream...how to drill a hole
  238. Electrolysis Galvanize and de-rusting
  239. OT: evil minnions
  240. My Grandfather's Tools Save the Day Again
  241. JFK Lever Collet Closer ???
  242. Welding Positioner help.
  243. Bearings in gear box.
  244. OT: New hobby...tree climbing.
