View Full Version : General
- machine tools in the USA
- Truck selection for moving lathe
- bending tube
- End mill sharpening
- "Hexagon Bar stock
- carrick-cg grinder attatchment info wanted
- OT- Pickup Bed Liners
- Contact area check for tapered shaft/ hubs
- don't know what I have
- lathe halfnut adj.
- Ford Tractor Sleeves
- problem with locating drilled holes precisely
- New Shop Truck
- Cutting a part manual on a cnc, joystick control that writes gcode
- Safety reminder - use proper lifting technique
- Steel vs Mild Steel vs Stainless
- Name that engine
- bbssystem.com is down for a little while.
- Help wire a winch motor
- OT
- Pipe purchase
- Photo: Hendey Lathe 1916
- 2 flutes, 4 flutes, 6 flutes a dollar...?.
- New Truck Again
- Is the motor fried?
- Need advice on truing grinding wheels
- making your own torsion bars
- Tool Grinder ID
- Photo: Nice Old Turret Lathe
- How useful are these.
- Compound infeed for 55 Degree 12 tpi
- Did Bridgeport make drillpresses??
- changing spindle bearings (help!!)
- Robot vision comes to my house, 3dScanner! need Help find a ?
- Way OT, Diagnostic Trouble Codes
- Interesting Threads on This Fitting
- Rudy Plans
- Lost styrofoam casting!
- MOTORS and Centrafugal Switch Doofers
- 40 taper
- OT: First tractor...sort of...don't laugh...too hard.
- Removing moisture in air lines
- Enco shipping code for June
- Marathon motor
- Yet another reason to have a shop
- Chameleon Face Mill
- Metric Die Nut
- Press fit for bearing
- useful site
- Days gone by
- OT: Not again! Astronomy related
- Interesting weekend
- variable pitch bandsaw blades
- Kinda OT- Engines and compressors
- Birmingham get together
- Combo lathes
- Telescopic pole
- What is this? Machine part
- HSS toolbits
- Parts for Victor Regulators?
- "Langelier #62 Drill" Press
- Pipe Requirements - bit'o humor
- Project idea
- OT - Happy Birthday U.S. Army
- Today is Flag Day
- Air tank leaking
- drill grinder
- OT- folder synchronization
- Saw for transexuals
- cutoff discs
- Document archive - good stuff
- Gone to work at Ocoee Hydro
- OT: Earthquake!
- How many HSM's and other metalheads are there, anyway ???
- cheap motor speed control for hobby lathe?
- Batteries
- Tipsbook 2
- Evan or Anyone with a Land Rover
- Surface Grinder Spark Out
- Well, ...duh!
- Solid stick cutting lubes - any good ?
- Slightly OT: another good dump find!
- Uncrated the new Grizzly 9972Z
- Semi - OT Trig Problem
- Ot maybe a bit of a laugh.
- Please tell me how they do it!
- If you've been holding out.............
- Bearings, Bushings or Steel on Steel
- Do you do B &W photography?
- shaper extension
- Boring Master Cylinders
- Automatic boring head
- how to drill square holes
- Fritz Ready to Run .But More Questions
- DRO question
- Tailstock Question Logan SB
- special machine for trimming
- Another howzit done
- When Is A Lathe Too Big?
- Who is being in Horsham Way,Apex,NC.USA?
- OT: More Than You Ever Wanted to Know About Tuckers
- Spraying epoxy paint
- tips book 1
- Cutter size for little mills
- cut-off tool
- old shop slide show
- shear for HRS shapes
- Latest project pics ( i hope)
- Software Help
- New tool gloat
- OT: PETA employees charged with Animal cruelty
- Rust prevention
- GIANT Compass
- Grizzley 7x12
- Clausing 8540 H-mill questions....
- HF tool grinder
- What's the proper way to mount a vise?
- OT: DVD Burning
- WHAT EVER HAPPEND TO THRUD?
- Will it go bad?
- Hardinge Clone
- aluminum casting
- Way OT -- How to Sell an Exotic Bird Quickly?
- turn-pro 7x12 problem
- Milling a slot
- Got a "wierd" present today!
- How is Thrud doing?
- What's "MAXEL" tool steel?
- Maximat7
- For Tech Teacher
- Weekend humour
- If This Kid ISN'T in a Shop Class Somewhere
- Photo: Old shop with some Threading Jobs
- Vacuum Forming
- Vee belt power transmission
- grinder crankshaft
- Fathers day
- FRITZ LIVES.. progress report
- Grizzly 9972z
- OT: The new Dukes of Hazard movie
- Is Photobucket down?
- OT: Fence post coating
- OT: Ebay questions
- engine drawings
- Tractor - no oil to rockers
- New Shop and House
- sheldon wm-56-p lathe questions
- In Australia - Need a gear cut - Can you help?
- Resistance soldering tool
- Moving Machinery
- OT: Need a job?
- OT - I need some input - off topic and sort of long
- What makes Loctite "kick"?
- Alistairs school report
- Anyone familiar with vbscript?
- No body heard nothing from Thrud yet?
- Manifolds and fittings are fun!(pics)
- CFM calculation
- tack hammer lost its magnetic attraction
- Wanted: Clausing 8520/8530
- Sand Blast Cabinet Window Material
- Blades won't stay on Bandsaw
- Bridgeport fuse problem
- Near miss .... not so gentle parting reminder
- Torch pics for Knuclehead !
- OT German Sub
- dro manual
- Tig. aluminum
- Knuth Tools, anyone ever dealt with them?
- looking for plans for a milling machine vise
- OOPS, Solution, Cutting the Nuts Off
- My newest baby is running
- Graphite Fishing Rod
- help me make a RADIATOR
- Polish Drill Chucks
- Felt cutting question
- B&S #9 Collets F.S.
- Beaver Turret Mill Mk2
- airco welder info and question
- Bad Customers and the Small Calims Court
- toolpost grinder
- toolpost grinder
- Machine torch cutting speed chart
- Thoughts on starting a business
- Norton Gearbox
- Squeaky brass.....
- OT-Bought new laptop off ebay
- Cut the nuts off
- OOPS.. I TIG'd my NUTS together
- 110V-->Transformer-->220V-->VFD-->AC induction motor
- OT: laugh of the day
- Tailstock Alignment
- Machinist's Jacks
- How good is your Chinese???
- OT Computer blocked sites?
- Flattening SS wire ??
- OT Need some computer/networking help
- hauling milling machine in pick-up. good idea?
- 6 X 18 Surface Grinder
- draw filing.
- OT, Cordless Drills
- OT AC icing up.
- hey guys , any of you had this.
- Easiest way to remove valve seats?
- 3D G-code, anyone?
- Drill Doctor DD500 on sale for $59.99 at Amazon
- old boy tells it as it is
- OT: How do you know when it is time??
- Help on tool and cutter grinders
- Yet another paint question.
- Machine Tools Visible in Batman Begins!
- 3-in-1 sheetmetal tool
- Unknown indexer - what is it, can I find parts?
- Shop Layout Help.....
- Photo: Lathe Hat and Pipe
- Photo: Big Spider
- Photo: Turning a Radius on the Faceplate
- Spark plug steam engine
- OT how secure is email
- Flair nut Seat Cutting
- Hisey machine works - anyone ever hear of them?
- Motorizing a chain hoist
- How much is this milling machine worth?
- Hendy and Norton
- OT, Kawasaki 750
- Building my own Kwik Switch collets..
- George Thomas books
- Homebrew soldering iron(pic)
- OT: Hay prices?
- Centercutting, non-centercutting endmills?
- "How To Run a Lathe", vol 1, edition 53
- CabinFever / IronFever / AuctionFever
- cnc lathe, micro sized
- Dividing Head
- Making a New Spindle
- Indicating a v-belt pulley
- Mighty big "thank you" to Mark Costello
- Cheap don't work
- Cool new toy excavator
- Engineer Tape Measyre. Why?
- Silver soldering band saw blades
- A little research pays-Rotary table
- Threading......Again
- 270v 3-phase alternator?
- O.T. Rodent repellers
- screwdriver ?
- Let me the first to say.....
- OT repairs to metal roof
- Stainless finishes
- Interesting co-worker / Ex-co-worker shenanigans?
