View Full Version : General
- OT. Here's and interesting site for the mechanically minded
- Running A Sinker EDM
- Evan - wave your magic wand
- Thank you everyone!
- Refurbishing South Bend Lathe
- O/T pollution
- OT-Whats a good used SLR film camera to get?
- good little fly cutter
- Oily Rags?
- machine placement (lifting) help...?
- Arbor and chuck
- looking to buy Myford ML7
- Clausing lathe clutch
- Paging: Paul Alciatore
- anyone got plans for a drawbar with closer
- Clausing 4911
- Setting Up Endmill
- phase convertor question.help needed desperately
- mill drill belts
- Find a Motor
- Whatsit
- Magicube
- Milling a Vee Block
- What to do with it?
- (Sort of OT) - Ride-on Mower Implements
- Small gear cutters?
- Vertical Band Saw Puchase
- Train Whistles
- Hockey Pucks
- Using air as a return for hyd cylinder?
- 3jaw expose, thanks Forrest
- B52 is no more.
- O/T Indian Larry Dies in accident
- Hardness of needle
- Didn't think that was the problem, but .......
- when to use NC or NF threads
- cpi injector unit
- OT- David Blane (Blaine?) levitates
- rotary table
- Boss Mill
- Thread Cutting on Lathe
- mig
- Thread cutting problems
- Is there an easy way to add reverse to my drill press?
- South Bend collet ?
- Photo Bucket?
- Material for Springy Part
- OT: A pic of a few stars
- OT: Why do they stay??
- Some kind of luck, tool purchase
- Three Jaw chuck jaws another idea
- Free plans
- Remember our friends in Florida!
- 100,000 + posts !
- 5 c collet info needed
- Insurance on home shop
- Clever trick to make a toolpost
- A Couple More Old Shop Photos
- Hats and Knickers
- Samuel Macinery Auction (Philly, PA)
- Delta Vertical Bandsaw
- grinding drillbits
- Widening a Slot
- my first 'precision' project
- OT Stupid media catch phrases!
- troubleshooting
- Auto Cross Feed on my Lathe?
- Bridgeport Boss 5 is now working
- Milling machine wear
- phase 2 or vertex
- Old tattoo machine just fell in my lap..
- DoAll CNC Mill Questions
- "Resting" HSS tool bits after grinding
- HSS vs Carbon steel for finish
- feeding in or feeding out when facing
- spindle -feed speed ratio
- OT: Astro pic of the day
- Question for the forum
- OT - Adjusting Spoked Wheels
- Straightedging woodworking machines.
- Bridgeport j2 machine variable speed
- parting off tip
- All Brass Carburettor
- Electrical conductivity questions:
- Brass Carburettor
- Help I just fried my new lathe.
- Bridgeport mill way wiper bracket?
- where to purchase used troyke or yuasa rotary table?
- 8mm-5/16
- Printer rods
- No stinking pedals anywhere!
- 220v plug styles
- elect. ,motor wiring
- VFD Ground
- OT: Help Me With My Roadtrip
- Cool web site
- "Old" Blacksmith... "New" Machinist
- OT Winterizing and structures
- OT: Alistair's "Who next, Hitler?" thread.
- CNC MAGAZINES
- energy storage material
- machining accident
- hole saw help...
- what would make someone erase their own thread?
- OT, Astronomical Question
- RPC
- I'm getting a Lowes and Home Depot in my city
- O.T. Genesis spacecraft crash
- Punches and dies for my ironworker
- Attractions for gearheads near Visalia,CA
- Backplate (pre-drilled and threaded)
- Shear sharpening ?
- It was bound to happen.
- Remembering Mother
- Just in Case
- bearings
- O.T. (sort of) 3- Phase power
- south bend B9 change gears
- Welding/machining pre-hardened 4140
- new user
- Update on Thrud
- OT - Lawyers-starting to hate them
- OT: Olympics in review
- Bolt and screw suppliers?
- Aluminum drops of 6061
- OT - Backfeeding from a Genset
- Auctions?
- Vertical Band Saw
- OT- Do words matter?
- Zues
- PC security
- Bronze Rebuild Of Damaged Shaft
- Derck's Gauge Dial
- One for Evan
- powered up my "new" lathe for the first time
- Roto mic
- Chips....what does it mean
- Elect. motor again
- 3AT Collets
- Easy Conversion Ironworker to 120vac scotchman 314t
- How to fix damaged motor shaft
- Question about casting aluminum
- OT/Master Evan,Help!
- What Oil to use?
- Garbage can
- Undo Care & Attention
- When building a rotary 3phase converter?
- underwater machine shop
- ROTO-MIKE sine fixture?
- Would you put up with this ????
- Why lower volts in USA
- SB collet drawbar in Atlas/Craftsman lathe,,
- Clausing 5913......info?....
- A hot time at the town dump tonight....
- bandsaw sharpener
- KEEP YOUR EYES OPEN
- Assault Weapons Ban?
- Why China is winning
- quill spring
- Lawnart?
- W.H. Nichols Miller
- Preventing rust on table saw table...
- Threads Growing????
- User name change
- Finally got my mill working
- Timely HSM lathe rebuild series !
- 2 piece chuck jaws
- Kind of OT: Machining for computers, and Do It yourself USB
- OT: Optical question for Evan et al.
- 1953 Ford Tractor starter
- Ivan the terrible!
- OT:Wow
- Clausing mill
- Metalworking Project Ideas for Kids
- OT...Continental engine
- Photo: More Belts and Pulleys
- Who the heck ever thought of left hand wheel studs?
- Pics... Adjustable feed nut
- Fireball from Aluminum Grinding Dust
- Enco's Free shipping promo
- tuition almost free
- Machining in the kitchen
- OT: Priority's?
- Latches & Fasteners Supplier ?
- metric threading w/ Clausing 5913 ???
- OT: Just when you thought it was safe to go into the water...
- Desktop CNC Systems - Need Advice
- Tapping Fixtures
- Dividing head question.
- OT- Computer Raid array question
- Bridgeport Parts
- Shipman Suface Grinder , Home and Dry (pics)
- RF 45 spindle lock
- What kind of tubing bender made this? clue?
- Broken Tap
- Cooking in the shop
- link belts vs. auto vs. fractional machine BELTS....?
- Wood stove in shop
- Weirdscience, how'd you fare w/Ivan?
- Getting out slivers, splinters, shavings?
- Anti virus programs éh
- building up bearing seats
- Info on universal dividing head
- arbor press,,,uses?
- OT: Dirtbike clutch
- Photobucket Problems? Or just Me
- .50 CAL question?
- 14mm / 2.0 Size??
- bend steel with his bare hands
- OT: Gmail
- Collet Type Spindles For Dividing Heads
- sheetmetal brake (pix)
- Generator for the Shop
- Forming sheet metal
- Next Stop Geneva
- Sources of Hydraulic quick-couplings ?
- Elena has a new site.....
- Crossfeed screw accuracy, .003" - .008"/ft okay?
- More nichols miller
- metric theading,,,,,methods...tried them?
- Don't let the smoke out
- need source for generator/welder
- Speaking of cooking...Born to be Chicken
- Changing rotation on 1 ph motor
- Fulton double barrel shotgun rebuild
- Sow's ear > silk purse
- plate V-Blocks?
- Dish Uses
- Janita valve grinding machine
- Neat little antique mini mill on ebay
- This beats a pair of fork lifts
- speed regulator
- Slots in Stainless
- form knurling
- New chuck for my brdigeport mill
- arbor press
- Deep Hole Taps
- OT:Remove cover,cook three minutes on high
- E.L. Essley
- Standby/Shop Generator
- Need help making new product in NJ
- Well Done, Randolph Bulgin.
- Just bought a shaper
- Vertical Band Saw ?
- enco knurling tools
- Spot welder timer?
- Pennsy K4 update, lots of machining
- turning commutators
- enterprise 1550 lathe refurbish
- plans/ prints for sextant or steam engine
