View Full Version : General
- great taper grinding article
- drill point gauge
- OT. an electrical question?
- A new life for old metal
- Premature: Look at what the stork brought home!
- OT. WHAT TO GET KIDS FOR CHRISTMAS?
- 2-cycle combustion chamber
- Compressor question revisited
- OT: Son and the Army. I just don't understand.
- diagrams of gantry as promised
- R8 Taper
- Gear Cutter Question
- Help! Taper Troubles
- Harbour Freight QCTP
- Machining tonight
- Necessity the mother of invention..........
- attaching small plastic gear to shaft
- OT: SU Carbs
- A nice little power supply with a compressor
- Some milling in the lathe
- what steel for holders
- South Bend 9" Gap Bed?
- What is it: Pump, Blower, Turbo
- Holding and boring HDPE, and/or LDPE as a bushing
- Alum versus Tap versus Corningware
- Chinese scale ?
- Tools still too big
- Question of clearance on mill?????
- More knowledge needed on 2 strokes.
- cutting/tapping fluid?
- making an end mill holder???
- Source for Lead Sheet
- servo II mill motor coupling?
- Noting a Higbee on a blueprint
- WHY ARE THESE GOING SO CHEAP
- Being Thankful for what I have recieved.
- Photo: More Rosie Riveters
- Loooooonng tapered bore,Ideas needed.
- Essential Raw Materials?
- loctite 248 stick
- Early Xmas present, New shop attire Attn: Alistair
- American Standard 200
- Differences in South Bend 10" Lates
- Wanted: gear -- 32 teeth
- Two door storage cabinet for tooling ??
- What's the most expensive "mill drill" on Earth ?
- Home Machine Shops
- Happy Chistmas to you all and your families
- Tenon saws
- metric left hand tap
- Welding class
- better cut-off method
- Old Hospital Beds
- what is this used for
- Getting the bugs out...... and winning!!!!
- PhasePerfect system
- Just don't feel like it...
- DLP tech. Have you heard of this?
- OT: Roll Up PC Monitors May Just Have Become Possible
- connecting 2 air compressors together
- Need to glue HSS to Aluminum 6061
- here's a beauty in German ebay
- OT: Optical Glass w Polished Edges
- removing compound from southbend lathe
- Glue UHMW to aluminum?
- Bought my first metal lathe - refurb or part out?
- Tired of making arbors....sources?
- Adjusting the taper spindle bearings on a RF-45 clone:
- Hernob 2000
- Clausing 1501 V S Lathe
- Nardini Lathes
- Let me show you……oops
- using a surface plate to construct a lap
- Preventing rust
- Flat Belt Drive
- Plastic Small Engine Project
- OT: This is your pilot squeaking
- Oops (crash)
- Metal condensation, Sweat? Moisture in unheated shop
- Bad weekend in Williams Lake
- Wanna Work For Burt Rutan?
- heat treating
- Sheldon Horiz. mill,,,manual??....
- Scissors type knurling tool question
- 4140 for tool holders heat treatment
- Tig welding screw up!!!
- OT, for Evan
- OT: Machining weather
- Paint Chips
- South Bend on Ebay hurry.
- OT: What's your favorite sipping liquor for stress reduction?
- Warning: How a scam works
- Aluminum Epoxi
- Cad Cam software
- Christmas Ideals, Add your thoughts.
- collet blocks
- Help! Fast ! Before Tomorrow!!
- Quarter Scale Merlin
- Sheldon 10" X 24" 1936 Sheldon Need to kow what the 6 speeds are ? Help
- Very nice Cnc mill& retrofit, check it out
- good find
- INTRO,OLD LATHE INFO
- MIG welders
- Homemade Hot Blue Formula
- rod for Tig welding Titanium?
- A "How to make" Question...
- extrusion cylinder
- Towing Vehicle
- Linear Drive needs to be shorter
- power feed
- Clausing 1500 Series Lathe????
- Lubricating a Bridgeport
- Insert holders
- New uses for a South Bend:
- Cut-off Questions and a Good Tip
- Atlas Craftsman purchase help...
- New "Kow Pye" chuck came today
- A gunsmithing question
- OT: Closed on the land.
- Need French speaker with grisly mind
- Whats it wiegh?????
- Digitizer
- OT: Seasonal picture (large)
- Northern Tool belt sander
- Are Sockets Hard?
- Anyone want a surface grinder?
- OT(?): Tractor restoration book titles?
- Evan, or other computer web camera question.. Related topic.
- Steam power
- Backlash Bridgeport
- OT: Chrsitmas ideas for dad
- Anyone going to the Reliable Tools parking lot sale tomorrow?
- how to get nut off of horizontal arbor????
- Auction results
- Tailstock turret??
- GOOD DAYS/BAD DAYS, KARMA?
- Dragged the mill out today
- Refilling a O2 Bernomatic tank with Compressed air
- Power Feed
- Photo: More Women in the Shop
- Boring head chatter
- model plans
- On a commercial carbide holder...
- Finished the engine
- identifying valenite inserts
- how to add links?
- Biggest badazs shoppe
- Photo for Evan
- Need motor recommendation for Surface Grinder
- How Do They Make Felt
- Collets Blocks Redux (long post)
- OT: Question for PHiers
- lathe
- Unique Milling Machine Idea
- 1.5 kw 28 volt generators...
- OT:another digital camera ?
- canedy-otto drill press
- Pinging Charlie Coghill
- The Future is being advertised today. PS2..
- Looking for bandsaw wheel.
- TIG welder questions
- Anyone with experience machining HDPE and/or LDPE?
- Waste Oil Heaters
- Dec/Jan MW p32 - air compressor coil???
- dead end internal keyways
- alternate uses for divider head
- 2 speed RC transmission
- The lathe at home (pic)
- Weird dividing head...
- o/t Nl in Canada
- Q? for analog electronics guru's
- Terry Cowan passed away Saturday
- uses of camphor in the machine shop
- 5-C Angle?
- Help please with metric threading on a Clausing 5900 lathe
- Carbide insert angle
- tip for the day !!!
- Source for shear pins?
- broach
- OT but good news
- Enco free shipping
- How old is this Steptoe Shaper?
- TROLLEY FOR YOUR SHOP? at cost.
- ot-Glue question
- KBC Canada service ???
- wrought iron table.
- Mill lead screw question
- Almost lost it,thinks to remember about cranes!
- OT:mirror for the wife,
- Atlas lathe carriage wheel play
- Neat site
- Reinforced floor for Bridgeport?
- Hi Everyone,newbe here ,first post. Info on 1st Lathe
- DRO help needed
- OT: Getting old.
- OT Firefox
- Star Lathe
- HSS Cutter for Ball Turner? (Photo)
- Cincinnati Toolmaster Drawbar Removal?
- Anyone heard of these folks?
- wanted: 2 3/8 X 6 Chuck or backplate
- A tool bench I made
- need design help
- strange HSS experience today
- lodge&shipley info, specs, etc...
- Waterglass (sodium silicate)
- My Homebrew Tool Post
- Milling machine handles
- OA Torch Cart
- Laser Mounted on Mill Drill
- Anyone know about the GEM500 Mill?
- Home made balance tool
- My Christmas Presents - pic links
- South Bend Fourteen
- 25 ton tip toe pics!
- Funny Ha Ha on me.. More funny to look at..
- Used laser parts
- Newbe - lathe advice
- Which CNC mill kit?
- CHEAP I/O board, breakout bd, cash price from ebay seller
- Photo: Russian Machine Tool Factory 1961
- Photo: Maserati Milling Machine
- Inherited Tools - Photos
- Making $$ with a shop
- Cutting Type A Point Wood Screw Threads
- bought this on ebay
- Forgive me Master Builder for I have sinned
- NewbeRmith Results & addt'l questions
- 12x36, Absolute Minimum Tooling for First Lathe.
- What a long strange trip!!!!!!
- Lifting dm-45 mill drill
- Some more christmas presents (just finnished)
- Roller Calculations.
- Yet another cool toolblock:
- spring wire
- music wire
- Need an oil gun for old Bridgeport w/Zerk oil fittings.
- Smallengine boring machine
- Pressing old bearing by inner race?
- Starrett #65 center tester
- is this a good deal?
- indicators????
- ENCO: Cheap carbide inserts: Opinions?
- BRAZING...The correct way.
- Filing technique
- Mystery metal...yet again
- OT: New baby!
- conversion of ac/dc buzz box into tig welder
- Air line
