- Cut off and grooving kit
- Drill Chuck Lubrication
- Has anybody run into this?
- thanks!
- Craftsman tool returns
- Building a Powder Coat Oven
- V-Twin Carbs.
- Craftsman Mill/Drill
- Broken Caliper Question
- OT:wind power
- tailstock "HEX" die sliding holder?
- Bi nuts and bolts
- OT - Joke
- OT computer printing question
- Need help starting out!
- "Lowest Price" site for tools?
- CRS Cracks?
- o/t: Scorses's winning film
- South Bend 7" Shaper on e-bay
- KO LEE Year code?
- OD grinding of glass tube- What kind of machinery?
- Beer Can Close
- Where'd my balls go
- Need help with glass scales
- Should I catch a beatin' for this?.....
- Transporting a bicycle?? Support it by the frame or let it rest on the wheels?
- GOOD JOKE.. need a laugh?
- Free 2D cad program
- Something worth building.....
- Air over hydraulic expert needed
- DRO Accuracy
- Bought me a shaper... now what?
- Small electric pump for grinder oil...?
- Mock Up
- Accuracy Of Infrared Thermometers?
- Aluminum lathe dogs?
- How to approximate a lens shape
- Threading woes. Any ideas?
- Enco March free shipping code
- Newbie
- threads not deep enough??
- Gear Shaping Machines?
- more than one person is picking up on mercury in CF lights
- Opinion- Cincinnatti Monoset-Owners & users?
- Hey everybody, the new Enco catalogs are in !
- Boring Head Shank removal
- 8" Grinder having problems
- HF shipping code
- Backgear Chatter
- Solar Panel Bracketry
- Tracer Attachment for the Lathe
- how to mandrel
- Using scanner for measurements
- Interesting lathe video
- Was someone looking for an Atlas Shaper manual?
- Cheap, solid lathe dogs
- Turning/Machining Rubber
- alloy substituion advice
- Chinese Knock-off - or the Real Deal?
- Machine design tools from MIT
- Herbert turret lathes
- Get your materials now!
- Granite surface stone
- Cathead
- TIG out broken stud help
- Aligning LONG SHAFT IN LATHE
- R.T. with built in chuck?
- OT: Computer attacks EVAN!!
- Warning To The Newcomer And Old Newbies Like Me!
- Question re pictures
- Selecting Machines For A Home Shop
- This may seem obvious but I want to get it right?
- How do these work????
- Repeat question..Ohio spindle adjust?
- Leaking
- Dorian Tool Dovetail end mill
- question for evan (or other comp expert) about DOS
- Surging motor on 7X14 import lathe-opinions needed
- Can anyone id this table?
- Knurling problems
- The ol' Ohio #2 is makin chips!
- Help ID an anvil and other smithy tools?
- Red Sulfur Cutting Oil
- Evan, want to shut down another scumbag?
- Poor auto machine work, crankshaft
- Another computer question
- DRO on a quill
- new chuck
- Oh My God!!!!!!!
- 2 inch pipe couplings,
- Horizontal mill setup question?
- CNC Mini-Router
- OT: septic tank
- Tool gloat and some unfinished projects (pics)
- How to check accuarcy on new DRO install
- need to cut internal 1.125" x 6 ACME thread 2.2" inches long
- Anyone with experience with a '87 Dodge Dakota?
- New Google search tool(patents)
- Question regarding "chip load" on vert mill
- Tramming Horizontal mill ??
- CAD question
- Interesting Website...
- Pinging Evan
- Long CNC Router
- size of gears I need
- YOD is now proud owner of........
- V-twin update 3-4-07
- Thermal Expansion and Absolute Zero
- Insert face mill question???
- How large is the spindle bore SB Hvy 10?
- Best pump oiler for ball-oiler lube points?
- DRO all done and machine is in place SAFELY!
- OT, LCD monitor, horizontal width...
- What do you guys think about this!
- Suggestions on a good home-shop sized Surface Grinder?
- any fisherman out there
- Reflecting And It S*cks!
- Steel Castings
- Is anyone near West palm beach?
- Anything new with Michael Morgan?
- Shaper question
- OT: New Zone Alarm Security Suite
- Follow up to replacing BP table feed with factory bracket
- Is An Anvil That Has Gone Through A Shop Fire Worth Buying?
- Small holes in SS
- Mystery Lever On Drill Press
- Coal gasification process
- clear finish on brushed steel?
- How to get more horsepower out of a C0 micro lathe ?
- shop sale in Mount Clemens to stay away from
- Milling picatinny rail advice?
- Ok now I need saw coolant. Any suggestions?
- Large Bull Nose Needed - Buy or Make?
- Clausing 8520 accessory ??
- Alistair is this you?
- Does someone on here have a Starrett CMM
- finding the center of a ball.
- Grinding Aluminum
- HF 13x40 Paint Color
- Looking for Glyptal
- anyone have a good design for??
- Question on handtool quality of SPI tools
- Another project...
- Shell mill arbor bolt question???
- Greased Chuck?
- CDCO diamond wheel?
- MTI BXA toolholders any good?
- what shaper oil to use?
- 1/2 Scale M2 Finished w/ Pics
- OT: computer question - rem
- This is a courtesy notification.
- OT: Testing the word remote to see if it is a keyword
- Shop roof leaking
- here's a nice drill grinder
- Anyone made thier own rotary table?
- Where are they now ?
- EMCO Compact 5 CNC
- How do you mount this chuck?
- NEED K O LEE surface grinder feed wheels. Power Feed on X Axis??
- Reaming & Cut Rifling Gun barrels (Pics galore!)
- Has anyone dealt with "International Tool" in Dallas?
- Atlas shaper
- Is this any good
- OT: F16 ejection video
- Thread Chasers
- Good deal on a Clausing 8520 In Portland area.
- The old girl likes carbide!
- Here's a guy who found a nice nitch market.
- The other Harbor Fright wannabe
- Best tool you bought from HF?
- Film at 5
- surely this cannot be correct
- Quiz - point of origin
- OT: Propane Tank Fill Percentage And Safety
- Question about spoof emails
- Shaper On E-Bay
- Headstock bore taper protector
- Site for welding/cutting info
- Timing pulleys and connectors
- 6pd copper nails,rivets Oh my
- On the subject of propane....
- What % Silver solder for band saw blades ...
- Bed Wear
- nicest shaper I have ever seen best condition too
- DRO Install on mill/drill
- How much will this go for? (ebay)
- J&L Drill Press - update
- Woofer manufacture with Lathe and Bandsaw video
- How to Cut a Pocket with Square Corners?
- Heaven cant be far behind!
- tough time installing quill dro
- nice vernier...
- parting problem
- ceramic inserts
- Ebay item- what is this?
- Advice on visting Boeing's Surplus outlet...
- Dunmore TPG on Craigslist MD
- Belt sanders we built
- OT? Cheapo copper pipe
- OT train cars containing propane exploded
- Can you do electrolysis on an old motor?
- project - old DC motor - yay or nay?
- Anyone know the going price for scrap yard aluminum?
- Tool Corral
- O-Ring Drive belt?
- Lathe setup problem
- Free 3D Modeling Program
- Grinder work head
- VFD Mounting
- Newbie brazing/soldering brass
- OT 0 intrest tranfers ?
- Found This in the Barn...What is it?
- 12L14 Bar Stock availability?
- which milling m/c
- Dummy marks
- Well it was funny in hindsight...
- Bloody Woodruff keys - I hate them
- re cnc against converntional
- X-Y Table Info Needed
- Ball Screws-????
- Four tools for holding small taps
- Apprentice Tool Sharpener
- Lathe set and leveled - What a difference!
- Color of BALLS
- OT: How can you tell if a copy machine is digital?
- New saw WOW. Some pics in action
- hi iam new here
- Bloody Roll pins
- Need help from an Atlas MF mill owner...
- OT: This homebuilt wind turbine looks interesting!
- Sheetmetal forming, metal spinning in reverse
- To Grind or Machine First
- threading question
- MY milling machine can only take the lightest cuts
- Do I need a height gage?
- Four easy pieces (1/4)
- Four easy pieces (2/4)
- Four easy pieces (3/4)
- Four easy pieces (4/4)
- model lathe
- How long do you wait for Ebay purchase
- opposite of lubricant
- Sharpening Carbide
- That Time Of The Month...PM Is Down Again
- Runout indicator
- cathead pics
- Check out slick hydraulic mount to press
- Machining 6AL-4V titanium
- drill chuck taper
- what to do with fitted cases????
