View Full Version : General
- Laser edge finder latest
- wire welder
- Simple Boiler
- 1ph Motor start switch arc
- Making endmills from scratch
- 9" South Bend Belt Replacement
- Let sleeping mills lay...or how to store your stuff
- WAYYYY OT- Classical music
- Storage solutions on a budget.
- Milling Laminated Wood
- How much do these (Gorton) go for?
- wanted bridgeport
- first projects
- Pingin Adrian...
- Original Tap Magic ... what's the magic ?
- Precision level
- toolpost drill, transform this into this! (picture)
- Boy,the boss got a good deal today
- Machinist Trade schools in NorCal?
- Parabolic Cobalt Drills
- OT- or summat.
- Another Steel Question
- Pump shaft, kind of...
- The Gunsmith Machinist by Steve Acker
- Anyone made a ?
- Tool grinding jig PT II (lots of pics)
- The need for a squre drive.
- flipping chuck jaws
- Snow Plow doly - makes moving it around garage easy!
- 4-jaw chuck/manual
- Got Lathe, Need Bench
- Hmmm..... roughing endmills work well....
- Metal Thickness to Gauge Conversion Charts?
- H.F. 6" tool grinder #46727
- Am I totaly useless
- the handwheel on Bridgeport powerfeed
- New grade of Aluminum?
- Winch Gears
- Nice Fuking chuck
- OT Moving a chain link fence??
- Need a pulley
- A great reloading / shooting setup
- A fine line between genius and insanity
- a real deal on Ebay [not]
- Another good class tonight.
- Edge of the envelope
- Milling brass
- Steady Rest - Which One?
- Alum. finish ?
- The New HSM Front Page
- OT - Metalworking on "24"
- Rotary phase convertor switching on and off
- Metric SHCS & Setscrew Assortment
- Sand blasters?
- Where to find lantern tool post parts
- clutch
- Small c&c table for plastic & light gauge aluminium portable? Where to start looking?
- Cut-off blade with no taper
- Burning Churches in the south.. OT: my perspective
- Fiel cannon info/kit
- Thinking of a new mower for spring ? try this one
- Building a Welding cart bending tubing cutlist
- Gearbox Oil for Jet Bandsaw
- CerroBend
- Niagara Circle Shear Questions
- Powermatic Milling machine,opions please.
- This is just too funny
- Plastic veneer(?)
- Leblond costs?
- Make a replacement half-nut for Leblond?
- Internet deal
- Harbor... Fate???
- Piston clearance?
- Bijur oil feed tubes
- Dumore Grinder...Did I Do Good?
- pictures for David Cofer
- Any one do any mig brazing?
- Bandsaw Blade Break In
- Strange AC motor - Brushes on start only
- Full of questions - What's this for? (Pic)
- Tilt-Shift lenses/adapters
- simple Quil design, anyone?
- EMI noise
- Aint it the truth!
- Sine Bar question
- private message
- Pics of Mill Move
- Why we say chinese stuff is trashy
- Networking questions. Shop robots, old pc's
- "Hurry, somebody's breaking into your truck!!"
- import plasma
- Chrome plating cutting tools?? Plating questions
- Electric motor application
- Building a Gantry Crane
- I finally got my sand blasting cabinet! (Pics)
- New toy - little gloat
- dro
- Cheap bridgeport converted to PC control, servos MA..
- FINALLY, a BIG Nor'easter is comming!
- Finally buyin tools again!!! (Yippeee)
- Casting material
- Cutting internal threads.
- What Model ?Lathe?
- CAP
- Evan, Once more the Canadians do us!
- acramill
- Lathe tailstock alignment: dye on center?
- OT: Dick Cheney shoots a fellow hunter.
- Finding "rack threads"
- Starrett 452 disassembly
- Way OT:Home Improvement Question
- Old House
- Aligned my lathe
- small ridges on workpiece
- Boring Bars for the Lathe
- machining Belleville washers
- Cutter geometry for zinc
- Helical Milling
- Cute picture
- Horizontal milling
- Email address for bronsaurus.net
- 5C spin index questions
- What to do with all those lathe chips
- cutting a key slot in the ID
- New Ebay scam?
- Looking for advice
- Product Ideas
- VFD Current rating
- Please remember SWMBO today.
- DRO Question for the Real Machinists in group, Forrest?
- Steel castings
- Delrin
- First and last time I do that!
- Dumore 5-021 8072
- OT=Anybody see the "Bouncing Bomb" on the history channel?
- Inexpensive CAD
- Setting Up a Boring Bar
- Does anyone here make decals?
- Ideal shop
- OT: Computer problems
- Finally installed an Accurite on my Lathe
- making a router collet
- Double angle cutter
- Building a CNC Plasma Cutter
- I feel like I got hit by a bus...
- Fun with a giant lathe tool
- Any you metric folks use 17mm thrd?
- Need a source for round gear rack
- Stiction of sleeve bearing vs ball bearing
- For Weirdsicense
- This Rhinoceros ain't bad...
- pWM
- Milling Arbors
- Magnetic particle filters
- Selling metal artwork?
- Previous post
- Long Keyway
- This is insane.
- OT: Just thought you should know
- making woodturning chuck jaws
- Second Annual CNC-Workshop
- 2000 or xp used ?
- Ideas for Drop Deck Trailer
- Commutator repair - even possible?
- Single Arm Tracker
- Ibewgypsie where art thou?
- Finally! - VFD/3-phase Wired up & Running
- Turcite - Way replacement? Anyone done this?
- OT: New computers
- Home automation controllers. Anybody using one?
- If I were driving, I would have ran.
- DRO
- Nice slotter on ebay
- OT search
- Bolt circle measurement question???
- Milling train rail?
- Wirecutter, how's the gear cutting machine?
- Hobbyist Machinist;
- what reading for beginner?
- Another bolt circle question (DRO)
- Looking for info on Wholesale Tool vertical mills
- rake angle for 7075 aluminum
- FAQ section needed ?
- 90 years young and still turnin' chips... Seed of a shop
- tablesawing aluminum plate
- 30 IPM is this inches per minute?
- Logan chuck mount
- OT, computer and lcd monitor connections
- EDM: homebuilt
- OT: PC Monitor of the Gods!
- Material FYI
- Rolling model railroad track for corners? Help? modelmakers?
- Measuring bolt hole spacing
- O.T. but true
- Synthetic spider silk
- Handy new welding clamp!
- 1/4" x 32 tpi thread?
- ebay tp grinder, what gives?
- OT: Browsing eBay - has this happened to your searches too?
- Got my rearend in this weekend
- EMCO FM-2
- My little contribution to inovation
- Using a PDA in the shop
- wheels and tool rest for grinding lathe bits
- OT ethanol plant expansion
- Material Sources
- OT Best ink jet printer?
- OT; Leroy and the Church Ladies
- Kitchen table
- how to make a proper hole
- OT-tree shear
- CheapAss polar hole calculator-program changes
- Model Engineering Issue #109
- Definition for "Silver & Deming "
- Turning Off 230vac Motor?
- 6" slitting saw speeds and feeds?
- Center-finder Optical sight Idea for Alistair, 2.5power
- OT Fire in the Harly-D plant
- Buggy's rear suspension prototype done (Pics)
- Carolina Bandsaws
- cnc lathe
- COMPRESSOR MOISTURE AUTOMATIC DRAIN KIT
- Well....I done went off and done it....
- HeNe Line laser on ebay...
- Free machining home class
- Lathemaster 9x30 CNC Conversion
- import 9x lathes
- Unintentional cutting taper on lathe?
- OT: Isocyanates?
- Shaping aluminum sheet
- Measuring small bores?
- 2 more new toys...
- "New" drillpress installed
- OT: Fuzzy TV
- Bader Grinder
- difficult collet
- Confusing Hob terminology
- This isn't fun
- OT Anyone have experience with TH400?
- What is this tool? (Pic)
- OT puter trouble VS shop!
- Simplex Lathe (Mondial?) need info
- A new wrinkle for gear tooth calipers
- newhobby,You have been busy.
- New tool post grinder holder
- Grizzly DRO
- source for cross dowels
- Internal Threading Woes
- plain bearing fit
vBulletin v3.5.4, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
