View Full Version : General
- Where to find blueprint small diesel engine?
- Note to Thurd!
- Liquid Skin Cut-fixer upper
- Ball is dropping.. 20 sec.
- Fireworks time!!!!
- Happy New Year
- Silver soldering+ Parkerizing
- USB 2 SERIAL 232?? Anyone with experience?
- Motor issue with my South Bend, Help...
- Off grid machine shop??
- Blueprint books
- 16ga punch update (photo)
- Humidity
- What is a Centrifugal switch & How do I lube?
- Simple tap project
- Wanted to Purchase
- Spin Indexer question
- small boring bar? HSS??
- o/t computer connector/adapter
- reclaiming bridgeport series I
- Controlling DC motor
- Tool Grinder
- Really Thin Taper Turning
- Servo motor info needed
- Oiler felts
- Herzog Vertical Spindle Surface Grinder?
- AC to DC
- anybody want to meet at NAMM for breakfast?
- Which mill to buy?
- PWM cap and power supply questions
- south bend V angle
- Swirl finish ????
- What is the cheapest (in $'s) Amer/Can lathe?
- Old B&D pedestal grinders
- 1967 Herter Lathe 12x36
- Homemade Lathe
- Driving small theta drills by hand
- Had a good visit from a fellow member today!
- Rotary phase converter
- Newbie question: G9977 for metal only (Long),
- Reader website
- Mill-Drill vfd
- pulley calculations
- HSM Magazine collection - Value?
- Looking for something odd I think
- Pics of projects to start the new year
- Stainless steel
- o/t computer
- Need a Link to an old Thread (readers hints)
- Nice Old Lathe, learning to use it
- Recent purchase
- Picture program slooooww, but why? Evan?
- Slightly OT: Timing lights
- Need HSM near Nashville, TN
- remember the cone question?
- OT: Military hardware and legality...?
- Continuing chuck woes
- Rusty air compressor tank
- Just got this from Dave(Thrud)
- HSM on CD... how about an incentive?
- Lagun Viaraible Speed Head
- Building a Mag Drill
- Wheel-barrow table for milling machine loads
- Is this a good deal????
- Thanks Neil
- Tap size questions
- SB heavy 10 spindle oil path
- Surface grinder tool
- Blowing down New air lines
- SB drive pulley
- Bending AL tubing
- Anyone fancy a UK holiday wth empty bags
- Bridgeport Series II
- Fowler brand = Taiwan
- Nice hobby lathe on ebay.
- Import Carbide insert review:
- SB lathe-reassembly HELP!!!
- Pure brass?
- 3ph Converter Starter
- Drill Doctor 750 review
- jet 1024p lathe
- jobs
- Clausing Colchester 6500 13inch
- Sad end for a lathe, or a promising beginning
- Steel angle designation
- removing oil from a rubber flat belt
- Amazing what you find when you look!!!
- Only a handful left...
- fascinated by the results
- Nice 115pc Cobalt Drill bit set....
- Tig welding old Harley Case
- Rutex Servo Drive, BIG thumbs up..
- Cutting 2" thick aluminum
- quick question
- Newbie here......threading question
- Well I did it anyway....
- R8 Tight Collets
- Forrest's Dial Indicator Article
- Tool Porn Calendar
- Jaws For Milling Vise
- Sheldon horizontal mill...
- Harley Hemi Heads
- Drill Doctor review - Confession time
- HF's Small Butane Torches
- Interesting Custom Motorcycles
- My machine shop
- Machining weldments
- please help selecting new CNC...
- Everything breaks at once
- Welding on a Flywheel Ring Gear?
- problems - rust - cars - attitude etc most likely ot
- How to turn spindle taper
- Enco lathe / Baldor motor problems
- Set up question
- Machinery's handbook questions.
- Tool question, twin blade saw
- Mini Mill
- Clock parts turning vids url in this post
- More vids here
- even more VIDS
- 3-Phase.. wanna build a real Go-Cart?
- tom senior milling machine
- BobCAD-CAM
- Toolmaking :make your own woodworking tools?
- OT-any recipes for some ripping red hot chile?
- Allen Bradley 1350 VFD???
- Lathe Infomation
- Tap Project Revisited
- Thanks Weirdscience
- Chuck woe solved
- Bison Adjus-Tru Chuck
- End mill questions
- Hello
- CNC conversion
- OT... Everyone likes pizza right?
- Thoughts on a Grizzly 12 x 36 Metal Lathe
- Adhesive(s)
- 6X12 Kent Surface grinder question?
- High temperature clear coating?
- Homeward Bound
- Rotary Multi-Axis Index Table For EDM?
- Beating a dead horse!
- new shaper and problems (pics)
- Formula for the depth of cut based on a compound angle setting?
- Stainless Plain Bearings
- yorkshire puddings
- Manual for Grizzly mill?
- Some stuff my boss gave me
- Another Hydraulic Question - Power Pack Valves
- ATLAS 10x24 TH42 Build date (072892)
- New Lathe!!!
- OT- motorcycles
- My new lathe!! and the pics work!!!
- Burnishing
- Reverse engineering? Scanning probe to dxf?
- 5c collet
- Brazing brass to aluminium
- WHat is it
- ANY ONE SEE THIS, Why didnt I think of this
- Dart 125dv-c control...
- Best way to control 120 volt AC single phase motor
- Indexer question
- Alexander mill
- A New International Symbol!
- 8020 extrusions
- how do you post photos on here?
- Harbor Freight Air Compressor??
- BP cnc oiling system
- A Dumb Question But
- OT Why do spokes cross
- Expo meeting update
- Quill Suck-up Question
- H Limit is I
- Compound alignment
- This maybe a no no but.......
- Backplate Design
- radial engine - bearing squeeze
- question of speed???
- Turning drill rod
- glanze turning tools
- D1-4 camlock spindles
- Lathe, Mill and Compressor in OHIO
- An electric motor question?
- how are rod journals ground on a crankshaft?
- R/Table chuck mount ???
- If i were to make a tapping block...
- Another Mystery Metal Question
- Another electric motor question
- I'm The Guy In The Foil Suit
- Gerstner "International" chests - any good?
- OT: Web digital clock.
- Boring tool grind angles?
- Using a wiggler
- Rockwell horizontal arbor runout
- OT New local gun store
- Blake test indicator
- OT - Getting Old
- 3-jaw chuck with mounting holes in back
- CNC machine control
- Photo: Another Shop from the Past
- Help! Hardinge Cataract Ball Bearings Replacement?
- CENTERING TO CHUCK USING INDICATOR
- cheapest endmills
- The shape of the shaper...
- Warped crankshaft
- Readers'Tip Book
- OT beach front property
- Zubal lathe
- Things that shouldn't happen
- lathe purchase
- Scrap it??? RK LeBlonde 24" x 10ft bed
- Proper oil for my lathe
- best grinding wheels from China
- Does the L00 spindle nose ...........
- OT. Evan!
- Machining Nickel
- Engine block mill shaft?
- What is it called
- need info on a lathe i'm thinking of buying
- Are you making progress Evan?
- OT; it's a sick world we live in (rant)
- Corn Stove
- Blower Fan
- Websites for Firearm plans...
- Gabro metal box folder
- Portable machining.. is it even possible?
- busy in the shop
- Anvils .... care and feeding
- new thoughts on imported lathes
- Threading tool
- For the electronics oriented......
- OT: Huygens lands on Titan
- Ipac Keyboard emulator, update.
- I made something...
- Split font for CnC plasma cutter?
- Who's great idea was this?
- Explanation to the advertisements from China
- buyng a mig
- found some steel
- Living near transmission lines
- Big LeBlond pics available
- Rose brand file Geo Barnsley & Sons...
- How best to get 3.5 volts from 12 volt source?
- OT: Northcountry computer terms
- WOW! What a deal!
- Material question?
- Zoller or Parlec comparison
- Grizzly Z-Series G9733 Lathe
- Grinding parts on the lathe
- inherreted machinist tools and box
